View Full Version : 2.7T V6 Discussion
- Post Engine Swap Intermittent Cyclinder Misfires
- CAM locking tool
- Bad Blauparts
- HELP 2.7T Trouble
- GIAC software
- :: ECS Tuning :: 2.7T Maintenance Service Kits!!
- New pricing on AWE Tuning RSK04 Turbo Kits.
- 2.7t c5 Code P0301
- tuning for economy and reliability
- P0300 - Removed 3 coil wires no difference
- Ignition control price variance
- Cluster message and multiple misfire
- GIAC x flash
- 2.8 to 2.7T swap help
- How can I disable the Secondary Air Pump
- 2005 Allroad exhaust
- 2004 A6 Quattro 2.7T Frigid Weather weird event
- Codes 17755 and 17748 after timing belt change, plus 18258, 18265, 01314
- allroad engine noise, youtube link inside
- Compression Test Results....
- :: ECS Tuning :: D.I.Y - VIN Decoding!
- Help with belt tensioner
- Car Died Right After Start, Cranks Now But Won't Start
- 2000 a6 2.7t camshaft reinstall
- Won't idle, codes galore, and I'm exhaused
- P1423 Code
- timing belt cam align with crank??
- Help Needed w/ Timing Service!!!!
- Problem with my s4 2.7t
- 2001 audi s4 (p0563 and gear selector turns red on dash)
- Any recommended parts to replace while replacing chain tensioner gaskets?
- Please help oil leaking audi a6 2001 2.7turbo
- Happy Halloween 2.7t forum!
- 2.7T Timing Belt Tensioner System Issues - Lever Slips off the Tensioner Pulley Shaft
- Correct Coolant Temperature Switch for 03 A6 2.7T?
- Need help with installing Gates timing belt
- :: ECS Tuning :: Schwaben Tools - Back In Stock!!!
- Vented Oil Filler Cap Cheap?
- Blauparts Valve Cover Gasket Kit - Is it me or the kit?
- Headlight, turning signal, wiper, heat/air, brake lights and tail lights don’t work
- Engine Noise After Replacing Timing Belt & Valve Cover Gaskets
- 04 A6 2.7t s-line layout for bose amp?
- cam locking tool borrow in the SF bay area?
- Failed SAI Pump (P1411&P1423) Causing P0423 Cat Code?
- Turbo spoolin'?
- No start!!
- Cam Chain Tensioner Seals Replacement Issues APB Engine Code
- P0346 code, 2.7t starts idles runs fine but lacks torque
- Engine pull to R&R cylinder head(s)???
- B5 S4 coolant leak...help!! (Pictures)
- 2001 allroad problems
- Radiator removal for timing belt change
- odd whining/spooling sound
- 'battery light' issues
- Low Oil Pressure Light
- Camshaft Position Sensor Code
- 2.7T head gasket replacement write-up
- 2.7T - K04 - inlet/outlet pipes or hoses or adapters
- Few issues, please read
- Denver Timing Belt Job Dynamic Duo
- Timing Belt check
- setting cams on 2000 A6 2.7
- Allroad battery/alternator problem
- Help the BMW Guy
- New audi owner - advice?
- Engine Troubles - Need Some Advice
- Should I be worried about this, (with pic)?
- 00 A6 Heads
- Timing help, camshaft pulley rotated
- Good Mechanic in Wisconsin (waukesha Area)
- Abnormal Misfire Situation
- Turbo Whistle noise under load???
- "Restrice Bi Pipes" - How restrictive?
- Larger Fuel Pump needed - which and how?
- need help with mysterious coolant leak
- Valve cover and tensioner replacement
- timing check
- PCV system - spiderhose
- :: ECS Tuning :: 2.7T Timing Belt Kits!!
- Need a transmission
- Cooling fan failure > blown engine
- :: ECS Tuning :: Cam Locking Tool Kit!!
- Valve cover leak
- power loss when warm 2.7t
- Motor stored for 3 years - alternator, starter, AC comp, power steering
- n00b Ko4 question
- 2.7t boost trouble
- Allroad alternator in A6?
- Buying my 1st turbo engine car, what to inspect?
- Coolant Flush
- P0154 Reoccurs Please help
- WTB your loud Secondary Air Injection Pump
- Drive... Pop, hiss... no power
- Intake pressure (boost) and atmospheric pressure values and sensors
- WTB: m box ECU. Pref. APR or GIAC. (Car down again, ecu died second time in 2 years.)
- Timing belt change - write up
- Oil Light Issue (similar to...)
- AllRoad Transmission Issue
- 2004 allroad torque converter clutch performance or stuck on???
- EGR Valve vs. Secondary air injection pump Question
- Trouble codes 17965 and 16490.
- Crankshaft Position Sensor
- R&R turbo's 2002 A6 quattro 2.7T auto trans
- 2.7t overheating and almost no boost
- Spare engine - make it 'better'
- 01 s4 boost issue
- Advice/checkup needed on stage 3+ upgrade for my A6 2.7T
- Motor out coming up - down pipe vs. piggy
- oily intake manifold bottom
- cam chain tensioner issue
- APTuning Black Friday Weekend Sale - Custom Euro Plates - APR - United Motorsport
- 2.7 Twin turbo Drag
- Intake, MAF, tubes hose for stage 3
- Clutch pick up
- cel errors
- HELP! Rad hose removal! How?
- Going Stage 3 very soon, little fueling help needed!
- O2 oxygen sensors!
- PCV system
- Oil level sensor defective warning light
- NTN Timing Belt Tensioner Idler Failure
- Dino vs synth; 155k on dino, should I switch now?
- 10k oil change interval?
- engine first start after ko4....
- Could Shop Have Caused This Problem??
- Timing Help
- Stranded by massive coolant leak - 2.7T allroad
- HELP
- 2.7TT to 2WD Gearbox
- Cam plug replacement
- Shes a keeper?
- help adjusting timing 2.7t
- Cam Chain Alignment ... or not.
- Vacuum for combi valves?
- 2003 A6 2.7T Issue please help!
- blue devil head gasket repair
- HEAD GASKET REPLACE
- Electrical Hickup as Car Shifts
- New to Audi's, need Evap advice
- cam seals w/o ruining valves
- What is this? And where....
- A6 2.7T Misfire can't fix problem...HELP
- Backfire
- Expert Help needed!
- Code P0741 HELP!
- APTuning End of Summer Service Specials - Timing Belts, & Alignments!!!!
- Help with a part # please
- HELP ME SPEND MY $2000!
- Audi timing belt replacement cost
- 2.7T timing belt job this weekend, does anyone have a cam lock bar in the Boston area
- Codes
- Coolant leak - plausible cause?
- 2001 A6 2.7t Couple of problems
- Throttle body diamter - boot clamp
- need help!!!
- I Need Engine Pics
- Lost boost, now 16487, 17965, 17834, 17743 codes
- Justice Brothers tune-up
- 2001 A6 2.7T Broken Timing Chain?
- APR Summer Sales Event, Now Happening at APTuning!!!!
- 04 A6 2.7T S line seat belt chime
- 04 Audi A6 2.7T S line Battery Meter ISSUE
- 04 Audi A6 2.7T S line CHIP
- Diverter Valves DV - what's the verdict
- 2001 Allroad 2.7 issues/questions
- Breather Hose Assembly???? Boost Leak???
- Coolant Leak
- car shutters under load only when warm, no codes
- air pump and EGTs which first?
- 02 A6 no start
- 2.7T Fuel Rail Questions...
- New here. I'm a machinist
- 2001 s4 b5 2.7T overheating and losing coolant
- Catalytic Converter - Cheap Fix from Dealer
- P0300 intermittent misfire code
- Cracked my FPR Line... oops!
- Code P0300b
- buying an 04 2.7t S
- cracked upper oil pan
- Part identification
- Looking at buying upgraded A6 2.7....come on in for details
- Help, Advice Needed....
- EGT?
- 00 s4 wont start up after replaced tranny
- 01 A6 2.7 T
- Whys is shifting hard?
- Valve cover issue
- cps sensor
- Ball Park on a clutch job on a 27t?
- Tiptronic Issues
- C5 A6 2.7t downpipes
- APTuning New Years Timing Belt Install Special for Virtually all VW/Audi Models!!!!
- check engine light
- Changed Both AGT's now vacuum hose connector doesn't stay connected
- Exhaust gas temp sensors
- Car is messed up.
- strandman
- APR vs GIAC?
- APTuning/APR December to Remember Holiday sale!!!
- engine codes
- Arrrrrggggghhhhhh
- stage 2 a6 2.7t straight pipe
- A6 ignition problem
- 2001 A6 2.7T ECT Sensor Location
- Do we really need the EGT sensors?
- any1 knows what is that conector?
- 00 01 02 Audi S4 OEM Fuel Pump Assembly Sending Unit
- allroad 2.7t Camshaft Timing
- auxiliary water pump leak
- 2004 A6 2.7T - grinding noise from engine on driver side
- FAQ on differences on Stage I, II or III?
- broken timing chain
- Secondary Air Pump...
- turbo problems ? help !!
- A6 2.7T 6sp won't shift into any gear
- Are EGT sensors interchangeable?
- Hood won't open
- Torque specs for Head and cam bearings
- rough running A6 2.7t engine
- BOV Upgrade
- s4 stock turbo?
- 17964/P1556 - Charge Pressure Control: Negative Deviation Code HELP!!
- Vacuum leak located, how do I get a replacement t-fitting part?
- Help with codes P0431, P1128, P1130
- 2001 Audi Allroad multiple missfire, code 16684, PLEASE HELP!!!!
- 2001 Audi Allroad multiple missfire, code 36936, PLEASE HELP!!!!
- Charcoal Canister bypass Questions
- Engine Restorer on 2.7t
- Check Engine Light and ABS/Brake lights..I have codes P1606/P1131/P0300/P0115/P1396
- 2.7t building the heads
- I need a RSK04 wastegate actuator!!
- Headlight washers
- ECS Tuning KO4
- Cam Plugs?
- 3391 tool dimensions
- 2.7L with GT28 turbos ECU program?
- Revo Technik Spring Sale Marth 27th - April 11th 2010
- Random/Multiple misfiring
- BOV!
- Oil light/pressure light turns on after 4k rpm
- Codes, Please help: EGT's?
- Turbo Failure
- 2.7T Engine & LPG
- 2.7 engine noise
- VAGCOM requested boost lower than actual
- engine problems
- Bad APR tuning cauing ECU malfunctions?
- Valve cover stuck
- New Turbos?
- oil in intake 2001 a6 2.7t
