- "Surging" boost problem....
- tried the zip tie mod but I still have a lot of slop in the shifter forward and back when in gear
- To those who have gotten new head gaskets...
- Shot in the dark but does anyone in the NY/NJ/CT area want to trade a spare stock ECU for some..
- So after deciding which rims to buy, i made the choice and put them on for fit. Cant wait till the
- Product of the day - Turbo sound without the turbo - AWESOME DUDE!
- would/could seafoam help whining turbos?
- Forum is slowing down big time. Any word on Tial or ATP Garretts? 2 Weeks?
- Classifieds Garage Sale: Three piece wheels and MTM ECU (All reasonable offers will be entertained)
- Thinking about ordering 19mm Neuspeed Rear Sway Bar, is it worth it w/ stock suspension...(more)
- EGT wasn't as hard as I anticipated. Its like a new car again! Little hard on a TIP cause of the
- CT Implosion
- which is rarer...
- What do you guys htink?
- Who has installed 034 Transmission mounts on their S4?
- Does anyone know where the hell I can find this shirt??? TIA
- ne1 have a Hitachi MAF electrical connector?
- how much wood could a woodchuck chuck if there was 9 inches of snow and he was only 2 y.o.
- sub 100000 uid back in action!!!!!!!!!!!!
- Dumb Question- I have a T-box with ASP code on it (K04/RS6). When I Vag it it shows up as an M box..
- Maybe repost: Read today that Audi is thinking of producing the R4, might be suitable replacement..
- Poll: Who here plans to buy the r8?
- Is this a healthy spark plug?
- FMIC Fitting Issues..
- home programmer won't allow me to load M or H APR stg3 software to my A box..
- Is this car an M box, based on vag scan and build date 10 00?
- does anyone make a lighter wgt dual mass flywheel?
- P0421,P0431 Cat Efficiency Codes with APR software
- Holy shnikies. Please welcome back UID # 69223. As an olive branch of peace, here are pictures...
- RAM WHERE ARE YOU!?
- First time filling up after AWE stg.3...815 miles to empty. I thought this issue had been addressed.
- Stasis 4:1 torsen diff (new installation), car vibrates +4k RPM
- ASP stage III guys... help... what spark plugs are you recommending?
- wich intercooler is better oem rs4 or apr?
- TASO TASO TASO
- What does the Lidatek sound like when it's been triggered? Just got hit by something, and not sure
- This is what happens when your Bipipe is not properly installed...
- ANyone have a link for the rear door window replacement procedure?
- Is there any way this can fit?
- Stock springs + bil struts up front...how much drop am i looking at?
- More AWE stg 3 logs with some tweaks... Need some input please...feel free ;)
- Now considering coilovers Stasis/streets good for dd, most bang 4 the $$$?
- Attn: DFW 1-20-2007
- Does anyone have a cam locking bar I can borrow? Or know where to get one for a good price?...
- Anybody hear anything on KMDs new shop?
- My 2.7T starts up and immediately shuts down....does anyone know from experience what the problem is
- just received a set of H&R 8mm spacers BUT....
- Turbo Lady sings:(
- walk out to find my car completely dead. last night as i was driving in wet conditions
- s4 coilovers fit a4?
- whats ur avg MPG?? im running 23.5 over a 1.5yr period
- Seafoam treatment planned after reading post below. First time...any tips/suggestions?
- Does anyone have the link to fixing the time issue on the RNS-D Navi's. I remember
- anyone blacked out there headlights? any pictures? what do people think??
- Stasis Motor Mounts vs RS4
- Temp AND humidity make a nice difference. 3.30 Avg FATS in 26F, 55%Humidity. That is all.
- would my car run with a M box ecu plugged in?
- Need to cut a hole in an RS4 acordian hose for the BB
- 2.8 heads
- keep getting fault code w/o a cel...16826 - EVAP Emission Control Sys: Small Leak
- Told-ja
- question.. ne1 try to pdf entire Bentley manual w. 3-day $19 subscr.?
- Been suspended? Want your old account back? AudiWorld® AMNESTY Announcement!! ---->
- Blackstone oil report says coolant in the oil is the cause of the sludge, now....
- somebody backed into my car and ripped off the left washer pump bumper cover
- Imola Soul-Ja Tech Post - Fuel Pressure Gauge Quik Disconnect For $50 (USD) <Edy Jun Alert>
- Anyone have any helpful hints on removing the alternator pulley?
- 19x9.5 et32 bbs lm, will these work on the back of our cars?
- Will these fit a B5 S4 with no problems? Also what size tire is a good size to mount these on TIA
- Can someone confirm that the injectors awe is shipping now are green giants? Volvo r injectors?
- Anyone found any OEM crystal-clear side marker lenses?
- I just spent an 1 1/2 changing my spark plugs because I had a misfire code come up on the VAG replac
- Holy smoke-screen Batman! Did a SeaFoam treatment today for the first time.
- How do my heads/cams look ?.. I pulled my valve cover to try to fix Misfires and rpms fluctutation
- What are the odds it's still good...
- REPOST? Simpply might be interested in this
- whould a 1998 b5 koni shocks fit a 2001 audi s4 b5 body?
- any body has koni shocks and springs?
- Okay i'm fed up, jacking points etc. New 2 ton+ alum jack etc what are the secrets!
- Ceramic coat exhaust manifolds when going Stage III or not?
- P0421/16805: Warm up catalyst efficiency below threshold, bank 1...
- carbon fiber hood...need advise
- Are many people having Airbag ECU failures lately?....
- anyone know where I can get a Fiber Images hood for a good price or anyone selling one?
- Paging: DJillusion & other problem AWE stgIII's... about to take car out to do some logs....
- Anyone know if 19x8 ET40 will fit without problems? Looking at wheels for Avant thanks!
- ECU X please help... APR said good luck Ben is not here until Monday!
- Help - RS4 clutch install questions...
- just sold my used stock wheels w/tires for $1000 to my local vw dealer :)
- My first VAG
- Any one using larger intercooler to tb pipes?
- Do you have similar VW temp sensor issue?
- Any of you kind ladies or gents live near Inskip Porsche in Warwick, RI?
- I'm heading to the NAIS in Detroit this weekend. Anything cool up there to see?
- need help : just got my car dynoed (apr stage 3).. need to compare #'s..
- Finally, with 6gal of 100 octane, and X-Chip, under WOT I have sand blaster!
- headlight bracket fixed.. but we'll see how long it lasts.
- Who else has a love /hate with the S4 car? (kinda long winded)
- **Revo Technik welcomes Greff Motors of New Orleans LA to our Authorized dealer network**
- anybody have an exhaust upgrade but no chip?
- Help bleeding clutch please!!
- Question Regarding O2 Zoldman Sensors and Piggie Pipes
- The VEYRON of Short Shifters ,I just found the shifter of all shifters........
- Stg. 2+ on hwy vs. e39 m5?
- What effect does adding/reducing timing have on gas mileage?
- I think my wheel bearing is starting to go...
- not to nit pick a good cause, but the OWK bands are more Santorin than Nogaro.
- Newbie Question: P0431 CEL Code
- Has anyone seen any gains with 2.8 heads? I can get 2.8 heads for a decent price just wondering if..
- How can I get a third party VAG cable to work properly? (more)
- What maintenance does Audi recommend at 40,000 miles?
- Just saw a broken down 335xi on the side of the exit ramp. Made me chuckle.
- Any Bilstein PSS9s here? I have a question about the adjuster knob.
- Who was it that was looking into re-using a Euro Diesel bottom end on the 2.7T ?
- Brake Pads
- Price for EGT sensor went up $100 in the past week at ECS, anyone know a good place to buy them now?
- Does anyone know more about the flares/extensions on this widebody
- What's a good asking price for a Phatbox these days?
- need ko4's asap....someone or some shop help
- Video: E90 3 series with E62/63's V10.
- Folks that know what LTFT is and have checked their LTFT, difference between b1 and b2?
- MAF? stock vs. ASP
- All set to go to 3-, but .................................................. .........
- Surging boost
- I've STFA but did not find a definite answer, are the B5 RS4 seats a direct swap with B5 S4 seats?
- is anyone running buehn's stg 2 full rs6 turbos? anyone have more info?
- Can you zero clearance any turbo?
- my first FATS, pic inside, what do you think?
- Pearl S4 Sedan (tip) with Texas plates in Philadelphia (East Falls) you here?
- PN for black plastic trim piece around hazard light switch is 8DO-863-321-B98
- aftermarket body panels
- Thank you to AWE - and a public apology to AWE and Todd/AWE.
- So if you get bad service from an advertiser & complain about it here it gets baleeted???
- Awesome!! WTF is wrong with this thing?.....hypothesizing time (timing related)
- dano, i contaacted you first about X1 will you sell it to me? whats the verdict from the other post
- so i need to replace the entire coolant pipe that goes across the back of the motor
- Short shifter or stock??? Any Ideas
- What have people replaced there blown worthless bose speakers with? Aftermarket ideas??
- Some rich kid with a 2002 CLK 55 AMG wants to race me from a dig, think i can take it?....
- STaSis Tracksports on Ebay, ending soon...someone grab these!
- Which one of YFFs were at the Great American Diner and Pub on 413&Bus Rt 1 tonight? Silver S4
- Clutch won't disengage...besides slave cylinder, what other culprits could there be?
- Fark. I'm cleaning out the avant & find out the spare tire is missing. :-(
- Where is the best place to buy RS4 Airbox, Y-Pipe, and.....
- Just bought a flased m box, it was flashed by awe in june 2006...is this
- What happens when you have Giac x with 91 oct and put in 93 oct???
- Ram@AutoSpeed is on a ROLL tonight..... kudos man kudos
- I have this strange red spot that seems to be growing.....on my temp display for the ac/heat...It
- Look what I got today...........
- Any idea how to remove ESP on my S4...
- she left me stranded...
- Blackstone Oil Report just came in, everything is perfect! = ) That is all...
- Any gains to be had with RS4 intake cams on an APR stg3 car? What do you think?
- has anyone taken an oil cooler apart? (the block that the oil filter attaches to)
- A new stable mate to replace the S as a daily driver.
- APR STG3 software 4sale + RS4 intake Y + airbox + ECU
- Dropped the car off at VAST yesterday for full Stage III. I can hardly wait to get it back. Also
- Audi RS4 Reps on a noggy? 1. Hyper silver or 2. gunmetal.
- Maybe ASP can sell ecus with emcs features..
- Quick question: On which side is Cylinder 4?
- August Werke 18" wheels
- I'm not very happy about this code. No! Not the AIRBAGS!?
- For those with EGT codes... change your EGT sensors now!!!...>>>
- Parking on a steep incline daily, better for engine to face up or down the incline?>>>
- Oil leak question/problem [PICS INCLUDED!]
- I got flipped off again. I think it has to be S4 envy. <long rant>
- Frank wants to show you his new drill, lol =)
- Fidanza Flywheel - 9 stud vs 10 stud variants...
- The truth about engine oil...(must read)
- Those with the 50w Xenon upgrade, a few questions
- One last xenon bulb question....
- Black S4 avant 6 speed for sale on ebay - relatively low miles
- Flik FTD wheel??
- Been thinking about selling my car. Someone convince me that Silver is better than Nogaro.
- Say I had a much-sought-after item, e.g. an X-1 intake. Should I sell it in AW classifieds or eBay?
- NE1 have any RS4 wide-body parts in stock ???
- Best option for a replacement battery (already STFA)? OEM (dealer) wants $150, is the...
- Where to buy Pagid Blue (4-2) Pads for the stock HP2 calipers?
- Some 997RSR info and a new team intro.
- wheres the best place to pick up the engine
- Toy Guy zip tie mod FTMFW!
- Paging KOPORK...ygm
- Throttle cut (or something like that) with APR chip?
- Does having an ABS controller in need of rebuild affect the connectability of Lemmi + VAGCOM?
- We had a great time with another Fellow AW'er from Alaska!
- BBB posts everywhere!
- Holy cow what a crazy morning - my S4 almost gets taken out by a Ford Turd -
- What would be a reasonable amount of $$ for a used RS4 bumper in exhange for a stock S4?
- What is it with our headlights twice now I've been putlled over by cops, who say they are to bright
- which blocks should I log to fully characterize my current fueling setups?
- The supercharged RS4 in the new eoropean car looks nice but...
- Miles Per Tank on 93 octane???
- PSA: When doing your timing belt, use all the tools to do it right. FATS improved by ~ 1 second!
- I finally got busted for "not front plates" 1:00 AM last night.
- a couple of folks asked for an update on Cactus ASP GT28RS.. (long, nothing exciting)
- what kind of fueling set-up do i run
- working on this at my shop.....
- Question/Opinion: Audi RNS-E or Pioneer Avic-D2? Each have their ups and downs...
- best all season tires for stock avus wheels? I have kuhmo ecsta now, not bad but curious?
- All you guys with custom Tuning. I have a question.
- Poll: Do you view AW threads in the collapsed or expanded view?
- What happens when you want to go widebody but the wheels you want are not available...
- Could someone help me find the guide for the right angle/spacing for shifter?
- New Tweeters didnt fix bad front left tweeter - Is the amp bad?
- S4-1, budgee-0 ww gross warning . . .
- Ebay has ETK (or similar) for sale; search S4 pro part
- drivers side HID comes on blue for 20 seconds, turns a tungsten tone and then shuts off
- whats wrong with this picture???
- Can anyone tell me what this is???
- I just raced a RS4 with my B6 and I won! 4.2 powrar!
- How many of you AW'ers use your S for your daily driver?
- A little late, but.....Many thanks to Santorin Ox.....
- I searched the forums. Anyone have any pics of a "DIY MAF" is a different sensor needed?
- Any reviews on the "B5 Panzer Plate" Heavy Duty Aluminum Skid Plate for all 1996-2001 Audi A4 or S4?
- Paint Codes?
- quattro advantage...
- is there any diffirence in seats between the leather and alcantra other than the material ? thx
- What happened to Wicked Motor Sports?
- Looking for shop in MD/DC/VA that uses scales for corner balance/alignment
- How well does a Recaro grey suede or silver dinamica from the CS mach OEM silver Int? pictures pleas
- Tracking down coolant leak - 2000 B5 S4
- anyone here have a pdf or a jpg of fender removal instructions???
- Anyone have blown rear Bose speakers they're willing to part with?
- car wont fire up
- Alcantara Sparco Milano seats...I need a pic with an RS4 alcantara knob for color comparo
- Eliminated the rear muffler on my ASP True Dual, sounds awesome. (More)
- Just put in one of the new xenon bulbs I got from ebay. Seems to be more white than the other old
- FK Konigsports Coilovers... Opinions/Reviews? Anyone run them or has heard of them?...>>>
- o2 question (sorry its long)
- I got the tran fluid from Audi hope is good!
- Anyone have close up pics of their 50W ballast upgrade kit? Id like to see whats included, and how
- 17965 - Charge Pressure Control: Positive Deviation P1557-35-10
- Need help diagnosing a problem....
- Kudos to Vast (from a skeptic) RE: resurfaced flywheel
- Hilarious: Anyone wanna race my scooter?
- A little teaser....
- Seems that both right speakers are blown. So need either some stock speaker replacements
- Just got off the phone wiht Valentine One...
- Lemmiwinks Connecting Problem
- Just got ASP Stage 3
- BT: Stage III ( - & + )
- engine mount installation
- Just installed new HD TRE's from ECS and...
- 18in BBS RGR's worth the hassle? -6+lbs per corner vs. current set-up
- ASP Sauce - How accurate is the customized peak and taper?
- Any Original B5 S4 Owners Remain? Purchased Mine October of "99"
- Boston Audi Group is shutting down =(
- Stage 3 (VAST/HB) impressions, FATS logs (93 and 100), little video, reviews, and a cherry on top
- B5/A4 wheels. Will they clear HP2's? I don't see them on FixedWings
- Overboost help! Drove the car this morning and everything was running fine. 21psi holding steady-
