- 3 months from HELL!!!!!!! How my engine blew up and my best guess as to what caused it......
- What is the cost of fixing/replacing the fuel sender?
- Oil Leaking From Cap?
- Fvck!! What NOW!!!! What's broken now?!?!?!?!?! Leaking yuk*******
- WILL MY CAR SOUND LIKE A RACE CAR IF I BLOW UP MY TURBO AND MAKE IT GLOW?????
- PBR Ceramics vs Pagid pads, which do you prefer? Will ceramic pads cause increase rotor wear?
- APR Chip
- Mika, I only have the belts. I'll look in my car for the other stuff
- audi a4 lower body
- i could use some help witha vc gasket repair
- Looking for instructions/walkthrough on installing motormounts for b5
- Fvck... urgent help needed... cv boot repair
- Can anyone help with this issue on my dads a6 2.8
- A/C Blower Motor (need steps to replace 2K A4 quattro) Thanks.
- 2 Questions
- Snooping around eBay for an S4 and found this beauty *yack*
- Questions about Replacing cracked oil pan on 1.8T AEB...
- Oil Sludge no tech and no FAQ
- Paging a parts guru please!!
- Anyone look @ the WF writeup? Bikini girls look kind of skanky! Hope others did better!
- Secondary fan Q. Secondary fan is not coming on when its suppose to. Fuse or relay suspect??
- I replaced my friends engine speed sensor on a 2000 1.8 the other day after it left him stranded.
- hey guys, i am burning oil!
- If 25 of us cough up 5 bucks each, we can buy QFrog a better tip, with
- X-post
- FB: Exhaust show & tell
- Can the pressure regulator valve on the intake hose cause low rpm surging? Im
- I need new rear brake pads want something with minimial brake dust... Are mintex pads good?
- Anyone ever thought 'bout switching to a colder t-stat in their 1.8? If so, what
- Roger @ dealership, I need a quote!
- Does anyone here have a used 1.8T tensioner and/or thermostat and/or other 'timing belt kit' belts?
- Keeping it in the odd-numbered "B" chassis family - and how much are ecodes worth in trade?
- I think my car is falling apart.
- Caption this:
- So, I need a new intake scoop.....=(
- Did the format of the forum change slightly....? It seems more compressed..and
- Quick question for the DTC gurus, 16806 - Main Catalyst,Bank1 Below Threshold code...
- FRONT LEFT SIDE OF ENGINE IS GLOWING RED AFTER I DRIVE
- Battery Help
- I know its early to start thinking about snow tires but...
- My A4 is gone...will you still be my friend?? LOL
- Got a quote of $225 for a shock mount from a shop.... resonable?
- So how far can I drive with ZERO rear diff fluid?
- Homelink Install Help. I am installing a homelink transmitter...
- I feel like a real pw lately but here goes: The new ballar winter wheels (j/k)....
- FB: Exhausted
- Seems I always have problems.. Got my Cobra seat brackets and driver side LeMans in..
- What did I break? coolant leak after tranny swap. I heard a definite
- Waiting for my rear sway linx to come from PureMS...
- Model T takes on a HUMMER in hill climb
- AC question. Finally figured a few things out. No leak, system is dumping it because excess pressure
- going to Massachusetts
- How does low and high end compare for GT2860RS 0.64 vs GT2860R?
- s4 suspension
- Strange overheating issue
- ac compressor
- high beam switch
- some pics of my car from waterfest
- Those who would like to send a little something to BitJockey, info inside..
- Missing tech article... rattling driver side window
- What should I look for in an '01 2.8 automatic?
- Axle bolts
- PIcs to come... I am back from teh Canadia wilderness. ;) Did I miss anything this weekend?
- What would you pay for a....
- I miss my car.....and chicago is making it even worse.
- Vent Tube question
- Does anyone have an update on Bitjockey's condition?
- Anyone know the stock HU crossover for the subs in the rear deck?
- Paging Ertman or bitjockey...
- How do I know if the clutch is slipping...
- Best way to get a Tie Rod screwed out of the inner rod?
- Does anyone have a diagram showing sunroof drains for Avant?
- with car on hill, in 2nd gear should the car roll? I thought the car was supposed to stay put when
- Twofer on Valvoline Synpower motor oil at Advance ... no 5w40 but they do have 5w30 though
- paging - IamRebuilding
- Remote Start on a manual?
- All this rain is forcing me to work on the car. I need to unclog the sunroof drains.
- As some of you know...I was debating about which muffler to get for my 3 inch setup...
- my latest mod..
- Motor mounts (1.8TQ)
- High Speed Brake Fade - In the Rain (cont...)
- Questions about suspension setups...
- I bought a new toy today... should help make the rest of my exhaust & intercooler plumbing
- Is anyone running without an exhaust flex joint ?
- Cooling System Question (2.8L 30V):
- Why do my 2.8 brakes sucks a crap ton more than my 1.8...
- PureMS snub in along with new DS tranny mount...
- : Extensive VAG problems , Trying to log new setup : few other problems w/ tune
- Decisions, Decisions, Decisions...Need Advice.
- Would a windshield sunblocker dropping cause alarm to go off? my alarm went off
- <Sigh> Did the Old "Crack the Windshield with the Wiper Arm" today....
- Car won't start - Testing for battery or alternator
- Transmission is replaced! Big thumbs up to Kleiner's Foreign
- So, are there any nifty R8 parts to retrofit / implement into a B5?
- Conflicting Part #s for Air Temp Sensor (I STFA)..
- Has anyone ever used this kit befor
- K04-15 Information regarding /Turbine wheel size?
- Timing Belt Question: 98.5 30V with 180k miles.
- Damnit, the parts websites are down. Can someone price # N-019-100-6 for me?
- Car started hard...Check engine light...Bunch of fault codes
- How long does it usually take for something to get shipped to good ole USA from UK?
- b6 17s on stock 1.8t b5
- b5 subframe
- b6 tranny swap into b5 - 1.8t
- High speed brake fade in the rain - '01 A4
- We now officially have another SC'd Audi on the board!
- Really dumb question
- bitjockey in a car accident, info inside
- Audi Diagnostic Program and cable
- ABS fault P1606
- OK... How many of you got stuck trying to get the lowerer end link nuts off the ...
- 01 A4 1.8T - Brakes complete failure suddenly while driving
- S4 side hardware Q
- Does the plastic engine cover do anything or can I leave it off?
- Is it absolutely neccessary to use the Audi brand gasket sealant when doing the Cam Chain Tensioner?
- Is the APR sale still on or is it done? If it is I think I'll be ordering the st.3 kit....
- Buying tools
- Fuel rail out.. Intake manifold out.. My TB is one dirty boy
- I conned some guy out of his car today.
- It seems the stern rear diff bushings have made the biggest difference in tightening up my drivetrai
- FB: Up and running.
- The 710n is 100 times smoother then my forge007 dv....
- . . . So do I have Euro Projectors or not?
- Difference between Blue and Green ECT
- initial pad + backing plate thickness?
- hit or skip?
- here's how my diy piano black came out...
- DYNO EVENT @ VAGKRAFT NOW $40 - BROUGHT TO YOU BY PFAFF TUNING!
- Looks like my Home-Depot-made fuel pressure gauge fitting is working. No leaks or bursts
- Carson or other part number gods. Qfrog etc...
- Mobil 1 10w30
- So one of my control arms only has a little play in the joint, seems more like a "flex"
- Fuel rail removal... Won't come out
- my new bbk
- removing Secondary Air Injection system. how to fool flow test so I can pass emissions?
- The A4's current status: On it's way upstate. Riveting pictures inside.
- Anyone have experience with Akebono Euro Ceramic pads? (Tirerack)
- Turbo maintenance
- o2 sensor?? part number?
- Ouch! Six Audis stolen in Edison, NJ
- Noise from Exhaust?
- I think I am losing it, I went to the Yota dealer tonight...long story so don't read if you have ADD
- wrinkle paint on the intake manifold, flat black on the throttle body...
- Why does going to the dealership always involve PAIN ?
- Instrument Cluster Replacement Questions
- B6 forum is kinda slow or maybe I can ask usual buddies, Are the teweeter covers in the rear doors
- Did some running around after work today
- My Moms new car! 2007 A4 2.0T 6spd Quattro Sport.
- Cylinder 2 misfire problems
- WIRES ARE SOUND cylinders still misfiring. what could be causing this PROBLEM!?
- Speaking of old threads. Who maintains the 1/4 mile list now?
- There IS video of my runs at Waterfest this past Saturday. Lucky for me, my car resembled...
- clutch help
- $1200 Wheel Bearing Job or Rip Off?
- Should I go ahead w/ GT28RS, what precise extra engine mods would you recommend?
- Pictures from the Pike's Peak Hill Climb and a brief story...
- holy cow... the stupid 2 color check valves cost $30 each... are there any aftermarket options?
- One for BT experts - GT28RS, GT28R, GT2871R - which one spools faster and gives wider boost range?
- Part name help... Dealing w/the rear suspension...
- Could anyone give me the Garrett ref. number for a GT28RS for a B5 1.8T?
- Stasis Tracksport Spring size question?
- Anyone with a 42draftdesigns oil pressure sender relo kit - where did you mount the block?
- Wow, stock airbox vs. evo intake makes a huge difference on IAT's.
- 2.8 30v output
- Happy BirFday to..... ME! ;-P Yay!! And a little on-topic inside....
- What would the best HID color temperature for fog lights? I have searched and still can't figure out
- Need new nut for atp exhaust manifold - know where I can get some ...
- Interior temp control sensor (G56) threw a code 00785-intermittent operation
- Vanity mirror light sunvisor connector repair
- Replaced ECT - 2 codes now P1101 P1106 HELP! I have to work!!
- Ahh rat farts, think my oil cooler is toast...just replaced coolant res...and it's poop brown
- Garage sale.
- Where can I get a fuel pressure gauge fitting for 1/4" line? 3/8" is too big
- intake leak
- At what interval (in years or in miles) should the Brake Fluid be changed.....
- There was a post about polishing the fog lights a long time ago... I can't find it now...
- Newbie question: spark plug wire replacement
- APR st.3 kit question? Does it come with a FPR? I could not see it in the list....
- Weight Question: Carson....MKIV VR6 GTi
- Left/right signals stopped working....at first the green arrow would light up
- CE light came on this morning, just read the codes....Can anyone translate for me??
- Anyone able to run a carfax report for free on a VIN? Thanks in advance.
- A1 anyone?
- Question about installing HID's
- Oil question, sure its been asked a gillion times+misfire?
- Just put 710N back in, much better than Stratmosphere DV?
- How to clean cloth seats?
- OT: part supplier for toyota?
- Need passenger side front lower grill
- Weekend mod thread...I know it's only Thurs, but close enough!
- Hey..i saw a wire diagram for the i/o pinouts of the rear sub amp once...
- How much of a job is swapping out mirror covers? Some low life twisted my driver side mirror
- I need a new CV joint, and boot on my drivers side front. I am getting mixed
- How do you tilt the Sunroof??
- New brakes, rotor question
- Noise from brakes
- Looking for Drivers Seat grey leatherette with heated seat...
- PSA - For new people to AW
- Long Time no post, need some help regarding the ABS computer
- just got my car back from KMD, great work thanks dion
- Shot in the Dark. Need gray letherette avant rear seat backs...
- Electric fan issues (questions)
- Vandalism Pics - Before
- Avalon Motorsports.... Event Sponsor for Dubs Along the Rockies 2007--->
- Wow i love the center vent gauge. it looks so clean and at night
- anyone bought some nord-lock washers recently?
- If you think ignition/headlight switches are bad on the B5 C4 series?
- paging pointby - ygm
- My 30,000th post and it's for you, my fellow B5ers. I guess this is considered WW
- Update: Manifold in
- For some reason, my valve cover looked better before I put it back on the car
- Ok i think I'm officially an idiot....how do you replace the 3rd brake light bulb?
- Caught on camera at Waterfest
- where can i get side door trim.....my 1997 a4's is peelin away...where is a good place to get it don
- Does it look like AZ crashed again to anyone else? Database error ut ohhhhh.
- Is there a coolant tank replacement write up? I am thinking to DIY.
- "Even the turbocharger has a turbocharger."
- can someone tell me where the engine speed sensor is on a 2000 1.8T?
- Who makes decent software for GT28RS setups?
- Brief shudder under load...
- installing the AWE center vent gauge and i just lost the stupid grommet down
- I think i have an ICM(ignition control module) problem, need a second opinion
- Other than Ice-Link (LAME display on the symphony) what are my options for iPod integration?
- Anyone interested in a APR boost gauge. VDO gauge. Heard it matches a4 interior.
- leaking antifreeze like crazy
- In the next few weekends: We should have a JoeyT/RVermont/Kris/DungB g2g...
- Joey T: YGM
- Boo for my APR exhaust flex joint rusting and APR wanting me to buy a new exhaust from them...
- Question about lowering a car...
- Paging Carson@RiversideAudi. Sent here to see if u got some B5 RS4 grills
- Timing belt replacement and what else
- Is the k04 PC16 file fine-tuned for 93PON gas?
- Sooo... Anyone have a Falken Rt-615 235/40/18 with 70% tread left....
- 'Sup Fellas... been a long time since I checked in on the B5 forum (where it all started)....
- Bosch 5.0 ABS Relay
- looking to order A8 rotors, coming up with a choice, which are the right ones...
- Update from last night - coolant fan issues. Sorta long and a question at the end
- I need new front rotors, where should I order from/ what should I get?
- Code Info?
- Anyone have experience with the Stasis Center Diff?
- Anyone know this car....
- Need new front axles. Recommendations?
- Dose anyone approve of the 2.75 millteck sport exhaust?
- looking for a good set of spring for my fwd a4....
- tip transmission - replacement
- This might sound stupid for some, but has anyone ever heard of or
- No flames please! :-) What are the best forums for reading about the 335i?
- damn, starting... looks hawt!
- hmm, so does anyone besides ECS sell a magnetic drain plug?
- What are the differences between Audi headlights?
