- clutch issue
- I've been looking for 18" wheels but every where I order they call me a week later
- whats next?
- Need help!!!
- Has anyone gotten custom exhaust from hanksville hotrods...?
- Power Coating Calipers, Anything that I need to Know?
- 8 years and 100k miles later...
- Pan and cam seals.........
- how do i hook up infinity basslink
- finished stage 3, wont start with new ecu?
- can i use a bentley with vista?
- NEW S4 Owner + Questions
- shutter under mild acceleration, Could it be tranny mounts? (TIP)
- Voltages fluctuage in humid/rain weather.. volt regulator/alternator?!!
- Test Drive
- Climate control, On Board diagnostics
- ABS 01203 error
- PLEASE HELP
- looking to buy stage 3 in IL
- b5 s4 tranny filler/bleeder ??
- Boost leaking from Injectors. Can anyone help me out
- APR tune or VAST tune
- Need help with my HID light
- Help !! weird symptom
- :: ECS Tuning :: OEM Audi Parts Database Search - Now Live !!!
- I vote myself new forum super moderator...
- Just purchased K04's and going Stage 3- ... what else do I need?
- connection
- blowing smoke, loosing coolant, throwing codes
- need part #
- Codes help please: limpmode
- Doing Control Arms and more. Am I skipping something?
- who was the dork with his gf that in oc that would not race me
- Help please...going crazy...charging problem
- anyone have front license plate parts for sale?
- Need 1 Dunlop SP Winter Sport M3 DSST (225/45-17)
- Bosch 044 check valve help (kinda long)
- new s4 owner in socal.....has questions??
- Blown turbo noise
- Photos from messing around at El Mirage dry lakebed
- Enter to win a Liquidcrack shirt
- Transmission Mount testing
- Getting into gear issue....
- Tried ordering some 18x8 wheels and they told me they wouldn't fit w/o spacers. Is it
- Looking for 17" Avus S4 center caps
- simpply run these guys
- What annoyances are you living with?
- Resurface Dual Mass Flywheel
- Checking out an S4 tomorrow... things to look for?
- Overboosting- Help would be appreciated
- Ignition Circuit Short to Ground
- :: ECS Tuning :: New Website Now LIVE !!!
- Center display warning light
- B5 RS4 Brake Calipers?
- SAFE mode on Radio
- HELP !! NOT BOOSTING!
- EGT logging with Vag, Block 34 and 35? Have EGT fault but readings look good.
- HELP!! ALARM WON'T STOP GOING OFF!!
- My ASP/WMS GT28 thread starts today, May 3, 2009!
- I just want everyone to know
- No one uses RS4 airboxs anymore?
- The count down begins...
- I bought a PerformanceBox, quick review and track results...
- steering wheel audi controls
- Stage 3 Tip Dyno
- HELP - Need EGT (Bank 1 / Pass Side)
- s4 b5 loses power in rain and make loud exhaust sounds
- Will importing a b5 rs4 continue to be difficult?
- Anyone know how to make backup CD's for the RNS-D navigation system? TIA
- Considering buy a 2001 S4 as a daily driver
- Suspension Q's
- percolating sound at low speed acel and decal?
- Anyone have a link to the Hockey Puck Mod for the rear diff?
- TQ clutch stuck off code
- A.W.E. releases Gen2 downpipes with massive price drop!
- turn signal bulb
- My S4 takes longer to startup..is my battery dying or should I expect something else?
- OEM coil springs; where to find replacements?
- bad alignment or driving issue?
- New Codes, Weird Problem, Help Please
- Anyone running Enkei J10's ?
- Where to mount a rocker switch....ideas needed:
- Power Steering
- Need to replace intake air duct, big and/or expensive job?
- remanufactured transmission....
- Does anyone have a better solution for this crap?
- UUC shifter failed
- Where can I buy Depo E-Codes?
- Need Help
- Stainless side mirrors
- Oxygen Sensor Modification
- SQUEEEEEEK when dry steering
- Blowout due to bad alignment-need new rubber - want comfort (low noise) & performance
- 40psi FTW . WMS GT power'd S4 1.88 FATS !
- Has anyone seen any s4's with the fog lights removed and replaced by led lights???
- if anyone has a Aftermarket snub mount laying around hit me up please! thanks
- The car, thanks to everyone.
- Seems every one is selling car, anyone selling vagcom?
- A.W.E. Tuning's eBay store - B5 S4 Vent Mounted Boost Gauge kit
- Diagnosing Exhaust Leaks
- Another one: Whats my stg 3- avant worth??
- dont let this happen to you!!
- I love this thing!
- Maintenance ideas wanted
- the most absurd thread I have seen. hint: NOS
- lost fuel cap, bought a new from audi dealer, does any body know where it conects too
- My car is FINALLY tuned! Full saga and logs inside (long)...
- Got diagnostic codes P1129 and P1127, whats the damage?
- Decision time- rebuild or not?
- Anyone selling Stage 3 S4 in Southern California
- Wedding ManRegistry Suggestions.. aka tool list for the S4
- Trade-in... how much ppl are getting for low milage (50K) 2001s?
- Tial R650 Turbo Kit, 2.7tt - experience ne 1??
- what is the rotor hat number on the ECS Stage 1 2pc. rotors?
- Philadelphia Audi dealer recommendation
- WANTED: Tire recommendations under $120 (each)?
- Looks like I will stay a member after all:)
- EPC and Starting Issue
- Audi s4 new owner and of course need help/love it
- Can weather affect turbo production?
- Buying '01 S4 with 87,000k.........needless to say, I've got some questions!
- no boost, no leaks...no whine
- 2 newbie questions
- Couple of quick questions about TB DIY
- Making the Most out of my TOTALED S4
- Uhg... One thing after another (A/C piping)
- Will B5 S4 Stock Sway Bars be any use to a guy with B5 A4 1.8T?
- What wheel dimensions to need to look for I have 355mm Stop Techs already
- Misfire/stumble driving me crazy... what else can I look at?!
- Reinstalling Front Bumper Help
- Window Regulator Replacement Help?
- Anyone install B6 crystal sidemarkers on you S?
- have 300$ to spend, any opinions? B7Rs4
- Car is "surging/hiccupping"
- motorswaps wild ride
- Any body seen a sunroof delete?
- Who has CHRA's for K04s? I need mine rebuilt.
- A little help please... :-)
- Where can i find D2S bulb for a good price and good light output
- xpost: no more tiptronic.
- CD player says ERR1??
- Photos from VIR 4/21/09 - (BWW!)
- collent temp sensor green top?
- No Idea what this Sensor does or goes to!!! HELP!
- x-post..... little project I have been working on.....
- s4 mods
- anyone need a set of diverters , upgraded 710B's less than 20k miles, $50 obo
- Help Fix my Friends B5 RS4
- what bulb is in the licesnce plate holder
- Rear 12v and ground source?
- consistent flashing cel only under wot
- Anyone know a cheap solution to a paint touch up on 2000 silver s4?
- Hey all
- friend is looking to swap your black seats for his black/white , east coast, also ->
- Officially posted my car for sale
- post pics of your s4 best pics that you have
- Anyone have a hubcentric ring for Mille Miglia's?
- Cause for vibration when > 80 mph?
- Quick Question!
- jhm linkage review? can find reviews on ss..
- 2000 s4, turbos leaking oil to intercoolers, bad turbos? Please Help
- Vanity plate ideas?
- Oil leaking into intercoolers: Bad turbos?
- right tail light brakelight stays on when the lights are turned on, ????
- does any one know where this loose wire goes too?
- How do I fix this?
- Door lock just spins when key is put in - need help
- One Lap of America 2009
- need some help recoding my ABS module
- just got my first audi
- Quick and easy (and free) bumper mesh mod
- Coolant sensor help...
- K03 Oil Seep...K04 Upgrade?
- WTB B5 S4 bumper cover
- EGT Sensor Code - Intermittent
- porsche brake conversion question?
- Stock exhaust system for 2001 S4 Avant
- First Engine Pull
- Spotted Bright Blue S4 Avant driving around Ann Arbor Michigan
- Any Fast S4s on this board ? SoCAL
- T pipe to the Coolant broke whats the part number
- Anyone have a stock airbox or want or want to trade for my rs4 airbox?
- m3 spoiler pics
- What FATS time closest represents your best 1/4mi time / mph? (those who have run)
- I will give you $25,000 if you help me remove my rear bumper
- 1996 B5 A4 Radio issues
- flashing CEL, misfires, checked everything!!!!!
- Vacuum leak-- Brake Booster hose?
- New video of my GenX GT28R S4: Smoking Tires Edition
- Poll: Which insurance company do you use for your S4 & how much do you pay?
- Curved vane solid rotos for stock brakes
- *Announcing Revo Techniks Forum Member Discount*
- Anyone runing S8 brakes front and rear?
- Just bought a 2000 S4
- pics
- new twin disc clutch came in the mail from WMS today
- shuts off
- B5 S4 Euro rear bumper available...
- Silicone Intercooler Hoses...
- James4 story
- Beru ICMS?? still have issues
- Giac X ECU - M Box -
- Where can I get some K04's rebuit? Besides Bloush...
- WHAA WHAA WHAA WHAA WHATS that noise
- Short Shift Recommendations
- Selling my 2000 S4...
- How hard is it? ko3 to ko4 swaps
- Carbon Fiber Hood
- X Post: Got internet connectivity in the S4, finally.
- bmw trumps new audi?!
- New S4 owner, got a few things done, looking to do more.
- is it worth it?
- Alternator DIY?
- How to put a stage3 S4 in storage?
- OEM Nogaro Hood
- Help! Misfires and bad compression.
- My B5 S4 Avant now has a sibling... '04 996TT
- O2 sensor error on fill up
- Swapping Winter/Summer tires yielded "mixed results" :/
- 2000 Audi S4 Engine Loud Clicking Noise
- S4 potential buyer questions
- looking for the best price on a part
- Drivers side o2 sensor update *pics added*
- 2000 S4 sunroof switch/dome light assembly
- Anyone have a OEM front driver side caliper that they wont need cheap?
- My 3.01L stroker gt28rs, progress, almost ready...
- electric fan seems to be always on now, even in cold weather at start-up (idle)
- 2001 S4 shaking on throttle: faulty 02 sensor
- Limp mode at the track this weekend - EGT sensor causing it?
- My car is a little too left-wing, help me set her straight
- News Flash: Wustefest 2009 Is Latest Bailout!
- Where to get Decals?
- (B5) A4 to S4 conversion?
- Stage 3 upgrade - How long to DIY?
- Are ebay silicon hoses any good?
- how to rebuild k04?
- Help! Drivers window fell into door...
- Removing radio
- Torque spec on valve covers
- Wheel Fitment??
- cxRacing FMIC install finished (pics and notes)
- IAT What?
- Car is totally dead; battery is fine. How do I track down the problem?
- The AE Performance Widebody Comp S4 (drool)
- apr intercoolers?? same as rs4?
- Selling my car - asap
- Is there a how-to for removing the front door panels?
- Started car and then it went dead right away - now I get no power.
- Drive shaft/center bearing alignment?
- Deer=0 S4=1
