View Full Version : 2.7T V6 Discussion
- Selling 2.7t from 2001 S4 and other parts... MUST SELL!
- Dash light question
- Audi A6 2.7t overheating
- A/C system issue
- What are your thoughts on oil-leak stop additives for the engine?
- car turns off i need help!
- P0171 - P0174 - P0300
- Check engine light flashes during...
- throttle body problems i need help
- cursed s4
- help! need a bumper
- Secondary Air Pump running intermittently
- Oil leak on drivers' side & oil in the bi-pipes leading to intercoolers
- B5 S4 Starter Replacement
- APTuning/APR Holiday Sale Has Begun, Nov. 23rd-Dec. 31st!!!
- exhaust
- 2.7t early engines = trouble?
- Newb to turbos. General care advice please?
- Fluttering VAC: Fueling, Ignition, Boost (or none-of-the above)?
- Oil suggestions for Montana Allroad
- s4 turbo identification
- Replacing front crankshaft seal & camshaft seals
- Where is the oil temp sender on the 2.7T?
- Tubo identification
- Secondary Air Injection and Catalyst errors
- '05 allroad 2.7t
- Couple Newb questions
- Can the passenger side head be removed without removing the engine?
- blinking check engine light
- Can't find EVAP Vacuum Leak
- BOV vs. Diverter Valve?
- Buring Oil Smell after start-up
- Anyone knows what of type spark plug OCT use with the k04 setup ?
- Cheap Blown Turbo Fix!!!
- coolant leak. Serached the forums already
- Turbos sending me to the Dentists, The first sign of turbo failure?
- Stumble Then C E L
- is this real
- remap for a 3.0L race engine
- brakes
- 90K and counting - miles and dollars
- Rear end thud when pulling from a stop
- Boost issues
- sounds like locusts attacking
- flashing check engine light under load - goes off if let off throtle (misfire cyl 4)
- limp mode
- timing belt change
- Humidity boost issues
- S4 boost sensor Part #078 906 051... can it be replaced with sensor for TT, RS6?
- what motor oil should i be using?????
- regarding k04 turbo upgrade
- WEIRD!! PLEASE HELP ASAP!
- Spark Plug Replacement
- engine code 16840
- opinions on chip-flashes
- NEED PLEASE 2.7t passenger side wastegate plunger with rod
- 01 Allroad Intake Manifold Spacer Vast 10mm Phenolic
- engine code 17535 and 17537
- Possibly the highest mileage 2.7t in the country.
- HELP!!!!!
- Help! Trying to remove engine/tranny bolts on 2.7T Allroad
- Emissions Problems
- 2.7T Cat replacement(s)
- Bad Trip
- crank sprocket
- ARP Chip in a 2.7t w/140K Miles
- Ebay Throttle Body
- 2000 audi s4 2.7 v6 bi turbo
- Need Big help on my audi s4 2000 clutch problem
- oil weights..
- How do I change air filter & pollen filter?
- Starting issues
- How many miles did you have on your first turbos?
- coolant expansion base sensor
- 5.0 bar FPR installation
- CEL PO346 cam sensor fault
- P0304 CEL 2000 A6 Quattro 2.7t
- Cam Seal/Plug Question
- Solid CEL
- Everything Wrong, Oil Leak/Engine Light Flashing
- APR 2.7t booast increase?
- Misfire Help
- 2003 A6 2.7 Quattro Turbo issue Please Help!
- downpipes
- HELP Please (long post): Car's acting up and in middle of Divorce:(
- new s4
- please help: 2.7t making weird noise
- In the market.
- Does more fuel in the tank equal to better performance?
- 6th Cylinder Coil Pack..?
- hp gains for 2.7
- 2.7T Engine differences??
- Fuel Cut-off switch
- Finally APR'd my 2.7!
- Camshaft Sensor
- Coolant
- What else could appear to be a rear main seal leak?
- Need help asap....oil leaks
- Low oil temperatures?
- stock downpipes to piggie pipes,is their any drawbacks?
- never ending CEL...
- miss fire
- My 034 engine/trans/snub street mounts came in today.
- 110k on Original clutch!cant get it into gear
- Really Need Some Help with Disconnecting MAF Connectors/Clips
- Meth kit
- Getting a random misfire on cyl. 5. My car is idling rough and.......
- OBD2 P1131 ERROR
- APR BiPipe or samco tb boot?
- request engine specs
- APR's Spring Into Power Sale March 9th- April 10th
- parting out 2001 2.7
- Completely stumped
- Random Multiple cylinder misfire
- PCV spider hose
- Cam Sensor and Cat Questions
- allroad rough idle, DTC codes
- spark plugs
- squeeking idle!
- Fuel injector stock or not
- Does any one know our cylinder diagram?
- Turbo Rebuild? Any Cons?
- Turbos
- 2000 A6 Engine Noise
- Any recommendations for an aftermarket warranty on a 2000 S4 Tip?
- advice for turbo change out
- Rough Idle with clutch out
- Acceleration hesitation problem
- obd reset
- Generic frozen PCV system story.... </sarcasm>
- Smoke coming out of the exhaust!!
- Smoke from exhaust
- Oil Leak, what do I check before changing gaskets and seals?
- Transmission Problems
- oil burning smell!!!
- X-post; FS: 01 2.7t OEM part out after Stage III upgrade, good for de-mod 4 trade-ins.
- DOWNPIPES...NEED EDUCATION!!
- EGT vin splits
- Turbos Fixing Themselves?
- INTERMITTENT Start-Up Issue
- Help bad white smoke and repair man might be smokin
- EGT sensor failure
- OK, so who wants to tutor me on solder-in chips?
- Crankcase vacuume leak (crossthread)
- ? Bad mpg 2001 S4 b5
- Help - I found red/green lights and button switch in fusebox!
- 2000 s4 thick TAILPIPE smoke
- Strange Noise has finally went away...
- Expected yearly maintenance?
- 2001 A6 2.7t issues
- Anyone know any good Audi shops in socal?
- How interchangeable are the MAF Part numbers? I have a Hitachi 06C 133 461 A
- can anyone help me..PLEASE?? Check engine light on!
- Clutch Problem, Need Help ASAP
- APR Stage 3 Raffle Winner is Announced Today!!
- Are Bank 1 and Bank 2 cam adjusters interchangeable? They have different part #'s,
- thinking of building a 2.7t with GT 28 rs and taking all pointers
- heating problems with my 2.7T
- anyone with information on tial turbos
- 2.7t differences
- how to remove starter on 1998 2.7t s4
- bad smell from exhaust
- Radio won't lock on channel for long
- bad n75 valve
- Service for higher mileage ?
- Sudden power loss - prob not turbo related
- 2001 s4 cel Help.
- Put in chipped ecu...now I have problems :(
- APTuning APR Chip/Software Sale !!! Best Pricing Ever!!!
- APR Announces 2008 Holiday Sale and Raffle!
- With higher HP engines, past 550 on the 2.7 turbo charged, pressurization is a big issue-
- 2.7t timing belt change. Does anyone have a cam locking tool I can borrow/rent?
- Upgrades for 2001 S4
- Changed my Diverter Valves Have a ???
- 2.7 t-turbo accelerating problems
- KO4 Turbo upgrade?
- No Boost, Lots of smoke
- Passenger side turbo (blown seal?)
- Carmel color oil, bubbles on dipstick, oil seems over filled when it shouldnt be....
- Throwing Intermittent P1131 Code @94k miles.....
- I GOT KnoNKinG
- help Plzz my ESP,ABS and CEL are all on
- i have some some problems about my b5 s4 plz help
- What's this part??????
- I Need some halp on PO103
- Is there any way to override the security lockout on an APR v 5.0 ECU?
- Stage III turbo kit for 2.7t with tiptronic (stage III minus)??? need help, is this true?
- 2.7t issues
- How to ps pump/cv axle?
- CAM SEAL HELP!
- 2.7T (S4) Engine Removal Guide how-to PDF
- 2.7T engine failure update...
- b5 coolant resevoir
- KO4 just installed. Now what?
- Any Difference Between Darintake Vs S Flo Set Up
- coolant sensor replacement
- Looking For N75 Upgrade for my AR 2.7T
- Coolant Leak?
- S.O.S.! Something wrong with front end!
- 01 S4 AIR BAG SENSOR. Need help
- just had a lot of maitenance done - 2002 Audi A6 Quattro 2.7T
- AutoSpeed K04 Install Specials
- o2 sensor? cat? please give insight
- 16486 - Mass Air Flow Sensor (G70): Signal too Low???
- allroad throwing codes
- Can't find a DYI and STFA for Timing belt replacement. Anyone care to send me a link on the tools
- X Post - Wicked Motorsports (WMS) - Presents California Custom Tuning
- x-post. what do you guys think about the following codes i pulled...
- simple boost question
- Help solve mystery repeat misfires on allroad 2.7t cylinders 4, 5, and 6.
- Hose Near PCV or Suction Pump?
- APR Customer Appreciation Day and Grand Opening
- abradable turbo compressor coatings. aka zero clearnance treatment
- High-mileage 2.7T and oil grade choice
- Oil Leaks under the engine. Cam Seals ???
- Help Running Hot =( Is It Blown Head Gasket? long
- Need help I have a 17799 camshaft position sensor Bank 2 G163 : Short to ground P1391-35-00.
- idle problem during shifting???????? much help needed
- Buying a 2.7T
- chip awe vs apr
- Does this boost chart seem normal?
- HELP,OIL IN ACCORDION HOSE!
- Suction jet pump
- RS4 clutch can't hang, what should I buy?
- Audi 3366 Tool (Cam Tensioner Tool)
- 2.7t engine swap into porsche 914
- Is this beautiful or what.
- Turbocharger
- Misfiring
- Stiff clutch and some grinding when going into reverse. Normal?
- 2004 a6 2.7t ECT Sensor help...
- need a lil help please
- P0491, P0492 2ndary vacuum bank 1 and bank 2
- 2001 audi a6 2.7t problem
- This weekends's project
- Another Bad EGT
- B5 S4 EGT Fault Code?
- Timing tensioner seal leak
- Question about this valve (vacuum leak)
- Part number for this broken part?
- Is it normal to have higher pitched spin sound when the motor is cold?...
- Swapping out my blown tracksports with some new ones
- ***NOW SHIPPING*** A.W.E. Tuning DV1 Diverter Valve
- New to Seattle, where is the best place for aftermarket cats??
- Black smoke under WOT
- Just completed Secondary Water Pump and Alternator Swap...long
- MAF sensor
- Turbo oil return line o-ring replacement...
- wastegate settings are screwed up...
- Misfire Help
