PDA
View Full Version : 2.7T V6 Discussion
Pages : [1] 2 3 4 5 6 7
  1. 2.7t Oil Temp
  2. Cam Chain Tensioner Screen
  3. Starts & Dies. 15-20 restarts runs dies & 15-20 runs & drives
  4. FI: Audi cvt oil?
  5. 2000 A6 2.7T
  6. 2.7t carbon/sludge buildup
  7. Low Oil Pressure Help
  8. Fuel Vacumn Lines
  9. 2.7T 04 BEL Auto NO Spark Has Fuel
  10. Help?
  11. 2.7t no boost
  12. 2.7t dumping coolant
  13. Camshaft Wear caulsing misfire
  14. Can i swap it?
  15. A6 C6 TDI 2.7 BPP oil leak
  16. Location of fuel pump control module 2008 audi c6 a6
  17. Audi c6 a6 allroad fuel problem
  18. Cant figure this out
  19. Faults faults faults! Some advice please!
  20. Building boost when it wants
  21. Subframe and turbo replacement
  22. 2.7t Bipipe Touching Rad Fan
  23. B5 S4 Starter Removal Issues!
  24. Help please....
  25. Diverter Valves/ Blow Off Valves Spitting Oil onto Hood and Engine Bay!!!
  26. 2002 Audi Allroad 2.7T
  27. A difference between the AZA, AJK and ARE 2.7 twinturbo motors?
  28. transmittion problem
  29. 2004 2.7t crankshaft only rotates 45 degrees
  30. Broken engine audi a6 c6 avant quattro 2007
  31. Tial 605 Turbos
  32. Need advice rattling /clatter top end
  33. No start b5 s4
  34. ENGINE HARNESS CONNECTIONS - 2003 AUDI A6 2.7T QUATTRO - HELP!!!
  35. A6 C5 Starter motor bolt "too long" (dumb noob question)
  36. My RWD 2.7t mk2 golf engine build question.
  37. Sensor Issue?
  38. Busted vaccum hose back of manifold
  39. !!HELP!! B5 S4 WON'T MOVE! Apparently no power to rear wheels :(
  40. 2.7T All-Road won't start
  41. B5 S4 Oil Change
  42. Separate Brake booster necessary for towing?
  43. '01 allroad transmission issue (works with tcu unplugged)
  44. Need some direction! B5 S4 ECU wiring
  45. 2.7T Headgasket?
  46. CODE P0141 (S4 b9)
  47. 2004 allroad 2.7 litre part
  48. Differential Service
  49. 2.7T Hard start when warm??? Need Help
  50. 2001 B5 S4 2.7 - Idle issues
  51. question about 2.7/2.8L timing belt replacement
  52. question about 2.7/2.8L timing belt replacement
  53. cam bearing torque specs
  54. JUst bought Audi A6 2.7 tdi special edition quattro tiptronic
  55. I'm lost please help
  56. where do i post transmission questions?
  57. custom PCV and catch can install
  58. Oil cooler hose B5 2.7T
  59. Did I just kill my valves? Same as in the allroad forum
  60. cylinder misfires new Denso spark plug damage
  61. Leak on the turbo oil feed line
  62. 2000 Audi A6 Quattro 2.7T spark plug gap NGK?
  63. Where does this go? Bank 2 wireharness two pole plug.
  64. Cold start pre-heater fan on engine
  65. 2000 Audi A6 Quattro 2.7t randomly dies at idle
  66. Transmission output shaft seal
  67. 0A3 bolt up to 2.7t?
  68. Starts then putters until it warms up.
  69. EVAP system P0441
  70. 2000 2.7 Quattro overheating
  71. 2003 Audi all road 2.7 overheating
  72. how do i drive my audi in turbo mode or switch to turbo mode when driving
  73. V6 mid-engine. Which manual trans code, or eng?
  74. Tolerance on timing belt alignment
  75. Different carbon buildup on heads
  76. Boost curve
  77. 2.7t cams making noise
  78. B5 S4 Triptronic transmission code?
  79. Timing belt jumped - engine destroyed
  80. 2002 Audi S4 triptronic
  81. 2001 Audi A6 2.7t Fuel Pump problems
  82. Catalytic converter issues **PLEASE HELP**
  83. 2.7 boost limiting
  84. Mystery Smoke
  85. B5 S4 misfire, can't figure it out!
  86. Coolant Warning; No CEL codes
  87. Misfires all cylinders bank 2 (4, 5, 6)
  88. Crankshaft Misaligned w/ Crankshaft, but Engine Runs Fine???
  89. 2.7T Power Windows and Alarm system
  90. Oil filter of audi A4 avant 2.0 2003
  91. engine oil of audi A4 2003 2.0
  92. 2 codes Random Misfires and misfires cylinder 4
  93. Just replaced aux water pump, now right bank won't fire.
  94. 08 w/ a Stuck valve
  95. Shifting between 3rd and 4th while maintaining constant speed
  96. Oil on spark plug, bad rings, head or worse?
  97. 2.7 or a 4.2 trans on a 2.8????????
  98. Vacuum Lines full replacement tutorial
  99. Fuel rail vacuum line
  100. Please help 2001 S4
  101. 2.7T-4.2 engine swap
  102. Oil between turbo and intercooler
  103. What brand oil and filter?
  104. Intermittent noise, possibly valvetrain after overheating at the track
  105. Down pipe removal- WTFudge?
  106. 2.7t B5 RS4 missfire
  107. No power at all. Like if battery was dead.
  108. motor swap car won't crank p0600 code
  109. Top Mount turbos!!!!!
  110. Alternator in 01 a6 2.7t
  111. Misfire in cylinder 1
  112. Fan control module write up?
  113. Boost leaks
  114. 03 A6 2.7t throwing misfire on all 6 cylinders
  115. Deleted N249 Throwing Codes
  116. allroad 2.7T smoked suddenly
  117. persistant DTC codes
  118. PLEASE HELP ME
  119. Unusual Timing belt tension failure
  120. transmission problems
  121. Piece on fan broke
  122. 2.7t Auxiliary water pump line
  123. 2003 Allroad 2.7T overheating
  124. ABT k03/k04 hybrid turbos?
  125. Anyone know if the 01E center diff is the same amongst the 2.7t's
  126. Lurching at consistant Hwy speed
  127. 2000 s4 fuel trouble
  128. Blow off valve?
  129. Alternator problem
  130. 02 audi a6 Quattro coolant leak
  131. 2003 A6 2.7T Trans Control Mod
  132. Vacuum hose leaking code p0492
  133. 2001 Allroad
  134. Catalytic Converter replacement? HELP!
  135. Quick question
  136. turbo or engine issue?
  137. Pulling Cylinder Heads--Help!
  138. No start with power surges during cranking
  139. Newbie Allroad oil burning issues!
  140. A6 2.7t Random missfire in needs of advice and help
  141. Stalling, Rough idling
  142. TOB?2001 a6
  143. Cylinder Head Reconditioning
  144. cracked piston
  145. 3.0 billet dipstick project
  146. Extinguishing check engine light 2002 allroad
  147. Messed up cam chain timing, bent valves
  148. Building out a 2.7t... looking for ideas
  149. Motor swap
  150. Misfires and clearing cel
  151. 2.7 T totally clogged PCV lines
  152. a/c bypass question
  153. 2.7T stock block - limits
  154. 2.7T APB - misfires cyl 3
  155. coolant leak question
  156. Source of plastic in oil pan
  157. Positive cable and battery terminal getting hot on 2.7t
  158. Clutch Randomly Quit Engaging 03 Allroad
  159. TDC setting on A6 2.7t
  160. AUDI 2.7t rough idle
  161. 2.7T - What Can I Remove?
  162. 2001 audi a6 2.7t
  163. So much SMOKE!
  164. Slow Coolant Leak
  165. How-To Do A Proper Boost Leak Test on A6/S4 - 2.7T
  166. Heater Hose Coupler
  167. need performance exhaust
  168. call for help after timing belt replace on allroad 2.7T
  169. skipped timing after timing belt job
  170. Blown Turbos?
  171. Engine Swap?
  172. power steering problems
  173. Anybody Else run laser platinum?
  174. Recorded 2.7t boost values - k04 vs k03 stock tunes
  175. Timing Belt Replacement Question
  176. Valve chatter....
  177. 2.7T - EGT delete - plug
  178. 2.7T engine bay streamlining - EGR, N70 delete
  179. So Woooooing sound?
  180. Mileage question.
  181. Another high-mile 2.7T question
  182. Coil Problem or ICM Problem?
  183. 2.7t allroad slow to start
  184. 2.7t Power Steering Pump for sale
  185. P0141 and P0036
  186. duel air filters
  187. Is it my Temp. sending unit
  188. Is 2001 S4 2.7 engine exactly same as 2001 A6 2.7?
  189. 2.7t slowly overheats
  190. 2.7T hydraulic cam lifters - 'lock'?
  191. 2.7T gasket set - mystery part
  192. Cam sprocket: torque, secure fit
  193. Camshaft hold downs
  194. new member! 2004 a6 2.7 s-line air filter question
  195. Very aggrivating leak...
  196. how to check coils?
  197. 03 Audi Allroad 2.7t blinking engine light/car shake
  198. 2000 a6 2.7t tranny help!
  199. 2001 S4 fuel injectors leaking when its cold out
  200. Engine block plugs
  201. EGT - actual vs. ECU calculated
  202. Cam angle deviation - normal? concern?
  203. Serpentine tensioner replacement
  204. 2.7t "Diesel" Engine Noise After Timing Belt and Valve Cover Gasket Replacement
  205. oil leak
  206. Pinout for ignition Module
  207. Allroad Tranny woes
  208. Auxiliary coolant pump replacement
  209. Independent dealer in Miami?
  210. Intermittent Oil Leak?
  211. 2001 A6 2.7t error codes need help
  212. Noise While Cold
  213. :: ECS Tuning :: Schwaben European Essentials Tool Sets!!
  214. creamy looking coolant...please help
  215. :: ECS Tuning :: Pentosin - Superior Fluids For Your Audi
  216. Help! I need PCV expertsF hose delete okay?
  217. Help! I need PCV expertsF hose delete okay?
  218. chattering noise under car when shutting off
  219. Default B5 S4 Identify this broken connector please! coolant/heat/ac of some kind?
  220. For Sale: 2000 A6 2.7T 6MT - $2,500 obo near White Plains, NY
  221. Camshaft Installation Guide
  222. APB engine - broken line top of engine - identification
  223. ABP - broken line identification
  224. How to fix an EGT sensor for good
  225. Mystery Oil Leak
  226. ProHeat Products-Oil Pan Heater
  227. 2001 Audi A6 2.7t
  228. 710N diverter valve
  229. Coolant question
  230. Stumped on rough engine - not coils I think
  231. Error Codes P1358 P302 Help
  232. 2001 a6 quattro 2.7t acceleration issues
  233. Vacuum Tubing hard?
  234. Audi Allroad running rough, misfiring. Pulled VCDS Codes
  235. Cold Air Intake for A6 2.7T
  236. Engine Swap from Automatic into Manual Car
  237. why only making 4 psi
  238. Help with 2001 2.7T !!!!
  239. I would like to acquire your failed TCU
  240. ISO 2.7t 6spd Manual tranny
  241. 2001 S4 In dire need of help...
  242. Lower Temp Switch - After Run Coolant
  243. Limp Mode - TCU issue?
  244. 2004 A6 2.7T Engine Squealing Noise after TB change
  245. 2.7T (allroad) Engine Won't Crank When Warm
  246. 2.7t gt28rs? setup
  247. Hi all - asking for assistance with P0118 & P0300
  248. Cam Position Sensor Code no start after accident
  249. low power
  250. :: ECS Tuning :: New PigŪ Mat & Dispenser Combo Pack!!
