- is oil temp sensor a little tiny brass colored thing? No plastic jsut a little nub?
- Took some logs of my friend's Stage 2+ S4....
- so who are the excited ones for WMS to ship out the ER's tomorrow?
- New LWFW and clutch with 5k miles on it, break it in or its good to go?
- Intake AIR FILTER choices?
- The A.W.E Tuning Holiday Sale Is On!!
- Braking in cold wet weather car was pulling to the left and brakes felt like they were slowing me a
- Stock downpipes needed
- adjusting the sac spring in a rs4 pp. Do the yellow springs just need to be compressed.
- Anyone know for sure if the Left & Right RS4 grill frames fit into an S4 bumper?
- Hey guys, anyone have add 3 used B5 stock wheels for my winter set up. $$
- Awful whining/grinding sounds this morning, what is it?
- Question about aligment of DTS with tranny after engine re-install.
- Paging "Woods4" or anyone else with ASP tru-dual fitment issues:
- Brake light problem, please give advice.
- Let the neutering begin...
- Can someone please confirm that Ball Seat 14x1.5 x 28mm Wheel Bolts
- looking for a new clutch
- anyone ever experimented with this single turbo kit from..
- rich at cold start
- Sleeve-type Coil overs?
- How many here waited until after 100K to do timing belt?
- What's the word on going with 2.8 30v heads? Are they worth it?
- Attn : Jason...
- I need new CATS and it looks like I can go with Piggies or AWE downpipes. I know there is never
- NEW rs4 clutch on ebay for cheap. It isn't mine.
- im changing my brake pads from hawk to something else, what should i go with...
- Just got a barrel of VP MS109!!!
- Whats the going rate for a 3 year old exhaust
- Vibration when Engine Braking.
- Good morning for doughnuts...
- Anyone know where to get a rebuilt 2.7 longblock?
- Odd sound when accelerating up hill or making right turn
- Lubro Moly 10W60 oil, anyone's ever run it (track or street)?
- uhhh I've been hearing the revving of my gangsta neighbors V8 Marauder for the last 10 minutes...
- Oil Temp vs Coolant Temp......
- Are the fan clutch and fan coupling the same thing?
- FATS run tonight
- where to get spacers for the old motorsport coilovers?
- Got back from Laguna Seca today, I NEED DOWNFORCE
- My Catalytic converters and sensors need to be replaced. It looks like people pay $2k to $4k
- Since this place is dead......
- Need an AWE center vent without the gauge for HFS-5 Water/meth inject 52mm gauge
- Replaced oil leve/temp sensor, no I don't have any temp reading
- Brian@Avalon YGM
- What is this squeaking noise im getting? Coming from the accessory belt area?
- Bad Alignment?
- If you had to guess
- Can a healthy Clutch Master stage 3 slip after it has been engaged?
- Coolant flush... shall I do it at dealership or it's pretty simple to be done at any shop?
- PSA for avant hunters: 01 silver S4 avant in the local paper...
- Tuning shop in CT, bout 15 minutes west of Foxwoods
- Woot!! Santa brought me an early christmas present....
- any idea on how much it would cost to flash an m-box stage 3- over to supertweaker? or giac x sauce?
- Boy I tell ya...that Axle bolt is a bitch to get out! I've post poned my install date because of it!
- so i got a set of fresh piggy's... anyone in need?
- 2 Forge Diverter Valves (black) in the classifieds for sale.
- While the engine is out, any parts really worth ceramic coating?
- What involved with setting up the city lights in e-codes?
- Is there a gasket for the lower washer pump that fits into the tank? The gasket on the pump now...
- Holding part throttle - boost starts flipping out - up, down, up, down... I can hear the wastegates
- So VW gets the Eos, and Audi gets essentially a new VW Cabrio
- Need some Dp's or piggies, any of you guys selling?
- $200, a fair price for an 85mm ASP MAF?
- AnY IDEA what a Tip Stage III w/ L10 run 0-60 and 1/4. Thanks
- H&R and Bilstein Sport combo, Yea or nay!!!!
- stfa.huge boost leak......................help
- Could anything bad happen if you torque your lug nutz down 2 hard?
- Need a new fan coupling...
- T-minus 5 days until my first track day @ Big Willow...
- Reminder: EPL Dyno Day This Saturday, Dec. 8th
- 1st day of snow and my wipers decide not to work!
- 2.5" vs. 3" downpipes?
- S4 + 8 inches of snow + quattro= FUN....that is all....
- Changing my coolant sensors yesterday, i noticed my coolant is very rusty colored
- I am piecing together my stage 3 set up. So far I have....
- Opinions on ECS Stage 3 (993TT) BBK... have come across a really really good deal on a slightly used
- Good spring compressor?
- I ran a 12.8 @ 113 with just a tune on the 335
- I searched about headlight adjustment and seems like lots of different answers. Some say use vag,
- Guys with vag coms and running vista..Hows it working for you?
- Just thinking...I was browsing through the Summit Racing catalog that came with my Energy Suspension
- Snow Tires: Buying Dunlop Winter Sport 3Ds tomorrow, anyone have em? lowered stage 3:) Should be fun
- Which fluid to go with for TIP tranny fluid flush..OEM?
- Just finished changing the trans fluid from Redline MT-90 and 75W-90 to Motul.
- holiday depression
- Does anyone have a good PS pump they could spare?
- Hey, (R)S4 SmokedU /-///, I've been meaning to post up this pic for you
- flashing yellow triangle comes on while under heavy acceleration-help
- Stage 3 Inspection
- Location of Rear window washer pump
- Broke my MAF housing at the loop where the retaining clip for the air box is. Need another one ASAP
- 19 inch wheels
- Lost 1st and 2nd gear after short shifter install/adjustment....
- Another FATs run tonight - Even faster...
- Where's the cheapest place to get a power steering pump?
- put my santorin tip up on ebay...
- R8 on dyno
- Tech question: How many PSI does the oil pump provide to the turbochargers (inlet)?
- Some questions for wide-body people...
- Evap codes...intermittent..p0455 and p0442..thought gas cap but having second thoughts
- front bumper mod
- 'Break Lines'?
- Coolant question. After finishing the engine install yesterday, I topped up the coolant with
- Help identifying two leaks
- Heated seat problem 2001 S4
- 01 S4 runs perfect until Full throttle
- Now I know why so many S4 owners lose their lights
- 19"s are rubbing a bit in the front - already rolled the front fenders...
- Tech. question about gauge readings
- about to do first tb job in a week- is the tb referred to as "toothed belt" in Bentley? tia Doug
- Any reported problems with inner CV boots from ECS?
- One word...
- FATS: APR Stage 3 ver 2.0 file, A-Box, 25 degrees ambient, Full weight + 210lb driver + subs + spare
- Geniology & add-up of mods to date. I feel ill.
- What clutch for Stage 2+?
- Odyssey battery owners...
- attn: problem solvers
- How many hrs 4 transmission oil change? Stealership quoted $500 for oil&labour! find it outrag
- rust: anyone have any slight cases of it?
- Any idea which model these Mille Miglia 18" wheels are ? Offset ? They fit an 06 S4.
- Quarter panel side marker part number please. Thanks.
- 2.7TT Swap?
- HIDs flicker with hard accel or ABS coming on. I can hear a click like a solenoid or something.....
- hit or skip on ADR M classics?
- What VW was it? It was big I thought it was an A8 when I pulled up next to it but it was a VW.
- logged the car today and new personal best FATS !!
- Just did a FATs run - FAST!
- Getting my car chipped, good idea to get the diverter valves changed ??
- So I blew a turbo at VIR 2 weeks ago and pulled the engine today.
- VAST hybrid or Sout Bend FE clutch?
- Bone stock 335xi coupe vs B5 S4 stg3, 6th gear 38-100mph
- Feedback Needed on Buying an S4
- Name that part... 8D5 827 347. Anyone with ETKA have an illustration for me?
- Eucher'd! 10mm triple square - needed for engine pull
- Pic request: Fuel injector O-ring
- Yea, no record but I'm happy with 12.18@119.5mph:)
- So going to replace the stripped bleeder valve, I manage to drop the new bolt/washer under
- pricing on AutospeedRS6 Bolt-on Kit? Looking for price and included parts.. listed on thier website
- (For the Archives) Stripped front coolant bleeder valve = 2 trips to Sears
- Just replaced bulbs and my light pattern is fvcked. Please help.
- FATS: EPL custom tune, k04/RS6 2 passengers, ~40 degrees, full weight
- TB Adaptation failure
- Can you name them all?
- Fog Lights
- finally got the s4 running again, but have a question. I replaced the turbos, and started it up now
- i'm lazy, what's the ID of the headlight washer hose?
- I need lugs for 15mm spacers.
- How can you install the Rear Main Seal without the white guide tube?
- diagnosis: lost 1 quart of oil and half tank of coolant last 200 miles, k03 turbo kabloooee?
- telly number for kmd??
- Update on my dead engine (fuel pump) problem...
- What is AW's prefferance for a cone filter??
- Please Help!!! I can't get the air out of my cooling system.
- Paging Nick audi-os[asp v3.0+]....
- Anyone have any red samco intake hoses that they want to trade for blue, or black??
- Whats with stupid people....
- Car wont steer. Help...
- 335xi coupe vs B5 S4. first observations after delivery
- I have a local shop that is quoting $750 for a timing belt.. good deal?
- Another "how loud" exhaust question
- Can anyone run a CarFax on WAUGL78E37A252888? The 2007 is 'new', but way under list. Thanks!
- BMW content.. but can't get an answer on the 'bimmerforum'
- This is my first winter with Quattro. I discovered how great it is drifting in 2" of snow...
- Saw an R8 at the Fairmont in Vancouver, Canada last night - are they out yet?
- I just ordered a few parts from Brian at Avalon - GREAT DUDE, class act! Great to deal with!
- Made a quick model of this Voodoo MBC I have sitting on my desk..
- Took only 5 hours to pull motor and trans for the first time...although he knew what he was doing...
- anyone have a set of sport mirrors they're looking to get rid of?
- Location of Blower Motor Resistor?
- bling bling!
- Will 99 audi a4 trunk fit onto a 00' s4?
- Paging s4gasm..Your car is on Ebay
- ECS sells coils in a 6 pack LOL
- Removing Axle later today after work, quick question before I get down and dirty...
- Where is the fog light relay located?
- Paging Carson@Riverside. Idea for you! With all the water pump/roller failures, some people have
- WIDEBAND help!
- K-04s in stock at Achtuning!
- I have such a love/hate relationship with Audi. Just payed $25 n change for a gallon of G12 at the
- All you stage 3+ guys without turbos bigger than K04s. What gives you the +?
- Limp Mode - Want to help Diagnose?
- I just have to say, in this weather ,my car is running like a las vegas whore on meth!!!
- So lets see who has a good solution for my problem.
- how difficult is a PS pump replacement?
- No Clutch : Jason... You around right now?
- Snow and your lowered s4
- what tire pressure should I use at the track (Laguna Seca) running 235/35-19
- Might be selling my SSR GT7's
- I remember a post with all these Romanian babes. Check out the Romanian Tuner scene.
- Looking for the left trunk door. The one that covers the 6-disc player. TIA.
- Reliability: K04>K03. But how is RS6 or 997TT compared to those?
- friday poll: ugliest (relatively common) car on the road
- Who has 10MM spacers they want to get rid of?
- Is anyone running or thought about these? Sorry if repost started shopping for summer project
- test & tune at virginia motorsport park dragstrip this saturday 11am-5pm
- Sweet. Gonna need windshield replacement #3. This one has a hairline crack starting at the
- is there any market for stock s4 downpipes???
- aftermarket radio installed with Metra insallation kit, how the hell do you remove this thing?
- Does this sound like a bad synchro?
- repost- coolant leak/ oil leak questions
- During winter wheel change over they left off hub O rings on a few tires...
- ran through a giant puddle on the passenger side tonight. passenger side headlight immediately...
- is my cracked radio face plate easy to replace?
- For another question (yes i stfa)... if your car has a peak of 22 p.s.i
- Just another boost guage that i now found out doesn't match interior
- Anyone know where i can get a borla exhaust on sale(cheap)....
- Easiest way to swap pass side HID? Can it be replaced without removing headlight? Looks a little
- Where to find parts for factory ski rack....
- Anybody want to part ways with OEM rear rotors? SLIGHTLY used is fine.
- should I go with wheel spacers?i know it doesn't increase handling but will it look nice?pics any1?
- How many trans bolts are there 10?
- selling my entire nav setup if anyone is interested
- Is this the fuel pump?
- car is acting up
- Dealer only offered me $4000 for my car as a trade in.
- Suggestions on exhaust and coilovers.
- So off topic but did anyone look at the new Lingenfelter Z06? 3130 lbs. and 1,518 hp!!!
- Playing with N75 and new logs inside...
- and for the most n00b question ever... why don't you guys run 2 boost guages?
- Smoking Deal - http://denver.craigslist.org/car/493524805.html - beautiful Audi
- Need some feedback
- Alright guys fess up, ECS's top selling item of the week is Carbon Fiber Front Splitter Support Set
- Any suggestions for trim removal?
- I got a new gauge cluster installed under CPO today, its really weird seeing all the pixels!
- how hard would it be to change out roof rails?
- Out of all the S4s in the US, how many do you think are still with the original owners?
- Anyone ever removed one of the mufflers off a Milltek?
- POLL: who has done DIY K04 install / Clutch upgrade? Single most difficult part?
- :: ECS Tuning :: Samco Boost Hose Kits - Back In Stock !!!
- Coolant Temp Sensor warning light on after cam tensioner leak fix, any suggestions?
- New member with new B5S4 Avant
- I am thinking to offer my wheels and tires on A4 forum
- How to diagnose a bad fuel pump?
- Rip in my MAF hose.
- Remote car starter a good idea for our cars?
- S4 Wheel Fitment Guide?
- Just celebrated 4 yrs with a fun car....
- first VAST sale item....Borla 3" single exhaust. and piggie pipes
- To align the clutch do you have to use a clutch alignment tool?
- I just installed new euro style wiper arms
- Who has 4 oem avus's with tires they want to sell to a handsome guy like me.
- Stoptech 332mm BBK's in Stock. Call for GREAT pricing.
- APR Holiday Exhaust Sale Starts Today!
- More issues.. Possible turbolady? I love this car but I'm spending more time on AW than working..
- Any stage 3 guys have stock injectors lying around, that you would be willing to part with?
- homer j fong you ever find out if the oil lines on the rs4 were different?
- ASP Logs.......Can't wait for 100 oct.
- K03, K04 and Porsche 997TT extended tip compressor wheel comparisons
- Any benefit to running aftermarket injectors on a ko3 set up?
