- Can't shake this P1128 code...VAG COM scan inside.
- Finally floppy Tip shifter fixed , 2 hr 10 min including AW search times.
- P/N Request: AEB coil pack rubber boots
- Ah, it's nice to be rid of suspension cluncks/squeaks.
- LaR H 88, I looking for j00
- what am i doing wrong, labree high flow cat install
- (Repost from local forum) Rental van scratched/dented any ideas?
- should my dealership have a rear wheel bearing?
- Name that god awful sound
- who as the best price on hsports sway bars??
- Oil Pressure Light On
- Audi/VW Island Cruz for Sat the 19th hosted by myself Kyle was a.......
- does replacing lifters require head removal? (30V 2.8)
- FB: Time to put the hood back on my Sedan...
- Wheel stuck on hub
- Ok, I'm running out of ideas...
- what color should I repaint wheel center caps? The original sticker thing w/ 4 rings on it
- GTRS Help!!!!
- Charging system help needed.
- a/c issues- diagnosing ...
- Anybody have any good ideas as to how to get the #@$% alternator pulley nut off?
- intermittent CEL & OBDII diagnostic plug?
- QFrog... You have some explaining to do.
- Getting a used evoms intercooler for 580 - good deal or should i barter some more.
- Name that VAG code: 17544 - P1136 and 16806 - P0422
- the plastic base around my dipstick handle is cracked...
- Is there a way to tell if oil is synthetic or regular by lookin at oil on dipstick?
- Got pulled over for "rolling a stop sign" Downshifted (and was barely moving to start with) Never
- ugh. brand new AWE boost gauge buzzes badly. You'd think for $240
- joe@ axismotorsport.. email addy?
- Ha... Honda vs Audi
- oh my...
- Cone filter recomendation for running a 90mm ford maf
- Cluch suggesting for a GTRS set up - not looking to upgrade the flywheel
- your vortex post of the day...
- When you let the clutch out without matching revs, & engine slows car down, what can happen?
- So, I picked up an A4. Came with some hot aftermarket pedals.
- Anyone here have a spare 1998 passenger side rear tail light for sale please?
- AZ POTD
- oil leak from back of block/head.. help me pleaseee
- What transmission fluid should I use on my 98 A4 1.8T?
- Front right headlight crooked?
- Are these parts interchagable
- Airbag module wiring diagram
- Does anyone know if the ford lighting 90mm maf will fit into the stock airbox?
- Looks like I have a gremlin running around in my engine... help :0)
- display shows driver door open all the time, just had timing belt done then this started
- What plugs should I be running?
- Is this the vag-com setup i want?.... what are you guys using?
- diagram of hoses coming off the coolant resevoir? help please...
- Anyone want OEM 1.8t chrome exhaust tips.
- Looking at this nice C/A write-up by BSK(and others), and spot this.....
- B6 guys figured out easiest way to upgrade 1.8T turbos!!!
- If you think replacing the fuel filter is a b!ch, try taking the cat off you car
- Sup fellas...haven't posted in a while..Question on nervousness at speed
- A question for those who use the Innovate LC-1 w/ a test pipe. Do you use the rear sensor bung?
- anyone have a polydrive tool they can loan me?
- Rear main seal Part problems
- Got a flat tire on one of my almost new PS2's this morning...
- Threw my first code......???????
- alright... i need some quick help
- After the trip to EPL, I learned the hard way about buying a used custom tune
- 2000 Audi A4 2.8 question
- FB: Kinda Together
- 2000 2.8 30V V6 quattro transmission acting strange.
- Neuspeed TIP vs ATP TIP for MY2001
- Weird problem
- Is this stock 2001 1.8t sport package shift knob? I have not seen other cars with this one, most
- took my car to renn-art the other day now my car runs so freakin good:)
- Bored? Me too... Run your VIN on Carfax for free... but be quick!
- Exhaust Problems
- East coasters...AW track day at Limerock this year?
- Got a few questions guys, need some expert advice...
- a little update on my DSMIC project...
- How loud would my car be if I took out the middle muffler
- N249 nipple broke off!
- Talked to A mech friend of mine... he said it's most likely a chipped valve
- trunk handle / license plate lights?
- I hate myself for selling my car a few month ago...
- recommendations on what high flow cat to get...have 00 w/k04 & j31...
- Who wants to see Pelican: Reborn in action?
- Help on Complete JL Audio Sound System Install Estimate/Quote
- Peal white paint with spray cans
- Paging: Those with 4:1 center diff...
- Got some new things to play with this weekend.... nice. ;) Kinda' wish it was a clutch though. ;(
- Timing belt or chain for 2000 A4 1.8T Quattro?
- Location of servo/wiring for headlights
- about to go have shock replaced, what is the liklihood the bushing/shock mount is toast?
- So, who wants to sell me a black or white '98-'00 1.8TQM with higher miles?
- Seeing as I am a postwhore today... anyone have need for two upper CA boots? 100% free.
- Stage 3 + 104 oct + 45 deg temps = FUN.... that *didn't* last long.... May she R.I.P. ~~ X-(````
- Inspecting GT2871r... need to replace oil fitting - is this the right one?
- RNS-E in B5 Pre-Restyling
- Vent-mounted boost gauge question...STFA and no meaningful answers
- :: ECS Tuning :: B5 A4 Maintenance Items and Service Kits !!!
- Yay! My first PS job... a new sig. Take it easy on the mega-noob!
- At EPL now, Plz help, K line radio wire is preventing Vag com from scanning what do i do to scan?
- would my old clutch and aluminum flywheel setup fit a B6 1.8T?
- Windows won't work with "new" central locking pump
- Weekend Maintenance/Mod Thread
- Muffler sleeves?
- Anyone want to give me the cliffnotes on a short shifter install? Have read the tech articles...
- Thinking about getting an A4...
- Replaced suction jet pump, one hose still had suction in it....
- would worn out bumpstops make the knocking sound i said i was hearing after my new cup kit install?
- MTM Second impressions/Question... 'scratches head'
- Last thing...anyone have part #'s for stock airbox on a 01 18t. AWM code. Thanks. Cont...
- Purems have headlight tab replacement kits? Thought they did, looked under lighting
- At my breaking point, cant stand stock wheels anymore, about to pull trigger on Kumho SPT's...
- Anyone know average HP and Torque
- :( bad news, friend passed away today ...
- People who run GTRS ndbw time to vote - tapp vs uni software
- Also, for same car...if I get GIAC K04 chip for car, can boost controller be taken right out or....
- Quick intake question: Can a MAF plug simply be rewired for a differant size opening? Explained...
- I'm doing the ultimate mod this Saturday...
- New toy! :-D (I'm faster then an s4 now)
- Finally, the axle on my dads a6 is done ... took a few days but I had fun and learned alot ...
- VW Passat being investigated for fires
- What bulbs go in this housing?
- So im going with the compression test... anything else you guys can recommend?
- that rubbery molding around the rear window (the big one above the trunk). Is that
- So I logged misfires today on a 4th gear pull to about 5500RPM. Forgot to log RPM, but it was all 0s
- So since I couldn't remove the pinch bolt, i took off the lower rear CA
- Some crappy camera pics I took of the car. Put the shoes back on last wkend.
- Is there any places to buy synthetic oil online for cheaper than the store??
- Vogtlands arrived today from purems...
- Rotors BT : Recommended rotors for a stock setup? Need to change them and sell the car so I
- Do these mechanic suggestions sound right?
- pulled the throttle body, it was sparkling
- Question: How long does it take to replace a wiring harness???
- This may be a noob question but ... how do you get the axle to not spin ..
- A Modified A4 1.8 2001
- does anyone here know where i can get an ipod adapter for my 99a4 1.8t w/audiconcert
- Okay im stuck... need some info and if you guys can tell me if im on the right track
- ECU softcoding - 557 N box - issues
- B6 audi a4 suspension
- DTC "C3001"
- How to replace passenger side Xenon bulb, 2000 A4
- a timing question
- I really, really hate Iowa. There's a proposed HID ban in Iowa (freakness, I'm thinkin you're right)
- 1997 A4, where can I get an ABS rebuild?
- O.K. dudes...after an agonizing ordeal getting my Concert I radio loose because of bent
- Rear Differential Carrier bearing replacement
- Ok so I have an opportunity to swap into S4 (power) alcantara seats today....
- o2 sensor codes w/ testpipe and non-foulers mod... fact of life or bad sensor?
- Does anyone have a gas tank cap part number?
- Two control arms replaced $380 - is that a fair price?
- How long would it take one competent person to change all 4 rotors?
- Sound system upgrades...
- Voltage drop issue
- Carson or Phil...
- So, my car is going under the knife today...
- What are my options for clearing service reminders other then reagistering my
- Anyone tried castrol mercon V ATF in their tip? My options are limited?
- Recommend a Mechanic!
- Happy Birthday to me!
- Anyone willing to give me a deal on stock rims?
- VVME kit for a buddy arrived today looks so good that..
- Painting Calipers and putting a sticker on... Should I do a clear coat or not?
- H-Sports FTMFW!!! Just installed tonight.........(longish)
- Is my ICM going again?
- '99 B5 2.8Q Sport... suspension needed
- PES T-28 1.5 bar software...
- Freebie at work ..electric cooling fan.... questions.....
- Anyone ever try to dismount tires on your own with out a tire machine
- After all the stress of DIY,
- Can 2004 S4 one piece headlights be used with regular H7 bulbs?
- Hvac fan making noise//////Grrrrrrrr
- Is asking $7,000 too much for my blue car?
- Performance Issues A4 1.8TQM
- STFA. Who has a working link for the Ski Sack Removal?
- damn, everything is running great...
- yo, TTight...you better step up your game.
- ZOMG this link!!!
- CEL came on last night, codes
- so after much research... im guessing my best option for an 01. 5 1.8t
- 15 minutes left on the ATW ECU on eBay....
- Ahhhhh, the car always looks its best after its first wash after waxing...
- Small oil leak coming from around the 2ndary Air Pump thing (very front left of engine)??
- Headlamp Washer Replacement
- I need some advice on what to do now,
- Riverside Audi : eBay wheel deals
- Does the APR chip's fault code erase get rid of an AIRBAG warning light too?
- CF trim is in... thanks Adam! Now to find the belt trim...
- 2.8 12v Auto, whats on the back of the block that is prone to leaking oil??
- Scan code check (not my car, generic P code): P0431 - Warm Up Catalyst Efficiency Below Threshold
- I am thinking about a quieter muffler...... anyone have suggestions? (I am not forking out $999)
- Powdercoated intake manifold color poll: silver, gray, gloss black, flat black, red? <edited>
- It appears that I have joined the 100K User ID club.
- And about Bugs!
- Best car wax
- I made up my mind - i am going to piece a PES t28 - need help
- roof rack help
- engine overheating
- Problems @ high Rpms
- Question about Wideband... Nunya?
- Which Short Shifter should i do?
- So, I just helped my friend out by looking at a car for him
- best way to...
- Just my luck... so do you want the good news or the bad news?
- CEL Codes - Already Searched, P1136 and P1476 Together?
- Probable ABS module failure - part 2, need confirmation!
- I want stg III - do you think apr will sell me it without the cat
- Should the highlighted numbers on the throttle plate be the size in mm?
- Quick freon recharge question....(STFA)
- Tire Wear Problem
- Hallo von Ingolstadt!
- will stock oem s4 b5 body trip tronic exhaust fit a b5 a4 1.8t?
- Emergency: car has fallen and is sitting on driver side rear rotor. Where jack it up from.?
- Is it ok to switch engine oil from Redline to Mobil1?
- raxles sent me the wrong size triple square bit to remove the axle ...
- P1114 Engine Code
- Paging *Audi Junkie* need your advice agian
- Doing tranny oil soon which one do you prefer.
- Can anyone tell me why the lower rear control arm in the front end won't come out?
- are people really this dense?
- Trying to remove lower rear control arm in the front end ...
- Any OG owners still left?
- Need Relay Diagram !!!!!!
- Looking for an Estimate for some Issues
- Paging Audi Junkie ,Just in, fuel recommendations jointly by VW Audi,GM , BMW ,Toyota and Honda
- My "new to me" 1999 A4 1.8tq dilemna....
- Seatbelt Tensioner
- wheel spacer question need help please!!
- got a nice little chuckle out of this one this morning
- Yar!... long days of work = awesome :) very fulfilling.. however yesterday i took the car out
- Heated seat stuck "on"
- My front lower control arms are shot. Should I just buy those or get the whole kit from PureMS?
- I ran 14.2 sec 1/4mile @ 96.72mph on pump gas full weight with K04
- with out having to go to the dealer or junk yard...
- ATE rotor F- Power stop rotor A+
- Awww...man. I think my n75 is dying. Coming home frome Fruita today ... pic's
- well stripped the indented allen wrench thing on rear sway links, thus ending the sway bar installat
- Control arm kit (PureMS) and TRE question....
- Does anybody have info on the new VW special editions? (Fahrenheit, etc.)
- Cracked my rear subframe...where do I go from here?
- 17" TT rims on B5?
- Headlight Upgrade - need advice/assistance
- help: trying to change interiors
- Need help: Gas tank woes
- New Caps time
- I have resorted to ebay to sell my A4.
- Basement is getting emptier. Wooo hoo!!!
- new Audi owner..computer screen doesn't like heat!
- Smoke During (5min) Idle
- Help Help: RS4 grill into Vis CF hood
- N00b's First VAG-Scan
- Lower Bumper Question
- vac line hoses.. what's the size
- Picked up W8 pan and Nuespeed sway arrived, time to play around under the car for few hours
