- final 42 pics of asp fmic install.. I finally finished installing it yesterday
- can i use that flashloader on my S4??
- Someone please shed some light.
- what do u guys think of techtonics tuning downpipes
- Anyone NOT happy with the sidewall stiffness of their Toyo T1-R's? Coming from 40 series S0-3's
- RS4 front bumper intercooler vents.... I was curious about how functional they really are....
- Rear view mirror broken
- Those who have swapped out the defective (old version) of the CPP upper CA's >>>>
- Oil Starvation (Low Oil Level) ?'s
- autospeed im callin and still no answer lol
- Powdercoated S4 wheels??
- H7 vs H11 Fog
- $580.00 good price for water pump timing belt.. including installation.
- Can wheel torque be backed out like wheel horsepower? discuss
- Will our turbo's fit on an 01 A4?
- Is the expansion tank overflow hose supposed to be routed anywhere in particular?
- APR stealth for something more obnoxious?
- shop quoted me 2.5 hrs for fuel pump install : how hard is it to DIY? link? tia
- Transmission Whoa's....can someone provide some info....
- (2) stock B5 S4 wheels needed
- i need a bike rack..whats the best roof top for our car
- Need more toe adjustment in the rear, explanation inside...
- Friend's giving up his '96 2.8 A4 today
- Some more pics from yesterday's S/RS Drive
- Automobile July issue page 125 the R8 review....
- Fueling and FATS from 6.0 to 3.7... 7 fueling set-up reviews/comments
- RS4 Mesh Transformation COMPLETE!
- Vogtland Camber question
- After Run System vs Turbo Timer Question
- Paging El Empire...
- Zimmermann drilled rotors - Are they directional like some tires?
- Looking for a shop/someone to do my K04 swap in SW MI area.
- Is the offset of the rear rotors different for B5S4 vs B6 & B7 S4s?
- Some pics from yesterday's S/RS CT Drive ..... (bww) .....
- Many people don't know me or my baby.....
- Yesterday I ran a tank of 100 oct. with the APR stage 3 100 file and now I have a problem ..........
- Upgrade advice for 01 S4 Avant..
- How hard is to replace the line btw clutch master and slave cylinder?
- yay got my ghetto sig updated, mmm ms paint, what do ya think
- xpost to b5 a4... one shipping plug needed
- So I put on a homebrew Intake, but still no "whoosh" sound...
- Interesting 4th of July for me
- I get the S back on Wednesday. Stage 3 with AWE Fueling w/5 program ECU...
- I tried to adjust the high of my xenon headlights and heard something pop on the driveside
- who has a pic like this but of a silver car,
- DocWyte, nice talking S4 stuff this weekend. Nice car (envy!envy!).
- S/RS Road Rally Pictures .- . - ..- . - ..- . - ..- . - ..- . - ..- . - ..- . - ..- . - ..- . - ..-
- Anyone know if APR ECUx will work with MS Vista ?
- A few S/RS Drive pics...
- Anyone know how to tighten the doors on the S to eliminate sagging?
- Finally installed my PC'd door levers...
- blew 1st and 2cnd
- any Stage 3 S4's in LA/OC/SoCal area interested in a little GTG 2nite?
- Knee deep in S4 parts. Need torque spec for 10mm 12pt halfshaft bolts. ASAP!
- Cupla S's
- VAST Flywheel = Great, Custom test pipes = Crap!
- Stock battery died today...what are the replacement options?
- After about a year of down time, my S4 is once again alive... (Long, BWW)
- Paging EuroDrive
- Extra set of Phenolic Intake Manifold Spacers
- Calculations - I lost 20 Lbs with an Odyssey PC-925 battery today and that equates to
- 40 mins to go on ebay 01 apr stg 3 car, 88k miles ONLY $12k!!!!!!!!!!!!!!!!!!
- Rear brake caliper piston help - am i screwed?
- Want to keep a soft ride but improve the look and performance of my car
- PICS of port and polished intake manifold with bigger plenum and ceramic coating.....
- Well just got the S out of the back of garage and took it to get inspected
- My stock intercoolers are going in the trash tomorrow morning unless someone needs them.
- Well there's been some down time progression while waiting for parts...
- OK....fixed the visor....here's what I did....
- Nogaro spotted in WInter Park, CO....40 headed east. NIce car!
- Your help or info would be greatly appreciated....................................... ..........
- what have people done for wiring up an EFK ?
- Anyone have a link to DIY Inner CV Boot replacement?
- Changing Rear Diff fluid?
- Are any advertisers here a Kinesis wheel dealer?
- cel on for "cooant input level high blah blah..." manual says..
- Replacing Half-Shafts, Upper Control Arms, TREs. Any last minute tips before I dive in?
- If i used regular spring water when mixing 50/50 with g12 is that ok??
- Another "How Much Is It Worth" Thread - 01.5 santorin 6 speed
- how do you get a lug pattern to fit bmw or porsche wheels? i've seen a few pictures
- what can I use to pull my stereo other than factory tools?
- will an s4 chip work in an allroad?
- anyone we know?
- if iconoclast sold, then we want a MFBWW pic post as a memorial service
- Need Help. Does our car have a "maxi" fuse that is between the battery and everything else? The -
- MYstock S4 needs tune up and tires...im running sumi's ..suggestions on tune up parts and tires??
- lower front control arm / wheel bearing housing - will not seperate. need some ideas
- Can not log/connect to ecu with lemmi/vagcom when car is running only when the engine is not
- Highway pull on M3...
- Just about to purchase $398.67 worth of stuff for the S from PureMS. Was there a summer discoun
- Highway pulls with a FORD GT!!
- Who has a modded Bumper in their basement/room? <<RS4 Mesh Mod Content>>
- new Safari friendly link for genuineaudiparts.com
- whats the best intake to do to the s4?
- anyone need a stock S4 suspension?
- Paging Ram ASP...door latch fixed!
- PSA: check the o-ring on your fuel pump electrical connector
- Q: What does this connection go to...? (sensor near the power steering resivior)
- Is is a no no to pick up the rearend of our cars by the rear diff useing a floor jack?
- Paging Rayhalla re: S4 logo decals: status?
- Does EPL flash their tuning on the stock ECU or is there a chip soldered/socketed on?
- Ouch!
- Rare 2001.5 Santorin Blue With Alcantera Sport Package 53K Thinking Of Selling
- Need a samco f hose on the fly. Will pay over night shipping.
- H&R Coil-overs or Bilstein sport shocks eibach springs and anti roll bar kit?
- Allroad headlights
- CEL won't go away
- Just put on some b6 s4 wheels, opinions?
- NE1 interested in a set of AWE ICs ? very cheap !
- help needed , turbo woes
- Looking for your blown turbo's in jersey area
- Attn RS4 / Widebody guys - wheel set for sale - CHEAP
- GT2 vs Supra vs S4
- What's the deal w/ the silver (maybe white) APR bipipe?
- Some pre-weekend car eye candy **comments welcome**
- davenew get tuned! that is all
- Finally got to use my radio removal keys
- where to buy vorsteiner carbon hood?
- ABS Light and Brake Light came on and off..I guess the.stupid ABS module is going bye bye...oh well
- Paging SreetCrawler(Cole)
- Best price on a Bosch MAF sensor? What's a good price? Also, can I just buy the insert or have to.
- AC compressor not kicking on when putting temp on LO, what too look for beside compressor failure?
- imola yellow s4 in beachwood cyn. always see you driving, love your whip!
- STaSIS Garage Decor
- People with lightweight flywheels, I have questions.
- How difficult is it to remove one of the exhaust manifolds?
- need more camber/toe adjustment in the rear. maxed out stock adjusters already, suggestions?
- Noone thinks it would be nice to have driver adjustable suspension in this car huh?
- Rear license plate holder (avant). 3 out of 4 screws/clips broken. Dealer requires full part replace
- "bolts in a blender" noise at front of engine....W Pump/Pulley? Not safe to drive?
- Stg 3 Tip Question - Has anyone went stg 3 with a stock tip until it failed...
- anyone here ever homebrew with MTM stage 1/2 software?
- Does anyone know about the Stratmosphere Stage II kit?
- newb or noob \'nub\ n...............................................
- What are KO4 cars getting these days?..if you take 50% of mods my car is between $23-25K
- Man my car is so much faster with this new light weight Odyssey 925T!!!
- I haven't posted much over the last year, but I must vent. When is Audi going to pull their
- How difficult is it really to find an '01.5 with around 60k miles for $17k?
- Help, A/C not blowing cold air at idle, normal or do i need a recharge? Works great under load...
- Front left wheel bearing: DEAD (that's what was making the terrible noises in turns)
- Anyone have pictures of the Sportech modded airbox? Already STFA
- Vogtland vs HR - I have HR/Bilstein combo on 2000 S4. This setup is rubbing like hell.
- Testdrives.... E46 M3 vs chipped Skyline GTS-t vs Evo III vs Stage 1 B5 S4
- Recommendations for front brake rotors......
- Anyone using an Odyssey PC925 with a low-temp fan sensor? Wondering how it's held up for you. -
- Crying about achtuning RS4 K04 Turbo Upgrade Kit
- paging brian@avalon!!
- who can get me a cf hood????
- Less than 24 hours left on some NEW, hard to find OEM RS4 items...
- If I switch my AMS box out for an MTM Stage II, what kind of difference would I notice?
- Any used AWE intercoolers out there?
- Clear coat or no with S4 caliper logos made by Golfrsi?
- I'd hit it (youtube video).....
- S4Bum....where'd you get your RCCR tails? Just curious..
- Has anyone done an Allroad suspension setup on a S4?
- having problem downloading the right software!!!
- Can this oil cooler from pureMS replace the stock one? Mounts in the same place
- pictures of SPAL electric radiator fan install
- Is the stock sway bar worth anything to the A4 guys? I have mine laying around and before I throw it
- New BMW 135i looks fun: 300/300 hp and torque.
- Looking for used K04s anyone know any sources?
- RNSE Experts.... ???????
- A4 Avant 1999 Tranny Problem?
- Paging Stage 3- Cars - Anyone running stock exhaust on this setup? Post your exhausts please.
- anyone nned to buy new bumper shocks to install an oem rs4 bumper?
- Ravelco will be doing another round of installs @ EPL late next week...
- any1 know the differences between s4 differentials? axle codes?
- 10:30 and already 109deg outside. Still didnt stop me from taking the guy in the new M5 down...
- 10 steps to tightening all four fuel tank strap bolts after a fuel filter replacement.
- Thoughts on the new MB C63 AMG?
- Front Mount Oil Cooler Group Buy
- "its a bad look for the girls, they get in the car and always want to look over and be like:
- B5 S4 roll call: ACNA Mid-Ohio Driver's School this weekend.
- killer deal on an exahust in the classifieds (not mine)
- Friend from atlanta GA was driving my car in Benton County MN, got pulled over for doing 83 in a 65.
- paging rktskicar
- Porsche has some tech on their new 997 turbo that varies the angle the compressor wheel vanes...
- Paging Stage 3- Cars - Question about K04's and running stock software.
- Boost tuning question: in 3rd gear, boost peaks around 16 psi, in 4th and 5th, it hits 22+psi
- Non-OEM oil cooler: Has anyone installed one?
- Anyone have a good front Bilstein laying around?
- Quick question - piggies any different for a sedan vs an avant?
- PSA : It is now illegal to sell a stg3 S4.
- Let me try this again...could someone PLEASE PLEASE tell me what the cam bearing tq specs are!?
- Got my STaSIS Street Sports and Superleggeras on last night... in the rain :)
- I drove a blown CTS-V with my roommate yesterday. WOW that thing was fvcking fast. His delima is
- paging sj6sp, had some questions about your exhaust.
- Anyone know of a Euro rear bumper for sale stateside?
- Is anyone on the board selling a nogaro with sport package stage 3 M6 with less then 60k??
- Lambo wheels?
- Broken passenger side window
- Simply or someone from WMS please contact me. Thinking about ASP FMIC kit and will be in cali.....
- Best place for parts
- how many guys run turbo timers???
- If only the engine hadn't blown...
- here's a funny one about a cig lighter
- For those that are stage 3, question....
- Opinions on c55 mb???
- No wrnty booo
- Can I rebuild my ABS module myself? Or do I need to send it in to a shop?
- Those who are using Motul Dot 5.1 and have bleed their clutch slave??
- whos has the evo intake and the v flow which one you like better?sound?
- On-line registration is now open for VAGKraft 2007
- suspension upgrade
- Anyone want to trade my auto stage 2 b5 02 s4 with 72xxx miles on it for your manual b5 s4?
- 6 Speed Tranny.. anyone need one?
- Anyone ever had their oil pressure sensor or oil pump go bad?
- Feeler: 19" iforged swifts. Black with Chrome Lip, 1.5" lip front, 3.0" Lip rear
- Falken Azenis RT 615s... Anybody running 'em?...
- welp. bought "new" halfshafts. "made in china" <fingers crossed>
- New tot he game
- anyone know the size of the oil feed compression nuts?
- I put her up for sale and you know what happens?!?!?! NOOOOOOO!!!!
- just got some new headlight bulbs, and after a few days, that bulbs flicker!!
- Does GIAC haved fault code erase when running DP's on Stg II+
- quick picture of DS valve cover. Is the black something I should be concerned with?
- "Chemical Decarbonization"
- Cheap/fast place to purchase Control Arm bolts/nuts "kit".
- After putting in new upper control arms one doesn't need to perform an alignment...right? IIRC its
- Anyone know of a cheap fix for this?.....
- I finally did it last week:
- Day 5 with the S4, first and 2nd CEL in one day... haha...
- Who is good at google? I really want these wheels I can not find them anywhere....
- TRMotorsport MT1
- X50 smart cord install ideas needed
- Oil in coolant, No smoke whatsoever, no overheating issues, possible cause?
- Paging s4orce.......Do you have pics of your mesh s4 bumper yet?......post em
- In case anyone is interested, the iPhone pairs perfectly with my Pioneer Avic Z1 Nav sys. Yay!
- Just did K04 stage 3- with AWE dps and GIAC - turbo lag ??
- anybody know the torque specs for the cam bearings??
- Anyone have August Union Wheels?
- Got passed going uphill by a 335i. 6000 ft elevation. I'm stage I. I need DP's...
- Thanks Al and CPT crew!
- Have any of you seen this fault code before?
- poll : CF widebody front fenders I CF hood I recaro : which one would you pick?
- How come there are no white S4s to be found anywhere?
- does anybody know the website for that guy at staten Island, is something like s4ny.com
- Ok i finally got the damn tensioner gasket out, new one in...however, cam doesn't want to seat now..
- APR EMCS home programmer questions
- What the hell is going on here?
- Something went on my suspension after a little parking lot 4-wheel drift. (semi-long)
- can somebody look up a p/n on etka for me?
- those with 3 ich Dp's what size are your flexpipes and where are the cocated compared to stock
- Anyone know if the new ASP FMIC will fit a tip? Im concerned about the oil cooler as well.....
- How many quarts does our radiator hold? not in the manual. TIA
- Anyone successfully running South Bend Stage 4 or 5 with Fidanza flywheel without issues?
- Trouble fitting RS4 grill in the CF hood. Any ideas or approaches I am overlooking?
- Need some assistance-
- FS: '02 Avant Tip...
- Compression test: Warm or cold engine? Dry or wet?
