PDA
View Full Version : 2.7T V6 Discussion
Pages : 1 2 3 [4] 5 6 7
  1. Just bought a leak tester, guess what I am doing tomorrow........
  2. During key off/Vehicle shutting down.
  3. also what is the propper gapping on plugs for k04's ?? tia
  4. how do you count the cylinders? ..i have a cyl 6 misfire. looking down from the front which is it?
  5. how to disable the alarm system
  6. Timing belt will NOT tension
  7. Poll: How many miles did your turbos last before needing replacing?
  8. Minute warm up / cool down
  9. MOTOR BUILD ASSISTANCE!!! oil check valve o-ring mystery!
  10. Alternator issue's
  11. Engine ID
  12. Newly installed K04, oil streaming out of oil feed line at turbo housing.
  13. Need stock or blown clutch discs from all 6 speed cars
  14. O2 sensor related DTC's
  15. Cranks and cranks but it will not start..
  16. HELP... P1242 Injector Circuit Open Cylinder 6
  17. APR Presents Waterfest 14 **Inventory and Activity Update**
  18. Boost Problem of course
  19. Boost problem my mechnica cannot diagnose... any ideas?
  20. Secondary Coolant Pump
  21. K03 failure at 50.000km
  22. Well for those interested in doing turbo swap, here are some (bad) pictures
  23. 00 audi a6 2.7 6sp.
  24. spark plugs??? (Long..)
  25. DTC P1624 on 01 A6 2.7t
  26. Need help....slow temperature gauge reading when car is cold...
  27. Those who have an RS4 oil cooler does the seating surface area for the oil filter....
  28. Need electrical help, please read... (k04 b5, small things)
  29. Left Front Carpet got a "bubble" in it as if there was damage from jack stand or something.
  30. which chip is better
  31. Symptoms of a bad diverter valve???
  32. k04s and 2.8 heads or 2.8 intake cams or neither???
  33. APR Stage 3 Owner's Corral at Waterfest 14!
  34. POLL: best upgrades for $2k
  35. RS4 2.7 BI TURBO throttle revving problems
  36. Alternator hard to replace?
  37. ETKA gods help with part # and compitable modules
  38. Highest Milage on 2.7T Engine (S4/A6), original turbos?
  39. alternator issue
  40. Having problems locating the Coolant Temperature Sensor
  41. Having trouble locating the F5DP0R spark plugs...What are the plugs of choice nowadays?
  42. 2000 A6 Boost drop off
  43. crazy question of the day
  44. compression test numbers.. what do u think?
  45. something is scratching the driver side window!!
  46. Bought an 2000 A6 2.7T Tiptronic with 93k miles. Need advise.
  47. Differences between 2.7t in 01 S4 and 03 A6, both have manual tranny
  48. why is this in the way!?
  49. How badly do I need an axle /engine alignment? - (see picture)
  50. Slight Oil Leak- ok to drive ?
  51. There's oil in my Y pipe...ideas?
  52. pure motorsports group buy for 2.7t, timing belt kits
  53. "HELP" B5 S4 Auto/Tip---What are these connectors???
  54. Pressure testing question and turbo lady fear: sorry in advance for the Noobatude:
  55. Rear coolant line -- X over pipe Seals?
  56. This forum needs help...
  57. Chinese Turbos
  58. 2.7t Engine misfire even side of motor
  59. maybe getting a 2.7t A6 ... some questions.. timing belt snapped
  60. Anyone care to play Name That Oil Leak? (cam tensioners is not an answer)
  61. Tiptronic performance code
  62. 2.7t boost
  63. SOS Need help with GIAC Software
  64. anyone have pictures of...
  65. Vast Tip Chip Feedback ??
  66. timing belt walking
  67. NOOB question. Please respond! :)
  68. anyone run mahle forged pistons in thier 2.7t? ...thoughts..results?
  69. Max boost on a K03
  70. anyone have exp. with rs4 fuel pump in b5s4?
  71. how to change engine oil and oxygen sensor
  72. Starter Install (Help)
  73. Logs
  74. Piggie Performance
  75. eating gas like a pig and wondering why. . .
  76. Occasional no read from temp guage
  77. no start
  78. Buying my first audi S4
  79. I searched archives and found little on performing coolant flush. I want to do it on my '02 allroad
  80. Looking for a stock J Box ECU
  81. How accurate is actual boost from VAGCOM tool? 22PSI?? with stock fueling?
  82. Fault code for downpipes?
  83. Turbo upper bolt (under heat shield) Need help
  84. no start issue
  85. What's this ?? Can somebody explain how it works ?
  86. ceramic rs4 inlets on ebay
  87. Rear Main Write Up Tutorial (Tech Help) 2.7T B5 S4
  88. K04 upgrade / Tip Transmission
  89. Coolants going somewhere, but where?
  90. RS4 heads VS. 2.8 heads
  91. brakes lock for no reason.
  92. about cooldown
  93. 2000 audi s4 spudding under full acceleration
  94. spark plugs for 2.7T
  95. A/C issue. kicks in mainly when driving, shuts off when idle...
  96. Timing belt service - DYI?
  97. Engine/tranny pull help!
  98. Looking for a casa six speed S4!!!!!!!!!! Anyone
  99. No boost
  100. anyone done their cam seals themselves
  101. odd sound at start up
  102. thoughts on aftermarket rods and measurements. May get rostens instead of pauters, any pics?
  103. kmd dyno tune price offer...
  104. Clutch peadle problem
  105. Piggies
  106. Need help deciding between RS4 clutch kit v. South Bend OFE...
  107. Did anyone ever get this engine code???
  108. Belt Tensioners - two ?
  109. Torque converter clutch P0741
  110. </pokes head in> Hmmm, this looks like a nice place... wonder if I should start coming here
  111. Faulty Oil Pressure Sender
  112. 2000 s4 k04 troubleshooting
  113. Oil analysis
  114. Non turbo V6 head on 2,7TT
  115. Boost spikes with GIAC X chip a problem? Details inside...
  116. Wining noise from engine???
  117. So i finally got the clutch fan off, and i noticed a little higher oil temp is this normal?
  118. audi turbos vs aftermarket turbos
  119. Interested in opinions - no start issue
  120. TC replacement
  121. Has anyone here ever built a 2.7t motor from the short block out? (timing issue)
  122. I need a write-up on removing a 2.7t
  123. PVC Suction Pump 2.7?
  124. Audi 2.7l biturbo
  125. Can i use high temp water resistant grease for my diverter valves?
  126. Chipped car
  127. "Engine Temperature Low" Code 19537
  128. Help with 2001 S4 horsepower
  129. Leak in the turbo oil feed line - do I need to fix it ASAP?
  130. Self Adjusting Clutch
  131. Water in Oil - Help
  132. Torque Converter Replacement
  133. Quickaudi - the engine mounts cured the vibration! And a somewhat amusing side note: I took the
  134. Loud whine when steering?? help a Noob....
  135. Oil Pressure Sender Location Pic
  136. car is smoking pretty bad
  137. Does G12 have a shelf life if it has not been opened?
  138. Boost leak test results in "boiling" sound from engine--intake loses pressure to engine by about
  139. Oil in intake side intercooler hoses
  140. My intake air temp sensor seems to report wrong values
  141. NJ/PA mechanic recommendation
  142. clutch fan slightly out of line
  143. Audi 2.7LT Allroad Engine rattling
  144. Storewide APR Sale! - Ecodetuning.com
  145. When pressure testing intake, air leaks from rear of passenger head--anybody know why?
  146. 2.7 Cutch
  147. Suicide doors for A6 4.2L??
  148. Think I may have found culprit to the boost leak, please help me find this part...
  149. whats the BEST BESSSTT engine oil for this engine? B5 S4?
  150. High-pitched whine on acceleration
  151. What's the expected life of the TBB?
  152. alternator help
  153. i changed my o2 sensor!! oxygen sensor signals swapped bank1 sensor2/bank2 sensor2 readout???
  154. Coolant Leak !!! Help a Noob!
  155. has anyone tryed the ZiZa 10,000K D2S HID Bulb Set from ecstuning
  156. How long til my turbos go out?
  157. Has anyone had to put more than 6.3 qts in after oil change to get the dipstick to read right?
  158. Bad misfire under load
  159. Gouge in tranny help - midst of replacing drive axle seals
  160. mangled oil filter from pressure?
  161. BIG savings during A.W.E. Tuning's Week Three Holiday Sale
  162. A.W.E. Tuning Holiday Sale Week 3 Is Running Till Christmas!
  163. Surging/Lack of Power
  164. Anyone ever replaced the Engine Coolant Temp Circuit on there car?
  165. APR Motorsport Vacation Raffle Today!
  166. Race fuel? jet fuel? 110 Octane?
  167. Does anyone have measurements for the Cam Lock Bar?
  168. My EPL Dyno Day Photos...
  169. 01 S4 Running perfect until you go full throttle
  170. New O2 Sensor:::CEL on Again... "Back to the future!"
  171. C5 A6 2.7T owners....who's installed the AWE Tuning intercoolers?
  172. Audi S4 (B5) - 2000 or 2001 ???
  173. Headlight
  174. CT Tuning shop - GREAT experience
  175. Oppinions on Denzo Irridium spark plugs? (recent Vag-COM showing multiple misfires)
  176. APR announces 2007 Holiday sale and Raffle!
  177. Bought universal Bosh o2 sensor and wanted to know....
  178. I got a CEL on today....
  179. In need of cam lock bar...
  180. Normal Spooling Noise??? help!
  181. B8 S4: Exclusive Performance Preview
  182. My turbos make a high pitched sound when starting the car in the morning and then it goes away?
  183. pinging
  184. Dyno numbers
  185. Turbo fail? High pitch whirrring after Sears Point HPDE
  186. Smelly car? Burning oil smell?
  187. coolant loss - drips down to top of trany....its NOT my 2nd pump - any other ideas
  188. Universal o2 sensors
  189. water pump replacement
  190. Projected hp with K04s?
  191. clutch help
  192. Audi newbie - need help!
  193. Engine Dress Up......Painting the Y-pipe?
  194. 2.7 swap help
  195. APR Motorsport to bid for 2008 Koni Challenge
  196. Setting readiness problems (Cat. Converts and O2 sensors)
  197. Humming Sound Coming when I drive the car
  198. 2.7 Biturbo no start after engine install
  199. unsolved boost mystery
  200. APR Stage III Question
  201. Will a 2.7T fit into a '99 Audi a4 Avant with 2.8l in it now?
  202. Water Pump AGAIN?
  203. 2001 a6 maintence and mods
  204. A little help please: Repair shop says I have "Leaky Cam Actuator Seals??? --
  205. ok i tried searching: is this the best oil to use for?
  206. Where to buy K04s....
  207. GIAC phone number?
  208. How to .. Clutch job? Ive STFA. No answers.
  209. Ball Bearing Turbos!?.....hmm?
  210. Stage 2+ troubles !!!Help ??
  211. Anyone in NE doing timing belt job in the near future? I decided I am going to DIY mine, but I want
  212. transmission
  213. Foul Vapors
  214. What do you guys think of this diverter valve?
  215. Good & Cheap engine mechanic in greater Pittsburgh area?
  216. lost power 2.7t
  217. purchasing a new 2000 audi a6 with the 2.7t
  218. EGT sensors
  219. Turbo O ring issue
  220. APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
  221. whats 2080bar equal to psi?
  222. WAs the ECS««tuning''dot««com ! service good?
  223. Installed APR R1 DV's...is a flute-like sound from 2200-3000 RPM's normal?
  224. Introducing Clutchnet Corporation as a new banner advertiser
  225. Just wondering.....Help someone
  226. NEED TO BUY GOOD USED 2.7T ENGINE
  227. Does the 2.7t fit through a standard sized apartment door? if its on a cherry pciekr
  228. throttle stuck wide open
  229. UGH! Looking for some help here Re: referal for "reasonable $$$" TB change!!!
  230. help!!! smoking from engine
  231. so i just finished with piggie pipes and its nice but i want it louder
  232. how can i replace the jet suction pump on audi a4 2004
  233. Turbo boggs on full throttle
  234. APR H2O International Sale Begins Wednesday September 18!
  235. How many points?
  236. brake icon on bord blinking
  237. 2.7t.....P1171 error code
  238. Possible that Audi mistakenly put an Tip AA Ecu in a 6 Speed?
  239. couple of piggie pipe questions? getting ready to diy
  240. 02 sensors codes 17521 & 17539 back after swap
  241. MAF and O2 Sensor questions......
  242. Need recommendation for mechanic in Chicago area - Torque Converter failure
  243. Looking for some guidance on Timing Belt and 1st Chip upgrade:
  244. how do you set valve timing?
  245. wheres the best place to hardwire in my V1
  246. Temp display needle is intermittent
  247. quad turbos? whos ready 4 dis...im gonna buy two more ko3s, open my hood,
  248. Strange pinging noise when shifting
  249. 2.7T Allroad check engine light problems
  250. where does the after run fan disconnect?
