- if an S2K puts 409 whp what could be the power that my car is putting when on.....
- I had my m3 lip painted today. However the painter removed the 3M Tape. What is the best tape to
- Just received new VAG-COM tool; will trade Denver/Boulder area VAG use for your knowledge of S4s....
- How similar is Lemmi to other tweaking software?
- AWEsom injectors from AWE !
- aluminum interior trim + Ashtray
- RS6 mirror housings are the same size / style as RS4 ones, correct?
- Adjusting Stasis TrackSports...
- H-Sport has teamed up The Tire Rack to bring you a great offer!
- from stg3- if i went with autospeeds 85mm MAF what software should i use??
- My first bad experience with CPO - has not been a good morning
- i want to go from stg3- to stg 3 but i got some problems.....
- staggering tire widths front and back why or why not?
- Curious anyone have a spare driver side stock IC shroud lying around they want to get rid of?
- 18"x8" OZ Supperlegerra Wheel
- 225/55-17, will they fit?
- Newest mod was delivered from Fedex today.
- how hard is it to change the after run coolant pump?
- help with part numbers for turbo install - TIA
- Another way to have our cars sound like it has a 3rd turbo. :-)
- I know what I have said to this question in the past, but AW is the only place that can help...
- Anyone have new GIAC 3- dynos, logs, graphs or estimates to share?
- Does anyone have the PN for a bosch 5bar fpr (or an application where it is stock)
- Outboard, suction cup camera mounts. Does anyone sell them, or is it a DIY thing?
- Work envovled in changing rear differential bearing?
- Can S4 have GIAC X???
- What is the thread count for the license plate screw?
- Well I came up with a fix for the top of my shift knob. My one friends dad is a machinst. He is
- New fastest 1.8t on our 1/4 mile list. 11.910@115.217.
- Used Milltek 3" install...
- people who have removed SPEC clutches due to failure
- 02 black/black S4 w/ 92k Considering purchasing. whats fair price + what should i look for
- Is it ok that im riding 235/45/17 everywhere except the front pass. side? front pass has 225/45/17..
- Lower timing correction with higher boost, can you believe it? Believe it. Testing results inside.
- Pros and cons of Duh FMIC and RS4/AWE/APR SMIC tia
- what upgraded MAF do people have and where did you get um
- Barret Jackson on Speed Channel right now..some cool rides runnin through the blocks.
- CEL came on...vag'd it 17521 Oxygen Lambda. I have a appt w/ the dealer on monday morning...
- HELP!!! Lost the wheel locks' key. What to do?????? :-(
- ECS tuning 440cc/min green tops and GIAC K04 program from AWE good enough to call stg3 from 3-
- Just sent my ECU to ASP for stage 3 fueling! Happy B-Day to me!
- How much is it to upgrade from X to the new Stage 3- software?
- Noone send me to the search page but what does the phenolics spacers do
- Emergency!: thermo Switch
- OK, its for sale, 2001.5 S4
- FYI NOPI has H-sport sways for $384
- Dan Jones' Fort Hood stupid car picture of the day
- Steering wheel shakes violently
- OK since we're on k03/16's again :P NE1 know the difference...
- DOES still lots of people have k03/k16 hybrid turbo issue? or is it tollay gone cuz they changed
- for the snail heads.....i've heard mixed things about clipping the wheels....is anyone familiar with
- WHICH CHIP IS BEST? WHAT K&N FILTER FITS MY CAR? WHAT SS IS BEST? WHY AM I YELLING?
- Who had a picture such as this...
- Re: how much hp is gained when you switch to k04's in a b5 s4? anything faster too? already stfa
- Does any vender sell a dead pedal other than Oettinger?
- For people who repainted their front bumper or have RS4 bumpers...
- ryans4....just saw your suspension page..i think the vogtland c/o's should move to the 1k-2k class
- Any info on this abd intake setup? I know a while back quite a few people were looking into it...
- Paging Ming or FBander...
- What kind of power are people putting to the wheels with stg 3-
- Which one of you is going to buy this RS4 alcantara wrapped steering wheel
- I want to install a boost gauge in the vent the one that AWE makes but is it worth it on a stock S4?
- ???"Engine noise" pertaining to stereos? How can engine rpm cause speaker disruption? more inside!
- graph of O2 voltages at different primary fuel trim levels: (open for interpretation)
- whats a safe psi to run on stock fueling?
- How many Lbs of boost should GIAC's XR be making on 93 oct gas??
- Where's my oil temp sender? (2000, built 04/99)
- I need to swap the turbo... what are my options with low budget.? beside RSK04 how is K03/16 or
- Love Cold Weather
- will a TCD on stage 3- make any noticable difference good/bad?
- Tiptronic Temperature Gauge tap location
- WHAT CLUTCH DOES EVERYONE HAVE!!!!!
- am i too spoiled for thinking tuner shops should include some discount on big purchases?
- Which one is better? APR?? GIAC??
- Anyone have instructions for coding a new inst. cluster?
- noobie question: Squeaking when turning (caution:flamable)
- Any hint/tips on the awe pedal install?
- Any good tint shops in Blacksburg/VT aea? (not much more)
- When you upgrade the rear rotors, do you get the S8 rotors or A8 ones?
- Who has Rs K04 Turbo and Pipes in stock????
- Need instructions on installing Piggie MBC and parrellel N75
- anyone know anything about this FMIC and its quality?
- Have you done it ?
- Cheapest place to purchase Bosch Platin F5DP0R
- How does one bench test an ECU?
- How much to ship a tire? Cheapest route of course.
- Drivers side CV boot is fried (BWW). Do you guys replace just the boots,
- Remote lock question...(STFA completed)
- brake still screeching after brake fluid change and pads check, any ideas on wats goin on?
- 2 questions for tweaking/logging braintrust....
- trying to find out *exactly* what primary fuel tweak does.....
- anyone have the part number for the foglight switch/cupholder surround? cost? thanks!
- why does my car studder!!!!!!
- Paging YELS4AVANT at CT-84/8: YSATtraffic.
- h20 international
- anybody know of a good place to buy porsche parts online?
- Rear Seat Covers?
- Not my car...but a rare combo that's for sale. Never a big fan of green but this
- 2001 S4 black paint code?
- Have a small problem. Have one of the old UUC titanium rob knobs. Problem is the piece
- nogaro on 695 around noon, you here?
- Stg 3 gains using rs4 intake parts...
- help,anyone know if any VW bolts fits stock avus?
- POLL : How much 1/4 mile time can be gained per each 100lbs removed from car weight?
- Anybody ever pulled on the inside handle to open the drivers door and felt something snap?
- AoA close to caving-in on my situation: Question is does anyone know of a real and permanent fix
- I love getting pulled over in the morning....
- I wish I were driving my S4 but..
- Before I buy new, anyone out there have decent used K04s and/or inlets for sale?
- Downpipe
- Get no respect on the road if not driving my Audi.....
- When i crank the steering wheel all the way to the left i get a loud noise and vibration...
- YAY, new toy should be shipping friday.
- CPP products in stock and ready to ship.
- I love my B5, but what angers you about it??
- God bless AutoWarrantyBrokers ... Dropped my car off at a local shop to get a CV boot repaired ...
- what possible reasons could my coolant expansion tank be empty?
- So how bad is it to drive with low powersteering fluid and the pump making angry noises?
- if canadians have sump oil heaters for winter why dont we all use them to reduce warm up time.......
- Today's poll : what downsides do you think a stg 3 S4 has ?
- Who in the world is stupid enough to brake check an S4?
- I Need to Roll Back the Odometer...Any Help? (I Can Explain!)
- Best replacement speakers? Fronts.
- My TUrbo is dying.!!!!!! dealer said the aftermarket warranty that I have will covered it..
- What shop in Denver can look over my S4 and tell me what I Need & what upgrades I already have?
- 100 Octane Giac X runs
- Ha, my friend bought a Civic Si 2 weeks ago and has already been challenged by a modded mini cooper,
- Tuning - Via Narrowband O2 Sensors - Interesting Post From Rennlist (Porsche Equivalent Of AW)
- PIGGIES
- Audi joins the hybrid game. Introducing the.....
- clutch decisions!!
- Got some 100 octane, gonna go out and make some logs...
- Need new Shocks, coilovers, front end suspension parts. What brand, where to buy & Cost
- Please remind me--official nomenclature for the options on my car.
- Desperately need complete drivers side headlight
- Paging Bauer. Found some pics of what you were talking about doing to your RS6
- I need an all-season tire that will be safe on the highway at high speeds. Suggestions?
- PAGING TOMASZ...what happened with your tire experiment? Did I miss the story?
- Race seat reccomendations?
- I'm a happy camper at last! FedEx came in with brand new AutoSpeed Exhaust Manifolds!
- Im going to buy a PA system for my car to harass other motorists. Reccommendations?
- If anyone was wondering 2005 AMG CLK55< S4 stage 3- :-)
- For those of you complaing about Don Rosen mostly B6...(Long)
- Weekly Top Gear Reminder 10PM Eastern Time Discovery Channel
- was driving earlier today and from 10-35 mph, i felt a "tapping" under my feet... i could feel it
- Update: On Inspection story today need help, Long BWW
- Coming to determination that AWE KO4 code can't be tweaked for ko4/16s...
- decided on track wheels......
- Anyone know this car?
- So today I got in my car to go to work and Im only boosting at 6psi...
- Repost: Purchasing from Chai Hu?
- Anyone know whether AWE ICs are in stock??
- I've been looking for a LONG, LONG time for this CD. Can someone help me out?
- Yum...
- Airbag keeps throwing code...
- can't believe what they've done to the R32
- Ok final extended warranty purchase advice request
- paging mike2ks4....
- <flamesuit on> Just spoke with the dealer, and now I'm worried...
- paging Daryl@tantrumworks - wanted to talk about Topline can you email me?
- I bet his tires wear unevenly...
- '01 center cap
- In case anyone was wondering how a stock S4 does vs. a stock STi ...
- Anyone here ever convert their piggie pipes to straight pipes w/ dumps... (ideas inside)
- intercooler availability
- Whats your thoughts on running dp's/cats on stock exhaust?
- Bin away for a while. Now I read stuff about unreliable hybrids. --->
- Quick help... How do I get the sensor connector off when doing TBB Replacement?
- Ok, best place and price for APR Bi-Pipe, besides APR. Thoughts?
- Best price on Borla G2 exhaust?
- Block 30...my values on the primaries bounce between 111 and 011
- APR chip on an M Box...
- Rear Brake question---
- A little midnight modding...
- Not sure if repost, but PSA: $4.80 MIR on Mobil 1 at Advance Auto Parts, now through 10/1. (more)
- Under what section or page area can I find pinouts for the ECU listed? In Bentley Manual.
- When changing OEM TBB do I NEED new clamps? Will it be okay for a couple of days without new ones?
- St. Louis to Chicago- 3hrs 30min..
- anybody know what bulbs are in the dome light? and the rear roof lights? Didnt someone post a list
- ***Sideways G2G*** Oct 21-23, 2005.
- Got my Vogtland Co from Mike@purems..
- I had an offer to trade in my blown K04's and get new ones for $1500. What do you think?
- The post below had me thinking about wastegate adjustment on K03/K16s.
- StreetSports still not feeling right?
- Technique for removing lower control arm tapered bolts from the upright w/o the special tool? BFH?
- Had a fun run with a Toyota Solara V6 on the way home from college today
- Inspection Tie Rod...
- BOBSKI - I hope you knew this
- These are getting installed tomorrow...
- What are the issues with installing a Parrot CK3100 LCD Bluetooth in the S4???
- Some more weight reduction ideas...
- Ok should I just write off every getting in contact with Jacob?
- Hmmmmm, Garrett Ball Bearing Goodness...
- wow, i could spend $60 at ledtronics.com for led citylights, WTF.
- opinion poll: does jacob buehn have a responsiblity to help pay for wastegate adj. costs?
- looking for a used high miles S4 for my A4 customer ,,,
- just ordered the odyssey 925mjt with the bracket direct from odyssey for $120.... good deal
- Reminder: Upcoming Audi Driver's Event at Barber Motorsports in Birmingham, AL
- Anyone every buy from chai hu?
- If the dealer replaces one of your metal clamps with a zip tie...
- Which OEM BPVs are people using these days?
- any chance someone want to trade a vagcom serial interface cable for a usb one?
- Seems like I always have to have the a/c running!
- What type of hard street driving brake pads do you recommend
- How much would a pair of blown K04's be worth?
- WANTED: Stock M-Box ECU
- Quick poll: Who here BOUGHT extended warranty, still has it, and how much was it? (edit)
- Wasn't someone selling K04 inlets for $499?
- APR vs. New Giac vs. AMS on boost ramp up...
- What's the best place to purchase an outer front CV boot kit from?
- Question about K04 install...
- Had a fun run with a Mitsu 3000GT (possibly VR4) after work yesterday...
- Questions about going to stage 3-
- Mark@ASP - YGM bud, i'd call but im too lazy to pick up teh phone.
- Brief vibration/hum noted while driving. I can feel it in the brake or clutch pedal. No abs light
- If you car is only running 50% of the time can you still call it a daily driver?
- Mike2kS4@PEB - J.Moss@TF - avantS4 - VonK / Imolavirus::Infected - Doc@PEB tuning- Mark P
- Need help installing Air/Fuel ratio on S4.
- Here are some logs from tonight... what does it look like?
- eric@spp can u help me out..
- grinding noise
- How wide can I go????????????
- Tie Rod Question: Does the inner ball-type joint usually need to be replaced or ...
- Thanks all for the friendly words and votes you posted on the occasion of my car sale. --->
- Help. I am experiencing lag from about 4000 rpm to 4500
- got the Key-Com, about to go log some data (more)
- MBC debate, Forge from ECS or Piggie (stand alone or parallel)???
- What kind of turbos are used on the cl65 and sl65 amg's?
- Dying battery? Bad starter?
- Wheel comparison: Volk LE37T or SSR Competition
- These look just like my ASP TD tips...are they the same?
- Haha, hopefully not a stupid question
- anyone ever seen/heard of this? seems interesting.
- start raising rear window, makes it to the top (I imagine) and hear 2 large
- Fort Hood retarded car picture of the day
- Damn.... I love having an S again. I am all :-D for the past 3 days. That is all.
- Just went to testpipes w/ASP DP and Forge....
- Paging "nomoreavants4" please.. have a question about your wheels
- throaty noise while driving at freeway speeds....
- Hey, would someone bid on this!!
- If you had K04's waiting for install... what would you do "extra" to them before installing
- Am I missing any wheels?
- [gunmetal O-Z SL's] - rims are on the S4!
- Battery Questions.. PC 680 - pc925
- Question for you all. I want to install this. Link inside.
- Only a honda owner could(would) do it....
- Mike2kS4 stopped by today and gave me a ride in the K04/RS6-Turbo-beast
- Does anyone sell APR Bipipe for less than $349? I need (want) to get one soon.
- Help me make a decision. Reman tip transmission needed. Level 10 or OEM reman?
