- I heard RS4 owners are hating on any S4 owners w/ RS4 wheels, read on...
- Anyone know what a coolant resevoir costs
- BIG THANKS to Mark@Autospeed
- i saw 3 b5 s4s in CT on 84 & ridgefield
- Anyone got passenger seat belt system, airbag in the seat, or headliner?
- had a lil' fun run in with a 2006/7 Aston Martin Vantage V8.
- just finished intalling a new exhaust by myself. On jackstands. I'm really dizzy.
- Anyone want to part with low mileage, no issues KO3's?
- Anyone have a set of Labree Testpipes they'd be willing to part with?
- For those who dremeled off the nub on the rear diff mount that hits the exhaust....
- Went to EPL to get my Stage 3 dyno'd today .....................................
- Need help with part number...not sure if its b5 a4 or s4- 8D0-711-4060
- so i had a run in with a ford gt driving home from work this afternoon...
- Sagging Door?
- Had the front engine mount replaced when t-belt was done, noticed this the other day...
- After turbo swap can't seem to bleed coolant system. Followed bentley procedure
- just for discussion, what other chemicals have people try to inject? pros and cons..
- Quick ?, no time to search...What are the sizes for our wiper blades (22" - driver's side and....
- FI Images Vented Hood Installed. Fitment not so great.
- any one in SoCal have a samco or stock F Hose FS?? i am at WMS and willing to pick up today!!
- Toy guy shifter install?.....Mine is the adjustable height shifter....
- Getting my software back to normal.
- STFA already and did what was recommended to others "engine cranks, but won't start"
- CV boot install on the passanger side? Hear there are 2 methods. How do i do it...
- Anyone have a Toyguy/Li-S4 V1 display they wanna sell?
- who is a MTM dealer these days that can get MTM headgaskets?
- A couple of issues...
- Homelink (garage door opener) doesn't work. Any ideas?
- 100@100...woohoo.
- does anyone run a MBC?...
- Any experience with Kumho tires, MX or SPT????
- Exhaust installation ?. Can it be done with just one person? Exhaust came
- EGT PSA: On my 6MT '01 S4, the pass side part number is 078919529D. This is different than all the
- new bumper pics, Santorin sedan, no sunroof, filled headlight washers, Canadian grills with fogs....
- Am I being silly for thinking this is going to be an easy install ?
- Clutch replacement woes (long)
- Coolant Temp Gauge Help
- Anyone have this Techtonics Dual exhaust?
- Best source for Kinesis wheels?
- GURUMAN'S '' VAG GT25R'S'' b5
- Does anyone run nitrous with the 2.7T???
- APR ecu adaption channel Help
- Testing sig picture!
- Dragstrip results at Commerce
- Help! What happened to my BBS rims over the winter? Corrosion?!
- MTM decentered rubber bearings for the inner upper wishbones, anyone has them?
- 4 torx screws that hold the shifter to the cradle?? Part #
- PIC REQUEST - S4 Sedan (not avant) with RS4 suspension...
- Homebrew Questions. Maf size, W/I and air to fuel ratio related.
- KO4/K16 + custom TCU tuning advice plz.....
- just got my new dv's in but one quick question?
- 8 more codes after replacing ECTS....
- RS4 Mesh fit Rieger bumper?
- My misfire problem was a coil pack. oh does it feel good to be back in boost.
- Are there any engine codes that wont show up on a Auto Zone OBD II scanner that would with a VAG?
- Who drives the silver avant I see every morning on 227 in San Luis Obispo, CA?
- Pure MS CV boot kit supplied an odd looking axle shoulder bolt? Not 17mm hex like stock..
- I-75 southbound, southern Georgia, around lunch hour today, silver with M3 lip, you on here?
- What size are the triple square (12pt) bolts for our front axles? The tech article
- gt3 brake caliper adapter question
- anyone have a thrust ring laying around?
- When I disconnected the MAF to replace the air filter, the o-ring came out cut.
- Just curious- how many here with after market DP's run test pipes often or regularly?
- Rear Factory Bumper (cover?) desired for 02 S4 Avant - silver preferable
- Blackstone analysis. 8k miles. Mobil 1 0w-40
- GARRRRH!!!! Should I sell my stock DP's on eBay or AW classifieds?
- Are all RS4 owners as stuck up as this one.
- Can I please have a status report on the new GIAC files for us stage 3 AWE sickos.
- Anyone have an extra/unused engine cover the goes over the MAF? Maybe one of the lucky...
- -******** Mike2kS4's TIP(Tiptronic Transmission) F.A.Q ********-
- I hit 28 psi on K04s this morning and nearly shat myself. Whoops, guess that other N75 I have
- Computer "illiterate", how do I finally attach a pic to my post? I am typing the pic number.jpeg but
- I was thinking of buying Mintex pads until I read the archives. Here is what I want.............
- Phisherman Fakes the Funk with Bogus Email Scams
- -******** S4ORCE's TIP(Tiptronic Transmission) F.A.Q ********-
- Anyone hear of Texstar brake pads?
- N75 Questions (ASP Stage 2+ Chip)
- Poll: But ECUx now or wait for something else? (my computer has a serial port)
- HELPPP... wheel/tire combo problems
- PureMS :-: Free Shipping on S4 TB Kits!
- Third water pump in 35,000 miles.
- AWE Tuning Package Special for April
- Is the clutch engagement point lower with aftermarket clutches? I honestly hate the stock setup...
- Looking to buy a Recaro Speed seat. Any recommended dealers?
- Twins? Close Enough. MAJOR BWW.
- How do you convert injector lbs into CC?? For example asp kit has 60lb injectors where as..
- Any other shops that can build a tip trans besides Lvel 10, IPT, and 2 Bennet
- front to rear axle weight S4 vs. RS4
- Need some TIP information.
- What do you guy's think of this FMIC? Does anyone have one or heard about this company?
- Searched and still no definite answers. Will the CM stage 3 clutch be enough for my ASP stage 3 car?
- Has anybody tried the new Goodyear Eagle F1 Assymetrics ?
- What's the difference between S4 and RS4 exhaust? Any big difference?
- squeaking from suspension area
- so why am i getting cel light for rear O2's with race pipes on APR stage 3
- Just browsing some post.. Found when o.w. kenobi gave me my first noob rashing..
- anyone make good intercooler water spray kits?
- Can anyone tell me why some 2001.5 and 2002 S4s have mixed and matched badges?
- connect four.
- is there are a market for...
- FINALLY AVAILABLE~!
- attn: frank@asp.
- Wanted to share this in hopes it will be beneficial
- Are our stock S4 seats made by Recaro?? I've always heard people saying that, but they don't..
- S4s around boston
- Question regarding AC unit
- axxis ultimate pads: any know a better deal than this, or another good set for less?
- towing capacity with B5 avant, man. or tip.? ...trying to convert dad from Subaru...
- New Wheels...
- Who crashed their Black S4 recently?? I just saw it...(front end collision)
- nu-bee ?: About to buy used mbox. Plug-n-play?
- tried to race a gallardo.....( too bad no race happened).
- Best place to buy spacers for stock Avus? Recommended size?
- Anyone fix their squeaky seat, mostly when pushing in clutch/going over bumps sometimes.
- kind of a stupid question, i already STFA, on going compressor issues
- Anyone know if the top caps on the stock front suspension are used on the H&R coilovers?...
- What can i do to clean up my front end?
- RS4 Motormounts?
- anybody seeling their S4 NJ north?
- Suspension install annoyance, ideas needed
- i don't know why i haven't posted this...but i radically simplified the way to attach a S4 badge...
- anyone interested?
- Anyone know of an Audi putting down >400 wHP on Dyno Dynamics?
- Replacing suspension, what else should be done while it's apart?
- what would cause my car to go into limpmode. its not the tbb, just changed it.
- what luck would i have selling an AMS chip? i doubt there is anyone NOT chipped by now
- will somebody make me a sig? thank you AW...
- will i havei have overheating problems if i go with a front mount
- What transmission fluid to I need to use for 6 speed manual?....
- Anyone have a stock 4 bar FPR laying around that they don't need????
- Who here has 600 WHEEL hp on stock rods and pistons?
- Poll: what oil do you use, grade and state you live in
- Show me your posters/banners!!
- Front half shaft/axles - Cross reference to VW part
- Had a chance to play with a B7 S4 the other day
- [O.Z. SL's] - Anyone ever have any issues clearing stock calipers?
- Anyone know a Nicholas Constant ? Email address QnZFiNeZT@aol.com ??
- Volk Le37 Questions
- Spring Fueling Kit Sale!!!
- Would anyone with a sedan widebody be willing to do moldings for me ?
- best stage 3 fueling kit...
- Zeitronix Special, C'mon guys have about 10, need 10 more...
- RS4 IC's, do you need the RS4 brackets to install?
- a few action shots from this weekends driver's school at Autobahn Country Club
- WHEEL ASSISTANCE - northeast/nyc related!
- Anyone offering a Milltek 3" catback?
- 2nd Sorry attempt at pshop sig.. Thoughts ?
- i went to a customers house yesrday to measure his floors, when i got in he asked
- spotted: pearl s4 in charlotte, nc parking deck. looked like it had some iforged style wheels...
- Do b6 s4 rims fit on our cars w/out spacers??
- B7 steering wheel in a B5?
- blacked out grill on pearl any pics
- neil ever sell his car?
- Coolant temps are acting up...
- Vogtland coilover and Stage 3 "minus" - On track experience... (long)
- I'm no S4 guy... but why would one go 3- and not just pony up and get the fueling for full stage 3
- what should i use to take off the bolts between the tranny and driveshaft, regular hex or ball hex?
- Not my car, but ouch
- Anyone else parting out an S4..
- AWE's Silver stage 3 s4 is gonna be in forza 2.
- Dear AW diehards..help me solve for X
- LI-S4 YGM @ VooDoo
- Which one of you fine fellows is responsible for this....?
- No longer s4wanabe ... handle now uBER.QIK
- What is the difference between part # 8eo407510c versus 8eo407510a?
- Anybody selling a set of B5 S4 (Avus) wheels???
- On a scale of 1 to 10, how hard is it to fix a torn CV Boot for a noob?
- Could you guys post pics of your fogs light with the rs4 bumper? I need to see how you set them up
- Update On Justdave mod: One more layer of primer and she's off to paint.
- almost famous...
- Well I finally found my overheating problem at idle for more than 5 minutes.. My thermostat is stuck
- a couple of broad questions
- Should I replace strut mount and/or bump stop when doing coilovers (75K miles)
- pretty nice pictures (albeit a little small) in Eurotuner online
- This guy should stop selling cars and start writing books, lol!
- Does anyone need an IMB-2000 Imobilizer kit? I have one avail.
- snowtrooper, did you see this classified, O1E trranny from tdi with wider first gear
- Turbos spooling...
- First weak attempt at a Sig..
- I found a video reference to the exact noise my turbos make. :-P If you guys were wondering... LOL
- Is anyone aware of any NHIS track days this summer that are still open
- diy ic mister: headlight washer pump needs how many volts? is the 12 post ok w/ switch
- Is anyone here running GIAC with a cat delete file?
- Does anyone know these guys? 18" Avus reps for ridiculous price.
- Will this buff right out(seriously)?
- Newbie here, just got a S4 and I was wondering if you guys can give me some advise on maintenance
- Signups now open - Bertil Roos HPDE+ 10/9
- Brakes almost didn't stop me...
- For those with aluminum uprights: Lower Control Arm Question
- Anybody running the h&r rear sway?
- who know a good place in NY to fiX the seat after airbag deployed
- new ASP Supa Spicy Sauce...
- The Sillver Bullet Makes a Appearence in Forza 2
- For those with ASP tru-dual, is it quiet when you want it to be? More...
- who's got RS4 (ko4-s) turbos and inlets in stock ? and how much TIA>
- does anyone have a dec. source for jsut a pass. side turbo? used preferred
- hit or skip? RS4 transmission for $2,332.77 delivered from germany?
- More stuff to add to the pile...
- hey guys can you point to the right direction i am looking for
- what do you guys think of these manifolds....
- Creaking noise from rear like a Bad CV joint?!?
- Should I risk the transmission and go with K04's + fueling and only upgrade the torque converter??
- who makes a good engine work stand? that i can get quick
- |skolnick, I received my Nav speaker. Thanks again. Turns out the speaker wasn't the problem. :(
- Oh noes!
- One set of Pauter Rods available at special pricing..
- You guys have any pics of BBS LMs on black? *cough*daseighty*cough*
- ambient temp gauge on cluster is acting wierd
- where can i find mirror caps??
- These guys are idiots...Porsche Carrera GT destroyed.....
- Just wanted to pimp my Eibach P/S Coilovers after a track event at Autobahn
- Pre-order sale on Vogtland Coilovers!
- Good shop near Austin, TX for stage 3 install?
- What is normal oil consumption for a Stage 3? I'm seeing 1/2-1 quart per month.
- what do you guys think of this wheel on a casa s4??
- whats a fair price for some stock DP's?
- If I buy pads to use at Road Atlanta for a 2-day school, what should I consider getting?
- Woohoo! Just sold my GSXR yesterday. Building mod list now...
- When was the last Stage I GIAC software update? Can I pay to update a used ECU?
- How would a Stg3 S4 with handling do on the Bull Run?
- AW's opinion? Soon to be going stg 3. I have access to a hyd. lift. Should I drop the frt. subframe
- Opinions: Carbon Fibre Hood? - there is a method to my madness...
- To throw more fuel on the fire
- already STFA and didn't find much info on this but, has anyone here had their a/c compressor
- Mod pics --- APR Stage III + RS4 IC's + Milltek DP & SD
- Exhaust valves, don't want to pay $55 a pop, WTB?
- OEM B6 S4 18" 45mm offset direct fit on B5 S4 or are spacers really needed?...>>>
- Oh the humanity!!!
- So I have a wheel problem..... can't decide what wheels to buy. MORE INSIDE.
- WTF is this? It fell out of my bumper when I took it off...
- Anyone have an Idea where I can get center caps for my OEM wheels?
- What's the purpose of the small (1/4 around), thin metal "shroud" around front rotors?
- Show me pics of your nice silver alcantara interior.
- d2s philips ultinons: anyone got a trusted+fast online source?
- what do you guys think if short shifters???
- Audi S4 Avant pics on Cape Cod... BWW
- Has anyone pulled their intake pipes from the turbos off without pulling the engine, if so...
- RS4 Mesh possibilities for cheaper
- What would cause my stg 2+ APR car to run pretty damn rich? Just general causes?
- Is 420chp reachable with my mods ?
- take the long ride home with ASP lol wow stg3 and loving it!!
- Dyno results, need ECU help!! (kinda long)
- Had a nice drive home today, thanks to all my modz...
- Any opinions on what should be the next mod?
- Paging Swank... got a link to that rear shock tower harness bar?
- Rear Badge Measurements
- I normally don't do the look what the post man brought posts... but I had to make an exception :)
- If you're going to convert an S4 avant into an RS4....
- StreetCrawler(Cole) YGM, Thanks!
- whatever happened to BBB?
