- Instrument Cluster Question
- Check out the August issue of Eurotuner everyone!
- mystery part number mass order...
- Smell of gas in cabin after gas fill-up?
- custom air intake done!!! - kinda sorta OT.
- Maybe a dumb question. Will a valve cover gasket from a 1.8t aeb vw passat fit my aeb motor.
- Quick update on painting my car...
- Finally
- F5DPOR's stopped my misfires at idle, i will do some logs tomorrow....
- Bad ABS Module? ABS, brake, oil pressure lights blink + tach goes DEAD
- OT: Jeremy Clarkson was killed this afternoon while filming an episode of Top Gear..
- Anyone pass emissions with a testpipe in CA?
- Do you guys know of any parts stores that carry the easy seal clamps?
- zoMg, hi2me!!! I'm 26 today!! (4 more yrs...*sigh*)
- Oy!
- AC no longer blows cold and I am getting a hollow scraping sound when AC is turned on...
- Where can I find a euro 1.8T badge? Body shop lost/threw mine out
- special tool rental....
- i am not trying to beat this to death, but i cant find a site which sells the giac (awe k04 kit)....
- Strange noise coming from my AC in first gear during acceleration
- PLEASE HELP,,,, ac just stopped working.
- Just scored a VR6 maf housing today (free), and bought the rest of the junk I need for the kit
- recommended engine install places in nyc area?
- heh... Today was fun.
- I'm about to order the control arm kit...Mikekim@purems
- APR WaterFest SALE
- suspension hardware has arrived
- would you invest $3k on putting in another engine in 97?
- update: my engine lower block completed grenaded confirmed
- Suspensions install - a hollow knock (HELP PLEASE)
- Happy Birthday Golden Rocket.
- Fixing Engine Codes
- Erg Solenoid
- Wowzers.. almost hydrolocked yesterday..
- Already STFAed. DId anyone ever find a close match touch-up color for celebration wheels?
- T20 security bit to take off the MAF, right?
- how do i take out my radio???
- Weekend maintenance: Timing Belt replaced (BWW)
- Car is hot-- viscous fan turns very freely. Dead? Part # and approx price? :) Gracias.
- Camshaft Sprocket Wobble... HELP!
- Uneven tire wear
- Ronal 17" sale
- HELP!!!
- Hey Qfrog, you at work? Can you look up a part number for me?
- So the car is still dead.... now in someone else's driveway! Any input appreciated.
- washer fluid motor?
- I am an idiot for missing on the control arm recall. That is all :-(
- Anywhere online recommended to buy 2.25" aluminum mandrel bends?
- MAF issues...
- repost for day crowd
- I'm off! See you guys @ Waterfest-- come stop by the Revo tent and say hi!
- Anyone have a pic of their piping from turbo to FMIC? I need to redo mine...
- mixture of 100 and 91 octane cures pinging....
- Paging mAd1(gt3071r), which 60 lb injectors did you buy from racetronix.
- Fraud warning....DO NOT BUY FROM DRIVE WIRE .COM....
- my radio smoked today is there a way to get it working again
- Back at the Glen...
- Subwoofer is silent with seat up
- FYI, 2.8 crank is universal man./auto, 1.8t different, according to ETKA
- How hard would a S4 swap into a 2.8Q be?
- Edgeracing sent me missmatched tires! This is strike 2!
- "Check Engine" sign.. cant be TOO bad, right?
- Anybody know where the evporator/heater coil weep hole is
- Few pics.......
- which is better suited for me K04 or ATP elim kit with gt28rs....
- x-post from auto detailing forum about door pulls
- Best place to buy VR6 MK3 MAF Housing?
- Anyone else have a filthy silver RS4 knob?
- Im not sure I know what Im looking for heres some pics & a vid from my earlier post..
- Yikes!
- Selling car. Lots of stone chips. Bra for it? Yes/no?
- Custom Sub Woofer enclosure wanted
- 333whp Stage 3 ATP GT28RS 1.8t for sale.. that whp number seems high?
- PhunkFX: YGM
- what "kit" do I want to select for stealth signal bulbs from PureMS?
- Curious to know how many/%-age Celebration pkge (01.5') 1.8Ts were built?
- Im finally going to get into the suspension on my car and see what all the noises are about..
- Somebody please refresh my memory -- what size are the stock rear speakers?
- how much do low mileage a4 aeb's go for? or would it be better to rebuild the existing grenaded
- Has anyone ever gotten the rear turbo bolt (3 bolts from manifold) out without it breaking?
- code p1342
- Sway Bar question: Neuspeed/Intrax
- Hey Madan!
- how much?
- MAF Replacement?
- how to program new remote to car. does anyone have the procedure???
- Highway RPM's
- Engine light= code P1131
- my apr chip is running at 17-18 psi =1.1-1.2 bar; APR runs at 1.0
- I installed e-codes tonight.
- What a waste....i started the CV boot replacment and i didnt get it done.
- Looking to buy injectors for GTRS Kit. Which injectors would you get.
- BT Guys, what year VR6 maf housing is needed.
- Vogtland coilover adjustment..
- wiring question help quickly please.........
- How do i get the caliper and rotor off?
- Update on painting my car...Most of it should be sprayed next Saturday..BWW
- Opinions
- Need Opinions
- Replacement MAF
- spark plug gap tool, anyone have experience with something like this?
- 1999 A4 Washer Pump
- My camshaft sprockets moved when timing belt removed....
- What PSI do you ATP Eliminator kit people running?
- Anyone with ATP's T3 Manifold?
- Do you have to take off the axle when doing the outer CV?
- Splash guard/Scrape guard: How important is it to keep it on the car?
- i am about to replace hazard switch assembly, anything else i could use besides destroying butter...
- wiring question
- a4 quattro 2.8 96 aftermarket cat-back exhaust
- Will our manual seats bolt into a B5 passat?
- Dension Ice-Link Plus V2.01
- 97 a4 aeb 1.8: catastrophic loss of ALL oil and coolant at once!
- Electrical Problem...need help figuring out how to diagnose
- Can someone point me in the direction of the proper procedure for using a claybar? Thx.
- I'm changing the water pump today...
- Oil loss - during long drive, not sure whats up
- Crazyness... I went to discount auto parts to pick up some Tire Shine and RainX prior to washing...
- Start my new job over summer next week...
- Edness - I now understand why you sold your A4 for the S2000.
- Vibration issue
- Klight now offers a....
- how do I identify which A/C compressor... no visible markings that I see
- WWAWD?
- wheel sensor
- Some car pics i took in rome last week.....let me know what you think
- water pump failure
- Hello all: few pics of my new car........
- This may be a foolish question............Detailing help please?
- used bose speakers....??
- have some pictures i want to post but how do i post more then one picture?
- Just got a GIAC chip put in.... now check engine light is on and A/C died. wtf?!
- Could spmeone estimate a CAPS time for me?
- light on door locks stays on??
- Update on faint rubbing noise coming from front. Brought my car to Quattrohaus here in NJ...
- can the comp on a 97 be programmed to open the window/sunroof from the remote?
- LLTek Black grill for sale. $90
- REPOST-auto up rear windows- where do u do the mod?
- Loud squeek/click when shifting from 1st to 2nd....
- Does it help significantly to have the car on jack stands when doing the TB and WP?
- 4 Bar Fule Regulator
- Anyone care to comment on how APR is getting 298HP from a KO4?
- Where can I source an Adjustable Fuel Pressure Regulator (with gauge)?
- alarm problem any ideas?
- bassed-pkwy burner to the white courtesy phone: I can prob help you next wkend
- coolant leak...urgent!
- Legality of a European-style Rear Bumper
- repost for the day crowd.
- Seat Motor
- Just wanted to know who will be heading to Waterfest this year? Hope the weather permits!
- Magnetic Oil drain plug for those with larger plug. Had this type on my 97 1.8T
- Paging silver streakin: I can do it this weekend, going to get the rotors/pads today
- Where do most group buys take place?
- REPOST but still have question
- New 87 t-stat and temp sensor and car takes a long time to get to temp
- batterys SHOT, wont hold a charge, whats a decent fairly inexpensive one?
- Can someone point me to the one-touch up/down rear window mod tech article?
- How many here have upgrade turbos with a auto tranny...
- Instrument Cluster Replacing
- Am I really out of luck here with the stereo code?
- WOOT! I pick up an S4 front bumper & side skirts on Sunday. Time for the S4 to RS4 conversion
- BLKPERL: is your car going to be in APR's booth at WaterFest 12? Who all entered Exhibition area?
- Trip Computer Display's
- Paging Silver Streakin'
- Gilliam, Yippers or others with ETKA handy
- Where should I get my timing belt kit and cam chain tensioner kit?
- can a bent hose for the AC compressor be the cause of weak air conditioning?
- Prob beaten to death BUT - 1.8T guys! What is your favorite exhaust?
- I dont cae what any of you say, the pathfinder is quick for an SUV...
- how does an aftermarket air filter increase gas mileage?
- where to find replacement ecru leatherette driver seat bottom cheap?
- i need to change my clutch slave anyone know how to change it??
- sudden LOUD clicking from drivers bank, front of engine (intake?)
- Somewhat off topic... but beware massive turbo video (supra)
- Needs some help with DTC's
- anyone in the market for 99.5+ - 2001 newer style tail lights
- I think I am getting new tires through my insurance thanks to the accident I was in last week...
- brake problem... i need help!
- dont get me wrong, i love the new RS4, but roughly 15k more than new M3.....
- My most Recent trip to the stealership
- AC Problem, sorry if this is a repost. (did a search already)
- Philly area people: Want to help with rear brakes/pads? I need a garage and a hand...
- My stupid lltek strut brace has caused cracks on the brake fluid reservoir.
- Tranny making a ticking noise in first gear
- Gas Mileage (again)
- NE Ohio dwellers, please help me.
- can anyone tell me what the sports package was for 2000 a4?
- Has anyone converted a 2.8 quattro to manual transmission?
- Trying to start the car for the first time after swapping the motor - won't start!
- Any of you run BBS RX with big brakes?
- Gas gauge question
- what gear/trans fluid is recommended? (97 2.8 qm)
- Anybody know where the evaporator/heater unit access hole is?
- Who, in your opinion, makes the best car cover for the A4? (cost is little object, I want to get one
- Is there a low brake fluid sign?
- Looking for an Oettinger RE 18 silver rim.
- problem with seafoam... help!
- ipod interface
- Is a B6 6-speed a direct bolt on into a B5?
- Check Engine Light is ON
- Question for 2.8L owners...
- Looking for a good mechanic in the San Diego area
- POLL: Intercooler???? GREDDY | SPP/RaceTec | eBay
- Whiring noise from the rear of the car?
- Spark Plugs for Big Turbo Setups. What do you guys think of Autolite 3923 plugs?
- Ronal 17" Wheel Sale
- Help with Rear Brake pads and rotor problems please. Uneven pad wear!
- Engine cuts power?
- take out the back seat and carpet?
- ECU Questions
- For those who know german.... translation plz!
- Ad in classifieds for powdercoated B5 intake manifold - First $100 takes it.
- Camshaft position sensor question.
- cleared CEL to prep for passing emissions, I'm wondering if these Failed readiness codes
- Looking for Giac K04 PC-16 or regular software/ECU...
- Audi Ignition Module / Ignition Stage Failure
- Looking to buy a rear bumper
- Are these any good?
- i sheered off one of the front zerk fitting for my h-sport sway the other day
- hit and run
- is it worth the money to buy just the rear neuspeed sway bar or the complete h-sport kit
- This little snail should help a little <BWW>
- looking to buy apr exhaust. Is a group buy possible? anyone interested?
- Very faint rubbing noise coming from the front wheel area.
- I have to find the color I am painting my car...Buying paint tomorrow...
- Computer displays 115 miles until empty when I fill up. Is there a reset?
- Who ordered the large bowl of RICE?
- Don't play with fireworks...
- Can't seem to find the answer to this. 01' non-sport ride height vs. stock sport ride height...
- Spring into Summer with the STaSIS Waterfest 2006 Sale!
- Best Intercooler for big application/
- Need Help w/ Check Engine Code
- Flex-a-lite Oil Cooler kit,
- Speaking of intercooler misters, anyone try something like this before:
- Anyone have the part # for a reman maf sensor for a '01 1.8t?
- Repost: Bent Wheels
- here are my 4 CAPS times
- Has anyone's AUTO button on the cc unit fallen off?
- IC Mister
- now that i am back, i finally get to go for a nice drive : )
- What is your comment on General Tire Exclaim UHP
- car got hit this morning in the parking garage, went down to see it..question
- Kris, Unpimp, anyone else who wants to help with my continuing electrical gremlins...
- Help! 1999 A4 rear brake problem, smoking!
- What *should* a 60K service, minus TB, waterpump, temp., really cost?
- How do the *inner* CVs remove to replace boots? photos/writeup?
- IPOD Adapter
- Anyone recall where I can find the link regarding $100 Dunlop's?
- Does anybody know a good way to reprint (or whatever you want to call it), the window picture on
- Will an S4 front bumper fit in my trunk w/ the seats down?
