- Radio is on, but no sound is being played.
- Default Coding Central Conv.
- Audi A4 B6 (2001) Quattro AVJ engine 400-500HP build.
- Transmission leaking from breather valve
- Engine not working properly after changing timing belt and chain tensioner 1.8T
- Random “ground fault”
- Car problems
- Broke my sump baffel/restrictor when taking of the oil pan.
- Seats swap
- 07 RS4 interior compatibility
- Coolant light blinking
- P0688 can't find what's causing it.
- Misfire on Cold Start
- Cold air intake
- Timing belt broke on highway 04. 3.0 is it the end?
- ABS module solution - replacement
- B6 A4 Cabrio headlight parts wanted
- Disable Door Auto Lock
- Plug and Play Xenon
- Brake Fluid Flush Problems With Pressure Bleeder
- Code for used Symphony II system
- Auxiliary 12v power supply
- 2004 A4: New member sign in first time
- Audi driver side lock problem
- oil light while driving
- Would this work to fix my Catalytic converter problem?
- Red oil light and cylinder 6 misfire
- Knocking sound on the back of audi a4 2006
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- 2004 A4 1.8t boost problems after new turbo!
- Fuel Vent Help
- Rough idle, engine shakes, cylinder misfire...
- UK: A4 Audi b8 fuel regulator switch
- BG: a4 1.9 tdi b6
- 01425 Rotation Rate Sensor, reference wire
- B7 rear brakes on B6?
- Coolant leak
- 02 front left door wiring harness
- Swap transmission
- Coolant leak under transmission area
- P2681 / 2181 - 2017 A4
- A4 B6 2.0 (ALT) autom. - no crank
- ES: Can someone pass me link to where i can get these buttons (europe)
- A4 Avant B6 Exhaust Fitment to Sedan
- LT: Disco party with lights
- Audi b6 bose pinout 8e5035223e please help
- Audi a4 quattro to golf mk1 conversion
- Help! Low beam headlight out!
- Subframe help, confusing quotes
- Help - sunroof water leak
- power relay audi a4 b6 1.8t wiring diagram
- manual trans prom
- SK: audi a4 question about silenblok in the front arm
- Help! 2019 A4 starts but won't move!
- Passenger side Windows not working
- ABS module Availability
- Terribly irresponsible audi owner
- auto to manual trans emisions test
- Need buying advice please- Multitronic apocalypse??
- NZ: Which Audi do I have?
- Issue after cat replacement
- Car running but locked out!
- audi a4 model help please
- SK: PR numbers and vincode
- b6 3.0 cranks but no start. no prime in on position.
- Missed connection
- Sputtering at 10-15psi
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- Trunk not opening electronically. Onlt works manually w/Key
- Coolant temp gauge problem linked to battery disconnect? Throws code 01039
- Do B5 seats fit into a B6?
- Relay socket (under ECU) - Audi A4 Avant (2004)
- Issue with computer 1 and 2
- Battery removal
- Starter is sounding tired 2003. 3,0 v6
- Car "stutters" when coming to a stop/turning
- How to
- Clicking from rear quarter panel.
- 2017 A4 stalling. Please help
- WTB: Credit card drawer and mechanism
- Key hits my knee.. ideas?
- 1.8T Stage 1 Boost Leak or Limp Mode?
- Aftermarket hoses?
- Climate control Heating issue
- ABS Controller fixed
- right hand lower suspension arm
- Door Lock Barrel Replacement Only?
- 2002 B6 Odometer and Trip LCD failure
- Shifter issues, B6 6MT, won’t shift side to side
- Car won't start and key doesn't work
- Need help with a part number please.
- Fun with LED Markers: turns work but parks do not
- Audi A4 B6 2.0 Negative Fueltrim Lpg, Positive fueltrim Gasoline
- 2.4 BDV and CVT - shuddering
- Sqeal/grinding in wheel -- the plot thickens...
- audi a4 b6 ccm draining battery
- audi a4 b6 2004 owner's manual
- 2002 A4 1.8t/ Cranks but doesn't start.
- 2005 1.8t Only reverse works
- NL: Can Lo signal short and lots of Error codes - Need tips/wiring diagram
- NZ: Why is 1.8T Quattro Rear Bumper Grill Only on Some Cars?
- Stage 1/exhaust upgrade
- Won't start from cold first time anymore
- NZ: 04 Audi 14 1.8
- Drain under battery is clogged...plus chirping sound in wheel
- Stock Fuel System Injector Upgrade
- FR: Help needed for oil leak - any guesses?
- Help Needed With A4 Cabrio Stereo Wiring
- Audi a4 1.8t 20v g28 fualt after engine rebuild
- Preventing CEL With a Test Pipe (1.8T Quattro)
- AUDI 02 a4 quattro 3. 0
- Gas tank collapse and fuel sender damage
- Left high/low headlight out
- Creaking/Rattling/Squeaking noise inside steering wheel.
- 1.8T - Set up and adjust the wastegate actuator... ?
- New owner, what door can I get?
- Weird problems with intake
- US: 2004 Audi A4 immo?
- American message board members.....
- Will a b5 driveshaft fit into a b6?
- starts and shuts off, flashers do not turn off key fob
- Car wont crank at all
- Automatic Transmission
- Long time AW member here. I just want to post back and say there is no other forum li
- 2008 Audi A4 TQM
- Torn inner cv boot. 2003 a4 3.0
- PRNDS fault
- Disconnect abs and restore speedometer ?
- 2004 Audi a4 1.8t 6speed manual w/clutch frontal damage assessment.
- Greetings from SuperSprint Italy
- 2002 A4 B6 1.8T FWD standard
- Key Fob 2017
- 3.0 engine harness for 2.7?
- UK: Audi A4 FSI SE Fuel Pump purchase?
- Any one use a $15 cable + CD Vagcom
- Question on Comfort control module
- Junkyard B6 3.0L - Need Help Identifying this Clutch & Flywheel
- Cruise Control retrofit not engaging
- Replace ATF fluid or torque converter solenoid to fix P0741 code ?
- b6 a4 3.0 into b8 s4?
- Bad idle to high idle to flashing engine light low idle
- UK: Audi A4 3.0 V6 blocked oil pickup
- 2001 1.8T Quattro Boost Gauge Installation
- Timing belt or Crank position sensor?
- Audi A4 2.5 V6 Diesel cylinder missing
- turbo kit for the 3.0
- NZ: 2001 1.8T Quattro Catback?
- Speed sensor. No speedometer 03 3.0 manual
- 2004 Secondary Air Injection function question
- Cd chqnger not working
- AU: B6 1.8T Vibration at idle & high RPM
- Boost Kits?
- SLOWER after APR 1+
- ECU file format and protocols
- A4 3.0 ASN -02 oil pressure
- Help-Water leak from Sunroof
- Not making boost
- short-to-ground, now passenger footwell light doesn't work
- Question?
- Question?
- My trunk opens when I switch my headlights on
- Transmission bad or?
- Replacement or rebuild of CVT for 2002 1.8T FWD?
- Leak
- 2003 1.8t - misfires, high idle, no boost
- 2004 A4 1.8 - Multiple codes being thrown after head gasket rebuild
- 2011 Audi A4 2.0 radio no sound CD players works with sound
- 2003 AUDI A4 3.0 AVANT - PROBLEMS
- Motor swap into a 2005 B6
- Windows won’t roll up after crash
- 2005 audi a4 b6 1.8t quattro
- Audi B7 2008 S1 Quattro replica HELP?
- 1.8t vs 2.0t
- Will a 52mm boost guage work for a vent mount
- 2004 1.8t running rough
- Electrical Connector - Quick Question
- Water in Cylinder 2 after headgasket replacement
- ABS/ trac control lights on
- RS: Deleting fabric d1s bulbs?
- Coolant issues
- Vibration when decelerating in gear
- Wheel fitment question
- 2003 audi a4 2.0l B6 gasoline
- Oil Dipstick
- EE: Cilinder?
- 2004 A4 B6 3.0 rear rotor/pad?
- LED BULBS?
- Automatic Transmission Issues in D
- Low Beam Bulb Size
- Creaking Noise
- CARB Legal Catalytic Converters
- NL: Bose retrofit sedan
- Stalled, crankes but not firing up, 38 fault codes, ECM broken?
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- Audi A4 B6/B7 cup holders
- 2003 A4 1.8t cranks but wont start
- Engine change
- Convertible Coilovers?
- Abs light and steering wheel shake after jacking up car
- B6 A4 Car starts and immediately shuts off also instrument cluster not working or a.c
- Fault code on 2nd day of ownership
- New B6 Owner
- Bought 1.8t off of a careless, terrible owner!!
- Seat compatibility - B6 and B7?
- What connector is this?????
- 3.0 coolant hydrolocked? Riddle me this!
- Very very Hard cold start
- Crank no start, coolant temp/level codes and more(please help me)
- 2004 A4 Quattro - Intermittent Limp Mode, P0706 Code when Issue Arises
- 2004 audi a4 b6 1.8t won’t start
- B6 Avant starnge electric problem
- 2003 Audi 1.8t Endurance racing
- Vag com errors- headlights
- A4 B6 3.0 asn
- Seat belt warning enable
- Audi won’t stay running for more than an hour at a time?
- Water pump failure? And rough repair cost
- 2003 Audi A4 3.0 Throttle hesitation
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- No ignition/turn over, No noise but lights come on?
- Heat only blows when interior circulation button is on
- 2004 A4 Quattro 3.0 Vacuum Leak Fixed, Now Another Issue!
- 1.9 TDI surging idle.
- Parting out 2004 A4
- I think she's dead, Jim....zero electrical after car shut off randomly
- Air snorkel direction
- Audi A4 2.0
- How to changing transmission range sensor write up.
- Trying to remove turbo , stuck
- Help! we screw up my car
- Spazzing transmission
- 1.8T Tuned Timing Belt Question
- Buzzing sound from interior air ventilation
- Needs motor w/AMB eng code manual trans
- AU: 04 Audi A4 B6 1.8T Quattro overheating
- Audi A4 2002 AVJ 1.8T QUATTRO lack of power
- 05 1.8T with stage 1 apr, still slow. What’s wrong?
- MMI has no sound
- BG: Peeling buttons
- Strange hole spitting oil on bell housing
- Coolant leak from front diff?
- '03 A4 1.8T Turbo issue
- A4 B6 1.8t Boost PSI
- ZW: Mr
- '03 A4 1.8T Quattro NO CRANK
- AUDI A4 CVT Transmission
- Replaced starter and still won't turn over just one single click
- Troubleshooting Drivetrain Clunking Noise, Car Shuttering When Hot
