- Anyone have a stock M-box that they want to sell me (or trade)?
- Have you guys seen the R3? It may be a cool car. Mid engine and turbo...
- I need some used front bumper shocks in good condition.....anyone???
- Anyone have a set of 3mm spacers they don't need?
- anyone with an RS4 cluster in your S4, and it is working, and you have a vag com, could you do me a
- Sick of bursting turkey basters! What should I use for pressure tests?
- Any S4 Avants w/ K04 upgrade already done, for sale in the SE?
- Track only... what will be the recommend tire pressures (HOT) on NT-01 235/40/18 for our cars?
- who here has expierence with Light wieght racing seats that are NON reclinable (fixed backs) in your
- EGT Sensor Fault Code?
- Can I use a boost controller to raise my boost a small amount over the 14-15psi set by GIAC reflash?
- How much of a PITA is it to swap motor/tranny mounts while the engine is in?
- tool for removing drive axle bolts? where can i get one that doesn't strip?
- Cool product if you needed to change a flat on the side of the road
- Anyone have side grilles willing to sell?
- Wow, RS4 Grilles @ ECS are 200 !!
- ACNA-NJ NJ Motorsports Park, October 21st and 22nd...some open spots...
- I rocked a Mustang GT tonight. It was fun. I know make fun what ever I enjoyed it.
- Friggin' muffler shop welded APR exhaust to downpipes...
- symphony bose radio 01 in safe mode, tried code from front of radio book but did not work, what next
- Stupid Codes!
- im bored, pls humor me for a quick poll. stg3 build time?
- Issue with Hitachi MAFS Conversion after GIAC Stage 3- ECU Install
- wtb - low mile stage 3 or greater. western us
- Timing tensioner seal leak
- 18" Oettinger RZs - fair price?
- Would a healthy stg 3 B5 s4, be as fast as a higher HP supra to 80 mph? With the supra being limite
- Any AWs rocking the stock AVUS wheel replicas that come in 18"? Anybody paint any AVUSs BLACK?
- piggies = done
- Just got the S4 back after 6 months. Drove it from CO to Illinois....
- Holy IAT's Batman! Just did a pull tonight in Houston. Started at 130F and ended at 150F!
- ebay link to RNS-E!
- where does this rubber sensor from radiator area plug in?
- NEED TO DROP SUB FRAME HELP!!!
- Need help with code
- Carbon clutch break in
- AIR BAG light on?
- Anyone want to trade a stg3 sedan for my stg3 avant?
- Where to order a clutchmasters clutch from?
- Help with codes please...
- I have RS4 instrument panel, but RPM gauge is not working!
- Can anyone vouch for STGeleventyS4?
- Audi Driving Exp. + R8 (Video from Super Cars Exposed)
- Mobile 1
- Is these errors bad? What I must change?
- How to remove driveshaft?
- Part # for Window Wash tank??
- //SFest '08
- Well, I went ahead and ordered the new crank pulley...will be here tomorrow
- what do you think of my "dream S4" shot?
- best method for pulling engine on a tip?
- wheel spacer Question ?
- Timing
- Installing RNS-E CAN Connection Questions
- Does anyone know anything about the Westfield Megabusa?
- Are there any problems of mating a Borla cat-back exhaust onto Labree DP's?
- looking for stage 3 advise
- VAST METH INJECTION/HOMELINK DIY PICTORAL
- Paging NogaroHiro, Changed my name btw.
- FEELER: If I were to part out a 2000 Silver B5 S4, what would you guys want off of it? Post here plz
- going stage 3
- What causes this problem-at least once a week I encounter
- putting the car back together. Q's
- The writeup on aligning your bumper to fender is probably the best ever !
- Potential causes of my oil temps hovering at 250* on highway and spiking to 270* on long inclines?
- where can i get a new/used autodim rear view mirror for my b5 s4?
- Anyone have a Silver Alcantara RS4 Knob for sale?
- [X-post PNW] To the Pearl White B5 S4, Washington, I-5NB, ~mile marker 145, 10am today
- is there anything else other than softcoding on a cluster that would cause the speedo to be wrong?
- S4 ownd by hurricane?
- poor Audi
- Misfiring - Exhaust Temp Sensor Fault Code
- What clutch are you stage 3 guys running?
- Is my clutch fubar??? I had an RS4 clutch put in about 25000km ago...
- Anyone have a side by side pic of Depo head lights with stockers ?
- My dash no longer works =(
- Anyone else see this picture??
- Good God they need some serious help.
- is the silver interior called ecru?
- Transmission is VERY hard to shift?
- BOTH bank 1 OEM O2 sensors took a dump in only 18k miles?
- Fvckin A Right!
- lots of stuff today.. stg2+ vs. GTO
- 66 @ 166k. :)
- Quick photoshop of RPM2's off of my Silver S4 on the Nogaro.
- I was doing TB job today and looks like my harmonic balancer sh!t the bed...anyone here seen this
- Fault code help
- does a B5 S4 clutch fit a B5 A4???
- Rear wheel, that long bolt above the wheel? (control arm I think)That thing is squeaking like crazy.
- How do you clean alcantara? i already used magic eraser + defuzzer
- Well, I picked up another S4 after mine got flooded/totalled, Clathrate's 01.5 ASP Stage 3 Nogaro.
- OT: Spotted an E63 AMG wagon and the new GT-R yesterday. Both are awesome.
- Air coming out of spark plug
- missfire on cyl 3 and slight lack of top end..
- Avant owners - Roof Rails - Anyone painted or made brushed aluminum look
- rear caliper dragging...
- Kinda OT - just got back from Los Angeles. Didn't see one B5 S4 at all.
- Looking for a Nogaro Blue K04'ed S4, anyone got one forsale or know where I can find a nice one?
- Is it normal that the F hose has a slight bit of oil? Not like dripping off looks like condensation?
- does anybody know whos car this is?
- Yet another milestone: 150 @ 150.
- New personal record. 5 hours from start to finish pulling the motor...too bad I couldn't
- Tonight was a good night...
- EGT sensor bolt backed out on drivers side..
- Just wanted to say thanks to Wicked Motorsports!!
- why won't my car start? I have fuel, I have spark, it tries to start but dies
- has anyone bypassed the 2ndary air pump and kept the combi valves?
- anything i need to know before trying to lube the rear diff?
- WOW....pricey!
- anyone ever make the 3rd button by the 2 fog light buttons (pre-esp) a working switch, and if so
- noise inside cat back. like a piece of a weld flew off and got stuck in there.. how to get it out??
- does anyone know if Miltek sells the Muffler section of the exhaust only?
- you want to see something purtty at WMS on a saturday afternoon?
- 2000 S4 having starting/stalling problems even while driving the car will turn off/stall???
- first "milestone"...thanks for 5 (almost) great years aw..here's to 5 more...
- Headlight washer cover broke off the passenger side.
- HELP needed i'm in Austin TX soon to arrive in Dallas , anyone here has some stock
- With Stage II do I need a new air filter upgrade?
- this cluster is unbelievable!! it made me smile
- Turbo noise/no boost issue...just installed k04/16 turbos and fueling, started it up and no
- ***Reminder, Hartford, CT GTG - 9/9/08***
- B5 A4 used as a decoy vehicle to catch NJ theives on A&E's new show 'Jacked'
- is it a bad idea to run the same 18s in the winter if i also plan on using it as my summer wheel....
- nothing in the classifieds... anyone looking to unload their ITG filter?
- Help with code... I did search
- I need a new clutch soon.Is it easier to remove the tranny by it self or it's easier to remove....
- Black Tip S4 w/ B7 RS4 wheels in the New Life Church parking lot during theMILL tonight
- Well, just got done with stage 3 swap...after driving it the driver side turbo is making a blown
- whats the tolerance for shaftplay on k04? 1mm? or less?
- NORTHEAST AUDI End-of-Summer JAM.....3 weeks away!!!!
- Hose clamp pron...
- Holy sticker shock (RS6 sedan)
- Swapping out my blown TS dampers with new ones...
- hey guys, Regarding a engine hoist Leveler?
- Source for throttle body cheaper than audi
- Is it possible to get the rear windows down all the way or no???
- All-Nippon ENEOS 0W-50 Oil! Has anyone tried it?!
- How much additional DIY time to change both motor and trans mounts, while doing TB?
- About to buy awe pedals, any other suggestions?
- Quick review of Stasis Motorsports (3 days and 400 miles)
- What a PITA - shopping for tip trans fluid and gasket.
- Which color: left or right?
- does anyone have a clue why my tranny grinds when going into 3 after a SSK install? Ihave tried
- Objection to Glasser v. VOA class action. <<== Reminder, if you are going to object...
- B5 A4 decoy car on "Jacked" Anybody see it?
- (edit for pk) S4=>rs4 bumper mod tips
- i need to see a race before i spend more money....any outcome.
- So I've done a bit of searching on fog light upgrades and still a bit lost...
- key fob no longer locks/unlocks doors...
- Are the cool kidz still running Bosch Platin F5DP0R plugs these days?
- Help: Car won't stay lit at idle..is the pump (walbro) dying or is it a bigger issue...(long)
- mile marker-failed
- UPS just dropped of my K04/16 hybrids from Audspeed. Look pretty good! I had
- OT: way off topic.... love forced induction? introducing the T-25 turbo bong
- noise when braking coming from shifter area?!
- ECU
- Going to be putting the K04/16's on tonight. Real quick, are there any vacuum lines or anything
- Shop told me I need new inner Tie Rod & Ends, where to get them?
- I sign of good things to come...
- This is whats going on at Wicked Motorsports at night :-)
- Calling on sphere for help...
- Oil Change Question: What type of ramps to use?
- Is there any alternative to ACHTuning for the mesh for the RS4 bumper mod?
- Anyone have any cool vector drawings of B5S4? I have a new project I am thinking about.
- Click sound from under hood? K04s just installed. Need IDEAS.
- Rolling rattle or knocking...
- Two quick quesetions...
- Cracked Expansion Tank. Pinhole Leak spits whenever car is warmed up. is it posible to use the B5 A4
- where to have turbo ceramic coated?
- WTB: Ashtray Cover & Hazard / Cupholder Surround (wood, plastic, whatever)
- Surging issue resolved!
- so tommy goes back to the track 11.64@119 Stage 3 SSP Tuned
- Enigma. Spark plug question.
- Indicator lights don't work via indicator stalk but work via emergency button. Anyone have any idea
- Couple questions (alarm issue, wheel issue) and all ready STFA-
- * Edit* VSS (vehicle speed sensor) still screwy. Any other tips?
- So I switched to 91 oct program and my rpm's are hanging between shifts . . .
- Anyone ever have this happen to their knob?
- Those with the 034 K04 inlets....has anyone had to trim the lenght of the silicone couplers? I
- Any tips on taking off the front bumper ?
- What base mounts do you recommend me to install recaro seats?
- Other than samco
- would greatly appreciate a carfax if someone has the ability...
- Help getting ECU-X running...
- 25psi spike on awe stage 3.. normal?
- Can some on school me on the vast water/meth kits? would my car like it with no tune?
- has anyone tried the 034 compression dropping headgaskets with k04s? .7 point drop
- WTB S4 Bumper licence filler & Right Fog Light
- I get the s4 back on Friday! It is finally finished after 6 months of it not running.
- paging skydive... any brake launches yet? :) how's she holding up?
- where can I get a TCD for a awe tune?
- there's a torque converter on audizine..
- Got this message-what should I do ?
- Anybody got a broken ABS module laying around?
- Anyone have 2.5" TIP DP's?? What are my options? I checked out APR already...
- Jibberjive has first dibs but has yet to respond. Lemieux is 2nd :-) Ihave a RS4 black air leather
- help, I'm out of power steering fluid and on vacation...
- So I'm getting boost spikes. 27lb! I would log block 115 right? What rpm/gear? VAG Noob here.
- 2002 S4 Driver's Side Mirror Lense Issue
- S4 Badge on Steering Wheel
- 8^O ZOMG! I want one. (500hp RWD R8 for GT3 Class)
- For those with Stasis rear brake kit, once installed is it normal to have much more parking lever...
- ACHTUN!NG | OEM Audi 17" Winter Wheel specials, $699-set!!!
- Bang for the Buck oil change..
- x-post...wheels for trade?
- Any ever seen this code, 16536 - Oxygen (Lambda) Sensor B2 S1: Signal too High??
- nice low mileage 02' sport nogaro in chicagoland
- Any reason why my front tires would wear on the outside edges? They are inflated to spec.
- Finally got the Service Records for a Listed S4 - Mind offering opinions?
- Any PureMS coupon codes? I need some 20mm spacers, like yesterday!
- Replacement AT Italia S5 (17")
- Thanks to audikillsbmw for the perfect condition UUC Rob knob! Also for the quick responses and fast
- ***NOW SHIPPING*** A.W.E. Tuning DV1 Diverter Valve
- Big thanks to S4Per for the RS6 wheel! Paddle shifters FTW! I felt like Louis Hamilton on the way to
- Doing piggies, knew it was a pain but f***!!
- WB with newly refinished IF'd Sprints >>
- Is there a pic somewhere of a Laser Widebody Sedan? Does one exist
- misfire on cyl 3, new coils, spark plugs, injectors, and o2s...
- Help me with this fats log I tried to run......
- Hawk Pads just showed up, came with connectors on all four inside front pads???
- wipers out of control !!!!
- absolutley doesn't belong in this section, but i thought if you were having a bad day, this can help
- resetting radio
- which one of you stoled my sig?
- family member just backed into the front of my car in the driveway. not paying attention FTL
- Just reset the SAC on my RS4 PP...can someone look at this pic to confirm it is reset correctly?
- Anyone have pics of alternatives for the according house (for crankcase pressure)?
- Longshot but does anyone have a working 2000 S4 TCU/TCM for sale? Tiptronic Control Module
- what in the name of all thats holy is this~!?
- Replacing IAT sensor: STFA returned little more than than that it's possible. Procedure anyone?
- okay, need some b5 s4 sedan santorin widescreen wallpapers... post up!
- Notice anything different?
- Stage 3 update: Everythng works great! Thanks to everyone on AW...
- Anyone have any experience with the Audi RNS-E system?
- Pratically "Brand New" 2003 RS6 For Sale
- twin gt28rs set up pictures??
- Code help please yes I stfa
- Replacing the PP to flywheel bolts...I have some allen head bolts that are the correct length
- Someone help me... exhaust shop is giving me the run around...
- who's got ko4s in stock ?
- Brian Sump YGM!
- Anyone know where I can source a central locking pump without paying arm+leg
- Anyone have a clean well maintained Stage 3 B5 S4 for sale?
- Buy back value is $1,500. Most likely I'm buying it back.
- Paging ColoradoBrad: Did you ever get the oil temp sensor issue resolved?
- whats the biggest turbo upgrade on a 2.7t. someone tried to tell me...
- wOOt! Just placed an order with VAST website and love the Google checkout and e-mails on conf. and
- APR Stage 3 guys. How did you orient your RS4 injectors?
- Thinking of buying EXUx.... questions
- When it comes to 1/4 mile times:
