- Have STFA, getting some Ideas, but not clear. Here's the symtoms
- I miss my stgIII S4 :(.. after selling it three weeks ago, I've purchased an A8L, it is an awesome
- Check engine light
- Low requested boost on Stg3?
- Which side is egt sensor two.............
- Damn Girlfriend!.......
- any thoughts on need for timing belt change by yrs rather than mileage?...
- What's an appropriate tire pressure for 225/17 Blizzack snow tires (front and back)?
- run with the hunted... still *original* K03s
- I posted before about my clutch slipping only at WOT. Should i replace the clutch and
- fvck! somebody stole my avant antennae, anyone has one they're willing to part with? TIA
- Hit/Skip? 2000 S4 with 176k (went from NY to DC often for work), all service records,
- Hybrid S4 (K03/K04-stock fueling) = 2, Lexus SC 400 = 0...I-95 South
- The circle is complete!... Finally full stage 3 after almost 6 years!
- Columbia, SC (Carolinas in general) role call...
- rns-d cd question...
- Hit or Skip? 2001.5 Black Avant with Nogaro Sport Package. How much would you offer?
- bt: tires / tyres...
- I cant get the axle bolt off!!
- looking for a new S4 (b7)
- OK can anyone at least help me with a diagram of the engine belt layout...
- Please help!!! STFA...nothing there. A weird noise from engine bay......
- Seat Heater Relay Help! Urgent
- How to determine which differential fluid to use? Redline 75W-90?
- Loose rotor wth???
- Minhea supposed highway video
- missing coolant
- where are all the sacto peeps??
- help: do I need to prime K04 turbos with oil before I reassemble???
- De-cat front pipes any suppliers?
- has anyone put a a4 fog lights on a oem b5 rs4 bumper?
- quick question... replacing clutch - what is torque on pres. plate bolts?
- When installing Neuspeed rear-sway, which holes are the soft & hard settings?
- Whats the cheapest place to get some redline MT-90 trans fluid?Any others better?
- Downpipes Question......
- What could be wrong? FATS 8.6 :S
- FATS - For all the HomeBrew Haters :P ..... 3.36 West Coast 93oct
- im looking to get intercoolers for my stage 3 whats better to get FMIC or SMIC
- Radio in SAFE mode
- Problem putting gas in 2000 S4 B5
- GTO-0 S4-2
- Anyone know the difference between Stg1 and Stg2+ chips from EPL?
- Kudos to Simpply, gardian of the valley. had some issues with car on way to WMS and had to pull off
- Would anyone be so kind as to run a VIN# for me and email me the results? Really appreciate any
- Intercoolers I havent seen before. What say you? Opinions?
- What kind of improvement are you guys noticing in FATS or 1/4 mi times by reducing wheel weight and
- Anyone know where u can get a fan clutch, and driver side t.b cover for a good price ?
- Panzer Skid Plate Installed!
- 335 & GTR info & questions: 335i has 1-piston calipers - anyone else find that lame?
- It's true! Axle removal in about 10 minutes!! Quick write up / how to
- so im still having problems with misfires at idle.
- lemieux@curbside
- is there a diy for the wood trim removal in the dash and door panels?
- I am going to be the only Twincharged S4 on earth with 2.8 heads and a PES Supercharger! ;-P
- Saw a red R8 on the 15 in Las Vegas couple of hours ago...so sweet
- Its about -6 degree's in Chicago tonight, and I walk out to see that someone EGGED MY CAR.
- more tidbits for the AWE-haters out there...........................................HA WE 3.34 FATs
- Ram@Autospeed or any other ASP homie - With the 2.8 heads you plan on running in future what
- For all the AWE-haters and ASP-lovers, here is my HB-AWE stock airbox file log for 3.21 fats
- do it yourselfers... check this out...
- What could cause the transmission to come out of 1st gear while trying to lauch at the drag strip?
- Mods done for the weekend: new cruise control installed, RS4 wheel/Airbag, boost gauge fitted
- Transmission Stabilizer Bar for Tiptronic Transmissions
- anyone running with a compustar alarm??
- Is it just me or is AW slow to refresh, post, update etc tonight??
- Anyone have a set of A4 fogs theyre looking to get rid of?
- X-post: central locking pump issue - any help appreciated
- avus rep center caps?
- Is LCP still around these parts?
- I dont know if they are a sponser but here are some good d2s
- adams metal polishes FTW! (rushed pic)
- What's the trick to popping the buttons out of the CC head?
- What are the vertical vents on the RS4 bumper cover for?....
- What are some good shelving solutions for storing auto engines?
- Love the new DPE S20 wheels but grimace @ nearly $4k a set! P-chopped em for sh!tz n giggles.
- Burning smell??
- Woo Hoo, just helped a friend doing logs this morning sh!t looks good!
- Help! White/Gray smoke from tailpipe
- Why does AW allow you to type more than 100 characters in the subject line, then yell at you
- Gt35r turbo kit.
- Help me pick my wheel...1,2,3, or 4.
- USE THE TIMING BELT TOOL... Lesson Learned.
- VERY strange issues, your advice is *GREATLY* appreciated : )
- Can i buy a stock ecu anywhere online?
- horrible dream last night
- speaker going bad?
- S4's are now safe in New Jersey!!!!
- Are the Hotchkis H-Sport sway bars the "best" option for replacement...
- Updated: Engine-pull notes...
- ok.. its 2:30am - I'm giving up!!!
- Anyone else have failed readiness for O2 sensors on ASP Stg3
- DIY Turbo swap progress
- Interested in buying B5 S4- Questions
- Looks like I blew a shock - H&R coilovers - anyone know the warranty terms?
- Tonight... tonight....
- Pics of Nogaro with Silver Brakes (pref ST)
- Has anyone had windshield wipers that stay on....?
- what a way to go!!!
- just installed my h&r rear sway bar, got to say i love it. havent been at higher speeds yet....
- Does anyone know the difference between the alloted book time for OEM bumper instalation and OEM RS4
- is it just me or?
- More random S4 Questions
- <edit> Latest FATS with Fuel pump replacement + O2's on ASP K04/RS6's code
- doors wont lock now using keyfob or key in door
- Clutch not disengaging? Details inside.
- Lumpy idle and rotten eggs
- How many TIP owners are there? Looking at getting a S4 Avant and its a TIP
- Does anyone make a bbs ch replica ?
- Cabin vibrations post ASP downpipe install...
- Anyone else's B5 S4 still under AOA CPO warranty?
- About to get started
- Whose going to Laguna Seca?
- Got pics? If I get StopTech 332s instead of Alcons, which color caliper to get?...
- yea for me. just ordered 3 liters of motul 300 from purems.
- Has anyone run againts a M5 or an M6? Saw an M6 on the road, looks nice but the guy wouldn't hit it
- PSA - when doing LARGE projects with shops....you can negotiate the final price.
- For those of you that have replaced your IAT sensors, what was the best way to access it?
- Any silver B5 S4's from Manchester, NH here?
- Just got a new short shifter from JHMotorsports and just wanted to commend them...
- bt: ASP 89mm 3.5" Exhaust owners...
- need EGT sensors...anyone got them ? best place .. price ?
- anyone got a stock or any M box ECU I can get my hands on ?
- Rear subrame broke again, left side now, had welded right side and now that
- Paging Moss@Torque Factory, please post pics of the car with Enkei NT03Ms when possible, TIA.
- DIY windshield replacement PITA rating? Tools/products needed?
- Need new motor mounts. Is Purems the best place to get them? Also how do I
- Help Please.... I think i might have a clutch problem
- Are you smelling fuel in the cabin? <more>
- Driver side interior door handle broke. After STFA, I found that you just have to replace that
- new BBS LM pics, for anyone bored this morning:) thanks AWE!
- Starting my 3- install today!!!
- What is a good LWFW to get?? Fidanza BLOWS!!
- aanyone heard of an upsolute chip? is it any comparison to apr or any popular chip or is it like TAP
- Startup Racing
- Need some insite on an S4 with an Auto.
- What would you pay for an 01' (pre 01.5') Casablanca S4 manual sport w/ 100k mi?
- anyone run 2 bar on their K04/RS6 ?
- this is so cool (B7RS4 1/18 scale) . why don't they make one for a b5? *sigh
- Boost On my Dash Screen???
- OK - Test #2 for the evening. In this pic there is an S4. How long does it take you to find it?
- Part number help - already searched the archive....
- just a group vote, can you guys please post pics of what you think is the nicest looking B5..thanks!
- Holy molymolymoly!!! parting out 2001 RS4 for under $5k!!
- Needed asap: Stock head unit for 01 S4
- Ow, my ears... Can you hear the ultrasonic ringtone or are you too old?
- Link to a pretty decent buy on a 2000 Cactus Green S4 w/ 64K & Nav and SPORT.
- OMG! lol! are these people serious?! look at these intercoolers on ebay.de...
- can't figure out why VAG.COM or LEMMI has no ECU communications for the life of me.
- Can someone please tell me what it's like to drive/own a stage 3 car?
- What leahter care do you guys use? I have lexol but feel it makes the leather dry..;any recommendat
- Are Mintex Reds supposed to squeal so badly?
- What do you think I can get for my two front OEM seats...
- Crapple, you in this forum??
- re: winter wheels
- Hit a huge pot hole with the right front and now the car pulls to the right.
- Not bad for an old "UR" S huh?.
- Anyone have any info on how much a turbo can make up for at altitude?
- MC guys...need your help/opinions here please
- Any more info on the ASP FMIC ?
- Laser Red S4 with 103,000 Hit/Skip?
- Live update on the 2.7T!
- can someone help me find the Fhose install writeup?
- I want! Video link to Veyron
- MTM RS6 Avant ClubSport...
- just raced a 2006 Evo.
- Thanks to socal life & nogaro nitwit for finding part numbers...Q now is anyway to get
- Update of the missing coolant and oil episode.
- Rear O2 sensor efficiency below threshold on re-located sensor???
- who was in the black B5 runnin with me on rt 9 last night in newton?
- fixedwing, didn't you have the porsche battery trickle charger?
- 2 questions - 1, we have a car with misfires on a single cylinder and seafoam question!
- Those with StopTech 332s and OZ SLs (18x8) - no fitment issues, right?
- What Transmission fluid are you using in your car? ... redline good? neo? motul?
- Bluetooth integration tonight
- Wow slow day...anyone embarrassed about how our horns sound?
- Looking for used front bumper
- I have to be 2' away from car to lock/unlock, is that normal?
- Anybody seen these?
- The beast comes home today! Many thanks to all my favorite vendors
- Boys. I have reaffirmed the answer to our demise!
- So what is AWE working on for the B5 S4?
- Changed tranny fluid, car still will not go into gear until about 10 minutes of use...
- IRIDIUM POWER IK20 for Audi S4...YES or NO?
- Which color is fastest? Vote by clicking on the fastest color down there vvvv.
- Anyone know who's Casablanca?....
- I've searched the forums, called the dealership(no help) but I can't seem to find the part numbers
- Blackstone analysis is back...
- Spun the S last weekend, should be dead
- not as good as the original, but another exhaust video
- First start up in morning, brake light flashes three times, and a beeping sounds along with it. Any
- question about oil aroma in cabin
- Anyone had a GOOD experience with Carsponsorships.com??
- What do u think of this FMIC
- anyone have problems w/pwr steering fluid foaming up in the cold??
- Anybody want to share a passenger side mirror glass?
- Whelp -- car goes into ASP on the 12th.
- Piggies in route from Vast. just need to confirm vibrant will fit on avant. item #1695
- Anyone running a clutchmasters stg3 with fidaza?kevlar or ceramic?likes or dislikes?tnx
- Any avants with Flik Justice out there? Pics please!!
- ABS unit from h e l l !!!
- one of my fogs is out..where can i order 2 new ones?? suggestions
- Brake light Fuse keeps popping.. Brake switch or ABS module?
- was at the dealer today for an oil change. they dicovered that my rt CV BOOT was torn.$475to repair?
- KBB VS Edmunds
- Random S4 Questions
- filled up at the pump 17.541 gallons.Think i was low? The most mileage u have gotten, all highway?
- bmwusa.com just pissed me off...
- help please! need part # or description...
- If you are bored and need a quick laugh, check out these guys...
- Quick question...are M box and T box Stage 3 APR ECUs interchangeable? Searched,...
- old pic but a good pic
- Besides "Tree", "Fiddy", and "Tree Fiddy" what are some 18x18.5 HRE 545 wheels worth that
- Calling all santorin owners. show me rims please! all types NO NOGAROS please
- '00 2+= 0 ..... 300c SRT8=0
- LOL
- Does anyone have a link for ABS module replacement??
- What to do with tax return money ??
- RS4 SAC PP question
- Does anyone know about puting a front mounted IC. Where can i get one? Are they better than RS4s?
- aux audio adapter
- Exhaust: Millek or Vibrant (is anyone running Vibrant?)
- anyone run something like...
- Anyone know what the stock alignment specs are? At work , don't have Bentley
- finally doing my brake lines - but having a problem.
- Checked oil after a drive while the car was on, it is a little low (tip of the dip-stick).....
- RS4 OEM Inlet Pipe Kit just arrived! ..... Question .....
- Turn signals not working
- Best extended warranty service? I know STFA but i am too lazy..
- Quick, how many quarts does the 6MT tranny take?
- where do u guys buy your oil filters? im sick of going to places that dont have the right 1, 00 tip
- Tip transmission/diff rear seal leak...anyone replace rear seal ???
- Why would my window wipers move very slow?
- Anyone have an s4 parts car ??
- Thinking of getting a new daily driver....
- Stage 3, here we go!!!!
- Hello, my name is Amir and I can't stop picking on Z28s and Vettes.
- jacob ygm!
- More EPL love
- just and idea. im planning on selling my car, how much do you guys think..........
- 0 degrees and my hood latch won't work.....suggestions?
- How do I tell the difference between orig green tops and new green giants?
- can altering alignment settings cause wheel spokes to hit calipers? need some insight
- So after my post today i changed my injector orientation on tip and.......
- Need Shop
- which giac program is this for 110GLosx.07a..............
- Help I'm LOST!
- I just found a Audi key with c/f on it!
- Newbie looking for info
- VALEO B5 Xenon Housings & 50W Xenon kits back in stock
- need help deciding Revo flash ecu or dahlback chipped ecu???
