- Found a nice daily driver.......what do you think?
- US a4 2.8 no start!
- Oil Pan Gasket - Use with or without gasket compound/silicone
- driving on the highway today, I blew my engine by braking a rod
- Installing test pipe without a lift = major P.I.T.A.
- Got some Bosch Icon Wipers
- Seat Replacement
- PO441 EVAP Emission Control System Purge Flow Fault
- Dreaded bubble of death RIP rear-view mirror.
- Anyone relocated their DV to the TB hose?
- Are the CH and M boxes Compatible 2001 1.8TQM?
- So it looks like I will have to cut and refiberglass my abt sideskirt reps to make them fit right...
- Mike @ Purems Question for you about your resurfaced flywheel
- Anyone make their clutch switch into a security feature?
- s4 aka killer
- whats the life of the coil packs in the 2000 1.8t?
- Angry Alex to the white courtesy phone,YGM...
- it must be that speedy is working on the wheel faq or i pissed him off
- Are the R and L front ABS sensors interchangeable? Other possible issues if ABS kicks in 'early'?(m)
- WTK: rear view manual mirror from 96 will fit a 2k w/ auto dimming
- I can see some brown residue in the coolant reservoir. Is that OK?
- Oil filter question >
- Hmm... I like but so overpriced
- Quick question
- So I'm beginning my 9 days of not being at work!
- When did AoA send out a letter regarding the timing belt?
- Still have not even ordered my trans for my car.
- on another note.... bad fuel mileage = chip
- just ordered greddy fmic... i could feel my wallet getting lighter as i made the call
- OT: Followup to the ANGRY key marks that were left along the left side of my car
- Am I risking too much by not flushing the break fluid?
- Got a strange package in the mail......with wierd markings on it?!?
- A4 carnage.....
- Universal CAT's
- While changing the TRE I overtightened the top bolt and it snapped.....
- Pics of my powdercoated valve cover installed:
- I think I am going to try to do the wheel bearing job myself ...
- ATP TP=smiles smiles smiles smiles:)
- 96 2.8Qm Wheels
- I haven't seen this vag feature yet. Where is the feature to change my tranny fluid?
- REPOST from Weekend - For Weekday/Day Crew - Need help with car.
- Ok I got the right one this time...Carfax anyone? 3p3aa46k0st542819. thanks
- any of yff's on here do this?
- Would I need to do anything to reduce pressure in the brake fluid reservoir, etc. while resetting
- unlock/lock button not working
- Fixed my door lock vacuum module for $10.50!
- why are aftermarket injectors made for the ko3+ on B6's but not on the B5?
- Is "oil sludging" a common problem with the 1.8T motor?...
- Opinions on wheels? I can't decide on which I like more
- Is this ECU chipped?
- cam actuator question
- hmm... nice deal i guess
- Bleh, just another little thing to annoy me...interior chrome (?) door pull is now loose...
- check this out
- Paging ModifiedA4: do I have to submit 3 caps times to be entered-in on the site...
- would like to borrow a VAGcom reader in moco area MD
- so any suggestions??
- do quattros have the same engine block as fwd?
- Something ALL car lovers would love...
- 275 for S4 Sides seem a bit much??
- What ECU part #s are compatible with a 98 1.8T tip besides 8D0907557P?
- Sunroof Leakage?!
- What kind of turbo does APR stg3 and 3+ use? How do they compare to the GT2871R?
- Door hinge creak-STFA and still no solution-
- forgot to mention the ricer i met/saw yesterday at the dyno...
- Ok so driving on the highway I hear a loud noise almost sounded
- Did my first CAPS run today...not really impressed... :(
- Can anyone help me out with part #s?
- 2001 A4 rear strut upper bolts (are they stretch bolts?)
- Oil Cooler Question
- Anyone have a socketed ECU they would be interested in selling (for GIAC chips)
- Looking to go bigger brakes....
- Part number for A8 rotors thtat work with the purems brackets...?
- mod day complete...
- Different Motors for a4
- roof spoiler for b5 avant
- so nice
- N00b Trifecta BLOCK!
- 1999 A4 turbo APR chip
- 1999 A4 1.8 Turbo
- Can I run k03 software with a k04 and 5 bar fpr?
- Does anybody know what the heck this? Part # K03005CL5024863 || D58145703L
- still intermittend boost problems, logs within
- Need tools-3366 cam tensioner and transmission drain plug....
- Wish that I had a accurate Carfax report on mine before I bought it...
- Can anybody spot me a carfax report?...
- Avant rear hatch strut sources? Autohaus Az is out. Anyone know another reasonable source?
- Can anybody spot me out a carfax report??...
- Looking to do spark plugs on my A4 what are resonable ones to get
- Bentley / Torque spec request
- MIG welding exhaust hanger while on car. Unhook battery? ECU?
- Help, anyone...!?
- I'm having a problem with my new GIAC chipped ECU...
- Reminder: Deutsche Marque Concours Sunday May 7 2006 Vienna VA (open & free to all Audis)
- When you guys have done boost leak detectors with air compressor.. did you just..
- Attention: Keep an eye out when attending group meets
- I commited 3 letter sin
- A4 front suspension
- Anyone interested in trading my VIS cf hood for a stock one?
- Interior door panels interchangable ???
- Post a picture of your favorite B5 ever (AND NO, it can't be yours)
- what is the proper name for this plastic piece..?
- so which s4 user would that be
- Got my new C. Arm on in under 45 min from pulling in to having the lug bolts torqued back town. ;)
- qfrog
- Its alive! Here some quick vid clips
- To part out the car or sell it whole.. I would hate to part it out. Anyone have any suggestions on
- A8 upgrade Qs for all and Mike at purems
- if you guys dont mind....can i see anyone thats got s4 wheels....original or the 18" replicas
- well just got back from dyno...
- fuel gauge goin crazy... 97 2.8 qm
- Two Questions - Rear speaker size on Avant, and AWW/ATW kombi interchangibility...
- Skyline drive picture from today
- Help! 99 a4 1.8t Q won't start
- Whats the going rate for a stereo system install?
- Broken turbo stud
- how bad is it that my flex pipe just broke and is totally seperated? how should I drive it or should
- Any pix of silver leather with aluminu trim??... (already searched)
- in light of my sedan's high probability of being incomplete by may 8th
- Link to Skyline drive thread AWMA crew had today...Pics
- Tranny & clutch question!!
- need help husbands car broke down
- Audi Streets of Tomorrow A3/RS4 Impressions -- Audi ruined me! (long)
- Did Valve Cover Gasket and spark plugs today, was very happy with
- Painting bumpers?
- 1997 A4 CD Player Installation
- airbag light just came on, searched faqs......
- Damn, there's something to this chip business!
- Does anyone have the 8D0-863-822 sound dampening pan installed on their car?
- Can I pick up a oil drain plug sealing ring at PepBoys or Autozone? What size am I looking for?
- whats the best set up for a custom exhast for my 01.5?
- who knows if this will work
- leak from valve cover gasket in rear where the half circle gasket is...
- Whats the best way to get the serial # from an installed turbo? Is it even possible?
- Anyone try ICE by Turtle Wax? AMAZING stuff
- Changed to s4 seats , airbag light on
- 2.8 engine mounts are in. I dreaded the install, but it was very easy. Feels much better now
- Euro Barrett Jackson auction for my car. Place your bid
- anyone watching the "racing" on Speed right now?
- wish me luck, im about to start the audi after some major head work
- What intercooler is the best for a 1999 1.8 a4?
- Just a reminder for teh B5 guys...(KTR GTG)
- Missed this weekends mod thread. Does ordering a sh!t load of parts for next weekend count??
- Problem with rear brake job....
- Change w/ stock or upgrade???
- PAGING ABUHUN! please delete your addition to the FAQ
- Gas pedal feels heavy when excelatring any theories?
- Urgent TRE Change question...
- Brake Shudder
- I think my friend's Wetterauer chip is requesting too much boost. Please advise.
- Fire extinguisher - aftermarket sound system
- picture request; black flik justice's (yes i searched)
- noob question: how do i check for a bad coil pack without a VAG-Com?
- where to get window guides?
- EPC light is on but i can still VAG the car
- looking thru the new mt i got today and noticed a couple of things
- Any good wheel shops in Socal (Orange CO. or I.E.)
- I still trust our B5 forum: where can I buy a die to re-thread a ball joint....
- Paging JETTARED! DELETE your addition to the faq please
- New tool post....
- just installed valve cover and forgot to put the
- Mintex Redbox
- sunroof Issues
- And you guys thought the format in the vortex was bad...
- Found my boost leak!
- changing/addning gear oil? 97 2.8 qm
- wewt finally got my old account back! when i made this account my A4 was stock and had fewer miles
- any common places for a gas leak?? 97 2.8 qm
- Anyone have info on the Samco turbo inlet hose?
- Can someone please tell me if the part #'s are the same for a Catalytic converter...
- OK quick question,
- Those who own Magnaflow exhausts come in ...
- Got my GIAC!
- Late Night Weekend Mod / Maintenance Thread: What is going on this weekend?
- some drivers deserve to get shot
- Ha anyone converted a PES T28 turbo kit....
- Hartmann Wheels needs more room in the warehouse, blem and clearance items need to go!
- Catalyst replacement/elimination?
- Rear roof spoiler install HELP? ANybody done this before?
- *plugs fingers into ears* I've decided on Vogtland/Konis. You can't change my mind. LALALALALALA....
- Finally settled on a new sig (same image as last night's, but cropped differently)
- did i miss the friday "weekend mod thread"?
- check engine light
- Thanks again TighTT... "unpimp the auto" :)
- Turbo Timer
- After changing TB there is a mechanical whine that correlates with engine speed.
- Check engine light- hate it!
- Hit/Skip
- ummm...any comments?
- Secondary air pump problem...99.5 2.8q
- Help with door locks...
- Removing Brake Reservoir Screen
- Missing Stickers
- Not my best workmanship for photography, but any from this batch look like sig material? (BWW)
- All Vibrant exhaust are on sale:
- 58k on my '01 cpo...best way to approach timing belt issue?
- How to activate euro-style parking lights with turn signal
- Anyone have the PSS9s on their B5 1.8T? What is the height adjustment range?
- What is the answer?
- new DV, new N75... still intermittent boost problems..
- Can't seem to find an FAQ to replace window regulator...anyone want to help? Got the part from ECS..
- Supersprint Center Muffler for V6 Quattro On Clearance
- Cheap pair of used halogen ecodes on ebay...$170 shipped with broken tabs..
- i need advice!
- Can anyone tell me if an aftermarket bolt on cat for a 2001.5 1.8t will fit my 97 1.8t? Thanks.
- Any B5 30v'ers running Tein Basic coilovers?? Need advice...
- GilliamOS:
- They are still at it
- Pic Request: for those of you who have painted your lowers, can you post a pic with the doors open?
- Xpost from the MA forum: Last call for Skyline Drive tomorrow
- Turn Signal Adapter
- Where does this part go 8D5 886 623 It was laying in my car.
- well, it seems ive got a massive cam tensioner seal leak...
- this week seems to be the B5 a4 death week... we lost to many cars allready
- Some quick first pics of the damage...
- do br5 a4 mirrors twist halfway off a windshield inlay bracket like the s4's?
- suspension on b5 v6 quattro
- Nevermind - I found it. In case you care more info inside...
- does anybody know where can i buy peice like this one
- Bah, new sig. If I get good feedback, I'll upload pictures from the night.
- Anyone with any experience with General Exclaim UHP tires?
- How much does it cost to go from APR stg3 to stg3+? What's different between 3 and 3+?
- New clutch needed
- x-post Group Buy on Forge Turbo Inlet Pipes if anyone is interested
- Ha, went on a coding beinge today and found a niffty code for my instrument cluster
- What is this hose
- STFA, what is the correct size flex pipe for a stock 1.8T?
- This car is such a love/hate relationship I swear to god...
- need to find out which atf fluid needed
- good bye everyone. My baby caught on fire yesterday...
- dahlbeck vs other chipping
- dahlback versus apr .giac.neusped
- I pulled a stupid and it cost me now I need some help (long)
- Looking into a new audi...need your thoughts.
- anyone have the alarm wiring diagram for a 99 A4?
- scheduled delivery date for control arms & tie rod ends is 05/01/06...
- Which Turbos?
- Jesus christ... changing rear o2 sensor = b!tch... i just got lazy so did the "easy thing"
- Well, just ordered them...
- dahlback if you wanna spend alot of money...
- w00t....Dealer is replacing a bunch of things under CPO warranty! (97,200K on the clock)
- Short Shifter install writeup
- It's never a good sight when...
- Well I finally broke down and my carputer/center console is leaving soon...
- New b5 owner and got questions about dalenbeck and revo please helppppppppppppp
- Update: DONT panic I have put my spare back in proprely!
- Just ordered these tires from TireRack, should be here next week.
- Does it matter if my IC coding is 00244 instead of 00242? Ross-Tech says 4 is proper for turbo
- I GOT THE JOB!!!!!
- I got a funny one (warning ricer content)....
