- Are there any overlays out there for K04's v. gt2x that ATP is going to offer?
- So what kinda damage would happen running the 100 octane program with a tank full of 91 gas? (Long)
- Check out this faker...Horrible picture, but it shows enough. Audi A4, WITH the A4 badge, but...
- while car is going through its works, i have thought about how much i will be driving it
- anyone have any pictures of tracksports installed, particularly the lower spring perch set screw?
- STFA reveals that coolant sender can cause all kinds of running issues, but can it keep car from sta
- Nav+ CDs?
- coolant temp saga continues.. or more succintly...
- is ToyGuy still making the V1 remote display housings?
- I can't figure this out!!! Help me please!!!
- does anything noticable happen if you have a small boost leak?
- what is the OD of the stock downpipes where they meet the exhuast?
- Steering rack question...Is the preload adjustment screw accessible from above or below without...
- Any recommendations for Foglights?
- O2 Sensor Question
- NEW MOTOR NEEDED
- I believe I hurt someone's feelings last night!
- does anyone have B5 S4 Avus stock center caps or know of where they sell them without the rings?
- Highly recommend Autospeed performance for work on our cars...
- B5 S4 stage 2 (full exhaust & chip 93 octane) vs. B6 S4 with full bolt ons and chip
- Can someone tell me if any special tools are required to get the panel above the pedals...
- i had one of these next to me yesterday
- Can you do piggie pipes using the stock exhaust?
- anyone have pics of "apr tuned" badge on trunk?
- raced my buddies t3/t4 GSX. he went 12.1 on his old turbo (16g)
- Hal_S4Shizzle::CBP................................ ......
- S4-0 vs Mustang GT-3 lol I got smoked by a GT man!
- Average life expectancy of K03s?
- Lowering question
- Any consensus on the number of Wastegate turns/cracking psi for K16's? (Mike/Jacob/Verruckt...?)
- Bought 11SecS4's Vortrag CF hood today. Very light (11lbs w/ pins!)...should I paint it?
- havent driven my S in a couple weeks... :(
- 600HP S4????
- LED failure on the gauge cluster, can anything be done?
- OEM battery died hard today. replaced it with a Sears/DieHard International.
- Just found 2 18" SSR GT3's to complete my set. But the guy has a set of 19's for only $800
- Poll: How lean do you run at idle, part throttle?
- If I was to just do the TC instead of the full L10 how much hp/torque will the tranny handle?
- Whats the best air intake to put on my 2000 with GIAC. Thanks
- Got a few things done on my car recently, getting close to going back in . . .
- Fun with the GTech Pro RR
- what is the inner measurements of the awe maf
- who is running revo stage 3 here.
- Has anybody purchased carbon fiber trim from golfrsi?I am getting a set and was wondering how it...
- questions for buying an S4
- Taking the good with the bad... <Updated>
- cheapest/best place to get fog light switch?
- EMCS help please. I got my apr emcs programmer but no email with new stageiii program...
- worn rubber in suspension control arms/links - replacement recommendations? TIA
- Aside from a B5 S4 or a hectic S60R, any other AWD turbo luxury sport sedans?
- Days like today make me love this car .... snow + winter tires = TEH WIN!
- Who has spent the money on the E-Codes with the Euro lens? ...
- GIAC 3- ECU testing (part 2)
- Poll on APR bi-pipe: Comments?
- Anyone with some spare time today? Sig request...
- Dead battery killed my instrument cluster! :-(
- does a worn e-brake just mean i need new rear pads?
- FIXED my NO START, thanks to all of the FORUMS! Check this out.
- My Samco TBB is the worst fitting TBB in history...
- Since it seems like a slow Saturday - here's something to read
- Poll: Has anyone done this before ? Started engine while on harness & while sub-frame dropped ?
- Help with B&M short shifter
- So why does the parking brake on my 15 year old Civic work perfectly in the winter...and yet
- Stupid oil question: What's the proper weight for winter use (like in Rochester)?
- Stage III B6 S4 vs Stage III B5 S4 on the top end...
- really dumb question, but should the side corners be lit up with the headlights, or
- 01 stock S4 during 3rd gear at 4500 rpm the malfuction indicator lamp flashed for a couple seconds
- Help with brake pads RS4
- The fun just never ends...
- Just solved my "unsolved mystery", car runs much better with MAF unplugged
- I just purchased a 2000 silver S4, would you guys post your pics with aftermarket rims. Thanks
- kind of a random question but does anyone have an 01.5+ grille badge that they would trade for a
- Just to put the turbo power of the S4 in perspective.
- What wheels to get, aready have OZ so what now, maybe black
- PES wheel nightmare...
- Adding gear oil to the fire...
- Ok, I'm sick of STFA... What are the best brake pads for street use (no track) in stock calipers...
- Alright... who told Shiv and Dustin they were being talked about?!?!?!?
- STI run in....
- UUC melting Evap/Vapor Tube..
- 1.Stasis Std rebuild tranny + stasis LSD or 2.Stasis Close-ratio tranny?
- Any way to fix sticky buttons? My up middle and low heat buttons are almost stuck
- Ramble about my car problems.. what's going on!
- Are the B7 S4 Avus wheels less concave than the B6? They look so.
- dumb biatch at the car wash...
- Looking for a set of wheel locks for my 01 S4....
- Transmission BT: Stock vs Euro Spec vs Stasis
- Parrot CK 3000 Evolution Bluetooth install
- I should know this. Can TIP trannies handle Stage 3 power, or is L10 required?
- Coolant temp gauge showing alot lower then usual
- Anyone running Hartman M1 wheels? They look like a less expensive alternative to the BBS CH but ...
- anyone have an old broken instrument cluster? need parts.
- Got my car back and took a few pics... since it will be leaving the safety of my driveway soon, once
- Attention home brew stage 3 guys... Used greenies with 3,100 miles...
- Anyone using Redline Manual transmission oil
- BT vag com, Just got this code...
- Hartmann Black Friday Deals Now Online Includes New B7 RS4
- Fender liner for rolled fenders - help!
- Lost my key! Need some help! Please read
- Towing?
- X-post: Pops needs a new ride
- suspension & fuel guage & rear view mirror
- Looking for a nogaro front bumper -- crappy weather + summer tires != good idea.
- Quick Stage 3 Homebrew Question...
- Need a new battery. Whats the best one out there (cold weather performance and lifetime wise)?
- OT: Dumbest/Stupidest Criminals!! In my neighborhood too!!
- crazy azz house OFF TOPIC
- Attn: K04'd B5 owners...I have a question
- Thanks to jasons4 for the L/W flywheel he sold me just got it today it looks great can't wait to...
- whats going on with awe i been trying to reach them but nothing yet.
- Imola yellow owners, how bad is the attention you get from cops? In comparison to other colors like
- Still cleaning myself up after seeing those S3 pics Chris put up...
- clearcoat too thick on caliper paint
- Well all i want to do is take my cd's and put them on the dms cartridge/??
- Why is the price for cf hoods so different from apr/awe???
- fyi: 245/40 re750 tires fit on 8.5" et35 rims with a very slight drop and tracksports with 700/800
- Awesome! Audi S3 with 550 hp RS4 motor!
- Hit or Skip
- Airbag Light On. Can I use generic scanner or neet VAG COM?
- Springs/Shocks Setup or Coilovers????
- Okay, I've finally snapped out of it. My car is no longer for sale.
- 245/45 Z17. Will these fit the stock B5 S4 rims? Thanks...
- Where to get 18" Volk LE-37's in gunmetal with the polished lips....
- Post for anybody else working today.....if things are slow, check out google video
- Just got a ride in the autospeed GT turbo'd S4.....
- Ever hear of " A & J Wholesales" out of Burlingame, CA? They have..
- Question About Navi Plus FX
- K04 install started tonight, tear down anyway
- We've got BLING for the holidays !
- Hood Pin question...
- So do you people with APR chips ever use the stock mode?
- Revenge is oh so sweet! STI: 0 S4: 1 ...Put 3-4 cars on him from a 60 mph roll. (more)
- Saw an Audi S3 yesterday with a 550 hp RS4 engine crammed in. It was actually a good fit.
- Which coilovers should I get?
- Phatbox question: how to put cd's onto dms cartridge?
- How much do our stock b5 s4 bumpers usually sell for???
- How to activate the heated driverside door lock?
- Need help with my wiper blades!!!
- Where might one order an RS4 steering wheel and can an S4 logo replace the RS4 one?
- What kinda wheels are these
- CHEKIT new sig..aaiiii
- Hey guys was just chatting with a fellow GIAC owner
- happy thanksgiving from Wburg...took some new pix today
- owners manual
- Replacing my control arms on this cold cold Turkey Day...
- Top Gear video of B7 RS4
- yeah...cargo net
- Just got the VAG - the code inside explains a lot...
- anyone with snow falling......
- The dentist drill cometh....Happy Thanksgiving.....
- Should summer tires be deflated for winter storage?
- Small fender bender: Lookng for both passenger side doors (more)
- hows the snow doin
- Who here is running Bosch EV6 injectors?
- Ok, it's been a couple of days now since i had both EGT sensors replaced and............
- Cargo Net Sale - Only $396.00?!?!
- Good Morning and Happy T-Day. Be safe, and pace yourself!!
- See, trees do serve other purposes.
- do i see some revisited interest in the 2.7t motor again? in the last 24 hours 2 tuners posting
- Question - PCV valve - blow by return hose
- exhaust issues
- New Performance figures for our S4 Stage 3. Now 465HP on 93 oct. Ask for chip 32098DKFJHIUEH90832.
- A question for the experts... Is this throttle cut? VAG logs inside...
- haha blast from the past! 'smellsogood'
- angel eyes... abomination or cool?
- Anyone ever have the Reluctor / Toner Ring on the crank slip?
- Whats my bolt pattern ?? and offset ?
- GIAC 3- initial RHP testing impressions
- owners manual
- just wanted to give a shoutout to influx.....thank you for the ride and giving me an s4 fix. his
- So Cal Pasadena meet on Sat. Nov 26th 630pm @ Fuddruckers parking lot!
- rear defrost interferes with radio signals.
- what's the word on spec stage 2+ clutches ??
- SPP yellow fogs, what wattage?
- 245's on an S4 w/o body mods? (H&R adjustable coilovers)
- What to do? What do you think? I'm new to this.........
- Bored at Newark Airport, flight delayed, terminal packed...
- Question about remote starters
- Tip FATS-like methodology: did anyone ever document a method?
- I rode in and drove someone else's S4 for the first time tonight. It was enlightening.
- What is needed from Clairparts to make the Phatbox work? is a VW to Audi cable required?
- 11/15 repost: yea or nay on the ECS lightweight pulley kit? (link to original post inside)
- StreetSport First Impressions
- WIper Linkage
- popping from front right under braking - what else could it be?
- Is there any surefire way to determine if a maf is bad?
- Anyone have a Fidanza Flywheel??
- Turbo Instlation info needed? KO4?
- Anyone have a lightned flywheel?? Rattling issues?
- Does Bentley list part #'s? If so, where?
- I'm having issues with my new brakes. Can't get the pedal to firm up, among other things.....
- Those running 205/50/17 snows, any issues or comments please.
- Attention: Anyone with-in 20 Mile radius of 91335 (Reseda) - Tarzana - Encino - W/ K04s or Hybrids.
- alcon b-type owners or resellers.. im looking for a spare set of upright bracket/carriers
- Cold weather vibration question (turbos/tranny?)
- Ok, I finally dyno'd it.
- test drove a Legacy 2.5GT, brief impressions inside....
- euro lights...
- rear trunk panel removal '01 S4 Avant
- Day People: K04/RS6 vs. OEM K04 vs. K03 ---> Finally planning on going STG 3 (-) - (Part I)
- I love how this forum has become the marketing machine for all of the paid advertisers. :-(
- license plate frame
- FWIW: Up In Smoke just started on SpikeTV
- IM BACKKKKK!
- so lonely here in vegas
- AWE Tuning Holiday Schedule.
- 93 in Indianapolis. What is the standard premium octane in your area?
- I have 2 set of S4 Euro Lights available right now!
- Vogtland coilovers going quickly.
- weird drivetrain problem... (long... sorry)
- Clamp diameter sizes for TBB please?
- Different ET numbers - what wheels can I fit?
- I need the part number for the O ring that goes on the intake side of the K04 (225TT should be same)
- Fuel Pressure Regulator at dealer cost is around $70, is there a better price available elsewhere?
- CEL Code Help
- Soooo, S4 don't like it when you run them in gear on a lift, then try and hit the brakes.
- 60F, 1 gallon of T sauce + 14.5 gallons of 91 craptane, AWE IC
- Anyone have a used stock/giac L box for 01 S4 they wanna ditch?
- Someone in the Bay Area who repairs Outer CV boots
- Audi Symphony Hidden equalizer settings - I STFA but couldn't find the post - anyone remember how
- VAG COM - Which one do most people buy? I was looking at the one for $249 - will this do it all?
- hi GIAC, why dont you make software that disables CELs for people that dont run cats?
- How much would a 2002 brililant black S4 (black interior) with less than 30k miles be worth?
- PHOTO REQUEST: 'before' and 'after' shots of stock wheels with 15mm spacers.
- Hey everyone. Considering a B5 S4 which I will modify (K04s). I understand that reliability is a
- FYI: a oil catch can makes it a real pain to do a preasure test
- Send us your pictures, get a free Hartmann Wheels T-shirt
- Homebrew guys please read inside
- Paging crew219
- damn it... I've developed an oil leak... :(
- bose rear deck speaker questions, what screws do they mount with any approximate specs?
- NO START! Still need help, Updates. PLEASE
- 4 those w/ stg3 lighting, r u able to place 50w ballasts inside headlight housing? (more)
- (Voice from the past) Paging Daphne!
- I just found the coolest feature on my car (not really) From a post below. You can unlock all doors
- Borrowed my bro's E46 M3 this morning ...
- Replaced Alternator.......
- Brake issue.
- So what are average whp numbers for stage 3? how about above average?
- We've updated our RSK04 turbo kit pages. New dyno sheets and info.
- turbines being replaced, 8 days cpo reamining......
- R the auto trans and Engine computer separate?
- Brake longevity?
- $#!@! My driver door lock just broke and my key remote is dead... Now what?
- Bently guys...What size is the fitting on the Tranny Fill Hole on a Tiptronic tranny pan?
- Samco TBB question, I already STFA
- is the AW heading wingdings for anyone else?
- Is this a rip-off - dealer fixed charge for diagnosing check engine issue?
- Motul 300 gear oil (GL4/5) > Redline MT90 .
- What is that noise coming from engine area?
