- exhaust questions? hummmmm so many. which one?
- so i've been noticing that the new lexus cars have a really clean (clear) looking license
- How much of a sound difference would there be with the milltek superdual, DPs, and test pipes?
- Gasoline and ethanol content
- So anyone from the EPL dyno day like DAP on race gas or Paul going to go to AWE to dyno? ;)
- Time To Change My Air FIlter.... Any opinions on...
- Plenty of STFA- I got a CEL today after installing piggies yesterday. I drove about 70 miles...
- X-post: All in all, I was impressed with Audi's Streets of Tomorrow event.
- pwnd!!!
- so which 2 of you had fire issues at julian yesterday? get them figured out?
- Suby vs s4 who wins?
- Just got done detailing my car thought I'd share ...
- has anyone every done a Laser Red B5 RS4 sedan? if not could you p-chop this one?
- EPL pictures (bww)
- Sugjestions to remove TB 5mm bolts to do Bi-pipe? They are stripped, all of them, and I was careful
- Dyno Day pics, X-post from A8 forum .. pics inside!!
- installing RS4 y-pipe on 2001.5 s4, what is to be done with the vacum line going to the brake
- is the Spider Hose for 01.5 part number 078-103-235-B..
- My EPL Dyno Day graphs/results (BWW)...
- S4 = 1, 350Z = PWNED!!!
- New track times last night. 12.2 @ 112 , Video inside
- Is there a new GIACX code?? i had mine flashed at awe in 09/05??
- Thanks to Tech section- I tackled my piggie install on jackstands yesterday....
- EPL Dyno Day Pics! BWW *Edited*
- milltek dual 2.25 exhaust
- Alright...suggestion and debate time, plain jane K04 homebrew setup
- Has anybody tried the Motopr0n 60#s with an R$4 fuel pump?
- how difficult is it to install tmc after youve already done the nav install and wiring?
- Another into the 100k club - extended warranty is up -
- need advice....
- 15 psi ???? is that normal on GIAC X.. i just pressure tested and vaged..i only found a small .....
- New way to solve Jersey theft?
- what are the symptoms of worn tranny or rear diff mounts?
- I'll have my results from the EPL dyno day posted shortly...
- Hey Mark P or Tony? When and where will the final results of yesterday's horsepower orgy be posted?
- Engine Wrestling: Engine - 0 Me - 1 Hint # 432
- did some runs tonight. not good.
- ride in couple cars today.. RS6, B7 S4, S3..
- Peter S/ContraCostaPete..you got mail
- Speedometer jumped - anyone experience that?
- May 30th Chicago GTG "sanctioned"--->
- UGHHHH NO! window broken, stereo stolen.
- Wow I just got a ride in a C4 Vette w/built motor & T-60 turbo on the bottle. Makes 700whp w/o
- 911 Turbo Wheels on an S4
- woohoo, car was running like crap, pulling timing and also high cfs, got an oil change adjusted the.
- Blown Turbos
- It pains me to see my car like this
- I did some logs before and after dynoing - FATS: 3.34, 3.32, 3.32, 3.36
- $3k for a freaking wedding photographer! I could go stage 2+ for that.....UGH!
- 19" RS4 DTM photo's or MTM Bimoto?
- PSA: Bleed your clutch
- I am absolutely terrible with photo shop can anyone help me out with a sig?
- If you were at EPL today, let's just say we had a little "After-Hours-Fun"...
- Mods, if you are baleeting BBB's posts, can you not? He wasn't being bad this time...or is he a..
- had to get a four door for my soon to be son...why not get an S4........
- New Cats, pieces of artwork
- Fvcking great way to end an awesome day at EPL. ;-(
- water in my car ne1 know where the drain plugs are located? h2o is on pass side frnt
- RS6 hybrids + worked 2.8 heads + revolver cams + ASP magic = ?????? on AWEs dyno?
- Is this the going rate for Mototrons or is this a xtra special deal?
- STFA about the 60k service since
- Today at EPL dyno: K04s, stock MAF, 17.5 psi MTM fueling
- Ran through a puddle tonight and engine bogged (more)...
- 19" wheel help
- PSA - Watch out when buying T&SUV Mobil 1. They came out with a new
- look what i found..... does she look somebody sig.
- Found two laser red B5 S4s for sale ...now I have to choose (help me decide)
- Informational: Diverter Valve Service (BWW)
- Dyno results from EPL. DAP will be posting ECUx data later on
- revolver cams...Do you get intake and exhaust or..
- Have you seen the RS4 Self Study Guide online?
- Looking for a trunk lid for my 2000 s4, silver would be perfect. Thanks
- (Concerning observation) Changed my primary driver side O2 sensor today...
- Question about this turbo timer i plan to get...
- I'm ordering my timing belt kit...anyhthing else I should pick up while I'm at it?
- Smoke on deceleration continued...
- roughly how much whp should i have with ko4/16,piggie pipes,3-code,5bar fpr,rs4 intercooler,evom int
- Anyone know whats the flow rate for stock S4 injector and RS4 injector? thanks
- brown single wire behind head unit w/ female spade connector (also brown)?
- Just discovered the Italians are worse than the Germans when it comes to requiring special tools.
- Racing hart CP-035 wheels, anyone heard of these things...
- NOT a for sale post
- Airbag Control Module Defective
- noob ? help how do i remove the line connected to the accdorin hose underneath?
- moving to Bay Area lusting stage 3, best shop for instal/tuning?
- Guys I need to fill up my coolant as I just replaced a few sensors
- Allan McNish in the R8 wins American LeMans in Texas.....for those following along @ home. Go Audi!
- Teaser, 500whp on 93octane is in reach
- Those of you with aftermarket wheels, where do you go for mount/balance?
- Phatbox not working...any ideas???
- Is there a gasket between the downpipes and the turbos?
- any reason to not get a wheel stud kit?
- Heatwraping metal MAF's?
- Wheel locks for Flik Justice
- Can you run RS4 injectors with 88mm MAF and stock FPR for homebrew?
- super short notice i know, but if anyone in the philly area is bored today...
- Jacob, courier says you received the K03s.
- need diagnosing help: gears dont engage when engine/tranny gets warm.
- Just picked up the Avant, here are the goods and bads...
- Help: Horrible cold start stumble with RSK04 2000 S4
- Bllleaat..
- Random Question: Can the B7 S4 Key Fob work with our cars? Can we program them to work?
- ground clearance question? I want to send my car back to Cali from Hawaii.
- So, it was about time for me to change the girl in my signature.
- anyone in the SFV have a headrest video camera mount?
- had a little problem tonight.....wierd, long and need some help
- Pretty fvckin cool..Google "valentine one display audi" and guess what comes up as number 1??
- whattaya think of the new sig??
- guess what i just got from ups....
- Removed ECU today and now cluster is acting strange...
- Got Vogtland Coilovers installed - Initial impressions
- I pulled a 450 WHP Cobra today.
- Looking into a 2nd car...can anyone CarFax me this VIN#?
- Old photo: Rollin the Prophet
- anyone ever use these as a theft deterent?
- AWE S4 stg 3- VS VW GTI Mk4 1.8T...predictions? <edited>
- Check this out 2.99/gallon for 100oct
- removing rear seat belts/tensioners....is it safe to unplug them or will my C pillar airbags deploy?
- So, my glovebox rattle goes away, just in time for my driver's side door sensor
- Stage 3-, Getting no boost what so ever? What to do.
- My S4 vs Tuned Lamborghini Gallardo Highway Pulls! (video!)
- Timing belt break in
- Would like to thank SmokinS4 for his help
- rev matching question, are you guys pretty spot on when downshifting, or are you going over abit?...
- ok i just installed ko4 16's, down pipes , clutch, ic's i am going get giac 3- code is there anythin
- Teaser video from huge track event at the Most Autodrom in the Czech Republic...
- Stock Exhuast with piggies?? I am going to install my piggies this weekend and I have to...
- can i fit 255/40 on a 17 X 8 oz SL for my s4
- DICE ipod integration thingy installed
- Just stopped by Hartmann/Achtuning. They have a TON of stuff in stock. APRStg3 kits, RS4 ICs, Lights
- does this sound like slave/master or pressure plate? engine off all but reverse OK, eng. on nada.
- Need some intercoolers, who has them in stock?
- Picture of my car on the rack at Wicked Motorsports
- Stage 3 w/ Stock intake. Any suggestions?
- OEM S4 Wheels on TireRack for $150
- Looking for a set of 2.8l heads. Anyone know of a set avail? Bueler? TIA
- can 5x114.3 be drilled to 5x112?
- Imolavirus: post of the pictures of my blown turbos. please
- So, What is the going rate for NIB K04s? Any place cheaper than 1900? I called some distributers
- Already STFA What would cause uneven left /right rear wheel gap, just aligned>>
- Spotted: Black S4 with european front plate (Move Over) leaving Lynn University in Boca Raton, FL.
- Hey check out these new sparkplugs
- Way to slow today. Post your best "Owned" pics'. I am gonna try and better each one. Let's
- Anyone ran 245/40R17 Tires Before on B5?
- Vegas peeps anything going down this weekend? Would love to get out and...
- ERIKS4 FATS TIMES
- PHATBOX Configuration File Tweak.
- <Paging Lord of the rings> New sig' for you. I don't suggest it, I demand it!
- will 5x100 or 5x114.3 bolt patten fit an s4
- People on normal AWE stage 3, at what RPM are you hitting full boost??
- Well I finally broke my Stage 3- in gently and floored it this morning for first time, big smile :)
- Those with SToptech 355's up front, what are you running in the rear?
- where is there a good ground behind the head unit?
- Those with the Fidanza/CM stage 4 combo can you comment on how your....
- Lifter ticking when engine is warmed up, what oil have you guys changed to
- Engine shudders/jerks around 2300-2500rpms when letting off the gas?
- Timing belt issues... Need help please.
- Looking for an ASP Tru-Dual - Who's got the best price? I thought I saw it for 899 somewhere..
- Poll: What setup are you running for amp and subs?
- when installing the rear euro saloon bumper is there hacking of the rebar or changing of mounts?
- So i reinstalled my rear seat and wham...I got bass boomin capabilities! lol
- I ran a 4.05 FATS, pouring rain, slightly uphill, ~55F, 1/2 tank 93oct...
- sigh...It's been 2 weeks without my car, and I'm still another week out
- anyone running the EVO intakes with bigger MAF's? more specific will an 88mm maf mate up to EVO?
- Any of you tuners have the borla cat-back exhaust in stock, i'm finally ready to
- Question about Multi-Program Giac Software
- Head Gasket
- My Dilemna...X and Tip chip combo or 5 new tires to put on my OZ SLs
- SCAMMER WARNING...crosspost from B5A4 forum...
- Question about my Hyperboost DVs
- Highway whine from the right rear, starts around 60. Sounds like an outboard motor...
- I need a good anti-theft system in my car. Please email me if you can help (don't post here).
- RS3 350hp - 2008?
- Attn: Hal_S4Shizzle::CBP, if you wanted those p/n for Euro knee bolster, here they are
- I forgot, what's the torque settings for Coolant & Oil Banjo's on the Turbo's ?
- a few questions about my broken S4
- How much are dealers charging for a stock M box?
- Thermo switch placement?
- New best fats time with my AWE RSK04 kit 3.80
- Round 2: Me vs. VelocityS4(Jeff)--- except Jeff got his IC finished..
- new cars! pictures
- x-post from az on my swap....
- put together my new airbox duct tonight...
- can you use factory springs with grooved bilstein sport shocks?
- Has anyone done an out of state trade + cash?
- Anybody else with AWE stage 3 have cold start, or running problems?
- What spark plugs ship with the AWE & APR stage 3 kits?
- Anybody here running AMS Stage 4 SW (i.e. S4 3- SW)?
- Help a NooB
- Cleaned the Ol' S up yesterday..few pics
- I had boost leak due to Benjo bolt on Dirver side turbo. and now the mech fixed th bolt
- New upper control arms...new front tires and an alignment...wow...she is silky smooth now.
- Warning!!!! about Autospeed Performance..........
- 17" stock s4 rims questions (x-post from b5 a4)
- just got my confirm. email.......getting the eibach c/o tommorow!!
- Any AMS/ABT chip owners out there?
- If i order phenolic spacers from Autospeed will I need new bolts and gaskets?
- Video of my AWE car 80 to 120 in 4th on 93 octane... no things being equal. Enjoy
- K04/RS6North......any update with your car?
- nothing like spending all day on something to find out your fitment is off by like 2mm
- With all the hype about AWE vs. homebrew etc... ran my car last night 12.2@113
- Going from Stock to Stage 1... If driven the same way, will my MPG increase??!?
- AWE vs Piggie stage 3 dialup users repost! I have larger....
- Looking for a set of headlights. Can anyone help?
- Climate Control Hell - Could use some help...
- for stage3 will the RS4clutch+ AWE LWFW suffice or should i get the AWE stg3 clutch+ 12lbs flywheel?
- eBay potential scam alert...
- Mah next car if it comes to our shores..
- Looking for some help on diagnosing a downpipe/O2 sensor issue
- So i finally broke down and put that AWE stage 3 fueling kit of mine on EvIlbay!
- modified car appraiser help
- does anyone make a b6 style taillight for the b5 with the triangle reverse light up top?might b cool
- DM-S4, if you get a chance could you please post what your mechanic said...
- ERICK with yellow S4,that works for JACK DANIELS AUDI in NJ....
- As requested, here are pics from last years CT S4 (now also RS) meet....
- PSA - the classifieds work! managed to sell a set of tires and wheels in <1 week!
- nice, if only i was looking to buy one... :(
- FYI, regarding the AWE Tuning RSK04 fueling kit:
- ABS module still off.
- seems like Autospeed is the flavor of the month? Is that the general consensus ASP > AWE > APR
- who makes this wheel??? tyia
- Hahaha S4POOR got pwned for the WW post he made earlier!
- who was it that recently purchased Josh's RS4? small favor / request inside...
- Crap..NeilM is at Willow Springs Raceway right now flogging one of 15 new RS4s..
- AWE Tuning announces new partnership with BBS Wheels.
- dyno done on 93 oct apr stage 3 s4 with new version software
- STFA...but still unclear regarding turn signal bulbs, following clear corner mod...
- Warped Rotors?
- Just picked up the bish from the piggie pipe install...
- Need help finding out if a particular OEM CF trim piece exists.
- Some stuttering when at part throttle, but ONLY in 3rd gear, and ONLY at a certain throttle position
- rough starts in the morning ?
- has anyone logged a 2.X FATS on straight k04s without wieght reduction?
- Exactly what is it in armorall that is bad for your car interior?
- S4 on Main St - you here?
- Sysetm Lean DTC's, Irratic boost and 032 fuel trims in the high negs...
- Signing off - sold the car
- How long does it take for the advertising dept of Audiworld to respond....
- Normal N75 behavior?
- removing intake mani for aux waterpump. does the fuel rail come out with the injectors?
- Please Help : Passenger side carpet is soaked, what could it be???
- could someone please tell me the PN of the bolts that connect the front inner cv's to the tranny?
- 2.8L Head on ebay...
- Would anyone swap me black interior for white?
- facing a problem...possibly its the brakes
- just got an email from coximports.com...they say they have the eibach c/o in stock for 1032 shipped
- could someone tell me if this is the bolt i need to re-attach my front axle to the tranny?
- I hate spiders :p
- Played a little with a C55 on the way to work... he didn't play nice
- Low Temp Thermo switch - will the one from ECS do the trick? 5.95 seems a bit low...
