- Transmission ECU question
- Coolant temp sensor... ECS or dealer
- Is there an upgraded bushing for the Neuspeed swaybar? I called Neuspeed today and the person didn't
- I have some really incriminating pics of Morgan. Want to see?
- Noob question about relationship between timing and correction factors
- New vibration/shaking present at highway speeds (75mph+) following suspension install?
- Interesting thing noticed, yet totaly expected. Throttle angle is now less at idle
- RS4 tbb adapters
- Long overdue...thanks Tomasz for the ASP Exhaust. He was quick with shipping and patient when...
- Could the secondary air inj. hole in the head be used to read TIP, CHT or EGT ? It seems to go above
- So does BBB Marc hold the record for fastest full weight 1/4 mile time with his APR S4 ..
- Congrats to PSmalls as Motown evens the score... : - )
- CRAP!! Car "stuttering" at 10psi <more>
- Exhaust videos... Milltek (superdual and downpipes) ... and ... APR Stealth w/piggies
- Does anybody know of a forum with good info on what to look for when buying a 993 turbo?
- On borla exhaust if I remove this how loud will the exhuast be or is this a good idea?
- Anyone from Vassar College on here?
- REGISTER NOW: New England GTG on Wed, Nov 15 in Framingham, MA
- Ode to the brakes
- New best FATS time for me.
- S4's don't look that good on flatbeds.
- Looking for log information. Boost vrs RPM
- Poll: Those of you running Stg3 with MBC/TCD, running MBC in stand alone or parallel?
- You know you're addicted to AW when you post WHILE you're on vacation...
- uhoh! audi has a new product! :oP
- My dyno graphs (Dyno Dynamics in shootout mode, crank HP displayed) 92 octane
- Whats better to have the Autospeed pulley or the ECS pulley kit?? Any thoughts on them?
- POLL: How many folks have not exp a stage 3 car, how many people went stage 3
- How far is WMS from say the Disneyland Hotel?
- saw a b5 a4 today with a odd set of tailights...
- EXHAUST QUESTION!!
- I'd like to hear from anyone running, or planning to run the ABD Big Bore Intake Pipe...
- Throttle Cut with APR 5.0
- Very weird vibration sound from rear of car above 20mph.
- jay got your e-mail what do you think my timing should be at? let me know if you need more info tia
- Does anyone know what the RS4 axle ratio & trans ratios are? Different than ours?
- Logging Experts: Would you say this boost log is indicative of a boost leak?
- Those short wheel based urqs were bad a$$.....
- Ugliest VAG hands down...Fantastic.
- Hey guys , anyone from Chicago area who is to willing to loan/sell a crankshaft lock bolt-screw?
- will a B6 symphony II fit in our car?
- Heres a better pic of my RS4 trim mod...
- Any Issues regarding wheel strength with the Volk / Rays TE37
- Hit 55,555 on the way home from the charity GTG yesterday
- Lower Front Straight Control Arm Part Number Check
- Saw this, thought you might be ...interested...
- Wheel Recomendations for the RS4 Body/
- Oil temp sensor bad?
- wow, i post a dyno vid for the B7 RS4 forum and a fight breaks out. cant we all just get along:>)
- Does anyone agree with this opinion regarding water injection?
- The S4 stable has expanded. :) First day in the garage shots inside.
- Can I splice into wires that light up the vent knob when you turn on your lights....
- Funny ad I just got forwarded...enjoy! (hopefully not a repost)
- Installed the Recaro SRDS in the s4, PICS !!
- Whoever said that modding the S4 is like a crack addiction was right
- Strange Problem with Tachometer/Coolant Gauge
- O.CT chips. Can anyone identify what stage this chip is? It came out of a
- AWE 93oct FATS... my best so far....
- Don't know how accurate the data is but here is a IPP IAT 3rd,4th and a little 5th pull
- I'm often asked , "what is your 0-60 time".
- EPL stg3 vs APR stg3 video.
- I placed PSS9s on sale - $1,795 shipped.
- FYI on Oddysey batteries, just replaced mine for the 2nd time...
- Finally, After Two Months without the Car, I got to Drive my Freshly Prepared Stg 3+
- Car doesn't seem to be giving it it's all, what can I VAG for troubleshooting?
- Video of Stock s4 with VM3
- So, Poll: 70K What's the best (Perf. car/truck/SUV) winter weather all in one??
- sat in B7 3.2 sline, titanium, black/black 6spd.
- Replacement Front Seat Heater
- Where to buy Pagid Blue (4-2) Pads for HP2 calipers? (Already STFA & STFI)
- 07 RS4 on Dyno Dynamics Video...
- I had my oil changed at a quick lube place today :-O
- Rear axle HELP!
- Brake pad install, anyone used the info in the tech section?
- Simply Amazing (x-post B5 S4 content)
- Can I use a vast resurfaced flywheel with a new rs4 clutch kit?
- Removing coilpack #1 - any advice for getting to bolt behind inlet?
- Gas ''v" Gas?
- If anyone has a lead on a low mile casablanca or hibiscus for sale please let me know.
- I searched the forums. whos has the clear corner diy?
- ASP GT25 on Dyno Dynamics Video...edit...oops
- POLL: Who is using: 1-Mobil 1/ 2- AMSOIL / 3- Castrol/ 4- Other?
- Curious...who bought the K04/RS6 hybrids from me about 6-7 months ago?
- Weird Problem: Replaced entire cv joint... now car moves when in park?!?!? And it's a TIP!
- curious, what's the cost for K04s vs K04/RS6 hybrids? assuming no other turbo mods or hardware
- Bought me some 2.8 heads.. that will be part deux for Cactus. say 3-6 months or so.
- I hope everyone knows this is just for the ecu
- Hawk HPS to fit StopTech ST40 source?
- which Ronal stage 3 chip is the tastiest? does anyone have nacho dyno logs
- my ecu looks stock but does not feel stock or show to be on my boost gauge.....
- Help!First time boost gauge. Boost reads 17 in vacuum at idel and 18 psi at full boost. AMS Stage II
- ok i eliminated the F hose by putting a hose from the mani toward the N80 valve
- Any data on FATS difference between 91Oct & 93Oct - same car & setup, similar conditions?
- $401 for new spark plugs and a transmission fluid change?
- What just happened to the video of Sweet Charlie and Spturks racing?
- oil at $57 a barrel why don't we see gas prices at the $1.50 mark???
- Just had flywheel machined and clutch&pressure plate replaced...>>>
- Violent bucking and stalling
- Here is a video of my car on stands idling and giving it some gas.
- Anyone know whos car this is?
- Can two (extra) front seats be stuffed inside of a sedan?
- need alittle brake help, kevlar brake pads
- Thinking of going Clutch Masters stage 3 with my Awe lw flywheel . Pros - Cons ?
- Poll: Best car/truck for < 70k for perfomance, handling (year round)
- awesome vid, not sure its a repost but whatever
- Pad Wear Indicator + ABS light + BRAKE light = fubared?
- Exhaust Clip: ASP DP's with Twin1...watch your speaker levels....
- Video Clip from my dyno pull...
- lil noggy lovin' =)
- Looking for old-style front grille S4 badge, if you have one for sale please email me
- Sunoco 104 GT Race Gas + Cool Weather = Fastest FATS/FATS+ Times I've Ever Recorded :)
- multi function display error
- New track times: 11.79@124mph is best time
- For those who log, does your laptop have a great battery life or do you have an inverter?
- Something not feeling right when accelerating???
- All this IC talk got me searching....anyone have the guts to try this one out yet? 1k off orig price
- Does this FMIC setup belong to anyone here?
- Nogaro Tip w/ Sport pack and a smasher right rear bumper @ Smith Lotus in San Luis Obispo, CA...
- Anyone has Zeitronix LCD display on there car?? Do you like it? do you have any pic on your car??
- Going rate for stock manifolds 2.7 from a CA "no rust" vehicle?
- How many hours for labor on a new clutch?
- New X1 Intake file + RS6hybrids on 93octane + 23psi curve = 471whp on 93octane ...
- Anyone cover the hole for the tow hitch in the passenger AWE IC shroud?...
- nice drive home....3 races
- Sorry Nyet and Piggie Smalls, no logs :-( My IC hose decided to leak
- just got some free time.....little preview from last nights action (600 whp Cobra vs Me).....
- Somebody call Stasis and ask questions or place orders. Their employees are having way too much fun
- NEWBIE question... Do I have to wait before I can remove my key from the ignition switch?
- Shabadoo Tooning rocks
- My reverse lights are only intermittently working. What's the problem, y0?
- Anyone else notice that a new forum has been added to AudiWorld?? :)
- Is this an AWE boost guage? I know its not one of the ones they use now, maybe an old one
- Autospeed Rocks: edit info added
- No Sunroof Santorin B5 S4 for sale on youtube....check it out if someone is interested
- Advice: When replacing inner CV boot, is it easier to remove entire axle, or just drop the inside.
- 16s
- Just ordered my oil analysis kit from Blackstone Labs.
- Stock versus IPP versus RS4 Intercoolers - Part II - The Road Tests
- At Watkins Glen last month, on back straight neck and neck with new ZO6, I talked to the driver and
- getting married tomorrow mornign fellas - wish us luck and good weather :)
- Paging Hibiscus Red S4, S4 AVT, & StoneMan. Ever resolve your coolant consumption issues?
- Help: Car isn't making full boost... tempermental.
- How come i hear of all these new products and upcomming release's from ASP but i never see them on
- Installation cost for StaSIS Tracksports? local shop quoted me $4-500
- How do you guys feel about only running 10mm spacers in the front for winter wheels to clear brakes?
- downpipe (piggies) painting question
- HOW you find out if there is an internal coolant leak in your 2.7T.well you should check this !
- Sitting in traffic next to a B7 RS4 thinking, a well set up 2+ should be an even match right?
- $110 is cheap for tie rods from dealer no? Inner and Outer.
- Moog Control Arms? Anyone using them?
- Repost: My dying engine sob story - very bad coolant contamination
- I'm REALLY pissed I forgot to take my oil sample at my last oil change...
- Who's selling H-Sport sway bars?
- Buying a used AWE DTS and the seller doesn't have the mounting screws...
- lemmiwinks and battery disconnect
- What is Jacob's (Buehn Engineering) phone number...anyone??
- Part # request: Inquire with in. 4 - 19" thingies....
- how much for new stock ECU's from stealer or clairparts or wherever?
- New O2's? 17528 - Oxygen (Lambda) Sensor Heating: B2 S1: Open Circuit
- What size Accuseal clamp needed? Can someone confirm 2.25" works
- ABS / Brake Light Flashing, OK to drive?
- Does this Vibrant Exhaust sound right?
- i am tired...it was a fun night, videos to come later Peace Out ;-)
- has any one got the o.ct s4 boost gauge installed ?
- 2.7 guru's . Looking for a spare cyl head. need not be working.. more.
- who here has an S4 Avant automatic that wouldnt mind me emailing them a few questions? (edited)
- Steering Update
- Funny videos
- Will my C5S6 LM's fit a 2001S4?
- WHOOOOOOOOA baby! Forgot I need to warm up the HPS in teh cooler weather....
- car surges
- Cam Lock tools
- whats the cost on replacing manual transmission, labor included.
- Need help
- Current feedback on Neuspeed sway bar vs H-Sport front and rear, stfa already, mixed.
- What would you do?
- Bought some of the SPP CF engine covers, $125.00 they are not bad
- seat warmers ( broke) ?
- Wonder what is Sex Machine's screen name going to be tomorrow lol rofl
- anyone try these air filters from AMSOIL,suppose to be the shzznet,no oil needed either.
- 2.8 Heads Tip vs Manual, what is required, just a block off plate for "what"
- I'm glad this guy dont own a s4
- So, my new driver's side KO4 is on the way. Wish me luck - boost, here I come:)....
- noob question: i stfa the search but didn't find exactly what this is...
- "You're forgiven for all the fast corners you've taken..."
- S4 dying
- zOMGWTFBBQ!!! ARGH! as I'm walking to my car to get my groceries.... *SCRAAAAPE* toolbag trying
- My engine is fvcked. Blackstone oil analysis --> coolant in oil. Help! (esp DAP & LI-S4)
- Thinking about going to hollow a4 front swaybar or no front swaybar for winter
- Turbo Coolant Leak
- Thoughts on Neuspeed Rear Bar
- Changed my diverters...screwed up the car.
- anyone here know of the price range of a S4 tip tranny ~30k miles
- Not sure anybody noticed, but there is a forced induction forum now...sponsored by Buehn Engineering
- Euro Lights vs. DOT lights
- Loose electrical connection to the starter - WWAW do to tighten it up?
- Serious questions about selling S4... how much is it worth.
- More news on the RS4 clutch pressure plate issue. Big thanks to Alex@Stasis.
- 2007 S6 LED DRL light bar redux
- uber-noob Q: STFA, seems the most common plugs ran are the Bosch F5DP0R and NGK PFR6Q
- Tial Eliminator's? Found on AZ...Link inside
- Anybody know if the stock front fenders have a "notch" cut out of them from the factory?
- Consensus on Tuning the AWE Stage 3 Kit?
- any word on what daseighty ran at the track?
- Post Engine Reinstallation Issues
- Those running copper plugs - why?
- NOOBIE -- needing some help with my 6-CD CHANGER
- My rs4 airbox top doesn't have clips like my stock box did -- it only accepts what looks like a 6mm
- Reminder: SoCal OC meet...10/19/06 Thursday 8:30 PM! 2NITE! UPDATED LOCATION
- battery opinions....
- How tight to get upper front control arm bolts?
- Has anyone tried this brake package for mostly street usage ...
- How to check steering U-joints?
- Paging PKMode
- Is WMS open right now?? Simmply please answer my calls...
- Is it worth it to upgrade from Stage 3- to AWE Stage 3?
- Anyone done business with "Marc @ "yoshi_gsxr AT hotmail" or waveducky?
- Desperately need HELP!! Please read!! Transmission troubles.
- "Simple" task gone bad, diverter valve frustration
- Neat. Carbon fiber intake mani from Diaphorm Technologies for a Honda turbocharged
- My freind just bought a 2000 Santorin s4 with new badges no sunroof and no rear door speakers WTF??
- NJ guys: where did you get your 67,952 mile service done and how much did it cost? Am I forgetting
- What's the operating cost of our cars per mile? I'm getting reimbursed at 44.5 cents. Is that worth
- Trapspeed Topic: What would be considered a good Trap on 93 Octane pump? 91?
- This is all AWB5S4's fault, and I blame you guys.
- Please refresh my memory, who else except MTM using stock MAF for stg3?
- My motor is out. Anyone has a pair of PP-Ceramic-Coated-Manifolds lying around?? Please help! Also.
- 80k scheduled maintenance on 2001.5 S4 sedan
- Tial Garrett Eliminator Turbos
- Can the childseat latch retrofit go in the center rear seat-or only left or right sides?
- Schumi to Audi??
- Fairenough: Safe move to Chi-town next week (NJ will miss U), this done in your honour last night
- which is the fastest off.the.shelf.kit? APR, ASP, AWE? vote for one!
- Ran some more FATS... even slower, anyone want to help me examine my logs...
- Laguna Seca Speed GT/ALMS this weekend - Invite!
- so the SL65 AMG I ran couple days ago Dynoed@627 RWHP LOL
- just got back from e`town,best run ,12.7 at 111.88 with 1.80 60ft,on 93oct no power ....
- Shifter Slop Video (side to side)
- <flamesuit on> Who has blown K04s and why did they move on to turbo heaven?
- How to get rid of minor sandblast on stock exhaust with removed rear muffler?...
- Need a Help, For the upgrade stock brakes Rotor and Pad, Any one can tell me.......
- For you log whores...& you know who you are, I highly recommend downloading the...
- WWAWD? Scenario: New S is H-box, stage 3- w/ a bum SPEC clutch.
- Real dumb question...How do i change the time and date on the dash?
- poll: years driving, fines for speeding/lawyers/insurance hikes, if you think that's good or bad....
- STaSIS Motorsports Prepares for the Final Round of the Speed World Challenge TC @ Laguna
- ECUx - Anyone around Philly want to help me out?
- Does anyone know if someone is working in a MAF delete up grade for the S4?
- Hey Guys, I need more info (logs, posts) on "Water Injections".
- 1st timer -- FATS and some logs on S4 Stage 2+
