- I just STFA. I need to know how to remove the rear door panel. Window won't roll up
- To fix or not to fix: please help me decide
- STFA, info needed about Garrett cartridges in K04 housings, from turbos.com
- i think we should change the forum header to a shot of Kenobi's car, i know there
- Moment of silence requested: O.W. Kenobi was killed last night in a freak crane accident.
- Boost problem / I continue to have problems with boost, recently installed
- Anyone offering deal on AWE twin 1 or 2 now?
- Awwwwwww snap guess who's coming home to dinner?
- Are T boxes compatable with M box Cars?
- My email is down at the moment if anyone wonders why they haven't got replys over the past
- the little things that you can do for better shifts : )
- For those of you who know how to play with FATS....
- So if I plug in a stock ECU will the dealer be able to tell I ever ran a chipped ECU?
- Can you mix leaded gas and unleaded gas together?
- Lets talk about Injector Duty Cycle %age being over 100%.
- VAG LOG instructions needed for an Adult with ADD...(no kidding)
- coolant temp/gauge problems... help please:
- Who had the picture of the Euro S4 that had 1/2 tan interior?
- thought I should post this here as well as the B6 A4 forum....
- Auto Dimming mirrors?
- Finally put in a boost gauge and I buthcered the vent with the dremel and clippers..
- Replacing Control Arms
- Downpipe install done--ish. Flex joint problem | PLEASE ADVISE
- can anybody email me a list of ASP products not on website please
- Which A/S tire would you go with?
- Drove the S4 828 miles last night.(my review)
- If you had a D2 S8 (1997-2002) with an RS6 motor and a manual trans (B6/B7 S4, B7 RS4) which turbos
- Where can I buy the upgraded metal pipes to the TBB? I've got the stock hard-plastic ones...
- Will a colder spark plug help me with pinging? which is a good colder range plug?
- alright, i'm serious when i say this, i'll trade my NIB PS3 for a stg3 b5s4
- Clipping Wheels on Stock Turbos?
- so lets talk worst case scenerio here.. multiple holes in the oil pan.. what needs replacing?
- 2 tires blown out
- Anybody going to E`town on saturday for the racewars?
- Are the upgraded Audi BPV valves everybody calls the 710s reffering to the Audi part #?
- Can't Bleed Master Cylinder- What's going on here????
- went to the drag strip tonight.. 17.1 @ 99 and a 17.6 @96
- Any ex-VR6'ers who can help me out with this POS?
- Yes, I would drive this to work. Damn it is the sweetest sound ...
- Just purchased two used KO3's what do I need to do to make them hybrids?
- Noob question KO3s and oil inside intake lines going to the ICs...
- Newbie here, 2000 S4, 45K Black/Alcantara White... A few questions
- It sounds/feels like I have a boost leak in high RPMs, but my gauge shows ~same psi levels....
- SO wish the S4 could do this..
- Carrera Gt vs. Procharged c6 zo6
- S-flo and Valeo wipers ordered for the car today...
- Oil test after blown turbos
- Looking for 18s for my black avant but can't find anything decent...what do you think of these RH's?
- Where can I buy a replacement for the front license plate cover, i noticed today.......
- I love my cats.
- Any tips on replacing Lower Rear (curved) control arm (driver's)?
- Another Poll: Yes or No. Does the person who starts the poll skew the results in ANY way?
- :: ECS Tuning :: ECS RS4 KO4 Turbos and Complete Kits In Stock !!!
- Turbo pre-install questions- Alright guys. I am going to install my new turbos, etc .next weekend...
- Can't get car into gears.. and ideas what the problem is?
- Engine Oil BT:
- VIN decoding; can I tell if an S4 is 2001 or 2001.5 by VIN?
- Pol(e)l: All things being EQUAL (mileage, mods, etc) would you rather own a B5 S4 in Nogaro or Casa?
- wheel liners
- test pipes
- Oil cooler
- turbo lady strikes again....
- turbo lady on the cover of network computing magazine...
- My first Oil Change?
- Is it bad that ive been running stock DV (w/stg1) with a massive leak for a while?
- Is there any chance a Level10 car can handle a GT25/28 kit?
- Repost: EPL "OTS" fueling kit introductory special!! Now thru Thanksgiving.
- POLL ==> Pick your B5's factory specs again: what color, body style, transmission and options?
- Any B5 S4s in NE Ohio with a spare ECU? Car was towed because the ECU died.
- Door sags a bit, about 1/4 inch from where it needs to be, anyone else face this problem?
- AWE Tuning has a limited number of pre-owned S-Flo kits available........
- Is there any better driving album than "Tweekend" by The Crystal Method? I think not.
- Paging S4poor....
- anyone know about Tyrol sport in ny?
- used hp-2 calipers?
- Test and Tune, this saturday at sacramento raceway...
- HELP! anyone have a S4 video that you can really hear the turbos in..
- What happens if I change the FPR without draining fuel pressure first?
- While we are on after-run coolant pumps...switching back to standard temp sensor
- toyo proxes 4,has any one ever used them in the snow ?
- So im narrowing down parts i need for N20/CO2 ic misters and....
- wow! just realized craig lieberman is sporting B7 RS4 and advertiser on AW
- Are there any dyno numbers for the Autospeed ecu tune yet? (stage 1/2)
- Got the after run pump leak, ok to run it?
- I'm about to give up on this thing!!! I can't figure out my boost spikes <long recap<
- Placing parts order for aux coolant pump replacement.. want to make sure i have everything...
- A lot of sleepers across the pond and a RS4 running 14 second quarter?????
- Why do I have S4 parts in nearly every room of my house?
- Going through my PicPoster, tells me I REALLY need to clean my car...
- w00t. Timing Belt parts from PureMS.
- would this keep up with an stage III
- does anyone know of any track days?
- Possible to tighten the driver side turbo coolant feed line with the motor in?
- ECUX Updated Logs
- What would be a reasonable but not wimpy boost level for my stage 3 w/o aftermarket I/Cs?
- Pictures of B5 A6 BBS oem wheels?
- It's time for another game of "What is wrong with my car?"
- anyone know how this dyno...
- which chip to use
- POLL: best high performance all season tire?
- is today's woot.com the ultimate VAG computer?
- Are OEM light housing (with amber insert) worth anything? I am considering getting e-codes and
- Ooooo, the rare and illusive 5 speed...
- Oetiker clamp sizes: which ones? I want to make a spreadsheet of all hoses and respective
- S4 clutch issue...any ideas?
- noob question how to unplug ecu ? thx
- how the crap do I unplug the MAF...it looks like its clipped in but I can't get it undone
- asp stage III graphs... maby a tad rich, what do you think?
- thanks for the advice
- boost question...
- anybody have grey leather(heated) front seats...
- new s4 owner: need advice modding
- Anyone from CT????
- Ok. Headlight Washers work but my Windshield Washers dont...
- Anyone interested in trading stock floor mats for monster mats (with S4 logo)? Black interior
- White alcantara onwers:
- X-post from forced induction forum RE:zero clearance logs
- Logged some 115's... does this look okay for Giac X?
- 2001 S4 Avant w/ 110K on it good deal? Has 10K left on warraty
- Sale on PSS9s
- So...I'm thinking of scaling back on the Avant. I had big big plans for it, but I think I'm going...
- guess what I got in the mail today?? Hint.. K04's,,
- awesome t-shirt designing website (S4 content)
- Need new tires - Any recommendations for stock wheels?
- B6/B7 S4 Seats - Anyone successfully install these? What's the process?
- Rear fog light.
- poll: who needs new control arms and tie rod ends? for the people
- Sportec Monos With Question!
- Pol(e): For those that have had issues w/ heated seats.... please respond *edited*
- Brake fluid
- Euro S4 transmission question and center diff question.
- RNS-E - Question for those who have, are considering or have passed on it due to the gaps.(editted)
- poll ! N249 . remove, or leave alone .. ASFA with no hits
- looking for a diagram of how fluid gets from the reservoir to the windshield squirters...please help
- Green plastic piece (i think window guide) on passenger front broke....
- sweet mother.... OMG
- just to confirm: you can use a VAG cable with APR's ECUx correct?
- coolest turbo EVER
- coolant under intake mani & leaking fuel injector... need help addressing these issues properly.
- Boost Problems Giac-X (long)?...>>>
- Help - late night dilemma - rear brake pad change...
- Anyone catch the S4 on Redline TV tonight??
- ECUX logs, feedback please
- What is this?
- Dialed boost down to 10 psi and running on target for fuel now...
- Lightweight Pulleys...looking for input
- PSA: VAST is a great company with great products. There clutches are very nice.
- Almost.. there.
- **11/14 Update** (LOTS OF PICS)
- Thompson road...stage 2+?
- Anybody got a 2000 6 spd tranny for sale? Saw one in the classifieds...
- So will the oem M3 trunk spoiler fit our cars perfectly? bro is getting CSL trunk and...
- Popping off Lower Pass IC Hose = Scary. For a moment I had flashes of K04's until my brain told me
- custom plates
- Weird Idle
- C5 Vette Z06 can I take him if I am running about 3.3 - 3.4 fats? Last time I raced on pump
- Clutch Identification?
- Just one more attempt, does the returned Ignition Timing include CF's?
- $300 a good price on Febi upper control arm/tie rod end kit?
- Tranny
- Homebrew graphs with airbox now.. 7% primary pulled... better.. still need some help..
- LOL
- Used K04 Turbos... hit or miss?
- Lowering springs
- S4 PARTS
- autospeed gt28rs kit
- ASP Stage 1 with Stock exhaust(w/ no rear muffler)= SANDBLAST...This is normal right?
- If i bent a rim in the front and it vibrates a little, will rotating tires lessen the vibration?
- caught one of the nj car thieves in the act
- What is OD of ASP 85mm MAF housing where it fits to the airbox? Thx...
- Please post your Borla soundclips here
- Has your jack ever failed-please visit
- Great deal on an RS6
- Well, I thought I could get away with 1bar on stock fueling but looks like no...
- RS4 oil cooler fit on a Tip S4?
- Two small red lights just ahead of sunroof dial?
- ECT G62 Sensor: Bought from dealer for $31.82 is this price correct? Or did I....
- Replaced brake switch twice, ESP and ABS lights still come on....help?
- Does pagid make front and rear replacement pads for OEM calipers.
- Does the bmw rob knob work on our cars? If not anyone know where to get the rob knob II used?
- E46 M3 Turbo 11psi 603rwhp (Stock Motor, Stock Exhaust)
- Seeks SW comparo: AWE/GIAC Stage 3-, APR Stage 3- and AMS Stage 3- (Stage 4) on 91 Octane. TIA.
- Moved from R32 to B5 S4 (driving impression/pics/questions)
- X-post - Trouble after installing intake spacers in my A6 2.7T
- How should I know what APR ECU version I have installed in my ECU?
- Heated mirrors?
- Couple of broken missing parts...
- No tuff guy, nor was i really that mad. lol just figured id push the buttons a little bit.
- Newbie here...just bought a black b5 s4 6MT
- Anyone with Navi-C for california? Does not have to be the latest one..pm me please!
- Anyone else here disappointed by the ASP GT28RS S4's performance?
- Has anyone used one of these mobile wheel repair franchises? I'm a little skeptical about any mobile
- LM-22 or LM-25: which is the better winter tire? For getting through snow that is, not performance
- What's more rare, a Cactus or Casablanca 6spd Sport Avant?
- Best place to get E-codes with ballast & lights?
- Anyone have an idea of what a 06' GT35r sti would in the 1/4 ?
- Mirror's don't adjust via power.......
- drivers seat heater very slow to warm - bad element??
- woot.....Mammy is Open!!!
- Wet braking delay with Hawk HPS pads - anyone else having this problem?
- Offset for 18in Rims for B5-S4 to clear Brake Calipers?
- Poll: When you step into the office and jump on to Audiworld who do you expect/know they will be on
- s4florida or anyone else who has any info regarding this intercooler plz chime in!
- Teaser: Pic of my "Wicked" little Piggies
- Avant Drone and Dynamat insall/impressions.
- Replacing rear main seal
- 2001 Hibiscus S4 Avant...Its TIP, but still cool...
- Wow, here's a treat..
- Aftermarket Warranty buyer beware post: I just received a card in the mail soliciting business for
- URGENT INFO ON BRAKES PAD
- Car Problems
- Was looking through my pictures... thought I would post a few.
- Whose Casa tonight w/ gold wheels and a slammed stance tonight in SLO...?
- Paging SHOOZ888...you've got mail. (sorry for this everyone)
- I have a Twin1 & piggies will i pass emissions? i was thinking about it the other day &
- 2KS4's car seems to be running scary lean. Lets play guess the culprit
- I can see how jack under breaker bar works for right side caliper bolts, but what about left side?
- oops...kinda broke my remote...now it wont stay together...does anyone know if the remote
- Video: Tuned B6 S4 vs Vast's 4.2 A6 w/ S8 Motor and 6-Speed trans
- More car problems- engine rattle
- Nice video of a Stage 2+ Tip s4 vs a cobra a lot of runs
- Remote not working --occasionally
- Call me crazy but I think I will be taking my chance with this ebay IC
- !quick! cold oil level on 2002 b5 s4??
- EVILEMPIRE You have mail.
- Wow, what a difference tires make. I threw on my winter setup (17" Nokian WRs V-rated) over the
- Did not know that 2.8 Avant could be that fast
- EPC light on a GIAC-X flashed ECU -- does it still limit performance?
- who sprays NOS??????????
- All day detail and claybar before winter 2 pics. Sorry for the size
- Know a good place to find some JE or Mahle pistons with a .040 overbore?
- Is this a fair price for my S4?
- What happened to the detailed Catch can install write up? Does anyone have a really good write up
- How much brake fluid should I order to do a front BBK install (for the bleed)? or should...
- Having some trouble with ECUx. Help please...
- APR stg3 kits on sale for the holidays!
- Where to buy the S4 logo trunk and badge logo?
- Audi S4 avant S6 dilemma
- Rotors off of ebay?
- How about an update on the Evolution Racewerks SMIC's?
- so If I am Abox and I got my Abox recoded to Mbox, i need to go into...
- Got some great news from our Socal Boy! *OC Avant*
- cluster change???
- esp, ebc, cel intermittent...throttle cut ...only when hot...clears up on own ...ideas? tia
- Old video I pulled up on the web, while searching for Volk wheels(non audi)
- I need to replace one tire, do i really need to replace all 4 of them? or just the other side?
- anyone have any experience with neons?
- Any ideas on how to polish up the stock exhaust tips?
- Replacing front two Potenza SO3s
- Where is a link for FATS description, I am trying to put something together
