- Water leak - help please!
- some might now cialowicz... well he finally finished building his old school S6
- okay, need help diagnosing sound........
- i guess kevcpa4 never posted it. but we installed a turbo timer in his car today
- pics from EPL GTG if anyone cares.
- gotta say I'm really liking my GW3's so far
- found a place that sells brullen cat-back exhaust for the 2.8, but it looks like the build to order
- Removed Cat for TP install...
- Need opinions
- RS4 Bumper Help Needed
- Intermimttent ABS warning light -- wtf?
- How common are hydraulic (power steering) leaks on the return line?
- Just crossed 100,000 miles on my '98.5 A4 2.8 QMS! Yay!
- I was driving through a non-well lit last night and realised how poor my headlights really are
- Oh, and more on my hatred for ricers:
- K04/GIAC/Samco....
- Control arm replacement BTDTs?
- A1crankshaft
- BRAKES - A4
- Paging MikekiM@PureMS
- Replaced n75 and it fixed my boost problems...for about an hour...
- Quattro whaaaat?..
- stupid C/O question: adjusting coilovers so car is raised. do i lower spring perch or raise it
- replace fuel filter with oem or one from az, napa, cq?
- clutch replacement
- Matthew Leboeuf Update
- anyone have quick access to a stock maf housing? can you measure the length of it for me?
- i miss my car... i've been without it for 2 of the 6 months i've owned it
- 98.5 TQMS jerking at 3/4 throttle (and up), Part 2
- Misfire problem with a 2.8 a4
- what suspension is the best bang for its buck...
- Can an A4 be pop-started/push-started without any major issues?
- Clutch Screeching upon engagement
- Spot the busted control arm
- Fumoto valve install went ok, just one snag. If you plan to install one on a 1.8T...
- Tie Rod Ends TRE's can i do myself and how much?? please anyone i need some help
- maf question 2001 a4 1.8T
- Does anyone have a brake duct setup?
- Few Q's about changing boost lines
- While I was at the dealer today I asked how much for the B5 S4 bumper.
- JoeyT: YGM @ your nycap.rr addy.
- Pulled the motors apart yesterday, here some pics :)
- Are you not supposed to drive an Audi in the rain?
- Quick Question About ECU Mods....
- Nuespeed exhaust in, no more head wounds, no problems--FANTASTIC exhaust in every way.
- need some help please, code 17536 - Fuel Trim: Bank 1 (Mult): System too Lean
- Decided to paint the crome trim on my spare grill. Hit or skip?
- Dropped my car off at the dealer today to have maintance done. They say it is too low and cant
- Clutch info
- OT:So I'm watching tv (tbs)...
- Doing the brakes (lines, A8 rotors/pads, fluid) this saturday... couple last minute Qs
- 98.5 TQMS jerking at 3/4 throttle - what should I be checking?
- power door locks stopped working randomly after i took a sharp turn
- finally got boost gauge working. 1 bar APR chip on 92 octane spiking to 24 lbs
- dealer told me to use regular?
- For those who like interesting tools....
- could someone please tell me this song.. the movie is audi content
- Question for BSK...Corsendonk Bier ...
- What do you guys think? possible engine failure? *video inside*
- did you notice they changed the banner for the b5
- adhesive removal- ??
- P032 Open MAP sensor signal CEL....
- gutted the cat...
- looking for k04 chip
- Qfrog --> Question about installing Navigation in my b5
- Dealer Denied me service records - Can anyone help?
- Has Audi always used the same coolant on the A4??
- Need a write up for changing the tranny fluid. STFA and...
- how many b5'ers have a bike at this time or planing on getting one over the spring/summer?
- Anybody here retrofit a VR6 MAF housing into a stock 1.8T airbox?
- What do you think of these logs?
- Is the Eurocode Testpipe the same as the ATP testpipe since Ecode sells ATP products?
- Damn damn damn, stupid lower door molding screw.
- Anyone here have MTM/Sachs Clutch what is your comment on it ?
- damn tint-
- update: new coolant sensor in.
- Koni shock?
- Anybody know this guy?
- what do you guys suggest using to push and rotate the rear caliper back in without the proper tool
- ECS Timing Kit Ordered anything else I might need?
- Looking for a US source for Osram Silverstar H7 headlight bulbs
- Blinking CEL/MIL, rough idle, 16684 engine misfire, 16685 cyclinder 1 misfire, ICU failure
- b5 a4 shifter problems, manual
- Test Pipe Users - Where can we get one?
- [SoCal] Saturday January 21st -- SCC Audi's Pines to Palms Drive/Poker Run
- Normal for battery to go tits up all of a sudden?? 2001stock battery! reconmendations??
- Any fix for the DIS fade?
- I know this subject has been beat to death but I have about $2,500 and I was going to get...more....
- Time for a new Clutch...what to consider and where to get it?
- anyone know the exact temperature range function of the coolant temp sensor?
- Weekend Mod Maintenance Thread! What is going on this weekend?
- Audio components ???
- cabin filter procedure ? '01 A4...
- anyone make a PEDAL set that includes dead pedal? if so WHO? and WHERE?
- Hit or Skip ... silver s4 seats for $250
- just got a DV-cam, need ideas for camera mount, thanks
- Sunroof troubleshooting...
- Where can I order body parts
- reading light switch problem
- One quick tire question xpost
- Help w/ Radio!!
- *New dictionary addition* Prybar: tool used for exerting great force on *object* then swiftly-->
- 8 pin CD changer question...
- Picture of my glowing turbo...
- so now its just time for an oil change
- Installed Blitzsafe iPod adapter for Concert, but head unit won't fit back because of ipod wiring
- VW owners peace eachother while passing eachother, Audi owners look at you funny if you look at them
- did clear corner now what kind of signal bulb do I replace this orange one with? astf :{ )
- This has to my next mod,
- Time for a new sig...
- More memories?
- Just wondering if this fmic is worth it????
- Memories... Oh the good ones...(updated)
- Where's the best place to get a turbo
- Stage 3 + plug choice.
- Ahhh...B5 forum, we've had such great memories...then this place was ruined with noobs and haters
- 6 more threads to 300k...
- what's a good year-round tire from BF-Goodrich? i have a voucher for free tires from 'em
- WHY?? What the hell are some people on!!...
- Need early driver's door in Cactus, shops want $1300 to repair and paint mine. Ideas?
- spring teaser pics
- Timing Belt on warantee'd 01 Avant 1.8T manual
- Does $1600 sound right for replaceing clutch and flywheel?
- Do you prefer the Dunlop SP Sport All Season or the Continental ContiExtreme??? I have had both and
- I've stfa but having a little trouble finding articles on Test Pipe Installations. Any Help Please?
- paging bitjockey
- yummay
- Cush v. Cursh o.O: Who's gonna keep their name?
- Need some help. Trying to remove driver door on B5 Passat.
- what's the name of the small piece on the exhaust that has the metal mesh on it?
- Kris is going to hate me for this, but...who is going to have the 300,000th post?
- Speaking of clutch slave, what are the symptoms of it going bad?
- Help!: dropped screw driver in engine during air filter change and can't find it!
- Where can I buy a used Comfort/Convenience Module?
- Clutch Replacement: Should I replace other things while tranny is down?
- any air intakes for the 2.8???
- free to a good home: oem 97 rear springs/shocks (non-sport) in nyc
- coilover wrench-key
- 97 1.8t - GT35 - internals - 450hp etc.. $21k on Ebay. Takers?
- Phils brain is overloaded with part numbers.
- wow my cd changer sold for 137$
- Thank You Neuspeed...
- A long OT life chnaging story lol... E-codes and light street legal tints...
- I need the part number/price for the coilpack wiring harness... Does anyone have an idea?
- think this was an approriate comment?
- Silly question - can you add a turbo to a 1.8 (NON turbo) engine?
- Need help - can't program my switchblade remote! And I've tried everything...
- a4 1.8tq PrePurchase: What to look for?
- Curious if anyone has succesfully used a VW N75 on their A4?
- Sideview mirror removal procedure? (other than a baseball bat) Need to do it asap!
- as I wait for the weekend mod post, I think to myself, how can a company take a week to proccess an
- Is there any reason why my car should sit higher one one side?
- 1.8TQ w/Tiptronic: idle speed low when in drive?
- Has anybody tried Evans NPG waterless coolant?? Long!! Xpost in 1.8T forum
- So my water pump belt broke last night...
- rear door mod...
- Auto-RX & ZF Tiptronic Tranny
- chirping sound in park...turbo sound?
- Paging WJM: Air/Water Intercooler
- What's a good price to sell stock sport f/r quattro sway bars?
- Ahh, now that's more like it.
- Estimate parts and labor cost for oil leak on 2.8Q? Any parts i can buy online to reduce cost?
- Can I get away with changing 2 tires instead of 4 (99 Audi A4 Quattro)
- D@mn, S4's keep getting faster and more powerful!!
- 1.8T vs 2.8L performance?
- Looking to possible buy an A4
- New Wheel/Tire Package, & Suspension?
- This is going to be an interesting semester :)
- So I got my boost gauge in....7 psi with t28-
- Need Front License Plate Bracket
- WTF?
- Knocking sound from reverse to 1st
- Avant hit & run.Damage confined to driver's door.Skin & repaint, estimates?Need sprayer top.
- For sale... anyone, anyone?
- Anyone have a spare electric radiator fan motor close to Washington?
- no compression problem, timing belt still on, timing marks still line up...
- poll: tint my tail lights yay or nay?
- I happy, thanks to ebay, I have a 30mm eibach front and a 19mm neuspeed rear sway bar for $255
- Has anyone heard of the intrax sways and are they any good?
- Can anyone tell me based on the picture what type of angine this is?
- rubber winter floor mats for grey interior. do they make grey ones or do I have to go black?
- engine starting problems...HELP
- In the last 18 months ive had the following items on my A4 break and then replaced
- a reliable inde mech told me i should never have to replace my fuel filter?
- Anyone have pic of APR Stage 3/3+ parts before install? Want to see everything that is coming
- Power Gasket = 30-50F lower at intake manifold, and incoming air = 20-30F cooler????
- just spotted this riced out a4 at the local autozone..
- Trying to post a picture but when I click on upload new picture the page goes blank. ???
- head lights wont work
- Cheapest place to order parts?
- What is the difference between Sachs Sport Clutch and MTM/Sachs Clutch ?
- Hey guys.. Looking into an A4 and have some engine questions!
- Wierd issue with my A4....
- Can anyone tell me where can I find the keyless receiver in a 98 A4?
- Air Bag light on.....tried the electric grease trick.....any pref. methods for the grease trick?
- Anyone have any experience with Borbet Type LS rims? Any pictures of them on an Silver A4?
- Looking for those stocker 7-Spoke A4 Wheels (Bolero Style) in the PacNW?
- How many have this Clarion headunit??
- 1 European trunk lid available at SPP!
- where can i get a pair of ecodes
- Anyone replace their tranny mounts? Can you post the symptoms before and after?
- ICM Failure. Cylinder 2. Broken joint inside gel. Screw paying for a new ICM!
- would having a wholesale license help in getting valeo ecodes for cheap? i kno nothing about the lic
- turbo boost??
- PSA: Just got an email from World Impex, the have iPod adapters for $149.95
- Is this anybody here...?
- how much is this 2001 a4 worth with dead engine
- air filter install troubles
- What do you ppl think of this new challenger? I LIKE it
- 10$ magnetic plug on ebay.
- Parked, went in Post Office, came back, left, car shaking, check engine.. yada yada. Sound like ICM?
- Surging Issues Continue, Advice?
- Cobra Seat One Time Blow Out Sale...
- OEM Rubber Floor Mats
- More fuel questions...mainly cruising and part throttle
- Wow 7-10 HP and sounds like rice.
- X-Post: Injectors
- New product, ECS Magnetic Drain Plugs
- B5 SPRINGS
- Back from Puerto Rico....what did I miss??
- Upgraded Level 10 valve body installed for Tiptronic transmission...
- How diffrent are 1.8T & 2.8 Airboxs
- Can't figure out this noise for the life of me!!
- winter tires for the 01.5 celebration wheels
- Is this all I need to know to change my air filter (1999 A4 1.8TQ)?
- Upgrading to S4 interiour
- what the hell could be rattling "in" the hood??? And belt tensioner question
- white smoke
- Downpipe or not?
- I'm looking for a good stereo deck that lights up red...any suggestions? Thanks alot!
- [[help]]oh no....serious problems occuring...
- Help: Turbo timer installed, now car will not turn over
- extra 2 hours of labor for tb update with water pump?
- illbill: have a few questions for yyou..
- Eclipse deck?
- Clearcorners / Clear side markers... Anyone know of a website?
- My outside tempgauge is acting up, WTF?
- What to check if my speedometer clicks as it moves and get's 'stuck' at times?
- K it's finally annoyed me enough... what's broken ?
- *NEED AUDIWORLDS BEST PROBLEM SOLVERS* - PC-16 install and now a plethora of problems.
- Would I be better off with 2.8 or 1.8T?
- Is there anything better than CarFax?
- A4 B5 fog lights
- Weird issue, When I cold start my car, it stays at 12v for a while, until i bring the rpms up above
- brakes stuff....
- Will 205-60-16 tires fit on in with the sport suspension...
- Help Guys Audi Overheating
- Anyone name their cars! my cars name is chuck
- where is the cheapest place to buy a n75?
