View Full Version : 2.7T V6 Discussion
- Oil Recommendation and Timing Belt Question
- Question re piggies
- Can a Turbo be made switchable ?
- and why does my samco tbb have to interfere with my front engine cover and the boost sensor?
- tons of s4 parts on teh classifieds
- oil temp whats too high?
- Strange Noise like a saw blade when starting the car
- What shall I do next....thoughts?
- new spark plugs and fuel pressure regulator
- Is Mobile 1 (0W-30) the right syn. oil for an A6 2.7t?
- Whistle noise from turbo?
- 2000 A6 2.7T Sound System
- getting 2 codes HELP!!
- New Project.....pix inside...
- Has anyone tried the "OEM Pentosin 5w-40 Synthetic Motor Oil" that they sell at ECS?
- K-04 turbos back on stock on Monday at Achtuning $2,150 per pair
- Exhaust on a 2.7t
- Boost Gauge Pod......hmm?
- At Water Wagons will you be able to reflash your ECU there?
- ESP light!!!!
- white smoke...
- unpluging the clutch switch to start the car with no clutch?
- 100,000 mile tune up question
- drivers side door wont unlock or lock using the buttons on the key
- Two Stock turbos?
- what should i do....
- diverter valves bosch 110's vs apr R1's
- TBB advice
- HELP........Alarm system is acting weird
- this forum is dead ; ( From The B5 S4 forum . ER Intercooler update ....
- what next?
- Insulating the Air Mass Sensor. Anyone ever tried this?
- The Million Dollar Question
- remote window mod
- Blow off valve vs Diverter valve
- A6 Automatic Transmission Pressure
- Allroad stalling - need help
- REVO SOFTWARE?
- is there any benefit to buying dp vs. moving cats and o2 etc?
- Disconnecting turbo engines
- will an s4 chip work in an allroad?
- The new K04s are in and I have K03s with 96000 miles - they are tied, but still turn, are they worth
- Timing belt complete parts list. "while youre in there"
- Timing belt replacement - any non-standard tools other than cam lock bar?
- clutchmasters stage 3 capacity
- Maximum pressure on a 169kw engine
- down pipes for Tiptronic on Tantrumwerks.com
- how could i tell? the car shakes at low rpms...but im on stick...
- turbos need service after 55k?
- RS4 $30,000 engine rebuild
- Help!!! Secondary Air Pump Issue 2000 A6 2.7 Auto
- Anybody know if a 2.7t would physically fit into an '86 4000csq?
- Engine
- cranking but not starting
- MTM Software Upgrades
- How to test viscous fan?
- 03 A6 Gasoline Smell - Any Ideas?
- Anybody with moded 2003 A6 2.7T
- Rotor size
- need new engine 2000 audi s4
- Throttle body cleaning?
- Timing change belt difficulty and cost
- designer of 2.7t
- Anyone need a Cam Locking Bar & Crank Pin?
- Need recommendation for mechanic in North Atlanta - Torque Converter failure
- Tiptronic: How to know if the seal on the TC has failed?
- 2.8 heads
- unbolting a front axle shaft
- 2000 A6 2.7t
- L Box whats compatable?
- Hi, I'm New. EGR valve doubt
- anyone in Detroit Metro area have a cam locking bar & crank pin to loan?
- APR Releases the R1 Diverter Valve!
- Rearview Mirror
- Diverter Valves
- Muffler size
- slight tapping from driver's side cam it seems
- Will a 2001 2.7T Tip A6 chip work in a 2001 2.7T Tip allroad?
- timing belt ??
- timing belt just done today now loud whining sound when accelerating
- Audi A6 2.7t tiptronic - radiator troubles
- A6 2.7t exhaust options
- 2000 a6 with 2.7t
- AWE Drive train stabilizer
- Weather killing/helping performance? Whats better? Opinions? Science?
- Vibrant Exhaust on Ebay
- Inmotion Chip
- Can someone help me put this jagoff in his place?
- 3 inch Intercooler piping kit on ebay? Worth it?
- Loud whine from turbos at full throttle
- Wrench size for 2.7t oil drain plug?
- Looking to buy a used B5S4 with 100k on the motor. Should I be concern about
- S4 1st and 2nd Gear difficulties
- Surging and down on power
- Fuel delivery problem?
- update oil lines 2000 a6 2.7t
- Value Question 4 all of you
- vag com
- anyone have a link for upgrades on this tranny or parts for it ,,triptronic
- I am looking for opinions... With knowledge to back them up...
- DV and TBB
- Turbos
- Does $650-$700 cost sound right for a 100,000 mile tune up on A6 2.7T?
- anyone know were to get an upgraded torqe converter
- can i change my timing belt without the cam lock tool
- clutch problems
- cutting my cats off
- triptronic how much hp can it handle
- 1k to spend on performance mods
- Obviously I'm new here.
- Cam seal leaks....twice!
- ECU
- 2001 audi s4
- hesitation with GIAC X at less than WOT
- Engine Codes P1128 & P1130.....MAF? Injectors?
- Vagcom: Reference code 18305 (In relation to lit "check engine light")
- 2.7T overfilled oil
- High pitch engine noise (sorry for redunant question still a bit confused),
- code 17125 P0741 035 torque converter lock-up clutch performance or stuck off
- Phisherman Fakes the Funk with Bogus Email Scams
- heres the deal i goofed at work and killed a 2.7t
- Is it strange that my engine took almost 7 quarts of oil?
- Exhaust Dilemma
- is there still a demand for AMS chips? are there any s4's out there not chipped anymore?
- '03 A6 2.7t with 68K. Noise at start up. Please help diagnose...
- Sluggish acceleration - help diagnose
- cat codes for CEL came before 80K miles warranty still cover it?
- I smell oil up front.
- changed mass air flow and...help
- Need help choosing a platform
- How many TIPsters out there modifying?
- Add a K&N Filter or Not
- Anyone think this is legit? catback system for 675? TYPO $1150
- RS4 Clutches now in stock and ready to ship!!
- Samco Complete Hose kits in stock at AWE Tuning AND...............
- xenon ballast
- anyone think these wheels would look alright or have a picture of them
- Oil Leaking from Iintercooler Hose????
- APR fase 3 kit, in a European S4
- A box ECU
- 2003 A6 2.7 rear spoiler ?
- 2000 S4 Q's -
- pictures of my a6..camera phone but not bad
- AWE S-Flo intake
- 2.7T Turbo Replace/Rebuild?
- Can anyone help with trying to get my A6 2.7t
- how do you tell if your car is 2001 or 2001.5?
- How to increase horsepower on 2004 A6 2.7T (86,000 miles)
- When is a good time to replace the exhaust gas temp sensors? more..
- RS4 Motor
- Car doesnt want to go into gear
- Hey everyone, I'm looking at buying a 2001 S4 and was wondering if there is anything I should...
- Stalling issues
- V6 DIS4-05 Ignition Wiring Diagram
- need a right side ballast
- Timing Belt on 2.7T
- Where can i buy the tool to compress the cam tensioners to do the cam tensioner seals?
- CHIP
- Wheels
- Turbo noise after turning car off
- Low boost with MTM chip
- Replacing ABS module on 1999 A6 with rebuilt from Module Master
- APR Stage III Questions
- Some problems
- How do I reset check engine light
- New Bailey DV Valves on Ebay
- Break-in period on my new short block?
- Autozone - VAGOM (1999 A6)
- Rear crank seal ??
- Oil Leaks-Clogged Suction Pump-Bad Turbo?????
- CEL 18032 P1624
- Burning Oil smell?
- S4 and A6 2.7T Power Steering pump the same? Mine died can get one fron an S4.
- what to do about my s4 avant in Miami FL Orig in s4 forum
- Battery Recommendation for 1999 A6
- 2001 A6-2.7t check engine codes
- newbie asking old questions about T belt
- 2.7's fully built bottom end potential?
- Has anyone changed their interior?
- Leminwinks settings for 2.7T?
- *x-post from S4 forum* - Question re: oil leak for the 2.7T BT.
- stage 2, have some stage 3 parts and time on my hands. Can I...?
- Radio in Safe mode
- Prices for Performance Upgrades
- I am hearing a weird [turbo] noise during acceleration...help Piggy????.
- 1993 90 s v6
- My 2.7T starts up and immediately shuts down....does anyone know from experience what the problem is
- I just spent an 1 1/2 changing my spark plugs because I had a misfire code come up on the VAG replac
- Service Engine Light
- car wont fire up
- Is it possible to log the MAP sensor and N75 valve to see if they are failing?
- Cam Position Sensor?
- Odd noise
- Does anyone know any good mechanic in South Florida???
- Oh My
- Need cats... Can I replace with downpipes?
- crosspost: help me get my AR into the shop under warranty
- I'm the #3 PW on this forum for 2006!!! Look out, No. 1 - I'm gunning for you in '07. ;^)
- Engine coolant temperature indicator w/ three beeps
- Kombi valve line, how much pressure?
- Need an S4 airbox
- Burning smell coming from engine
- Have problems with EGT sensors??
- 2001 S4 Which EGT is #2
- Wow..that's all I can say...
- Damn, I think I am in for major bills
- where could i get my car to pass inspection with tinted windows in the north jersey area
- Chip and ECU problems
- X-post from PNW forum, my mechanic looking for assistance with my TB failure
- XPOST looking for feedback
- What Forged Rods will work without clearancing of rods or boring motor?
- Anyone know the difference between the 3.0L V6 heads and the 2.7T heads?
- 2001 s4 sparkplug/low rpms issues
- need help, trying to put motor back in car after cracking k04 housing, >>>
- What dyno and drag numbers I can get from VAST stage III
- 2003 A6 2.7T Tip(5spd) Please read and help me figure this out
- VAG code suggestions
- Source for EGT sensors?
- Bars Leaks, Alumiseal, etc...
- new owner 2001 S4
- anyone here ever do an engine oil flush on the 2.7t ??
- Going to check out 2.7t A6 6spd, vag-com in hand...
- Recommended Chips
- VAG Interpretation Help (Inside)
- O2 ?'s: Which side is Bank 1? Which sensor is S1? Pre or post cat?
- S4
- Check Eng. warning light
- Newbe
- ABD Big Bore Sound
- 2.7T GIAC Stage 3- running rich
- Car is making a low pitched short lived WHOOOO sound on acceleration
- APR Holiday Sale and Stage 3 Giveaway!
- camlock tool for 2.7T
- 2.7tt... how much power before building the lower end???
- 00 2.7t fuel problems i think
- I NEED A TCM FOR A6 2.7T QUATTRO
- TRANSMISSION CONTROL MODULE AUDI A6 2.7 T QUATTRO - PART NUMBER
- Boost problem / leak I have problems with the boost, recently I installed
- The sweet smell of Coolant.... AGAIN!!!!!
- lightweight pulleys <x-post, B5 S4>
- boost, got none
- Very Poor MPG. Dealer saying that car is ok
- on injectors the question
- Can of coins rattling sound on start up............. intermitent
- 2001 s4 transmission
- Engine/tranny repair questions
- How should I be checking my oil?
- Help......... code 1113
- Are 'universal' O2 sensors okay?? I'm a DIYer and can splice wires, what
- serious lag and a strange grinding noise... help!
