- I have a friend with an audi cabby with the v6 engine... the main oil seal on the back of the engine
- how do u get a key remade if you lost all yours?
- anyone know what type of bulb i need to replace the rear brake lights?
- Wire from locking pump to bumper?
- P/N please
- Driverside inside door handle
- ???? Odd White Steam Like At Startup
- Gayest car I have ever seen
- ~2k on new plugs and bucking/hesitation back...
- Salvage...What do you guys think?
- 600$ + labor to reprogram a key!!!
- black schmack
- Horn upgrades?
- So I test drove a CPO B7 2.0tqm sedan the other day...impressions vs. B5
- Wow, I had wood.
- anyone knows how to seperate Torque Converter from tranny???
- Help with Front Axle
- 60tKms maintenance
- Things needed to for power steering rack assembly? Searched around but didn't get definitive answers
- Been slacking a bit, but managed to get a few things done this weekend opinions and thoughts?.....
- The McBoost.com Waterfest 14 Gallery is DONE!
- GT28 Turbo Housing Failure
- borla question....
- Is DSMIC a good idea for K04'd car? Anybody runs it yet?
- What wheels are those? VW Inspiration
- for those with the RNS-D, what do you use to connect your iPod?
- my car bounces around like a trampoline
- I have searched the forums and had little luck. LED replacement license plate bulbs
- The latest road block in me getting the a4 back on the rode...
- Power steering rack leaking
- Pice Check please: 01 a4 avant 150K with some new parts
- Help me decipher round fault light?
- Rebuilding the suspension on the 1.8T....my H&R sports arrived from Tire Rack today
- Guy on Audizine selling a Full cluster w/o Cluster pox...only $95!
- A42.0rgy Need some help
- PSA- KONI Challenge 2pm EST Speed Channel (Birmingham)
- how to fix play with gear shifter
- I've been cheating too like everyone else here
- Vibration At 70mph +
- Can anyone give me the part number for Brilliant Black touch up paint for an '01 TT?
- Secondary Air System-Weird
- I know it's the B5 forum but I lub you guys: Older Audi, would you chose 90-91 CQ/Euro RS2/4000SQ
- Exhaust and catalytic converter . . .
- Here's a quick graph of APR Stage 1 100octane timing...
- passenger side dash airbag: Should that be one piece/seamless on all
- APR ECU upgrade for 2000 A4?
- Anyone have access to Carfax that can run a vin for me?
- <Puts on flame suit> - What do you guys think of this FMIC kit?
- EGR cleaning diy?
- My A4 drives funny
- front end shutter going over bumps
- Calling all fuel pressure / fueling guru's...
- Help with this ABS ECU harness - where is this connector supposed to go?
- Front seat removal...Airbag Light
- Do they make the MSW Type 16 rims in 17?
- Pro-tuned vs. APR Stage I chip
- Climate Control Programming / Repairs
- Need help AW... Injector wiring colors.
- For those interested: on Perf. & Tuning list> dog set for O1E trannys only $18,500
- are b6 s4 wheels with 235-40-18 Mich Pilots going to rub?
- Anyone know for sure if the analog output of the LC-1 will work with the ECU?
- Quick coolant question
- Flickering idiot lights and engine miss - WTF???
- rear passenger spring broke... is this normal?
- Code p0322 after new motor
- ETKA Help? Need part number for relays under the dash
- Today wasn't a total loss. Painted inside door handles. Before and after pictures.
- Misfiring, compressor shutting off, EPC comes on occasionally, PLEASE HELP!!
- Still overboosting and going into limp mode with a p1557 code after a clutch replacement.
- Zaino is pretty neat. (Gapina warning)
- any good power upgrades for the 2.8 30v not super/turbocharging
- Can anyone NOT carfax a vin for me?
- Anyone want two of those just dave emblems?
- Anyone have a working N75 they can part with?
- Audi A4 Quattro Manual Driveshaft Axle Shaft Front
- tried NGK Iridiums on my 12V yesteday, also cleaned RSA cone filter and MAF. Revs fast now...
- Zeitronix Wideband Datalogging Systems now available at Avalon Motorsports...
- How reliable is this ebay item? I need front control arms!
- Is anyone looking to go standalone or BAT chip soon?
- FYI: Tail lights and a brand new outter TRE in the classifieds.
- sort of a clunk/knock when accelerating ...
- Which spark plug for a 1.8T chipped? 6E or 7E?
- How to identify
- its time for a whole new cat back, but 97 2.8 are a pain, help
- How many miles did you get out of your Power Steering Pump?
- OK, lighting question(s). Replacing stock bulbs (non Xenon)
- Is Joe standing ready by the Axis phone or is he still on vacataion?
- code P0118, engine coolant temp circuit, high input . . Anyone know what would cause this or
- I have now unsubscribed from ECS Tuning's mailing list a total of six times. I keep getting 'em!
- front end noise nightmare...
- What's this part called? (The rusted part going into the differential that is)
- Will this Drain Plug come out? (Rear Differential)
- Will this Fill Plug come out? (Rear Differential)
- Anyone wanna trade stock lights for my Valeos? They are pointing at the ground and no one seems
- how often do u have to change ur fuel filter(read inside)
- Question: Having Valeo 1-piece headlights and a HID Kit should not affect the function of the....
- Waste Gate Actuator/Turbo
- 30v Intake and PCV parts
- I'm looking for someone who has removed their wood trim in favor of aluminum or CF
- To the guys who have recently rebuilt their 1.8T's...
- Whining noise... what is it!?
- Fan went out on drive home yesterday
- Car Value
- Code P0411 - Will there be irreparable damage if I keep driving?
- Update on 02 situation, please advise.
- Paging: Roger @ CapitalAudi... headlight question
- Whats the coilover of choice nowadays? I think its time to replace my H&R S4 coils for a fresh
- Changed the coolant temp sensor, now my car is really angry!
- Who's running harnesses? Which kind do you have and how does it mount?
- INNER tie rods are the same between A4/S4 correct?
- I was bored so I found all the MT B5 Avants on craigslist $7K and under w/ pics
- PAGING "Jretal"----> here's the pic of your free foglight, is this the one?
- Shimmy in reverse during hard left
- Any of you Cleveland area guys willing to do me a favor? Pick up some bodypanels and ship them to me
- Recaro Sport Topline's.
- Confused by a/c water leak....
- ETKA hos and pros: I need a part no. for the accordion hose on an MKIV 12V VR6 Jetta
- how to remove trim peice to replace climate control head unit 1996 A4
- For you guys that track your cars - Brake pad question
- Rear wheel bearings on '99.5 2.8q . Any tips ?
- Stratmosphere SALE - last day is Wednesday!
- Waterfest 14 Gallery is live!
- More pieces of the new puzzle ---
- 1996 non quattro A4 2.8 DCS tranny down shifting problems at 30MPH
- What does a white tip on the o2 sensor mean?
- 2.8 aftermarket cat back exhaust anyone?
- still no reading from my coolant temp gauge. Changed sensor behind motor, and t-stat... what does
- Anyone else get the class action suit letter for the car keys from audi today?
- Any real difference between the Stern and Apikol rear diff mount bushings?
- Current belly pan part number and price?
- REMINDER: San Diego GTG tonight @ 7pm
- Searched forums, didn't find much about trip computer retrofit...
- I want POWER and RELIABILITY (Been out of the scene for awhile)
- Where is closest dyno to Concord NH - would like to find one that can hold load, dont care how it
- So who has a spare passengers side fog light to an '01 A4 laying around???
- WaterFest was a blast this year.
- WTB A/C Compressor for 01 A4
- Broken ABS sensor ring
- T/F SS lines question
- Valve cover gasket (hopefully) or piston rings (hopefully not)???
- I know why I don't hang out on VWVortex anymore.
- Opinions on EBC pads, Green or Red....
- Longest 3 hours of ever.
- Anyone selling a scorpion exhaust for a 99 A4 1.8TQ by chance?
- Post ONE random photo of your car that is currently your favorite into this thread
- P/N request, marked 29 in attached pic.
- Any online stores having sales on lower control arms?
- Does Ronal still make wheels for Audi?
- just finished CA kit install....developed new problems...tricks for getting ABS sensor out
- Does Robin still work for REVO?
- If i were to install a TP/HFC onto a stock exhaust, could it cause issues other than a CEL?
- Bassed, SilverStreakin', or anyone else local to Reading, PA....Does anyone have a Vag-Com available
- How do you test ABS sensors?
- The Great Exhaust Debate
- T Minus 2 hours, 7 minutes
- Where are the Waterfest pics for those of us on the other side of the country?
- doing custom FMIC........
- So I saw my first R8 the other day driving down the street....
- Grinding???
- Waterfest today... 3pm, whats wrong with this picture...
- where can I get some high-quality T-bolt clamps, 2.25"?
- gas gauge is dead - fuse?? electronics box??
- 373 Relay?
- Question for the Water/Meth folks...
- Boost leak in the engine?
- Waterfest was great good seeing tons of you! Can't wait for H20 and cool weather.....
- Well after 5.5 years of driving my A4
- FYI> timing belt class action suit (x-post TT forum)
- Is there a noticeable difference with the heavy duty/S4 TREs?
- Clutch engages high?
- Building a water to air IC for the TDI Rover - anyone have exp. with these?
- Michigan...
- Water in cabim...Already unclogged the drainage hole..Where could it be coming from??
- I STFA and the FAQ, need help identifying a BPV/DV
- Bought a car from another Audi community member... w/ a ****ty transmission- today it failed...
- tried searching...any write up for alternator replacement awm motor? special tools needed?
- had 150 sq feet of 5/8" thick flooring in Avant yesterday so now I know what it would look like
- Non vag-com computer diagnostics: what do you guys have?
- just replaced all coil packs, few days later i think alternator dead... any possible relationship?
- stuff ...oil ,atf etc
- Anyone in the Maine/NH or close area know of a mandrel bending shop for exhaust? TIA!
- Free B5 S4 grill if anyone wants it
- Do the EDL's still work if ABS module dies?
- ***20%off Revo Technik Tuning & SPS-Switches for Waterfest 14***
- L hose is collapsing. I think this is what's causing my going into limp mode. It's a new style hose.
- Help - What's the large aluminum block unit in the brake system?
- about time, but soooo far still to go....
- In need of a car cover, but i have an Rs4 front, will an Oem cover fit? would anyone recommend anOem
- The Passat came in for a breeze visit and leaked all over BWW
- Sorry for the OT: Someone here posted "The Many Uses of Google" awhile ago..
- <Sigh> No Avant for Me This Weekend......
- Sorta-OT: Anyone have any exp. with Schwitzer S200 extended compressor turbos?
- Bently Help: 17544 Code
- Look guys, I'm famous: (AudiExpo '08 article on AW by Josh Decker)
- Follow up to previous O2 question, sensor or cat?
- Was looking at the total quartz energy 9000 @ purems
- FedEx just dropped off some new lower trim door mouldings from Blau! 1 hour later,
- bought a car with ecode headlights... *scratches head*
- 97 A4 2.8Q - high pitched squealing/whining from rear wheels, intermittent
- CLK320 wheel users, or anyone else. A what would you do question
- Detailer's Domain: Huge Waterfest 14 sale upto 20% off
- Boost logs...I'd post graphs, but Openoffice has a crappy interface for producing simple graphs
- A/C troubleshooting
- Weird whirling noise rear right tire area
- How come they don't use banjo fittings on a FWD Passat?
- where to order an auto dimming rear view mirror >$300? the 'blob' took over and is leaking...
- So this dude was saving for a tbelt job.....
- Removing the fuel rail---AHA A4 2.8L V6
- why is my pass. side mirror smaller than my drivers side mirror? n00b??
- <Sigh>
- Ahgrrrrrrrrr
- GIAC introduces Flashing and Switching for the nDBW B5 A4 - Waterfest Specials!!!! (updated)
- Part Number Help - Locking Pump Vacuum Fittings
- how long do alternators last for? At 102k miles, i think mine is officially dead... the car bleed
- Huge Favor! Central Locking Pump Picture
- Sweet! my new iPhone 3G works even better w/ the bluetooth integration i had
- May have FINALLY killed my clutch...
- Fuel Gauge won't register a full tank...
- Fuel Pump Relay
- If I soak my nuts all weekend..................
- dang.. achtuning wants 1000$ for a high flow cat?
- OK, I know it's crap but how in the h3ll ------>
- Does the G89 Ambient Air Temp Sensor play a roll in engine management?
- OT: : sigh : The person I sold my GTI to scraped the lower valence and put on an FMIC with no pipes.
- Ive seen a few people over the years talking about B5s being targets at waterfest...
- Anyone have a schematic for the B5 Quattro drivetrain for a 2.8L?
- Will tires fit?
- Save 15% Storewide at our WaterFest SALE - one more week!
- APR Presents Waterfest 14 **Inventory and Activity Update**
- Carnage from this morning :(
- CTS Replaced on 01 2.8 - Thanks Audiworld
- Sparco hoodpins=****e. Windshield an CF hood are toast! It never ends.
- Are nickle/cadmium plante, zinc coated or otherwise rust proofed rotors worth the extra $$...
- Looking to get a 1999 A4
- slight squeaking/(metal dragging on cement noise) while driving, goes away when i press on brakes..
- X-post from the B5(S4) forum: Crazy seafoam story - beware when using it...
- 2001 Brakes
- Car back into the shop after recent rebuild.
- who's going to waterfest? would be nice to meet some of you east coast guys finally
- Buying a 1.8T tomorrow- opinions?
- Any brand names to avoid when getting tie rods or wheels bearings?
- Just got the car back after a 1 month sit and clutch replacement and now going into limp mode.
- anyone know if apr or milltek exhaust is going to be on sale soon? i found a pretty good deal on a
- anyone have a non-working symphony radio they want to get rid of?
- Could it be?!
- Bottom Mount New Rear Speakers?
- There once was a Spec 2 Clutch. Loving the new Clutchmasters with LW Fidanza Flywheel.
- P1141
- so I'm debating parting my car out.. the whole thing, here are my conservative estimates
- 1996 A4 2.8Q radio and amp wiring diagrams.
