View Full Version : 2.7T V6 Discussion
- New wheels
- WTT: Two Polished Forge DV's for Black Forge DV's
- Anyone using the ECS race N75 valve in there 2.7t?
- BAR Certified Mechanic in Metro Detroit Area??
- CV Joints
- Motor dead, want to rebuild, where to get BUILT parts?
- how much do 2.7t's usaully go for? i want to put one in my 90.
- Torque converter problems
- Need Help Modding My 2.7t
- I'm getting a allroad
- So who is to blame, in your opinion....
- 200-300 rpm drop at idle...
- Please help for the 2002 Adui A6 2.7T, hot starting problem.
- xpost Turbo coolant leak
- AWE's stage 2 clutch Vs Stage 3 ClutchMasters
- Reliability of B5 platform
- will down pipes from a manual fit the Tip engine?
- Secondary Air Injection Insufficient Flow Both Banks
- Engine Codes - P1131, P1129, P1127
- Questions about the DPs, STFA already and is still confused. TIA.
- need help!! buying the best 2.7t clutch??? AWE's stage 2? Vast's stage 2? clutchmasters' stage 3??
- What to do first???
- Twin-Turbos on A62.7T
- Boost gauge
- What's up everybody
- Diverter Valves
- tranny pan
- Forge MBC
- I have an air leak!
- s4 blowoff noise
- Proper Turbo Use and Maintenance
- How much boost can you push with RS4 k04s [for a friend]
- Stg 3- in process. Installing oem P&P ceramic exhaust mani's w/ no tabs for heat shields......
- Flash programming
- apparently I need to change the afterun coolant pump///any how too's out there...is it hard?
- ABS Issue
- Throttle Bottle boot questions
- Check Eng. Light on '02 AR w/64k mi
- a6 2.7t 0-60time
- Where do I get Bentley Manual and cam lock bar...doing timing belt pretty soon! 01 S4 Avant
- Engine Oil
- ABS LIGHT AND FLASHING BRAKE LIGHT
- i have a problem with my A6 2.7T
- RS4 Tranny Mounts engine/ tranny propshaft alignment
- rough idol
- 2.7 valves toasted
- 2.7T - crank trigger??
- time to start tinkering
- APR Announces H2o International Sale offered throughout North America!
- maf question.....
- Has anyone had a Timing Belt tentioner (hand grenade) fail?...I did
- FS: Secondary Air Pump & Combi Valves for 2.7T
- SECONDARY AIR PUMP
- Rs4 intermittent issue. Rich crazy running on idle and beyond.
- Install boost gauge but now ac does not work...
- recomended plug gap for NGK Iridiums ?
- Will an A6 intake work on an S4 (same 2.7 motor, so i'd assume so)
- Misfire was on cylinder 6 now multiple......
- OCT or GIAC Tip Chip
- VAG results -catalytic measures over .90 for Bank 1.....can I assume....
- noises from within?
- Random misfire code 0300
- Cam tensioner reoccuring problem dealer can't replicate
- Transmission Output Flange Seal oil leak?
- S4 O2 Sensor Blues
- How does the TB in an MY 03 2.7T differ from earlier years?
- slave cylinder location
- oil leak
- Going stage III with 80K miles, should i have engine rebuilt
- check engine light. codes......
- Audi 98 Transmission Board
- MAF Sensor
- Cylinder Misfires - help needed
- CHECK ENGINE LIGHT
- PSA: GIAC Tip users, make sure & check your boost!
- Anyone know where the Ingition Control Module is located on the 2.7t ?
- p0300 check engine light Any way to fix without swapping ECM??
- Check Engine Codes!!!
- follow up post, regarding custom exhaust and downpipes>>>
- always expensive
- OIL FILTER.?
- chipping my 2002 allroad [2.7t]
- s4 auto to manual tranny swap?
- I should have asked sooner!! HELP!!!(long)
- What is the PN for the TT Diverter Valve "upgrade", or what model to look up at parts store
- looking for feedback on my lemmi article
- Timing Belt & Water Pump Question
- Fan strength?
- Secondary Air Injection System/ A6 2.7T
- A BIT OF BLUE EXHAUST
- Clicking Noise From The Engine when its in 2nd gear at a stop sign and stepping on gas
- short shifter instruction
- 01 s4 exhaust
- heat shield question
- abs brake light on-2000 s4
- drilling on engine start
- APR WaterFest SALE
- Ideing too rich & CRC MAF Wire Clener
- Blackstone oil analysis
- Doing an 80k service and need some help
- cam adjustors - noise like a failing water pump...
- EGT problems and misfires - need your help
- Coolant leak oddity
- Misfiring
- PO304 error (01 S4)
- Common Probelem?
- Checking VAG codes P0118 P1131
- Be sure to check out this article
- Cross post from B5 S4 forum, mysterious coolant loss with the 2.7T engine.
- How much added HP/Tq from Piggy Pipes?
- Engine turns over, but wont start...NEED YOUR HELP!!!
- Is the bently manual a "must have" to do timing belt service DIY
- ECS afterrun thermoswitch; do I want/need one..?
- How does stage 3- software differ from the Stage 1 software?
- P1169 Fuel Rail Sensor In-Range High Failure
- stage 3 mileage
- Will be doing my timing belt soon, where can I get some of the special tools:
- Can't do a search on this forum so I had to post...
- Exhaust noise after replacing valve cover gaskets... any ideas?
- Those that know Turbo
- Audi Expo 2006 - Come be a part of history again!
- Scratched Cams, oil leak? (2000 A6 2.7T)
- 143k miles... should I be worried?
- Vag com data dump (follow on to my O2 sensor post). How screwed am I?
- How hard is it to replace an O2 sensor (bank2,sensor1)?
- ECU Swap from S-4 to A-6 2.7T
- APR Chip Upgrades
- No boost at all
- Anybody around O'Hare?
- oil in intake
- Any alternatives to $240 ecu flash? Please Advise (Kinda long)
- O2 Sensor, Where from?
- Engine Won't Start, HELP!
- Hi all im currently in the process of getting K03/K16 turbos and...
- Need help getting stuck oil filter off!!!
- Audi Expo 2006 - It's coming!!!!
- ANYONE HAVE AWE intercoolers, and live in SoCal>?????? PLEASE RESPOND........
- Anyone got some used/ but working 2.7T heads?
- Neuspeed's ECU Flash Programming Now Available at North American Motorsports Connecticut Location
- EGT sensors issue
- HELP!! 2.7T nmotor seems to be leaking oil some where down there.
- installing bi-pipe and pipe will not lign up with arched bracket mount. do I need to
- K03 or K04 Upgrade?? Need Help!
- Converting S4 Tip to S4 MT6
- Anyone use universal O2 sensors? Can we just splice them with our connectors?
- HELP!!! 2.7t problem! coolant light, oil in coolant?? <LONG>
- F-hose question
- How does the 2.7t work?
- Looking for rods and pistons for 700hp build
- Dealership says the two front O2 sensors are bad as the cause of intermitten CEL, are the K03s..more
- ECS magnet drain plugs work, in my "research"
- Prefered Oil? What do you all use ....
- After-run switch/pump for Allroad/2.7tt?
- best vacuum line to use when installing a turbo boost gauge? any thoughts or rec's?
- Question on DV's ...
- where to buy brackets to use 345mm b7 s4 rotors
- QUESTION ABOUT MY DYNO RUN, Plz help.
- anyone have their headlamp washers fall off? i was driving in some freezing NE weather where the wa
- best chip for 2000 2.7t a6 with tip trans?
- Need opinions on the coolants condition
- So has anybody been running the ATP eliminator series in thier S4?
- KO4s w/o the full fueling upgrade, stage 3- (?)
- Is it dumb to put a revo technik stage 1...
- Diagnosing 17547;17545 faults
- turbo swap
- What are some custom tuning program options for the B5 S4 and where to get them?
- 2.7T engine problems
- Best way to launch an automatic car....?
- Anyone ever up the displacement from 2.7 to 3.0 liters?
- New Level of 2.7T Performance, check out the crosspost....
- Echo!
- Coolant Temp?
- Engine Help
- Grounding Kit HELP
- NEW PARTS
- Common electrical connectors
- Ever wonder what our facility looked like?
- x-post HELP- Dealer only wants to replace 1 turbo... How do I argue?
- 2001 S4 wiring diagram
- **Projekt GT25R2 Update** X-Post
- Question on Revo chip
- Does NE1 have the Borg Warner or OEM P/Ns for the K04 turbos? Please post, TIA
- A.W.E. Tuning at H2O International September 25th
- Are the newer versions of the 2.7t engine more "robust"
- Fault Codes Due to Aftermarket DV??????
- short ram intake
- 2.7T first upgrades
- ----> EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help)
- Anyone using APR 5.0
- Projekt GT25R2 - Cross post
- Where is the pcv valve on a 2.7t manual A6?
- B5 S4 - I wanna stay convinced.
- Intercooler/boost controller/chip question
- Minimum modifications
- Extended Warranty (X-Post w/ A6 forum)
- 2000 s4 intercooler questions
- Newest Toy
- Starting the 2.7T allroad
- Kudos to ATP Turbo...x post
- custom intake?
- turbo help
- performance air intake
- Comparison of OEM K04s and Buehn Engineering K16 hybrids.....(X post from S4 forum)
- engine misfires when air temp above 88 degrees
- 5th Annual Audi Expo - Schedule:
- 9 days 'til Audi Expo! - Have we heard from you ?
- Kansas city area GTG this Wed at the Blue moose
- Surging after chip...
- Coils: Can anyone point me to a diagram that shows what the four pins...
- Should i replace my stock air filter?
- Do i need to fill my car with 91 octane??
- 5th Annual Audi Expo - Come be a part of history again!
- Torque Converter - ?
- S4 and A6 2.7T Piggie Pipes the same?
- Mihnea Custom Tuning in Colorado -- Last Chance
- 5th Annual Audi Expo! - It's coming!!!
- i see the write up for valve cover gaskets in the tech section. are the cam tensioner seals also a
- NEW 2005 PRICING!!
- X-post from S4 forum: Write-up on tweaking AMS Stage 5 car
- NOS
- X-Post:VAG data questions (LONG). Why is actual boost not closer to requested? Also low MAF reading
- With all this talk about Garrett turbos (at least on the S4 forum)...
- Looking for V6 Cam Lock Tool in KS or MO
- Leaking Oil.....
- x-post. Dyno Analysis. (graph inside)
- STFA and need a single concise answer please
- So I've actually got an issue I'd like to discuss in this development forum
- So quiet.. you don't even hear a turbo spin...
- burning oil smell source?...........
- Echo....
- X-Post not for the faint of heart. Timing belt carnage on 2.7
- quick need help with configuring old school iso cable and ross-tech software
- X post new 1/4 mile times. opinions needed
- X-post: Lookie what I got!
- Can a chip for a ko3 setup be modified for use with ko4s? . . . .
- anyone put an euro rs4 2.7 engine in an a6? (uk)
- from the S4 forum ( blown motor )
- TantrumWerks New Year sale on LaBree Motorsports Split Downpipes ends next week!
- Bosch FPR parts numbers: 3 4 5 Bar Fuel Pressure Regulators follow:
- How much boost is everyone running w/ K04/16?
- Paging Imolavirus....
- New to the 2.7T game.
- does anyone know if the apr k04 kit forthe s4 fits the a6 2.7t?
- Does anyone know a place that cross references Audi part numbers for fuel injectors into Bosch
- Octane on demand.
- Allroad oil Spil Service report x post
- TantrumWerks New Year sale EXTENDED on LaBree Motorsports Split Downpipes
- anyone have software optimized for k16s?.....
- Blown turbos?
