- how bad is it if i dont have the little gasket that seals the inner cv plate to the tranny?
- So just looking for some knowledgeable advice about exhaust...
- Help: Question on Failed [Massachusetts] Inspection
- Big Socaleuro GTG May 20th @ Ventura Fairgrounds (!!!FREE!!!)
- Check engine light went out?
- About to reserve a spot at EPL dyno. Does a wet weather / wet tires effect dyno reading?
- Video of AWE Stage III vs. Homebrew Stage III (3rd gear pull)....details inside....
- Can you add Heated Seats or the parts to make your seats heated?
- got a copy of ETKA finally, but now i cant open it
- Can anybody host a video of a 3rd gear pull - AWE Stage III vs. Homebrew Stage III? (4.85MB)
- Calling on Funkweasel, GET ME THOSE CAMS....You're a nickel holding up a dollar!
- does anyone have a picture of an S4 or RS4 bumper with silver mesh in it? TIA
- Need a fast response...When going from an A4 front to S4 front...
- Test drove a Stage 2+ last night...and was surprised at the turbo lag...
- My wheels say Ronal on them when I take the caps off....shouldn't they be avus? do i have copies?
- (Feeler post) Is it reasonable to think that I will be able to get...
- A what would you pay for this car post.... '00 S4 6-speed with ~50k miles, K04s, DPs, exhaust,
- anyone have a stock leather e-brake handle grip laying around that they would like to sell??
- anything else under the car (near the middle to rear) that would make a repetitve thumping noise..
- If you had a chance to get the B5 S4 with the right color/transmission..but with the wrong interior.
- What is wrong with this clutch? (bww and longww)
- Has anybody tried to....
- My wife is complaining about the brakes on her allroad... anyone who upgraded their rear brakes have
- Cat Back Milltek Exhaust S4 2.7T
- Question about primary fuel tweaks:
- anyone here going to the Audi ride and drive this weekend? Why did they pick..
- Yatzie! No start problem fixed!
- How can I reset the ecu? STFA but futility...
- NYET database question....
- for those waiting for your Pro-S, this may tie you over
- ASP stage 3 FATs inside
- The latest installment of Streetwerke's "Hall of Shame" . . . water pump failure 101 . . . mbww . .
- AWE Stg3 vs. Piggy Stg3 - video
- anyone need side curtain airbags?
- HELP! Front Suspension Creaking Noise
- Installed hoen titanium h7 fogs...
- Something I've never personally seen . . . new cluster. Serious EFU customer . . . = )
- Would a vacuum leak cause my brake pedal to get REALLY firm if I don't drive it
- anybody wanna take a swing at this one....
- Some Logs... tell me what u think.. 3rd gear 2500 - 6200rpm
- I need a little help sourcing a "clunk". I have narrowed the location to the f.left (A6 x-post)
- Grease points?
- 00 S4 2.7t vs. 00 A6 2.7T
- What you guys think about the console trim?
- Bling! Teaser shot!
- been reading European Car Magazine for 20 years now... the new July issue has got
- Anyone know where to get the RS4 tranny mount hardware...is the dealer likely to have em in stock?
- How many stg3 people feel "clunck!" when you let the gas off on WOT(on high rpm)
- PAGING X-1 Racer..
- last chance to get in on the San Diego/La Jolla dinner tomorrow!
- funny joke.... what did the drivers side front axle say to the Uli?
- Whats the going price for a used APR bi-pipe? They are tree-fiddy new.
- When does timing belt have to be replaced? Dealer says 170k kilometers...>>&
- x-post: o2 sensor problems
- What type of leather conditioner do you use? ..Brand and type?
- I am going with the EFU guage, want total stealth, which options should i get
- WWAWB5S4F do?: AWE center vent gauge just arrived. Reconsidering, but AWE charges 20% 'restocking'
- Anyone have an extra drivers side door handle cover they want to get rid of?
- Question on a code I'm getting: 17884. Possibly a bad N249?
- power steering messed up
- oem mirror caps ....
- FYI: Don Istook front Control Arms are back in stock.
- k04/k16 awe fueling kit and a 5 bar FPR and a tune from tony hit or skip. Or ...
- Tech Article for Front & Rear Rotor & Pad replacement
- Whats the easiest and cheapest way to fix an ABS control unit failure???
- Any O.Z. SUPERleggera III owners out there?
- Paging Tweaked Blueberry RE the REs: Sorry I didn't get to respond to your post earlier; I love the
- Im ordering mesh from mcmaster soon for the lower grilles but what dimensions should i get?
- Looking for a set of wheels around $1000 w/o tires any suggestions?
- jacob YGM
- Those who've had their dash clusters replaced recently due to the fading LCD display....
- is it possible to get a set of rims with a deeper lip for the rear of the B5?
- May be coming back into the fold...looking at a Laser Red Stage 2 B5 S4 tonight
- DTC's system to lean.... time for new o2 sensors? DTC inside..
- great vid had to post it this guy owns all these drivers
- Car is already at shop, how much extra labor do u think for 710n DV's install also? I have the parts
- Brand NEW N75 (078906283B) from "stealership" and my boost problems continue..This is absurd! :o\
- What 1/4 mile and 0-60 times should I expect if I do Stage I
- Finally got around to painting my calipers last weekend.
- Homebrew water injection near completion...
- So what's the current consensus for max safe power on stock internals for our engines?...
- It's funny how far the forum has come from the anti-Autospeed DTS scandal days...
- Very cool car I finally got to see in person this weekend (E30 M3 Cabrio):
- Thinking about ECS Stage 4 setup, but have questions on bias. (more)
- best place to buy an ABS pump ?
- Enjoy this one.
- So I can't seem to get Carbotech XP8 in time for MMP, any other recommendations for race pads?
- For a moment, I thought my car had been Jerseyfied....
- hope this wasnt any of you guys <audi crash inside>
- <Paging Dr. Kevorkian>, please go to the critical care unit. Your "work" is needed on K03's.
- Can you use RS4 f/b brake calipers & rotor's on B5 S4?
- does anyone use these?
- ASP FMIC is nearing completion and almost ready....
- Need help with the Secondary Air System
- So I reinstalled my APR Bipipe yesterday and I had to mess something up..
- OK..so while I am on the subject...K04 - versus K03/16- ->
- Are there RS4 replica's that come sized at 17x8 or 17x8.5?? And...
- Anyone know "euro2ned" account #105000...I need to get in touch with him ASAP
- is there anyone located close to me with an B5 S4, i'm curious if there are any other's around me. I
- Bored?
- Post DP question on Turbo noise
- Clutch Prob.?? RS4 clutch in 01 S4, slipping??
- Is race gas safe to use once in awhile with just catback and an air intake?
- 5/13/06 - This Saturday: CT/NY Audi Group & EPL Gathering / Dyno Day (3 open Dyno spots)
- Are these hybrids? K04/?
- STFA is getting to be a lesson in futility... Searching for best source for K-04's
- What are these worth?
- Any owners with a Borla Exhaust in NJ? I would like to see how much quieter yours is than mine which
- $10k for mods or sell the S4
- Seeing I now have to start from scratch, can one of you please tell me how to
- BRAKES AND ROTORS..WHAT IS THE COST ON A JOB LIKE THIS? ANY RECOMMENDATIONS ON PLACE IN CENTRAL MASS
- how do people use stock seat belts with aftermarket seats? seen pics in archives
- Sourcing an AFPR. Though I prefer Tylorsport. Are there any alternatives?
- as i let off the clutch..the car s making a HUMMM noise. not all the time though
- what's the size of the B6 S4 Maf ? .. i asked the b6-ers and they have no clue .
- Ever feel like you're walking on egg shells? Just wondering.
- i need some advice frome the homebrew crew, my CFs are at 12, my o2s .86 and no matter..............
- Part Number request for the hood latch for an MY00 - TIA
- Anyone need a lower knee bolster before I throw it out?
- Paging TwinTurboTerror: Looking for side shot of your car with the Vogtland Kit...
- Vote : NO.BRAZIL has the nicest Casa S4 evah!
- Hint for those looking to sell rims, wash them, then take pics...
- Can stock resurfaced dual mass flywheel handle RS6 brids, ASP fueling and upgraded clutch/pp??
- Thanks K04/RS6-North, I rebedded my brakes and they grab much better now. :)
- my F1 GS-D3s saved my life last Sunday...
- UGH...I'm coming over here for awhile
- anyone try nitto NT-01 R comps for track use?
- Dyno plots from dyno day April 28
- O.T. Any thoughts on a car, new or used, that can replicate Porche 911 drivability..
- got the title today!!!!!!!!!
- The turbo lady called yesterday at the track.
- unused parts value
- Random: I want to get these seats in the next one....
- Advice on whether to get this extended warranty?
- Professional Sunroof Removal: <All Interested Please Give Feedback>
- Who's actually resisted full throttle "testing" during their new clutch break-in period?
- Not sure if this has been posted before, but...
- *The official SE Drag/Dyno Weekend Poster* [bww]
- Any ideas what would cause oil sprayed on the outer edge of my driver's side front wheel well?
- Hey Level10 Tiptronic guys
- eibach pro street c/o's........does anyone know where to get them at? besides shox.com???
- Is there a more stealthy way to mount the Blinder? Looked at FixedWing's pics / writeup and that's
- Wher can i buy mesh from to do the RS4 bumper conversion thing?
- factory top speed...142? I hit 147 ??
- No more C6 Plans...
- any A box switch to RS4 fuel rail, pics would be helpfull or real RS4 fuel rail routing pics . . .
- speaking of 710Ns, mine have ~30k on them, any reason to get new ones?
- stock front calipers, how much are they worth?
- Ok, question about brake bias......
- LOL! Found a video on Edyjun's video section...3 years ago when I was stage 1
- Any tricks to installing coilvers that my shop wouldn't already know?....
- Whoa.... what did i miss?
- Wow... first drive since installing the 710n's. No lag and quicker spool up/response>>>...
- can i find SSR wheels besides tirerack?
- The Real DIY downpipe-gutting install: 85 Easy Steps (warning long)
- PSA: the crankcase breather is *not* designed to be removed with the coolant hardlines in place.
- Where to buy Carbotech XP8 from?
- any issues with venting the vapors from the ACF system to air rather than plumbing it back into the
- Another crack addict is born..
- Achtuning tire special, $500 for 225-40-18 Michelin Pilots with any 18" wheel order
- AFPR sources...
- Creaking in the suspension...Possiblity that the struts are going?
- Other than the buzzing are there any symptoms of a failing stock fuel pump
- Is 23 psi @ 7000 rpm gonna kill my K04s in a drag race?
- Is it wise to cut out the internals on the inlets? i been thinkin about it would it help?
- Got out of a 19 over speeding ticket!!!!
- What do these two codes indicate?
- anyone have any experience with dismantling the calipers
- [Saturday, May 13th] SoCal, last call for our annual Julian Drive. Should be big like last year.
- How important is the secondary air injection system/pump? Mine is making noise in the morning
- Good 5th Gear Vid here. Slow DL for non-members thou.
- NE1 have or know the cheapest place to get 5mm spacers? TIA
- OK guys I re-did a pressure test and NADA!! Could this be a programming issue??
- ok, here's some pics of my car : not for the faint at heart :)
- Ok, looking for some hard numbers: AWE RSK04 vs. Homebrew
- Need help with wheel fitment - feedback appreciated
- JD/Doc shared this info re: camber. His local shop was having issues, and Alex at STaSIS shared...
- Mod gods... Can I please have my account reinstated? I am sorry for my slander and angry
- EGT Fault cause of low boost?
- Just changed my dv's... found alot of oil in the drivers side and both did not (long)...
- Need to purchase Hawk HP+ pads. Can you guys suggest a reliable vendor with quick turn-around? TIA!
- FREE S4POOR from account suspension!!! That is all.
- <cough> check my sig for new additions to the classifieds </cough>
- globs of green grease on DS front wheel (inside); CV joint boot cracked?
- Just got back today... how was the KMD event this weekend?
- Project build advice please..........
- Need Suspension advice
- dscottjr YGM!
- Went to get my new summer wheels mounted today... and the shop refused to
- C'mon guys any other ideas???
- so would i be a fool to use toyo R comps on the street for a little while this summer?
- Changing transmission fluid B5/S4
- help with CV joint, wheel bearing, etc. diagnosis! please!
- Where can I purchase Audi Collection bike rack for best price?
- WRX - 1, S4 - 0, SLCPD - 1
- starting stage III project monday...
- Another happy LASER experience.
- I have done a lot of research in effort to keep my S4 beyond CPO and found a reputable company...
- stock wheels and racks back on my gutted, NOS equipped, non street legal machine....
- new wheels, 19" gunmetal TB's hit or skip?
- looking for used 225/40R-18 tire(s). Anyone?
- Heads up........Pearl Avant 6-speed 47k mi. LA/SoCal
- Anyone in the midwest area (Northeast SD) that would be willing to help with an
- Any Stage 3 level 10 guys on the east coast?
- BIG Brake question............
- Does Stasis offer the Motor Sport kit with rear external resevoirs?
- City Light install ? Any writeups?
- Have a sort of dentist drill sound when I first start driving my car. I haven't been getting into
- Where was that really nice RS4 bumper install write up? a;ready stfa
- Car won't start because of "central locking unit" failure! Please help!
- Ronal May wheel sale
- The "BOOST SAGA" may come to an end with the help of an expert!! Please take a look (logs inside).
- Definitive answer on APR stage III anti-theft behavior-follow-up from yesterday...
- Car has 78k miles (124k) with stock dv's. Looking to do some preventative...
- repost? b7rs4's getting pwnt
- How do I remove the trim piece around the hazard/fog switches? I've done the shift plate, ashtray
- Look at me, I'm PaJohn!!!...
- Never thought about a B5 S4, but ones available in my hood.
- Spacers anyone?
- so where does everyone get their copy of ETKA or some other form of cd-rom manual
- AW 10th year anniversary party, Tonight - Charlotte NC
- Anyone finished the interior trim in another colour beyond piano black?
- Got my Neuspeed G2 exhaust on in 30 minutes. I was very happy when I got
- Black B5 S4 exiting NYS thruway exit 40 @ 5 pm yesterday. You on this forum?
- Any one ever drive Rt6 in northern PA?
- Custom headers?
- Any suggestions on what parts would give my car the feeling of a tighter, less sloppy ride?
- Any interest in a slightly used Stoptech 4 Wheel Brake Kit? 355x32 FRONT / 328x28 REAR?
- That you snow trooper?
- Anyone have one of their xenons go out, but come back on when you flick the lights off/on?
- I'm selling my books back tomorrow & thinking about buying Tip piggies. Vast guys no more sale?
- help on a S4 purchase
- Thanks for all who sumitted for the Fast and Furious 3 reshoots.
- Very scary event on trip home today-long
- I love my S4 but how does everyone deal with the car getting just plain old...
- Good Brake fluid for mainly street use?
- Trying to help my sister out with a dealer problem....
- question about used s4..
- Got busted for tint and front license plate!! Got any ideas for a ghetto mounted front plate...
- Does anyone know if Labree DP's for MT and ko4's will fit on a KO3 and tip?
- I need advice on short shift kits, In the market for one..
- Need help figuring out what this plug goes to
- would rs4 tranny mounts work w/tiptronic tranny?
- Please... Some S4 advice
- I graduate on Sat. The girlfriend said I should pick out something for my car as a present...
- Well the car is back from stage 3 - install; need some minor adjusting but I'm more than happy.
- Many thanks to Mark @ Autospeedperformace, & Mike Moore for the ride :-)
- intake mani removed in an hour and 40 mins, im proud of myself :)
- Homebrew Stage 3 in progress, Lots of Technical Questions
- I'm getting this homebrew thing on track now....with so many new homebrewers posting lately.....
