- Low engine temp, need advice......
- X-Post: Where is J533 ("Data Bus On Board Diagnostic Interface") ?
- gauge cluster issue
- pics of New custom FMIC and front bumper mods....
- I passed smog today with the new AWE RSK04 file and Fast Intentions exhaust
- Two rear bulbs burnt out w/in 2 weeks of each other... possible indicator of electrical problem?
- Thinking about IPP intercoolers. I've STFA and have read some not so good things.. can
- What is the correct name for the position output sensor on the airbox and where can I get one?
- Tuning guru's... engine ping at spoolup and again later in rpms.
- Video of Jeff Moss with Brent's S4 in the Ultimate Street Car Challenge
- quickaudi....do u have pics of your boost gauge?
- Possibly taking my car to the strip tonight.....
- Link on diy manual boost controller?
- this is why i'm moving back to the burbs
- Does anyone have trouble adjusting the volume on their bose radio?
- Single turbo VR6 B5 A4
- EGT Sensors
- 2.7T PDF File
- can someone post a pic of the avic-d3 in cellphone mode?
- The Widebody got some lovin' tonight...
- Does anyone have PICTURES of the fog light mod?
- Changing my plugs tonight,and found some oil on some of the spark plugs..
- Any feedback on the new AWE code at higher altitudes? Good, bad or anything?
- Anyone else used it? Oil change with new Mobil high milage 10-40 and everything seems........
- 2007 NORTHEAST AUDI FALL MOUNTAIN TREK
- Desparetely need an sdr vented hood? Anyone have one they are willing to part with?
- Killer shop in the Atlanta area?
- Failed NY inspection today..I had cleared all codes prior too! Had one code >>
- Bumper and hood respray a big red flag??
- turbo timer which one should i go with? and where can i find a step by step for it
- Melange A4 Pics (Tint Sportec shots inside)
- First time trying Royal purple 10w-30 and I really like it. I could tell the difference. I used to
- Stoptech 332 and 355mm BBKs ready to ship!
- ross tech is out of stock is this e bay one okay?
- Anyone else get a call from AoA regardig center display?
- Brent's 2.7tt Motor Teardown Picts and Info. (From about 2 months ago)
- oh the irony of it all...could use some help/opinions.
- Rattling from the Back
- Where to buy good worm gear hose clamps?
- Is it possible to run a 245/35/19 tire on a 19x8.5 et32 wheel w/out rubbing?
- Brake groan after 1000 miles on new pads/rotors.
- Quick Question, I have tip, is it worth leveling up? more..
- mobile1 0W40 and 0W40 euro blend?
- San Francisco GTG this weekend? I'm here!!
- who online can i purchase these radiator support screws from? tia..
- DTS for Tip: Stg III folks in particular, and L10 folks especially...
- Consumer Reports most fun cars to drive and S4 makes it in.......
- Timing Belt
- hill climb video?
- I need a part number for the wiper switch in a non navi car.
- What could be wrong?
- Is ASP still at old location?
- do you guys know where i can get a abs module fixed? i staf coudnt find a thing thanks
- Took some cool shots last night - lighting is cool as sun goes down>>>
- does anyone make steelies that fit over stock brakes?
- Need help. I have a phantom problem with my boost.
- where do you guys meet around the New Jersey area
- how are fats measured for TIPs?
- s4 vs. lightning (video)
- modded c6 on pump vs k04s4 on c16
- Should i toss my stock sway bars? Are they worth anything?
- Hotchkis Sway bars
- Trackd my Tip the other night in sac....=(
- is ASP not making their sway bar links anymore?
- Any custom tuners in the Maryland area?Need stage 3 tuning or giac chip, help!!!!!
- Just my freakin“ luck! RH headlight went out, found wiring inside housing all fried up (more)...
- Eibach Pro Street install on rears. How much thread?
- Cross post from allroad forum. Thanks for any guidance.
- Would a loose Oil drain plug throw a cel? Please read...
- Clearcorner bulbs... Plz read thx
- anyone in sf bay area have a stock suspension lying around that could be made available for local
- Anyone have OEM bumper supports for sale? TIA.
- getting misfires while idling in cyl bank 4, just replaced with new coilpack and oem ngk plug but st
- Finished my OEM engine cover make over...
- Anyone have a set of coilpacks in good working order they want to get rid of?
- would you say the twin 2 is the loudest of the "quieter" CB's?
- Plans for next car after 01 S4 Stage 2+?!?
- Was looking at Bentley online. Noticed the book is for A4, S4: 1996-2002 (more)
- Anyone running 2.8 heads and with what turbos?
- What are oem bolts made of?...
- Anyone know where to find Carson. I need a price check and I can't get them thru there web site. :-(
- Wed, Oct. 10th Audidriver9 and I are flying out to Cali to pickup a new car at
- help me choose winter tires!!
- Finally Stage I -------->
- Repost: Which is a better boost gauge, nexus or defi?
- Anyone have a right rear caliper lying around?
- Is it possible to have bad egt's but still get correct values? (thru VAG)
- APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
- has anyone else had trouble accessing this forum today?
- Looking for one SSR Comp - 18"
- Free Stern Snub Mount with Purchase of a Timing Belt Kit!
- Can I ask why all the companies make a center boost gauge and not one for the far left vent???
- dealer says to get my stereo out of safe mode they have to hook something up to the car/stereo--
- any updates on this wide body job???
- Retrofitting a B7 Steering Wheel
- front upper control arms are a PITA to get off...any suggestions?
- BBS LM Reps will they fit
- stage 3 or 3- TIP rollcall / info
- Thoughts on running 2 different tires? (more inside)
- Bentley Manual '00-'02 S4
- Anyone looking to get rid of there duh front mount or are they pretty much impossible to get?? also
- I need one Last part for my RS4 oil cooler
- help with LED tail lights
- Can I please get some help choosing some wheels for the WB...for the winter.
- Which is better boost gauge? Defi or Nexus?
- TBB question.... I want to put my engine covers back on but due to the Samco TBB
- 2 questions before the engine goes back in...
- Has anyone used this Ebay FMIC kit yet?
- Ordering motul gear 300. Whats a 6sp capacity? Thanks!
- Fellow Brothers of the almighty S4. please help me!!!!!!!! URGENT!!!
- Urgent help please: Bosch pulley on to Valeo alternator?
- anyone selling used awe boost gauge?
- Stage 3'd B5's For Sale??
- Could someone direct me to what I'd need to buy to fix this leak?
- Is removing the turbos the only way to know if they are blown?..
- AW .... RS4 Poll Within..............
- FREE Boost Controller for A.W.E. RSK04 special is winding down
- Has anyone run an E39 M5(sure many have),how does it compare in S4 terms? Stage 2+??
- well apparently the gas gauge on my new s4 is off a bit
- Opinions - 235 45 17 on Stock Avus with 5 mm Spacers or 3 mm Spacers?
- Whats everyones opinion on running 225/50/17 tires on the stock Avus?
- WTF?
- A.W.E. Tuning Online Ordering Back Up And Running
- does anyone make an aftermarket cross member mount for the rear diff??
- vagcom or boost gauge next?
- URGENT!!! I filled up with gas and spilt a little while removing the nozzle! HELP!! =P
- I went to change my s4 wheels and the front rims hit the caliper...
- ******Anyone have a write up on replacing the secondary coolant pump?*****
- Interior rear view mirror
- Awe/giac stage 3 race vs pump
- As always, I just wanted to say thanks to Mike and Justin at Wicked
- Do you know by any chance if a Clutchmasters Stage 4 clutch works with Vast Aasco Aluminum flywheel?
- Anyone have a hitachi MAF sensor lying around? I need a used one. M-Box software on its way :)
- can heads with bent valves be reused if you have a set of new valves?
- Anyone interested in some IForged Rims?
- CF doors for the B5 A4/S4
- DP dillema. want to upgrade but:
- Check out this jack. Solves the lift point problem
- Can anyone chop some flat black RS6's on the WB for me?
- wanted: set of B5 S4 oem wheels
- comparison. asp tru-dual w/ asp 3" dp's or fast intentions wide mouth dp's w/ their custom exhaust
- Any REAL world differences with the knew GIAC flash for AWE Stg 3
- remote issue: all doors except drivers unlock on first press, then drivers unlocks second press
- Would Anyone Be Interested In A Tint Strip For The Rear Taillight (reverse white part)? =>
- piggies = 20-30 hp gain at crank, asp pipes = 20-30 hp gain at wheels?
- How to improve Gas milage? and I know the light foot remedy ;)
- SDR CF air boxes in stock at WMS ...
- How much do you guys think a used 4 wheel stoptech kit is worth?
- is their any market for stock headlight shell's??
- M007 left a message, don;t have his contact info can someone ping him and have him call me again ?
- Grrrr.....turned over 100K miles recently and was going to change the oil today.
- Boost Issue question...details on car... stage 3- Giac code
- guys is it hard to replace secondary air pump? its making a crazy noise very loud jeeezy noise when
- Getting to the clutch to replace...whatever is wrong :)
- A.W.E. Pedal sets back in stock... AND.....
- Hit / Skip OZ UL 18" - can anyone do a Photoshop?
- Anyone who has had, or is having, dead pixels in their cluster tell AoA here.
- Paging: EPL. Ya'll build old Volvo motors? Interested in beefing up the internals on an B230F.
- Anyone use a twin disc clutch setup? Frank@ASP ugm!!
- Where can I buy matte RS4 mirror housings?
- Stern Bushings and ASP Diff Mount install/comments...
- !!!AUDI ENTHUSIASTS!!! CLUSTER DISPLAY!!!...LONG!!!...letter here-->
- Does the GTG/car enthusiast gathering at the Edgewater, NJ Starbucks happen every week?
- Now Playing on Joost: Audi Driving Experience with Chemmy Alcott
- guys I can't find Forum Archive for how to installin the secondary air pump... also part number..
- Would a bad evap purge valve (N80) cause...
- Trying to get an idea of what shes worth.....
- This pic I took this morning came out pretty cool IMO. Downtown LA+Mclaren+S4
- H-sport rear subframe brackets
- audi says don't change gearbox fluid. Is this really followed?
- Anyone know the measurements of the ECU? Length by Width?
- For those looking for cheap K04 inlet pipes....
- having a rough day, jsut got walked hard by a turbo mini S
- Please tell me why RSN-E sucks compared to newer aftermarket units, thanks.
- Average cost to repair/respray rear bumper?
- Another failing instrument cluster display call to arms...
- Staggered wheel combo 19" - roll the fender?
- Vagcom :o2 senseors INternal resistence too high and fuel trimming too rich--
- 8,600 mile oil analysis. German Castrol 0w-30. 3k oil changes are for sissies!! ;-)
- Anyone have a audio clip of turbos in a stock car?
- 2001.5 santorin blue s4. 6spd Sport package 61k. MINT
- Need a stock ECU.
- weight of stock clutch and flywheel ?
- anyone have part numbers for me? hazard relay, and passenger fender blinker housing? thanks!
- Twin2 to twin1
- less than 2 weeks left !!!!!!!!
- What is the weight difference between a sedan and an avant?
- Slower traffic keep right...
- look what I found on ebay......
- Simpply check your e-mail please. Thanks.
- Can I just remove the rear muffler on my twin2 to make it twin1 or is
- PLEASE help me diagnose my A/C issue
- one of my hoses tore...
- do these injectors have spacers on them?(dont mind the retarded guy in the picture)
- do the rear door speaker covers just pop off?
- anyone here with the Sir Tools B90 wheel bearing kit willing to rent or loan it out for a few days?
- Anyone think theres anything better than 60# Siemen injectors for hybrid setup?
- Clutch doesn't work anymore... that sucks.
- clean sunroofless 02 stock s4 for sale (not mine)
- Quick question...tools needed for rear bumper removal and estimated time?
- Half painted grey 2000 S4 in vegas on fri night you here?
- Saw this, this weekend... So Money!
- Weird thing happened while trying to downshift into 2nd. Would not engage into 2nd gear.
- !!!ALL AUDI ENTHUSIASTS!!! CLUSTER DISPLAY!!!
- From now until Midnight tonight! ~RSK04 INCENTIVE~
- Great experienc with Raxles for C/V's
- Good day at the track, now I need torsen rear diff...(Long)
- Question about front/rear tire pressures and weight distribution?
- Clutch options...
- H20 sucks my f*cking car got stolen!!!!
- Wheel Suggestions Required
- Saw 3 B5 S4's in ten minutes this evening any of them here all in Ptld
- WOW brakes were simple to install!
- Nice meeting everyone at h20 this weekend !
- paging Asicks2.7T email me
- Got someone good the other night.
- HID bulb question
- Are Sportec Monos still available?
- Another reason to have an Avant (+28hp)
- New price & newly modified add getting some response on the car! -Thx Guys!
- Stage 2+ on 93 octane vs. 100 octane FATS
- Bad clutch or ASP way too much power for RS4 clutch?
- is this car ever on a track or on the road~!?
- Blinder MX-25 laser jammer install writeup
- Petit Le Mans Lodging
- after 3 years of putting off hitting the track: 12.1@115mph
- Ran some logs this morning. AWE boost control feature not working?
- I talked my friend into Stage 3ing his 1.8t 20th aniv black gti.
- 10 piece CF install Complete!
- top right corner of the pic. Does this hose read vac on boost gauge?
- Buying a used B5 S4: good idea? any year better than others? things to look out for?
- Anyone know where you can buy some Audi swag?
- demolished a stang last night
- What DV's to get?? 710n's or some aftermarket??
- WTB: 2001-2002 s4 in jersey! cash in hand!
- 2ND gear clutch slip.
- anyone want a full apr RS4 intercooler kit?
- Stage 3 S4, DONE!!! maybe...
- hit a huge speed bump, now my car makes a buzzing noise. help!!
- who sells a steel single mass rs2 flywheel for our cars?
- who's S4 is this ? claimed to be a tweaked AWE stg 3..
- Going stage III need a final check list and also need to know how much to focus on downpipes and exh
- if anyone cares, removing stereo without tools, one way is to pop off hazard ight trim, then pop
- Hotchkis Install Help
- Coolant Change - Instructions?
- Wierd local repair shop in Bristol...
- Need suggestions on wheel finishes...
- Any companies out there willing to discount Nuespeed RS10's?
- Car stuck in gear...?
