- Anyone have a used or blown Central Locking Pump/Unit
- Stock engine chip available for a few more hours...
- weird question.... best place to get a shift knob?
- Whirring noise when turning right....which wheel bearing is it?
- for recent dyno: Where did they connect the front straps?
- fvcking k04 inlet pipe does not fit K04. AWE also forgot to supply o-rings for inlets...
- Piggies how to
- HELP! best place to get my S4 lowered in the North OC area of CA?
- How much difference does a vented CF hood make? ANy issues with ater getting in the engine bay?
- Helping my friend t00n his S4 <more>
- anyone with CF beltline trim want to trade for piano black?
- 99% Decided on Eibach Pro Street Coilovers
- Clutch issues.. need input.
- Can you guys post some pics of your vented boost guage? im trying to decide if i wanna make one or..
- Car wash anyone?
- Enthusiasts United for a Cause
- tips on driving tip
- Decided to log the Noggy tonight after a short break (~3 weeks) from monitoring her performance....
- Did a double-take in my garage today...who's kick@ss car is that???
- my first awe dyno day...400whp 407wtrq 93 octane....
- Where does the braided vacuum line go to that sits just below the vacuum check valve, how do you
- Look in NorCal for my 2 year saga update . . .
- Is AWE ever going to fix their vent gauge lighting problem?
- Has anyone seen SnowTrooper? Been trying to contact him
- is there a trick to getting the tre's out of the upright? i can only get it to move down about 1/2
- Misfiring/steady CEL anyone in SoCal South Coast/Santa Ana the can VAG the car for me?
- People who have ZEITRONIX WB installed... why do you have to tap the speed sensor and TAP sensor
- What size tires won't look stretched on 18x8.5 ET35 wheels and not rub?
- any advise/experience with slave cylinder replacement?
- Engine bucking
- A visual compare and contrast B7/B5
- Aux fan control module: Don't order the heavy duty cooling one from thepartsbin.com
- any stage 1 APR guys out there using the TurboXS Standard Boost Controller? i have a question about
- S4 forum. 100 Dollar contest. - Creat a name
- sorry if i missed the post, but how many guys VAG'd on the dyno and compared the VAG dyno to the AWE
- has pat posted pics of the car completed yet?
- Can someone please e-mail me the TCD installation instructions?
- anyone have any tips on how to get the rear upper control arm out on my car? i'm doing the cv boot.
- After yet another AWE Dyno Day, I tell ya, I'm more and more impressed by GIAC!
- Tips for doing timing/water pump: never done this before..I searched archives
- Bilstein Sports... Eibach or Vogtland springs? Repost before purchase...
- Note curbside crew member.....
- Has anyone seen or done IAT's before and after phenolics?? Just curious...
- Tomasz thanks for the shipment :)
- hello fellow AW'ers. Wondering if you can recognize the pad part #, compound, and/or
- My best run @ AWE today: 418 whp / 387 wtq
- Best place to buy K04 Inlets? Saw them @ purems for $489, anywhere else have em cheaper?
- Just replaced my front end upper rear control arm. No problems. I was looking at the...
- Thinking about ordering a Boost Gauge/Tubing Kit from egauges.com help me choose
- What RS4 fenders run these days ?
- My results from AWE Dyno day on unleaded race fuel with closed dumps 315whp 348wtq. Dumps open:
- PSA: JasonS4 is the man! Great transaction all the way through...
- Still need a TBB asap, day repost, dealer has none , thanks! S-east here!
- I really hope to see AFRs from today AWE dyno day shoot out. That is all.
- is this bad?
- Latest oil analysis result.
- stfa already any ideas or links to engine timing tia
- Is the finish on this trim the same as the silver trim found in your cars?
- What kind of Chip can I get?
- Should I or Should I Not
- Ordering VDO boost gauge and tubing kit. Is 6' of tubing enough, even though AWE calls for 7'?
- A picture of my passenger side fender in an attempt to piss off all the anal retentive members....
- WOOT ! AWE Mustang dyno day results for my car. :>)
- A picture of my bumper in an attempt to piss off all the anal retentive members....
- NE1 heard anything from AWE dyno day? TIA
- wondered if you could go to this site I built and tell me if it looks alright...
- Not sure if this is a repost, but: "Pierce your ride"
- Poll: Which Do you like better ? 1 or 2 ?
- 5cyl vid
- Anyone want to sell a short shifter....
- Would a missaligned shifter cause a clutch to blow?...>>>
- Do any of you think if you put as much time into your job that you put into your car would you be a
- We've got paint on a car.
- broke down tonight, clutch is stuck on the floor. is it the slave master cylinder?
- What time is the AWE dyno day tomorrow?
- anyone have a rebuit motor instock? eurospec? i am in need of one.
- So who lives <5mins from AWE and is not going tomorrow? this guey --->
- Thinking of buying a 2001.5 Sedan and need opinions/help.
- resale?
- Anyone in the midwest offer a tranny rebuild service like Stasis?
- Lost wheel lock key.
- Officially Stage 2 Now
- in need of a TBB asap, oem or aftermarket, thanks
- Curbside crew is there any place to get race fuel near AWE?
- My alternator is dead, need a new one, anyone know where I can get one,
- Opinions and thoughts about wrapping turbo oil feed lines in reflective 1200F tape (CoolTape)???
- Paging *SAC-CA-S4* please email me asap! Thanks :)
- How much extra gas does a bad O2 use???
- Is B2 S1 the Drivers side upper Oxygen Sensor???
- Definitely going with Bilstein Sports. Vogtland Sport or Eibach Sport Springs?..
- I need these. with the window controls in black leather. Check out my PS skillz
- I need some insight on an RS4 clutch install.
- How do you guys feel about buying an S4 without a sunroof?
- Bottom of the line coilover shootout.
- Did a dyno run and confused on the number. I've got SAE numbers, is that the same as crank?
- Thoughts on this car?
- 11.76@120.5 today on APR Stg3 104oct v2 :o)
- trying to get some interest in a control arm group buy... follow the link
- R8 Cabrio
- Anyone successfully running stage III upgrade on thier e-codes? Where do you place the ballast?
- Frame damage
- Just installed Samco TBB last night, couple of questions...
- anyone have a set of used or shot ko4's lying around?
- 10psi = torn TBB? anyone have a spare if so?
- she's almost ready : ) ) but I am running out of time : (
- My mechanical clutch fan is scraping my bipipe now.
- Rebuild of HID ballasts might be possible?
- Snow Trooper ygm!
- Made the switch, first pic says it all (Warning Alcon porn)
- chrome mirror cap. vs. rs4 mirror cap?
- Getting an M Box w/ older GIACX code.
- Anyone have a phatbox they want to get rid of? otherwise where to get one?
- n00b question: what stage is this?
- Nail in tire... is this bad? Should I pull it out?
- Need to replace tie rod ends. Do I just get the tie rods or the whole assembly kit? thnx
- Does shifting gears get harder/notchier under wot? It seems every time I launch I have to force to
- Saw a B7 RS4 on the road yesterday...
- Green B6 S4 with minnesota plates in watertown SD around 11:45 at mcdonalds..are you here?
- graph from the last dyno (stage 3 minus), please comment - tia
- For Jackson (see name) ====>
- <sigh>......
- Best cure for 3-4-5 shift clunking? Already have DTS - Poly snub, RS4 engine mounts, tranny mounts?
- Anyone replace front Upper control arms for bad pivot bushings?
- Any one from N.E. Jersey or NY want to meet up on the way to AWE dyno day?im in Paterson,jersey.
- Would Enkei OR52 18x8.5 (from edgeracing) clear 332mm Stoptech?
- Nogaro Blue S4 on Route 309 in PA are you here...
- So who sells a quality camber kit for B5S4?
- Does anyone have the installation instructions for the Vast TCD?
- How hard and how expensive is it to retrofit heated seats into a non-winter pack vehicle?
- No Brakes after my rebuild
- Moven SP 10??
- What clutch are you using with your stage II to III+
- Cheap nogaro avant.
- anyone have a photo of a silver avant w\ black roof and avus wheels?
- New wheel pr0n (mBWW)
- while tilted open, sunroof "clunks" when going over bumps, any suggestions from the experts?
- is the top part of the trunk double-walled? some jackass dented the top of my trunk, 6" offline....
- Poll : How noisy are your K04/xx turbos under boost ?
- ABS Sensor 5mm Allen Screw Snapped - What to do?
- After getting my pc680 i am in light weight mode! This afternoon while being bored...
- Casa S4 King here's your sigs....bww
- Some new pics with some CF goodness
- transmission
- and it has started
- Updated n00b index script
- How do I adjust front dampers, Stasis Tracksports???
- someone said that the radio code could be on the sticker in the wheel well...where on the sticker?
- My rear view mirror just sprung a leak - does anyone have one laying around?
- Great spoof on lawyers if you've got the time to watch this...
- Oil filter spinning with oil cooler...help!
- ASP Custom-Tuned Stage 3: First Impressions
- Former Enron employees driving to work.
- fluid suggestions?
- car seems to be accelerating on the slower side through 1st and 2nd, into 3rd the boost seems to be
- Smoke question...
- Whats a fair job quote$ for cam tensioner seals, valve cover gaskets,oil cooler seals,rear diff seal
- Here are pictures of 3 shirts I bought at cafepress.com, all driving and turbo related....
- So, hypothetically speaking, how much would a new X-1 Racer intake be worth? (other than tree-fiddy)
- anyone else have retaining clips for aluminum trim laying around?? TIA
- Lemonade from lemons!! Clutch crapped out, so now going stage 3! My mechanic does a sub-frame drop
- Where can i buy a heat shield like X-1 Racer intake uses
- paging dasEighty......
- just got my bentley manual reinstalled.. Now I need new dell laptop w/serial port
- Opinions on these EBC Rotors
- More clutch issues. Slave cyl. Pulling trans..
- way..WAY too much Neg. Camber up front!! Burning inside edge off tires, Upper control arms?
- FAK! I was getting in my car this morning to head to work when I realized one of my tires was flat.
- looking to buy an S4
- Help, I need a new drivers side S4 Euro headlight assembly as cheap and as soon as possible.
- what are the odds my car has a leaking dipstick tube?
- Cost to install rs4 cam. ? Fair Price ?
- will these (19" RH C5) fit in our cars?
- I've been gone for a couple weeks, and I'm not sure if any of the other guys posted this...
- vogtland coilover adjustment
- Cam tensioner seals, valve cover gaskets, oil cooler seals....all being replaced...
- Selling car...should I do all the maintenance, or sell as-is?
- Question regarding piggie pipes...>>>
- XPOST: Full-serve fill-up with 87 & added octane boost. Other than a waste of $
- Cam Tensioner noise after having Cam Tensioner Seals replaced (long)....
- Fuel Filter size question?
- repost from AWOT, nasty subbie.......
- Where to buy Laminex headlight protectors? Thanks
- Does the B5 S4 forum have any use for some web space? Long story short, I had intentions to do a
- My Zeitronix wideband 02 sensor woes continue...
- rs4 rear bumper fits a rs4 conversion sedan?
- After removing the interior carpet for an fellow audiworlder i had the sudden urge to wiegh it..
- Interior aluminum trim part #'s....
- Looking for thoughts on clearencing vs clipping the turbine wheel
- steering angle sensor throwing codes....
- I trapped 100mph at the drags last night on 93oct and I was pretty happy...
- Probably a repost, but it looks like Audi is going to offer a 5 cylinder turbo engine again.
- Just put on my RS4 grille, and now I would like to see some pictures of options of black rings,
- Is there a difference between what is listed as a RS4/KO4 turbo and just KO4 or are they both really
- Suspension tuning guru's - Spring rate question- - >
- Kinda OT but is it true if you got a plate from the DMV that says SLO S4 that someone else...
- Someone willing to check out a car for me in Prarie, MN?
- wtf, egt sensor not covered in my warrenty plan? thats a crock of bs.
- Have been STFA... Any photos or reviews of Clairparts 'foam rubber trunk mat'?
- i already checked search forum....what are s4 madman headlights ? how do you make or buy em?
- Paging docwyte...ygm
- an oldie but a goodie.............
- Mike2kS4, I need some help with something... sent you an email.
- Is there such thing as an AA box?? a friend of a friend is getting rid of his APR ecu and said its..
- Damn, people were racing like crazy last night. I wish I could say the same. That is all.
- would a BAD coolant temp sensor throw a code? and would it also cause loss of power? thanks
- Updated Name and Sig.
- s4=2, E39 M5=0, first race he said he got a bad launch, (i didnt launch).............
- S4: 1, Trek Madone 5.0: 0
- Would like to refinish my RS4 DTMs... Opinions on a new, darker color?
- S4: 2, SRT4:0
- S4:0, C5 Vette: 1
- Calipers rusting, should i be worried...??
- Audi: 1 Cruiser: 0
- Stage 3 - black smoke, is it normal?
- Daily Reminder: EvilYankeesA55EmpireWMSClown or whatever you're calling yourself these days. :P
- anyone planning on the SPEED World Challenge races at Laguna Seca.. i have free tickets for sunday
- imola and breckenridge
- Whaaaat!?
- Brake lights not working....night drive tomorrow...HELP!!!!!
- Hey, guess what? My car has no more death rattle - and still NO BOOST!!!
- Basslink II Install help - B5 S4 Bose
- Somebody just sent this to me ...
- Anyone feeling nice??? in Santa Barbara...
- awe dyno day
- i have a apr chipped s4 (tip), and my buddy just got his 07 gti chipped (6-speed).. now he's sayin
- Wow a sweet stage 3 nogaro sedan just popped up on the classifieds...
- anyone know how to get the non tamper screws out that hold the ignition switch in?
- Which 17" RS4 reps clear Stoptechs? Someone has a set but I forgot who it is?
- So if I'm doing my cv boot rebuild, just the outter boot kit and I'm going a long...
- Help!!! Ground terminals 1 & 2 on ECU go to ground#83, Where is 83?
- who has the best pricing and availability on h&r wheel spacers?
- Anyone have pics of custom painted Avus wheels? Mine are goin to the body shop next week for........
- Hey MarkP are you going to NE anytime soon? A bunch of us are trying to get together for a few runs.
- Ok guys, Im gunna try to run the S4 next week at the track. My question is....
- Used vs new axle bolt, yep, it stretches :)
- Hmm.. I had no idea newer S4s had exhaust flaps
- Anyone have a worn out left or right blown ko4?
- Brembo brakes from an evo
- PSA the sachs throwout bearings sold by ECS are:
- Value of an S4: what do you expect the value of our cars tobe in 4-5 years? I imagine about 10K....
- Anyone want to sell a black stage 3 s4 avant 6 speed?
- is a stage 3 2.0t a4 faster than a stage 2+s4?
- As Promised rs4 pics and a review this one i drove ......
- outter cv boot, front passenger side, DIY yes or no...?
- And I thought some of the posts on this forum were silly. Here's a great question from....
- does any one know how much stock hood and front bumper cost. i just rear ended some guy who doesn't
- My Samco TBB blew up today. Anyone know what the warranty is on one of these?
- New after market headers.
- Anyone have a STaSIS Tracksport rear brake install writeup with pictures?
- 5V valve cover? Is it on older model engines but not MY2002?
