- lawl.
- Repost from last PM (with a link to a log)....my car is broken :)
- What's the general feeling for Erik @ DUH Engineering? Nothing in the Feedback thread either way...
- What does the intake manifold mount to? More...
- Are there any benefits of this FMIC over AWE or IPP sidemounts??
- took most of an afternoon running around trying to find a 22mm or 7/8th combo wrench
- Having a hard time finding 5-point Temper Resistant Torx Plus bit for MAF screws. Anyone
- Need some advice on a few fault codes pleaseee =)
- Vibration/thumping coming from left front wheel...
- Oops.. don't try this at home.
- Definitely having a love/hate experience with the car lately
- Defi BF Gauges
- Stock 00 M5= 0 AWE STGIII S4= 5
- Still revelling in my phenomenal B7 S4 Ohlins install . . .
- spoiler
- any1 happen to have a clip of their boost gauge in action?
- Can anyone guess the (max) pressure in the downpipes at WOT/Redline?
- Just was over on Supraforums, forgot how little respect our cars are shown on there....
- Going nuckin futz ---->
- Apr Test pipes and AWE twin II Exhaust getting along (video) :)
- Back from the track - - the car is broken.....short version of the story - hope someone can help....
- S4 Stage 3 (AWE) vs. GTi (GT2871R w/dumps, 324whp, 2900lbs). (Video Inside) (Edited)
- http://forums.audiworld.com/other/msgs/5868284.phtml
- driver's side IC hose popped off 3 times today.
- Will bank 1 and bank 2 lean codes damage anything? Trying to figure out what it is but dont want to
- Replaced both precat O2s, coolant temp switch and DVs. Getting bank 1 and bank 2 lean codes
- Side mount intercooler fans. Anybody tried it?
- 1st and snd gear slow?
- what to get.. used Milltek or new Vibrant (Audi collection)??
- Need to tap out my EGT probe threads in manifold. Size??
- so finally got around to installing IPP ( SILVA ) intercoolers...
- Could someone check my cooling system sensor diagnosis logic?
- Temperature Issues
- How much does the stealership charge to cut a new key ?
- Difficult to get into reverse sometimes.....
- PSA. AMG Test Drive on SPEEDTV EST.
- LAPD's finest.
- Pros and Cons of ITG(foam) and KN air filter.NEW not when someone puts to much oil on them.
- pagin nogarohiro...On the link you gave me I can't get to your yahoo photo account..
- Any comments on this car I am thinking of buying feedback please
- Eibach ProStreet Coilover Review
- ASP K04 software tweaking for higher octane
- HELP!!! broke the clip for my coolant temp sensor...
- easiest way to get the motor to TCD? (to get the crank pin installed)
- Stage 3 gurus, just a couple general questions.
- OK, where can I find a freaking 19/32" drill bit so I can do my non-fouler mod?
- Martin Brundle's Supercars
- Anyone know of an B5 with like a totally destroyed rear end ?? kinda long..sorry
- I'm sure this is old news but...
- BOV WITH NO ENGINE LIGHT ON?
- rear drivers side Axle Assembly is shot
- Audi G2G in San Francisco on Aug.19th at 11am......................................
- Anyone here with the Nagora Blue S4 on I90 in West NY that saw my silver TT Sat.
- Need help on windshield washer fluid leak:
- Both CV boots are torn...is $100 per side labor reasonable?
- Zeitronix Wideband Weirdness.....
- Help!! Putting test pipes on and doing the non-fouler mod....My zoldman 02 will not screw into the
- Paging DAP
- So, um, why am I an idiot and can't figure out why my AWE pressure tester is leaking
- which homebrew has dyno`d the most HP or fastest FATS,injector size and brand,maf size,which chip?
- What's wrong with my car? Went to the Dyno, only doing 9psi on STG 2+
- Best Owned Video I have ever seen...possibly a repost....Hicks vs Yuppies...BMW car chase
- Went to drag strip and recorded a best of 12.1 @ 118 on pump map....
- i want a cig. lighter
- Shifter Movement when Throttle on/off
- Beebees Rex Deuce (BWW)
- Nice day... played with a 1992 Ferrari 512 this afternoon -
- Thinking about meeting some friends in Queens NY for Hot import nights. Will my car be safe in
- Poll: I might have a race set up tonight >
- Need Suggestions: looking at '01 S4 tommorow, what to ask/look for?
- any widebody avants for sale
- in need of stock t-box,any one know where to source one?emailed the one in classified no response.
- just installed a stratmosphere SS and let me tell you how silky smooth that bearing makes things...
- Trying to guesstimate CHP for the following mods
- I replaced both my hood and trunk lifts. Now they both squeek when going up and down.
- Bob's thought for the day... Since I dont't run a belly pan... would there be benefit in...
- Now that I'm in a Logging mood.... what else should I log besides 115 and 003
- toyguy shifter impressions
- Saw a nice ~2001 Nogaro S4 on the Milford Green today. While I was leaving my office. Not DAP.
- Im bored and no one is on here.
- 115 and 003 log graphs... looks okay?
- Ebay FMIC core good/bad hit/skip?? I am pretty sure thats what velocity S4 is using.
- Went to the track last week...
- Getting a 4 lane freeway all to yourself on a early saturday morning..
- LI-S4....What was the cause of your cooling issues awhile ago?
- WTT - Anyone want to swap Eibach/TrackSport rear springs?? my 700's for you 750's??
- headlight washer hose, how is it secured in the front bumper area?
- Will Sportec RS4 intercoolers work with our S4s?
- May be Repost.: Group Buy on PSS9
- is it possible to roll back the odometer in an S4 or whatever with cluster and ecu swap
- long shot: any1 in NY/NJ area have H&R/Bilstein combo? Impressions please!
- Looking for infant car seat....
- want to buy piggies and exhuast. Email me if you want to sell and what you have....
- Someone was nice enough to send me a pic of the 4 wheel brembo kit with the parking brake
- Anyone who did the wood to sport trim swap, did you use any clips besides OEM?
- Paging Farbs, what is your email addy?
- Anyone know anything about electronic exhaust dumps? similar to MarkP's only controlled by a button.
- Accordian hose: what benefit, if any, would a CF one or a bigger one or one lined
- Orgasmic RS4 (none of that B7 stuff)
- short shifter question: when I got it, I screwed the knob all the way down, but I
- Just finished my Koni coilover install. Some observations.
- Rewatching the first season of Grey's Anatomy...
- silver s4 on new CHs in Mirage employee parking lot Vegas, you here dude?
- owned.
- is $2526.30 + shipping a good price for straight k04`s,inlets,and matrix super duper install kit?
- more help needed, what are the tip box breakdowns?
- I have clunk too... only when I engage clutch in 1st gear from stop. Is this normal for these cars?
- speaking of instrument cluster codes... what are the other codes?
- update: clunk sound locate
- PAGING MAF knowledgeables (Chuck S4, Nyet, and all others)
- Have a great weekend everybody :)
- questions for the wideband guys:
- How do you know which suspension part is bad? Control arm, tie rod ends etc. I have a rattle on
- What is the part # for stock front rotors? (2001 S4) TYA
- I can get GT's and manifolds for $4000. How much would a custom tune cost?
- Still can't get the rs4 inlet tube to clear the upper radiator hose...
- OO I have an S4 again... based on my instrument cluster
- Have you ever rolled against a GM Typhoon? Ford Lightening? Results?
- how much hp do the newer rs6's have ? just say an old couple with florida plates up here.
- Am I the only person who would be interested in an 87oct tune for daily driving?
- x-post: BMW 335 = 276 hp / 299 tq on a DynoJet
- ABS light on
- Anyone have a motor diagram to show where alternator/starter is?
- OK, can't decide...PSS9's or Non-Adj. Penskes...
- car running sh*tty, overboosting at WOT...what blocks to log?
- dgmodel, Do you have hat Milltek DP adapter.
- Can I visually inspect motor and transmission mounts? NOOB.....
- a4.s4.rs4....
- Flik 17" Hornet
- Jon@x1networks.com YGM sir!
- Hitachi MAF(AWE) on a RS-4 air box?
- Anyone in the ct area wanna help out with downpipe removal??
- How to test if the fuel pump is going bad???
- Should I buy used stock 17's or Flik FTD 17's for autocross, both would be $430 shipped
- Anybody here with stock exhaust and aftermarket/piggie downpipes?
- No code and no boost, what block for looking at LTFT and STFT or whatever they are labeled
- Misfires fixed, thanks to Ah10::A55clown, STG3S4 and SLPR S4
- last night they tried to take my key fob at the reno airport !!!!!! this is out of hand
- Please help with MAF!
- ASP downpipes. Pardon my language, but...
- I need to locate/fab the wiring harness for our headlights...
- OK, tired of this...STFA, with little help, Brakes are teh suck right now
- Dinan supercharged E36 M3 vs. Stage 2 B5 S4...who would win?
- My first boost log - graph inside
- FYI - apparently some 100 octane pumps don't shut off automatically...lots of gas can spill out:)...
- I feel like buying something for my car
- just got my car back,had a turbo timer,remote start(made for 6sp),and alarm installed(110db siren)
- Do you guys think the thermoswith for the aux. fan can be changed topside?
- so which one of YFF is this?
- Options on replacing the stock accordian hose? I have a ripped one...
- For those who are getting EGT/O2 codes and misfires...Replace your coolant temp sensor!!!
- Major DTC help needed please.
- <Paging Lemieux> Leave work now, I want to get up there and swim & water ski!!
- about to pull trigger on apr chip today miles of smiles on ride home!
- So..I just have stock and 91 octane APR programs right now (version 5.0)
- So I tried to teach my girlfriend to drive my car (6-spd) last night
- turbo installers
- S4poor: is this the guy you work with? guess he's *really* bitter abuot that pwnage :p
- Boost levels for stage 3- ???
- Brake piston area
- So weve seen pics of your cars and owners.. how bout pics of your animals lol........
- Are the fellows with the Silva ICs using stock Ducts? Is there any real benefit between stock and..
- Who holds the record for fastest full weight s4?? also any news on the ASP gt28 kit? Dyno?...
- will these A4 rims fit our car? looking for some winter wheels.
- Question: I just got new wheels.. but hub ring is missing... do I have to have hub ring? or
- Made an interesting control arm observation today.
- B5 S4 Widebody Wheel Fitment info...
- paging 1bads4 - got those pics ??
- any long blocks out there?
- I am in need of a shipping company that will ship a full rs4 wide body kit, reasonalbly priced
- Lookin for an S4 B5
- Discount on Zeitronix A/F ratio meter ends August 16.
- Who needs K04's when you can add this for $50?
- Another nice day at the track, pictures inside including some carnage (not my car)...
- Does anyone have/host that video of 3 or 4 S4's lining up on a Hwy in Cali from 4/5 years ago...
- Finally got some pics of the alcons......
- control arm kits. What do you get when you purchase them?
- Is this normal.....
- 1st week being STG II+ LOVE my ASP DP's, first week not having any CEL's!
- Need a part number for the bolts that connect the upper strut plate to the frame.
- Can't remember who posted the part # for the VW van Aux.H2O switch for me...
- more misfires, caught while logging
- hadokenny or anyother casa avant owner....
- Need help with running hot and part number......PLEASE....
- Stasis engine mount sure look damn pretty
- Oh sh!t...
- Evilempire you have mail concerning the borla exhaust for sale, let me know
- OMFG!!!!!! hahahahahaha!!!!!!!!
- So who wants my resurfaced flywheel?
- Anniv. gift from wife: neuspeed 19mm rear sway bar and awe vent gauge...
- Has anyone succesfully died/colored the interior of the car from (Onyx) to black?
- Autospeed Tru-Dual 225 Series Exhaust with 3" or 3.5" tips? Anyone have this? Opinions>>>
- Burning smell after trying to start the car multiple times in a row.
- piggy fueling,how much,any hp numbers,and whats in the kit?not on their website and stfa but no info
- with the tirerack SO3 sale, has anyone run 245/40/17s at 25.5" - rubbing?
- Anyone in NYC with HB or off-the-shelf stg3 wants to do friendly runs on 93 oct?
- Is this the nav unit that everyone raves about or have i got the wrong part number?..
- Potential problem with wiring to MAF. Ran the test in the manual and failed.
- B5 S4 Piggie Pipes Install?
- anyone selling a vag com? or have an extra they want to get rid of?
- Rs4 inlet pipe won't fit with upper radiator hose in place...
- What's involved, in removing the front bumper ??
- HELP! Diagnosing possible starter/battery problem... Where are the ground straps I need to check?
- Click in the left rear, sway bar link?
- OT talk for the day .. WTF is up with this world and the oil industry ..as much as i love horsepower
- I think.. Marc (10SecS4) and FrozenS4 are little offensive in this forum... however
- Woo hoo, Thanks Alex and A55clown Daddy Ben, i got my Stasis mount that is all! hehe
- just bought stop tech rotors..
- Overheating Issue: It appears that the hose connection on my aux water pump broke off...
- turn signal bulbs
- I want this car
- What's book time on replacing the outer CV Boots?
- Just bought APR boost gauge. No electrical included. What gauge wire should I use? <more>
- Still need brakes, will go with a great front kit and a okay rear kit (anyone have a powder coated
- What 17" oem wheels, other than avus, clear the oem front brakes? Looking for a cheap spare.
- S4 (B5)
- Will an oil analysis provide any benefit if I seafoam before the oil change?
- What is stock IC pressure drop on stage I S4?
- Yo JoshD, bust out with the bib cause you are gonna drool :P
- Just bought a 2000 S4 78k need help finding a decent aftermarket warranty
- Ah10 HB Stage III - 1 Three AWE Stage 3 cars - 0 8^)
- Where can I get the plate filler of rthe front bumper?
- So is there any advantage of going RNS-E over D? The D is cheaper and fits perfect but
- How can some stealership parts departments live with themselves? My dad drives an A6 2.7T and...
- tire opinion needed: Falken Azenis RT-615 or S-03 Pole position??
- With zero static toe setting, does the front toe change negative out or positive in when moving?
- Feeler post: Dyno day in SE Michigan >
- Anyone else remember this pic
- New Brembo 332mm kit is coming in today.
- What damper setting on the Koni Coilovers?
- ? rs4 parts
- *this* is pretty...
- stfa and asp website,cant find any hp numbers or price on their k04 fuel kits or list of parts.
- Help me understand: 2 S4's, both stg2+, 45f amb, both run exactly the same 1/4. Then one of them
- looking for best price/site or deal on S4 bumper, inserts, grills (used silver would....
- since search for the B5 S4 forum doesn't exist, have to post directly
- Lets try something different... lets see some pics of your dash!
- weirdest thing just happened.....heading home with 10mi DTE
- How many AWE stageIII guys have normal trip comp readings on your average miles per gallon?....is it
- Want to buy exhaust - gen 2 borla or ASP let me know if anyone wants to get rid of theirs TIA
- I have left over 5ohm seat resistors - anyone can have them
- Did Cosworth design the 2.7t? more questions and explanations inside.
- some good reading
- Short notice emergency. need an rs4 TB
- Finally got my car chipped today! Then got in my first ever accident...
- black on black CRIME !!!
- clutch wont fully disengage
- big power loss, misfires, then it went away after I let her cool down
- Paging Mike2K24
- StopTech rotor question - clicks under braking...
