- repost: 17536 DTC
- how to change right side oem fog light?
- OT: has anybody driven Pikes Peak?
- anyone race a mostly stock Fox body mustang? Pretty confident ill beat it.
- Front 97/98 Guards on 99
- PLZ don't yell at me... I'm looking at a Black 98 1.8tqm
- So how many people here are actually SERIOUSLY planning on going APR stg 3+?
- so at this point the stage III+ can help use whip m3s then?
- help please... drivers window goes up and bangs hard...
- Hahahaha
- GTIVR62801 + Audi, What makes your parts guys good?
- Are OEM Flywheels the same for MY 97-01 or differ
- Situation: My coilpacks keep popping up causing my car to misfire?
- Got my battery and alt tested tonight at Autozone.
- Boost/Chip working when it wants to...
- Thanks for the help gents.....
- Since Im the suck at computers....I took a pic of my screen with my dyno run on it...
- anyone here good at 3d studio max?
- For the night crew: Visiting Long Island on the 17th,
- 98 2.8 A4 with thick smoke from exhaust
- so looking through the FAQ we are missing some things
- horse power gain
- sfexboy is coming over to replace his spark plugs and coil packs (need advice)
- can anyone tell me where I can get brembo caliper brackets?
- Where can I get a TCU
- Aaaand the turbo just popped.
- Well, I think I'm selling my car...Opinions?
- I want an S4. im kinda sad to say it but it just makes sense.
- Well just found out someone got my 12.8 run beating the GTO on video.
- any projections on quarter mile times for stage III+? 0-60, 0-100mph?
- Royal Purple GearMax installed into all 3 quattro diffs, very smooth.
- When the cam chain tensioner makes that noise on the 01's
- hid
- Newbie help?
- You can't run a 32-bit processor on the new windows 64-bit can you?
- i lowered my exhaust today so i dont have to cut the rear valance
- Does anyone have busted, broken, or otherwise FUBAR projector lamps? need specific screws
- does anyone have that picture for a b5 a4?
- So we all know that APR doesn't have K04 software for our cars... but why for transverse 1.8Ts?
- Small rant,...car stranded longer than I've owned it
- phil:
- at work and have no photoshop here, anyone wanna do me a favor and change the color of the rims...
- looking to change my interior to black with leatherette
- Anyone in Chicago or Milwaukee parting an A4?
- Water Pump or Thermostat
- Anyone know what size the stage III+ injectors are?
- "Fault in basic settings" is this message for a new Throttle Body
- Oil Leak 01 Audi A4 Quattro and High Mileage Question
- Need help. While driving Battery light came on, and then turned off...(more inside)
- Two chipped ECUs, one will need to go (feeler)
- Aftermarket HU adapted to bose?
- Headlight Washer Cover Removal
- Ebay find... check it out
- 2004 s4 1-piece xenon headlights on a 98 2-piece halogen?
- Does any one have pics of this wheel on black?
- So I got the temp sensor...its a damned tight fit...will I need to remove
- what size injectors are you running?
- Which one of YFF's wants to hang out in LI on the night of the 17th?
- weekend maintenance lists? what choo gon do?
- Is $700 shipped for a brand new in box K04 a good price?
- Viscous fan question
- tried this video before, think it should work now
- one touch up rear windows
- would a '02 TT concert II headunit fit a 99.5 A4 1.8 without modification?
- Timing Belt changed at 75K, here's a couple of pics of the belt...
- Cold start problem?
- Heat situation....
- where is everyone grounding amp in aftermarket amp/sub install? (MORE)
- Is the dealer the only place to a buy a new engine bonnet inside cover.
- Stereo Reset after changing battery
- Is purems down for everyone else?
- my new sig... well depending if it's well received..
- Anyone want anything from Japan, since I am here already?
- Xpost: Avalon Raffle Number 2 ! Alcons, Konis and more....
- Hooking Up An Amp
- ECS Brake Caliper Piston Tool.... worth buying? $45 shipped?
- B7 RS4 Reps All Shipped today. Thank you everyone for the orders!
- just to clarify AirBags only get damaged on VW's using VagCom there is no mention about it to Audis
- seat heaters
- Question, Ran out of Gas (stupid me)
- Anyone have an Audi Concert I radio?
- I noticed something interesting the other day... My engine bay is dirtier with the skid plate on
- Me+A4 play in the snow, come watch.
- Decided to keep the car....
- Drop
- My lights are driving me crazy!
- 2000 s4 housings on a 98 A4
- Four new black door pulls in the Classifieds!
- follow up on post from earlier today
- Anyone have any Ronal R28 bolts that they can spare?
- Not sure if this is a repeat post....but rs4 on ebay
- Only 11psi on GIAC chipped 01 A4 (long)
- what voltage powers the small electric fan up front?
- It looks like APR Stage3 handily beats Stage3+ up to 3750RPM...
- Stock clutch slipping in 5th, 4th, and sometime 3rd under hard accelleration...
- Has anyone went to the dynos and got their cars tune.
- any trick on getting the inner cv boot off i cant seam to get good leverage on the bolts
- so i finally got out the figgen up link out of the lower control arm after removing the arm
- Who would have thought a phatbox, heated seats, radar detector, and an amp would overload 75x?
- need some serious help...any suggestions?
- winter tires came for the black avant today
- my taillights are for sale in the classified (link inside)
- I'm on my A4 search again...
- this is what i call a custom build... he is using an s4 radiator
- does anyone else have their secondary fuel tweak advanced via lemmiwinks?
- Hey Raj. Here's Nicole at Kinesis. Lol.
- Can't open the hood, maybe a snapped cable
- blown engine
- hey i have a 99 1.8t wheres the IAT? is it in the MAF?
- Plea For Help w/ Sputtering + Backfiring
- Rieger RS4 bumper shall be in soon......How do I eliminate the headlight washers?
- Had flex pipes on my 2001 2.8 replaced, now hear loud whistle, any thoughts?
- Radio antenna question below sparked a new question I have about FM/AM reception...
- Excess Body Roll... Installed Eibach Pro-System.... NEED ADVICE !!!!!!
- Bored in class right now, decided to browse the archives and noticed that the knocking my engine has
- You know, Kinesis is a great company. Brand whore stuff inside. But I wanted to share.
- what type of aftermarket injectors & what size are best for the quarter-mile?
- Control arm effects on steering????
- loss of power... im about to drive this thing off a cliff... help!
- After stfa found the problem to my static on FM with rear defroster ...
- 2.8 at 100,000: PCV vent hose
- whats thebest/cheapest place to get my clutch installed near boston, anyone heard of kga motorsport?
- How often does everyone here change their blinker fluid?
- ATTN: Solaris (Certified)
- OT- looking for bmw accessory parts
- So this weekend My friend decided to run into me while i was parked... more inside...
- xpost- check out this idiot:
- For WJM: A Trip through the Wayback Machine on TAP
- 2000 A4 1.8T Timing belt
- ECS Tuning Holiday Sale 2005, up to 25% off Select product
- has anyone replaced the head on a 1.8t?
- AWE Tuning Holiday Specials for Dec 6th through the 11th!
- NEW Eibach Pro System - - - Excess Body Roll !!!!!! <<<<NEED HELP PLEASE >>>
- What Audi (non-A4) would you buy for ~$5000 or less?
- What FMIC will fit behind the stock bumper?
- Fogs not functioning...need advice.
- B5 Stage 3+ Released
- must...resist...G2...in...marketplace...must...fig ht...the...urge. Arrrgh!
- So, I ordered a new DV from the local stealer... requested a 710 N, got a 710 *P*---should I return?
- [newb Question] Do I have to remove the headlight housing to replace a bulb?
- If anyone is going to go stgIII+ with your B5 and you want to sell your current setup...
- I can't figure out what's leaking
- got new winter shoe's from a Firestone shop in SLC... WINTER FORCE...$213.00 for all four tires!!!
- My Amex card is twitching in my back pocket. Anyone wanna buy a PC-16 setup? hmmm... :(
- Reputation check-Mike Savoy?
- Help guys...please read! Camshaft position sensor issues.....
- APR Holiday Sale Tuesday Release....Stage III+ for the B5 A4
- im holding off on paying for some parts in hopes of APR having some kind of decent holiday sale anno
- Update
- this just in.... TAP to beat APR to make holiday sale announcement!
- Bobbling idle... ISV or dirty throttle body?
- psa: the 16" ten spoke "sport package" wheels clear A8/TT front brake kit.
- come on APR post it up! I got sh*t to do...
- Ok.. It's the morning.. Where's the APR announcement?
- '96 climate control acting up
- Is there a diffrence between A4 sport suspension and the S4 suspension?
- And you thought it was over....APR vs Mike
- system 1 bank running lean in my '00 1.8t. what can cause this fault code?
- CDC A/B switch
- If I were to buy all used parts, How much could I do the A8/Porsche Brake upgrade for?
- brake line bt: does the a8 brake upgrade require longer front brake lines?
- Did anybody ever use COD delivery/shipment for sales/buys from/to private parties?
- muffler
- Question about body shops (paging those with volcano black cars). . .
- Proper line to hook fuel pressure gauge to? Also, should it be cut or
- Hi, does this VAG-COM cable work for 99.5 A4??
- Climate Control Fan Rattle
- A4 won't start, neutral/park relay (long post)
- UUC short shifter
- xpost... i dunno if this pic was repost but holy crap....
- Weird...i think its the thermostat but maybe something else??
- Magnecor 8.5mm wires...how much?
- Alright, I know the ATP Exhaust Manifold was universally panned when I posted pictures of it....
- i am disappointed. like 2" of snow here in virginia and the streets are still driveable
- psa: changing over to snow tires in an unheated garage, with no air tools, is NOT recommended
- I'm brand new to your board. I'll lurk for a while and try not to ask dumb questions
- Speaking of sand in the intake, here's an off-topic blast from the past. This is entertaining.
- Tire blown; 3 with 3k miles and 1 new ok for quattro? yay or nay
- Is 245 is too stretch for 8" width rim? TIA
- Is there a difference between the EVO MS intake for b5 and b6 1.8T?
- when someone says housings only...what do I need to get in addition to that?
- CV/Axle assembly issue - help?
- fog light question
- Check back here in the morning for a nice announcment for you B5 guys!
- so i hit the NAWZ button for the first time last night...
- Some classy statements by APR... Just remember this when you drop 5k on a turbo kit.
- Just had tires replaced and alignment done, now i have a problem..
- Major coolant leak, need help finding it.
- For those of you that heel and toe, do you actually use your heel?
- How long does it take to take off the valve cover, is it just a few screws?
- For all you Avant folks.
- OK, now that i have figured out how to post a pic, does anyone want to make me a sig?
- just trying to figure out how the fvck to post a pic in my sig. Help
- Need help removing MAF sensor.
- SoCal Dyno Day results from Tuning Technologies (Colton) - Dec 4, 2005
- Is 500$ too much to pay for used but pretty clean s4 bumper and rear valence?? thanks
- engine bay p0rn!
- who makes urethane shifter-bushings for our car
- I have an APR boost gauge kit 1N110001 (VDO) and can't figure how to
- Airbag control Module
- Paging Kris Hansen: You around at all today or tomorrow??
- im about to get raped :( by Big O Tire's in Socal!
- a junkyard find...
- just saying good bye...
- weekday repost: anyone got any used/new K03 sports that they have for sale or want to get rid of?
- Part number question: p/n N-013-849-2
- So who's done a cam chain tensioner R&R? Any write-ups out there?
- X-Post from last night: Clean MAF or no?
- For all who have welders...
- PSA: If you chose to play in the snow, don't hold your wheel agaisnt the steering lock
- N75 "J" valve install...
- Ecode help needed
- Tool Definitions?
- with all the snow predicted for the east coast tonight... who will be spinning like this?
- anyone here had an ATW (model year 2000 1.8T) coil pack go bad?
- lame question but...
- Exhuast questions.
- Water Pump BTDT: gasket sealer, yes or no?
- awesome fuel economy.... 250miles/tank...wtf????
- coolant temperature needle is a little bit to the left
- technical name please for these hoses'
- Qfrog...
- '98 Audi A4 Quattro Avant (late model) Timing Belt Job Questions
- sludged to death AWM
- Winterizing an A4?
- Alternator issue (96 2.8Q)
- Well, the OEM clutch is in.
- After Chipped
- My 2.8 idle bounces and sometimes stalls even when warm
- Car still wanders at highway speeds (long)
- Loud, low frequency vibration that is RPM and gear dependent under WOT...
- happy beginning of teh holiday season...
- slight vabration under low throttle, Need help finding out the problem
- paging Mike @ PureMS ---
- Brake noise... How hard would it be for a guy with minimal skills to remove the rotors and do the...
- Anyone have any experience w/ the ECS 2-piece rotors?
- any one interested what a MAF looks like inside
- OT: Anyone here in the Grand Junction CO area? Comeback, break 1-9, *inspired by the CB post* -edit-
- Big brake Kit?
- s4 glossy exterior b-pillars
- My CB Install...
- OMFG THEY STOLE MY FVCKIN HEADLIGHTS!!!!.......
- where should i get a different downpipe? or even a testpipe
- P1624 code help
- new siggy...
- I found that the adjustable fpr that I got through USRallyTeam.com changes pressure as...
- bleeding the brakes on the chevy truck today i gotta say i love the audi
- Turbo Question.
- cleaning out the parts bin..any interest?
- Hooking up Satellite Radio through CD changer trunk input
