- for those who have done the Ypipe conversion...
- Expert opinions please - car doesn't pull well in 1st or 2nd gear (doesn't seem to make boost).....
- random pic of car...what do you guys think?
- PSA: SMICS and ko4 based turbos are so not hot right now
- engine overheats when car is running while standing still but cools properly when driving ??????
- Some pics of the new drop with a friends PIMPED escalade
- Water Pump Failure?
- DMV approved my license plate: "BITURBO" Me so happy! :o)
- Recaro's? Anyone other than AMS carry them?
- Man.. i think I am getting pissed to APR.. they never send me activate code for ECUx...
- Are the Induktion turbo oil lines larger diameter than stock?
- Noobs: this is a race car with BOV's... you can't buy these for your car!
- what is a fair price for a used stock tbox?
- So I was Googling for a pic of George W. touching Angela Merkel, and came across this instead...
- Has anyone had experience with Cry02 Cryogenic systems for cooling the intake temp? know how well
- what is the going price for new ko3s... and/or new modded ko3s...
- Anyone has spare Ballast/Igniter laying around for 2001 B5 S4/A4 Xenons ?
- shouldn't an '01 Avant that has full alcantara and aluminum trim also have chrome mirrors?
- recieved my zoldman o2s from vast today, i have to say these o2s are quite bootiful!
- anyone have an extra oil pan they want to get rid of for some cash so I can drive my car?
- Ok, I designed this Stage 3 badge... now somebody make it!
- Poll: Should I dyno with pump gas or race? I'm going to try to do both but might run out of time.
- I forgot to mention VW fiasco leaving waterfest
- So, where can I buy the silicone hoses that connect the inlets to the turbos (K04s)?
- Is it possible to get APR to do software for K04/RS6 turbos?
- how hard is it to change the front left axel? grease everywhere!
- Information on OEM windshield, AoA no help as usual
- what is the width of the stock hp2 s4 caliper?
- Lot of people have been going stage 3/3- lately... what are your prices($) running?
- Ouch............. just hit 115k miles this morning!
- G'damnit... My cluster DIS is starting to die AGAIN!
- Guys... I need your help.. What happens when I break the 300 g/s mark?
- seat belt harness installation: does the plastic piece at the base of the b-pillar simply pull off?
- Is a H box interchangable with M box??
- WWAWD: Hail damage :-(
- 0-60 in 4 seconds and no gas
- A little added Bling!
- Car stalls while in motion and..
- Any you guys thought about or actually traded in your B5 S4 for
- New clutch STILL not disengaging properly. Please help!
- Boost leak symptom? I'm GIAC L308X code and I've started noticing a drop off in boost & power
- Hey guys..how much for a trans install?
- I just finished making custom IC covers to go with my custom ducts...
- Paging JoshD to the white courtesy phone...
- Is $166 about the right price for a new EGT sensor?
- 80k service, what needs to be done?
- Using / adjusting MBC for dummies!
- Update from Plug swap last night.... problems still occuring....
- Just got a call from the bodyshop....10-12K in damage, and I won't get the car til at least mid-sept
- FATS = 5.04 STG 3- @ 16 PSI w/ 91 Oct.... Who needs injectors!
- For you DIY oil cooler kit owners...What cooler core did you use?? Size?
- Anyone know where I can find the u shaped horn bracket assembly for a b5 RS4... LIS4?
- i need a shift knob and a boot
- AWE Stage 3 issues.....GodAwful Gas Mileage with CAI file (Cold Air Intake).....
- Radio headunit problem
- Just opened my Europrice K04 Installation Hardware kit... am I missing pieces?
- *** Stasis Motor Mount Groupbuy is going on! JOIN NOW!!! ***
- 104 oct is approx 8 dollars a gallon. what if you filled up with 93 and used octane booster? What
- variable-geometry turbos, good thing? ...
- Thoughts on Tranny fluid options?
- Mud-flaps on an S4........not good-looking is it?
- Need some help guys. I went and test drove this A6 2.7T that was for sale real cheap. It sounds
- would it be ok to use meguiars plast-x on my semi pitted e-codes? Or will this product be to abrassi
- Anyone have a spare fuel pump cage they dont need?
- My EGT reads 1030 with the engine off instead of 1035. Are they bad?
- Dynoing the s4 today ill post up the numbers later on.
- Has anyone here ran NOS on there S4? Can the engine handle it? If you have
- i need a new exhaust.
- Anyone here running K03 Hybrids?
- Question about ECU chips
- Does the MTM software really ignore faulty EGT's? I can't see that being true...
- repost from last night for morning/afternoon people. Race gas question on none race gas code
- can anyone match a tech article for the install of Greddy Boost Gauge? TIA
- ARG. so not only did i curb a wheel, i noticed i have a nail in it as well
- my windows are haunted :(
- anyone know what dyno was being used at WF?
- How to test HID(xenon) ignitor and ballast unit?
- WTF ?!?111 look how bad this is .. just got it back rebuilt (misclocked) and i even put lines on it
- I'm arranging a dyno day in Michigan with several VAST project cars ....
- EGT sensor shorting with ground, anyone else ever get this code?
- Shout out to Jeff Moss, GIAC, and SIMMPLY for a nice collaborative effort on tuning our GT25/28 kit.
- Can the oem headunit (non-bose) power aftermarket speakers adequately?
- Need a sanity check. How many threads do I need for "safe" lug usage?
- S4 = 1 C6 Corvette (auto) = 0
- NE1 have a bosch 5 bar FPR? New or used. TIA
- Is it just me or do ecodes seem to be gappy around the edges by the hood and grill
- All this heat got me thinking about intercooler efficiency. So I made these mods and ducts...
- so who here races there s4 for money ?? any1 ?? how did it go ?
- This post is CLASSIC AUDIZINE material. WOW
- who's running meth inj
- Great!! My reverse gear goes in and dont come out automatically, now I have to pull the shifter
- There was a guy parting out an s4 last week on Ebay. I can't find the auction? Anyone remember
- So, mr silver S4 on the 101N . Nice try, but you should have someone take a look at your suspension
- damnit.... i curbed a wheel. :(
- newbie...getting 01 red s4 avant Thursday
- anyone heard from Snowtropper? isnt he coming to Socal?
- alright .. who da bastiches waiting for stasis trannys? =b
- Curious about this response by Evilempire, its about racegas..
- Need some advice about my turbos
- Can someone explain "speed density mode" when MAF is unplugged?
- Earlier tonight, I saw another S4. I go from the right turn only lane and cross
- SPOTTED.:.:.:::..2007 Yellow RS4 in Union, NJ with Cali Plates,...sounded sweet when on the road!!
- This just came to my mind...The B5 chassis & basic styling was virtually unchanged for 6 years!
- HB S4: 1 SRT4 Stage 2: 0 ... Neither of us launched, but I took off with the idea
- holy crap - strange storm just swept through philly. wonder how my hail damage my car took..
- Rocking Front Seat
- AWE Fuel trims... mine +3 idle -14 part throttle.. i have replaced lots of vacuum hose, spider hose.
- Broken DV valve. Safe to drive to get it fixed?
- PSA: Check out the Group Buy forum!
- which Chip is bestest?
- does anyone have a wood trim auto shift surround?
- AWE flashed ECUs....can i just get reflashed to another file (flash over and no need to flash back)
- X-POST...GTG @ Hooters on Hempstead Turnpike (Nassau, Long Island)
- Laser Red S4 at the LITE center in Lafayette, Are you here?
- Anyone need a Drivers front Aluminum upright?
- A buddy of mine bought an R32 and we wnet out for a little cruise last night.
- wOw. i ran a 104 yesterday...im so proud
- why didn't I see the asp booth at waterfest?
- car is running so well with maf unplugged, why even buy a new one?
- Any word on what the ASP gt28 cars have for HP??/
- I got a warning that looked like "(o)"... WTF is that?
- jPrice, I desperately need your help, my damn ECUx will not work! :(
- 20" "RS4" Wheels from the 2007 A8
- Anyone know if Flik Hornet's in 17" will clear Stoptech 332 BBK?
- For about 2 weeks now the mpg holds at 20.8
- 75 deg - STG 3- w- GIAC X @ ~10 PSI MBC Stand Alone vs Stock K03 --- Boost Ramp Up is Faster?
- Stainess Braided Brake Lines: cheapest place? TIA
- Guys, what is the going price for a used UUC Shifter these days?
- Need a stock S4/RS4/AR accordion hose for a few days!!!
- Anyone know of a shop in southern CT who will do a reasonable CV boot and
- BlauParts ATF kit
- Cactus Avant is teh Hotness......that is all
- Ok what are the chances of a stage 2+ S4 against a mopar stage 3 srt4?
- 5w40 motor oil options ? Which is value for money? Not looking for the best, just a practical
- In need of advice please- trouble shooting issues with my car (Missfires, LTFT's running rich..)
- i thnk one of your S4 guys is lost. please tell him keep his nude pics here and not on awot
- Apr v5 93 and 100oct..differences?
- What have some people gotten for their traded-n S4s recently?
- type of oil
- Has anyone had problems with Avalon's intercooler misters??
- Where is the best place to buy an AMS TBB??
- whos got the Audi Vibrant Collection exhaust? I know it's quiet (good)...but is it a 3" throughout?
- Credit Card ? If i charge something (sign carbon slip) back in January....but they forget to charge
- New style B7 RS4 wheels will be in soon!
- Got called out need advice...
- breaking the motor mounts and ripping the ground? easy fix?
- Poll: What is your preference for refinishing rims? Powdercoat (PC) or just Paint (P)
- need a new rear bumper will a sedan bumper fit on an avant ?
- Blauparts Control Arms
- Contact number for Vast Performance..
- Are the bushings on the front upper control arms replacable?
- Dyno Question: what kind of mustang dyno do GIAC, AWE, EPL, and whomever else runs Mustang use? 500
- Anyway to Modify A TIP Motor To Fit a 6Spd Body with harness
- What is the going rate for a GIAC chipped M Box?
- A Midsummer Night's Audi GTG Boston Area August 8th
- Is anyone here near Naples, FL? I need someone to check out a car for a friend. :)
- selling my car in the classifieds....
- 1/4 mile and dyno: My observations from Waterfest!
- Ronal, JULY Sale, 17"
- Poll: What 93 octane is the most consistent in quality and yields the best timing? I have been ...
- What would you guys say is the quietest DP/Exhaust combo out there?
- Had the car corner ballanced & aligned, the pig is at 4060lbs with me in it! WOW!
- What is wrong with my car...
- ISO Retailer Suggestions for Headlight Bulbs
- Thoughts on high temps......
- Purely FYI - Just installed my AWE DTS - fantastic; what a difference.........
- Need some advice going from Stg2 to Stg3
- repost for the day crew - rumors of an MTM 'super-kit' including motor internals coming to NA?
- Am I missing something? I can't post or anything on AudiZine...says I don't have permission
- RPost for Day Crew..Brake Booster hose on the bottom of the Accordion hose on M-Box..expendable?
- I know this has been asked before but....(dealership detection of ecu upgrade, after stock is swappd
- quick question for the B5 group since you guys are the king of mods (in my book anyway).....
- are b5 s4's equipped with cabin filters?
- Please Help Me Fix My Xenon Headlamp
- cheapest place to get Borla Cat back?
- Recommendation on spark plugs?
- would a apr chipped b5 s4 (auto) beat a stock 03 m3? from a line and on the highway?
- Cheapest place for oil pan? Thanks!
- Waterfest 12: From the Autospeed Booth...*EDIT*
- How much does a brand new short block cost?
- Porpoising with Koni Streetsports ?
- is 4-5 shop hrs reasonable for suspension de-install/re-install ? (Intrax MC replacing stock)
- For those with coilovers, if you were to do it over again, what would you get?
- does anyone know what paint i can use to match this bright silver ? i got me 18" moda r6-s
- STG 3- vs STG 0 - Stock ECU K04/RS6 vs K03 boost ramp up / does hardware make a difference?
- How's Paul Bauer? Settlement for his "pitching arm" comes in and he's too good for us now? :p
- How much do you guys pay for 100oct? I'm shelling out 7.49/gal in Long Island.
- The next progression in my S4 to RS4 bumper conversion- ->
- Any of you replaced clutch and flywheel at the dealer? I was wondering how many hours do they charge
- pole dancing girls at waterfest for those looking for this particular pic:)
- fixed surging finally. yay.
- In lieu of tire shaving, what's a good estimate of how many psi to drop to match rolling diameters?
- waterfest pics V
- waterfest pics IV
- waterfest pics III
- waterfest pics II
- waterfest pics I
- oh yeah almost forgot, L.A. GTG @ The Stand (Encino/SFV) tomorrow night -- Tuesday, July 18th @ 7pm
- So I narrowed down my coolant leak....I see it dripping down the front of the oil pan....
- Visiting Thousand Oaks, CA (LA) for work trainning this week. What to do?
- How do I remove the ashtray assembly?
- stock exhaust needed in socal. Anyone have one? I can pickup :)
- those that upgraded the dts rubber mount to the chevy poly mount ......... (more)
- How did the B5-S4's do in the Waterfest drag event?
- question on idle
- ground wire question
- What size, length, and threads are the two long screws for the exhaust hangers?
- Where is the place that will groove Bilstein in 2 days instead of ECS's 6-10 day period?
- Stage 2 B5 will beat a similarly modded B6/B7 right?
- Some Waterfest 12 pics....
- Whew, Im not sure what you are asking here? If you used both the cold side and hot side wheels from
- Valeo Ballast Connector
- turbo guru`s,complicated question,has anyone run the complete rs6 chra`s in a ....
- New Front Grille Conversion
- how much for a stock M and or T Box from Dealer?
- so how much longer until the "my car got jacked at waterfest" posts?
- Where to get replacement vacuum tubing and heat shielding for oil lines?
- Questions for guys with IC misters...
- MTM 520 hp S4 in development for the US market
- did i switch the polarity (+/-) of my new JBL rear deck speakers?
- need new driver side mirror glass - any issues to look out for ('02 S4)?
- Mysterious Coolant Consumption & Elite Motorsports
- Autospeed @ Waterfest (more pics) ENJOY
- 2000 s4 fuel injector question.......................................... ..........
- would a giac tip chip increase acceleration because it shifts faster?
- Best place to buy a set of aluminum trim? Also, what could I get for my birds eye maple trim?
- hott waterfest content thanks LI s4 for the pic :-)
- I'm thinking an RS4 clutch will be enough for me, anyone strongly disagree?
- How fast is new M5 against stg3 S4 in 0-100??
- How many of you have Aquamist (water injector)? how do you guys manage in the winter for the water?
- Part number for S4 front Bumper licence plate filler
- My Waterfest pics...
- Anyone running OZ Record wheels? I've searched and came up with zilch.
- 2005+ compass mirror for B5
- Has anyone experience a torn TBB (newer "T" version) with the new clamps?
- Is there any officialwaiting list for X-1 intake? i can't get a hold of him
- Anyone had an issue with their ETC light? *Long story*
- No DTC, Climate Control Unit = Out, Oil Temp Indicator = Out, Ext. Temp Sensor = Out
- The award for the hottest slore at Waterfest goes to:
- Cleaning RS4 ICs. What are my best options for cleaning.
- if you can, do a FATS run in this heat so we can create a guestimate of FATS vs temp ...
- Sweet GTI...
- before I pull the trigger on an AWE boost gauge...
- need hood latch - pull-tab at grill broke and rubber boot tore. looks like....
- Photos from changing my front CV Boots
- some photos of DAP and Expstang at the drags from the last time out...
- What MY's have the extra nipple/connection on the bottom of the accordian pipe??
- S4 came off State Farm's Top Ten Stolen Vehicles. That is all...
- Dohhhh!!! Car is about to get towed to the dealer, all the parts are in the trunk and I forgot
- APR snub mount has held up well for 133k miles of use and many drag launches...
