- AWE Tuning Waterfest Update.
- wheres the paint color code on our cars?
- Is it *really* bad to mix coolant...(read)
- Quattro Cars Only: Please post your 1/4 Mile Trap Speed and Weight with Approx. WHP
- ARHRHRH!!! I just removed my front suspension, raised everything exactly 3/4 of an inch then
- looking to replace the aftermarket stereo in my car with an OEM unit...
- question about performance differences with an x-chip vs a k04, in particular on a tip
- First time at the track this weekend and a boost level question....
- Burning oil!?!?!?!
- Achtuning Anniversary Sale! Prices good this week only!
- anyone got s4 sides for sale?
- any advantage or disadvantage with running 710N on stock boost?
- I found a great used Audi parts website: Tail lights
- Any good tips on changing the rear brakes?
- Where should I install my fire extinguisher?
- question about my alignment situation.....
- Winter Essentials?
- where else can i get trim guard besides lltek?
- New audi owner Prescott AZ area CEL
- Update from misfire problem I posted about last night..
- Opinions/help wanted
- New Sig?
- Abs sensor from S4 fit a4? ANyone know
- Anyone know of a good detail shop in the Los Angeles area? TIA
- Exhaust Flex Joint fell off over the weekend.......
- Chip my A4 w/ 73,000 miles?
- Kansas City - Reminder - boba/bubble tea run TONIGHT
- Can I fix these?
- N75...how do i order one? They don't have anything called the N75.
- this seems rediculously cheap, is it the real thing?...edit, link works now
- anyone here using the palm version of the vag-com (prodiag?). thoughts?
- suspension/new wheels? aka dumb question
- finally broken in
- Nice seeing a bunch of you A4 guys last night in Edgewater...see everyone at W-fest!
- At waterfest...
- 99.5 1.8t climate control ... a few buttons stopped working the other day, now they work again ...
- Rolling Pics...
- for those with the coolent leak above the oil cooler..
- Joining the new wheel club (BWW)...
- already stfa, cant find website selling euro badges, it was posted here a few months back
- Vac line is broke
- Cheapest place to get euro plates?
- Need Help Getting door panels off
- Help, STFA, already, Where can I get Pentosin Power Steering Fluid in chicago besides stealership?
- What is this?
- question on timing belt change...
- are you able to see the timing belt if you are replacing leaking valve cover gaskets?
- Anyone have a link to Paul_858's thread with the high res interior pics?
- Airbag light on
- Can a timing belt "slip" and keep running on a 1.8T?
- anyone using OBD tool, what are you thoughts....I have one but haven't used it
- thinking about ordering a new car this week, now i'm just debating on the color....
- If anyone has a spare non-DBW ECU they want to sell please let me know.
- so I was driving around yesterday, going about 55mph, when some @ssh@t pulls out in front of me....
- which button do i pressed in order the air from outside goes inside the car
- xpost "Jetta Tard" the newest in the jetta line & Brrmans new wheels.(BWW)
- My dad got a "camshaft angle" code and a CEL 200 miles before the TB broke on his 2001 Jetta 1.8T...
- Repost for day crowd: Q's re: timing and also help from someone with Bentley
- Starting problem. Not flooded
- hoo rah fault codes!!!!
- Fixed my cruise control problems
- Just how many miles can you put on an A4?
- If you could get any vanity plate on your audi what would u get? (related to Quattro turbo audi etc)
- im confused on lighting options, help needed
- head unit question
- Coilpack settlement question
- Heading to dealer tomorrow...
- X-post: My Suncoast Pics
- A4 KW Sport Suspension...
- when installing aftermarket side skirts do i reuse my oem lower door moldings
- w00t! i just got 23.34 mpg on my last fillup. all city.
- Could someone please post a pic of where the a/c high pressure switch is located. Tia!
- LCD and Temp. and seat belt question...
- where online can I get some cheap brack discs?
- Stupid question but does the ECS Ultimate Timing belt kit come with any directions?
- abs is good stuff for sideskirts?
- Oh man, autocross next weekend. I still don't have
- Anyone have a little red button behind their fuse panel - 97 A4TQ Eurospec
- Early A4 folks: Is the Ercu interior technically leatherette or what?
- Clearing up different 1.8T A4 B5 Engines
- 97 2.8 ac compressor stop turning on? how do i check cluth or compressor
- Will 18x9 fit on my 99 a4 1.8 T non-quattro
- stoptechs and tie rod ends are on: big thanks to aaronbryan
- About to buy H&R cup Kit...what do you think???
- name some unique mods
- Not sure if this is the place to post, but does anyone wanna start an OZ group buy????
- **sigh** So, who wants free injectors?
- Trying to debadge the trunk, i need the easiest and safest way to do so.
- Lost power brakes today...question for you guys who know about the check valve
- Anyone curious what these will look like on an A4?
- anyone with experience with this company's products, or this
- weekend no.2 hidden sub trunk floor
- K04 turbo alone with 1bar P-Chip or wait for the Super K from Neuspeed for non DBW, Pole what do you
- Does this sound normal? My coolant light will come on whenever I stay at a particular angle other
- A4 Driveshaft center support bearing removal
- Quick Question!
- Should the A4 forum create a fats-like test similar to the S4 guys?
- System Se7en Car Show, Green Bay, WI 7-10-04 pics..... smaller....
- autox day...placed 3rd
- Questions about timing (belt) and valve chatter...
- Install 710N with Timing belt? While i have it all apart, is this a good time to put the TT dv in?
- Watkins Glenn ??
- engine leaking water??
- Need Help diagnosing a/c high pressure switch problem
- cheapest place to get euro lic plate frame?
- Strange Hard Starting Problem
- Anyone have all-weather mats that don't fit on the holdowns?....
- quick ?'s
- pictures of my nav unit after install
- System Se7en Car Show Pics, Green Bay, WI
- Man I wish they made these OZ wheels still
- help quick k04
- What do I do about these
- What kind of transmission fluid does 97 2.8 auto take? Synthetic or regular?
- Would Quattro rotors/pads (front and rear) fit FWD? 96 2.8 Quattro ----> 97 2.8 FWD
- Looking for something to lower my 97 2.8 12v FWD, any recommendations
- First problem with my Audi.. rough idle and flashing check engine light
- brake squeal?
- ooooh...weird sound coming from the steering when i'm making a turn @ full lock...
- jack point for oil/filter change?
- Need K03 Turbo (used) Has anyone upgraded to K04?
- A4's back to stock now ... boy what a difference!
- I don't have my manual, How do you enter the radio code on a Audi Symphony radio for 2001 A4
- hoses to radiator.....need quick help
- Friend just totaled his B5 S4
- DIY clear-corners dumb question...
- 5 Bar Fuel Pressure Regulator (FPR)
- I STFA and Classifieds but is anyone selling a NDBW PES T28 kit?
- Coilovers installed, Possible Problem
- FM tuner?
- can't seem to get a tech article to print in any sort of viewable fashion. any suggestions?
- radio
- alarm motion sensor questions...
- Anyone tried to program the homelink with the craftsman security + garage door remote?
- Several Questions???
- X-Post from AWOT.... Clean car pics,
- ARGGGG!
- Are SK04 Installs yet?... what happened to the group buy?
- Need dave for badge inlay
- I need Sameer Pandya's email if anyone has it...
- Rim refinish
- redrilling rims
- need some help....
- VAG com extra features list...
- Anyone in the Bergen county NJ area want to meet up tonight?
- boost gauge...is the 6" tubing kit required?
- Rear differential locking up and slip in auto tranny
- I really hate when people lie about what their car can really do in the 1/4 mile.
- steering wheel noise
- Scratching 3rd Gear
- need help with 2001 a4 1.8t 2wd bov
- Where to get rings for Kamei Grille? besides dealer and off rear end
- Sonnen Motorcars teams up with STaSIS Engineering for ALMS July 17-18
- DashBoard
- stupid boost guage makes a hissing sound
- A few ?'s
- ideas on sale items
- Radio Question
- I know I have posted this before but....
- Buying Tiptronic A4 question
- P shop request TIA
- Really dumb noob question...... sorry tiring to learn.... washed car and I'm waxing the.... my
- *sniff* Good bye A4 . . . *smile* hello 350Z!
- Torn APR snub mount...
- Vivid Racing Redeamed,,the Hybrid GFB BOV is in!
- Question...My car has just died while driving several times over the last year...
- 1.8T Turbo problem - need advice
- Someone remind me: how is "service INSP" light diff. from "service OIL".....
- Car threw a CEL today. Limp mode. Vag'd and came up w/ this.
- Meguiar's Hot Rims/Cool Care All Wheel Cleaner...awesome product!
- OT: just watched one of my favorite movies "The Wraith" anyone know what kind of car it is?
- NE have a pic of the GFB Hybrid in their car?
- Friend needs help locating a part...
- wow. just checking out spp's GB page and saw
- Ok, so im getting really nervous about this timing belt change. Im afraid im gonna f*ck it up. I've
- Wheel bearing problem, need advice
- really lost this time ( long)
- How do I take the glove box out? (1999.5 A4 QTM Sedan)
- Does anyone know where In SoCal I can get Motorvac or my engine decarbonized?
- paging andysprague re: rs4 lowers
- pics of s4 front on the car.
- I love it when you're in the middle of a project and you notice something else wrong...great...
- What is the size of the hex socket for the front and rear brake rotors?
- getting check engine light, just changed plugs.. more..
- There's a second Audi R8 entered by Champion Audi at Sears Point next weekend. Wonder who's driving?
- Are these really....
- Anyone have experience with the Blitz Full Auto Dual DTT DC II Turbo Timer with Boost Gauge ????
- Can someone please photoshop these FLIK Black Rims on my Santorin A4?
- The new shoes are on ! (BWW!)
- brake bleeder valve
- Does the antenna amplifier have a dedicated fuse ?
- well..atleat the CEL isn't blinking....
- what would happen if i....
- having 3.5" ground clearance is TEH SUCK in NJ!!!
- @ 120 all bugs dont even have a chance
- APR snub mount
- i shoulda gotten an avant...:(
- accident with door
- Expert Advice, Car pulls to the right when going straight. Solution is Front Sway Bar or Strut Bar?
- there is a certain feeling of notoriety that comes with backordering a part
- Turbo timer install without splicing harness
- choosing and installing Recaros
- tech articles....submit to AW or create my own website...
- RS4 for sale on ebay. just ended
- how much would replacing a vavle stem seal cost?
- What is your RPM in 5th gear going 80mph
- Buying Valeo 1 Pieces or 2 Pieces...
- OT: for those who care...here's the TT's new stance...
- My local VW dealer rocks!!
- Got stuck in 2hrs of NYC traffic last night in the A4. After 1 hr my clutch started smelling like...
- Audio Install Help
- problems.....can anyone help?
- whats the best rotor for the redbox's?
- i have a question about trading ECUs.....need to sell my APR chipped ECU...
- Paint color question........................
- Is this ECU chipped?
- towed my car to the car show today....
- Do you guys think the dahlback FMIC would fit behind the kerscher front bumper?
- Intake
- Need FMIC Sizes...
- What turbo manifold to get
- hey sightpost..there's a turbo timer in the classifieds
- Need some advice...
- my washer fluid leaks, is that something i can fix myself?
- Damn airbag light came on ... first time.
- Which direction should I install the N75 J valve? It looks backwards to the stock one
- poll: have about 50k on my car now. when should i do my tbelt?
- need opinion on exhaust
- anyone have up close pics of rs4 lowers for a4 bumper?
- Any one know what this is?
- Motodyne??
- lifespan on a 1.8t waterpump?...
- what do you use inbetween washing to clean brake dust from wheels?
- I'm looking for rim ideas...........
- Stuck gas flap... how to open???
- will rims fit
- Coolant Problem... (Somewhat Long)
- Ok Dumb Question...
- Can I get a price on timing belt replacement for '01 2.8QM?
- Kumho 712's or hankook Ventus K104's?
- Need to replace MAF....
- Uh-oh...a little help please
- One touch window mod tech article?
- Source for new S4 bumpers?
- just coded the central locking module last night, cool as sh%$t.
- focus group for Audi drivers. pays $100. MUST be in Bay Area!
- Fuse #14 problem...ANY ideas??
- HELP!! I can't get my gas panel to open...and I have 10 miles left on the tank! Can I override it??
- $380 to remove and paint all belt line trim pieces. Good deal?
- sources to get free copy of "Fear and Loathing in Las Vegas"? (the book, not the movie)
