- Can I use Mobil 1 Turbo Diesel Truck 5W-40 Oil?
- engine oil?
- Axle grease leaking out of passanger side outer axle boot
- !/4 mile in 10.75
- What the fck happened to this website?
- P0300 code- running like crap.
- FLOPS = @udizine
- WTB _ ko4s!
- Turbo help
- S-Power Arrows Photography PhotoShoot
- 2000 Audi S4 pad and rotor replacement cost for set of 4?
- Timing belt kit special, limited qty, get yours here! :)
- Clutch Kit Question
- Who's running the ASP RS6 kit
- WTB: HP-2 Calipers
- S-Fest West 2009 (Inchelium, WA) - August 15th 2009 - This Saturday!!! Registration
- exhaust shop on long island
- Boost Spiking Problem
- Radio displays "phone"
- Build date w/o driver door sticker
- Anyone here had any trouble with...
- Curious: Is there any difference between the s4 and a6 2.7t engines
- Looking at the OP Parts rotors ECS sells
- Stock exhaust piece with 3" downpipes - how bad is it?
- 2.7T Timing Belt Kits - new lower price!
- oil cooler tube and o-ring seal
- 034 Clutch and flywheel group buy!
- boost gauge 10psi to 6psi?
- anyone have the harness side of the primary o2 connector they can snip and sell me?
- Stage 1-2 & 3 whats the difference?...
- ABT vendor question...
- New suspension + good alignment = steering wheel off centre
- rs4 parts question
- overheating
- Spacers for wider stance a good idea?
- Stock 2.7t boost taper - 9psi to 5psi?
- Pad wear warning light
- replacing turbos
- Blinkers dont work
- quattro world .com is waaaay better
- down pipes
- B6... 18" S4 Alloys?
- ECU Help
- Best wheel choices for 18" with no spacers used
- Burning smell coming from the engine bay
- LWFW
- custom exhaust
- S4 boost sensor Part #078 906 051... can it be replaced with sensor for TT, RS6?
- Automatic transmission fluid suggestion needed in central coast California
- Driver's side power window relay location....
- Bad MAP? 16621 Manifold Pressure/Boost Sensor (G31) Signal too low code
- FS: Orig Owner 2000 S4 AWE stg3
- Noobness question - picture included
- A6 Spark Plug DIY good for B5 S4?
- 10.832 @ 135.54 mph, still 25 psi, better driving...
- how do you confirm bad cv joints?
- Top mechanic in N NJ Area
- Best logging tool?
- HELP! Can't figure out how to remove brake master cylinder
- strange vibration noise from pass fr wheel
- Looking to go Stage 3, any thoughts?
- random stuff I need to get rid of
- Dentist Drill - how long till FUBAR
- Any Experience w mechanic Rennsport in Hackensack, NJ
- where to buy a set of KO4's?
- Fender Rolling - Any tips
- Silicone Hose Kit???
- Lunge/Surge at idle
- Air conditioning died
- Strange Engine Sound, Help Please.
- Silicone Inlet Piping
- Ignition Coil / Coil Pack Replacement
- clunking my 2001 s4
- S4... the expense continues...
- anyone out there from the old days?
- oil temperature gauge missreading
- Coil & Sparks, Flashing CEL
- Somitomo HTRZ III
- Stg 3 S4 vs modded C63, HPF Stg2 on pump, 2008 z06
- ASP stage 3
- Flashpoint wheels
- 18 x 8 (245/40/18 tires) wheels will clear a stock 2001 S4 suspension?
- S4 vs. 0304Cobra
- Interior Trim Recommendations
- 3 digit rear differential code... Where is it?
- doing the exhaust
- Rear view mirrir upgrade
- Thinking about s4
- Anyone with brake warning light issues?
- slots
- ? about lowering and re-torquing CA bolts
- what could i do ,for advice!
- Radio is dead WTF?
- Custom ECU tuning
- Poll: How many people still running their original K03's and what mileage?
- Broken door handle spring?
- Used 01 s4 front brake pad with sensor wanted
- How to switch foglights on without headlights?
- Cam Tensioner adjustment/Timing
- GIAC switch related question....
- fuse #29 Car won't start need help
- headlight washer cover
- Changing Rear Brake Pads - WTF?!
- Brake Fluid quantity
- took a little break from the forums..
- Carfax help...
- S4 2.7T downpipe blowout sale.....
- Mechanical malfunctions Stage 3s
- Power Loss Issue..... Logs included
- S4 missing around 4000rpm
- alarms, locks and remotes oh my.
- Downpipe legality?
- Safest “Stage 1” software at altitude?
- Nogaro F/S in Princeton
- Lots of clunking......Still...
- Buying a 911... keep S4 as 2nd car, or buy another 2nd car?
- Some of the fast cars at Waterfest
- water/meth questions
- I am a bad bad man...(WF runs inside)
- Hopefully Quick and Easy ? about brakes
- Audi RS6 vs 50 Trim SRT-4 (Video)
- Surging and Hesitation PLEASE HELP!
- My 10 sec run from Waterfest 15
- Shipping wheel/tires... how?
- Does lowering improve gas mileage
- ten sec s4 in his RS6 vs rx-7 the fight breaks out
- Pics from WaterWerks '09 Tacoma, Wa
- Already SFA - I am looking for part # for coolant expansion tank.
- S4 engine parts...
- Goodridge Stainless Steel Braided Brake Lines
- O2 Sensors or MAF?
- Merc C63 VS. Stage 1 S4
- Need new Front Upper Control Arms, how do you guys feel about the CPP Adjustable Arm?
- So who attended WF 15????
- experiencing considerable idle drops when turning a/c on and off...
- Tapping Noise
- DIY - Offical B5 Comfort Signal Mod (3 Blinks)
- Good News, Bad News....
- intercooler
- caliper fitment
- Waterfest....
- Could Use Some Opinions/Help.....
- how does the factory phone option work?
- Finally posted some photos
- Alignment Help?
- WhEELZz
- can find diy for cam tensioner replacement
- borla Exhaust
- Audi RS6 vs Dodge Dart Drag Car (Video)
- What air intake should i go with
- DUH FMIC Kit for b5 s4 for sale
- idle misfire cause stg3?
- ECU question: have ECU from Germany
- Hotchkis Sway Bars in stock!
- RS6 vs '09 Suzuki GSX-R 600
- Rear Caliper Piston Issue
- No front plate in Washington--how legal?
- LED light upgrade for 2001 S4 with HID too!
- racetec fmic for 01.5 s4
- New 034Motorsport billet rear diff mount, intro offer inside:
- Turbo Timer on a 2001.5?
- Zenlaracing Hoses from Ebay - first impressions
- Any idea where this would be coming from?
- Audi RS6 vs 2009 CTS-V (556HP Supercharged V8)
- Tire size for S4
- here piggy piggy piggy!!!!
- I must be blind! DIY for tranny flush/fluid?
- Last pics on the track
- Any body selling a set of piggie pipes??
- Rota Tarmac 3--fit B5 S4 without spacers? Anybody have them? Pics? Gracias...
- how can i hookup my sirius radio to work off my CD Changer
- Help Locating 2001 S4 IAT and sensor wires
- broken cam adjuster plastic ear
- strut buhsing dosent fit koni shaft
- Stage 2 Brake Install......?
- Audi Bentely Manual CD Help
- Stock Avus center cap.. anyone have one to spare?
- Wanted: MTM "A" Box ECU
- 02 sensors - any market for used ones?
- My first 10 sec run (GURU)
- Got a free 5 Qt, jug of Mobil 1 synthetic from a friend
- Help...coolant issue?
- 2000 audi s4 broken timing belt (how to set timing )??????
- Intake hose replacement
- Help with Brakes!
- What else do you do when your license gets suspended...?
- Greetings from a S4 noob
- Anyone have a set of recaro sportsers cs installed?
- Multiple Cylinder Misfire + CEL-HELP
- Ecux help needed : 'Ecu initialization failed'
- Help! What is this connector and hose?
- The sloppy door handle issue
- How did you remove the Autobahn88 logo
- Car turned off while driving...No Cel...
- cell flashing?
- VAG 020/021 logs
- I'm starting my driveshaft replacement now...
- s4 vs ls1
- A4 UltraSport 3.0 Q SALE!!!!
- Rich's -Free- Noggy Build Thread
- A few questions....doing some work on my friends 02 S4
- Clunking Sound when Steering
- I need a car cover. Help
- Engine starts "fluttering" once i get to about 4 or 5 psi. Details inside...
- apr chip and custom tuning with lemiwinks
- anyone have a spare primary o2 sensor kicking around?
- turbo failed after oil change
- testing n75 valve
- BEGi rrfpr
- A.W.E. Tuning Waterfest 15 Sale: July 6th – 31st!
- Fastest S4's in the world.
- SUMMER BLAST SALE 10% Off STOREWIDE. V-Maxx Coils, Milltek & MORE!
- Clutch and Such
- O2 sensor blues, any ideas?
- AWE K04 - do I really need high flow exhaust?
- Aftermarket Nav Ipod interface options
- Engine swap????? My Autospeed stage 3 into...
- Car Video
- motor is missing and noticed white smoke today......
- Boost Leak - Uggggh
- Audi RS6 vs GT37R 2.3L Evo (Video)
- New milestone today!
- My exhaust system is too loud. any suggestion to damp it down?
- Buying an 2001.5 S4
- Anyone have one of those stock b5s5 wheel caps around? Someone took mine in NYC..
- metal brace on back of brake pad
- S4 not holding boost?
- napa sucks
- Car might have came with piggies...?
- N75 question
- Car too lean - please come inside and read
- It's been a while since i've been here...
- hood w/minor damage, where can i get rid of it?
- can i sell just the chip outta my abox
- ac leaking on floorboard, lots of H2O
- O2 Sensor?
- Spring rates for track S4?
- ECS Stage 3 or 4 BBK kits - Yay or Nay?
- boost guage/ housing
- I got new tires on my stock wheels, and the tire guys put 40 psi in the front and 50
- My display is broke, but I get a beep and something flashes...
- Fraud committed by Long Island Audi Dealer
- Phatbox Replacement
- S4 Pricing?
- still looking for some ER intercooler
- major b5 s4 clearance!!!!!!!!!!!!!!
- will these rims fit an 00 S4?
