- Trip computer display
- first snowflake of the year this morning...ohhhh boy!
- will s4 clutch disc bolt in? with all the rest a4. and is there any benefit to doing it?
- Washer Fluid Tank - Same across B5 audis?
- Suspension work, 4-wheel alignment, timing belt---> drives like new (almost)!
- Anybody know a good MTM chip service center in the Los Angeles area?
- interior help
- working K04 >> K03 with a bad wastegate.. that is all
- side skirts?
- Anyone replaced their driveshaft?
- scanner
- Is it true you can only get S3+ on an AWM now?!
- Sorry to bother.
- correct codes for97 audi a4
- i hate kids.
- car running rich.. help needed
- Boost reading
- Water Pump Leaking
- so i felt the loss of power recently, assuming boost leak i've been procrastinating...
- Is this a dead battery or something else?
- Is the part number for the infamous L hose the same for AEB/AWM/ATW?
- What do you think my T28 turbo (20K miles on it), PES T28 chip, & 440 CC injectors are worth?
- Does anyone have some detailed pics of the KO3 exhaust side?
- Just got her back from the mechanic...
- Mods 1999 1.8T- ***NOOB ALERT***
- OEM S4 bumper & fogs on 98 Avant
- Recommended 75k Service?
- [TUE Oct 17] This is it L.A., last GTG @ The Stand for this year... don't miss it!!!
- Just did another CAPS run, shaved off half a second but sprang a boost leak...
- Ticking sound from the front grill area
- how many feet of vaccum line should i buy?
- Its TOTALED...
- need help on ignition recall
- Should my fan be kicking on when i'm stopped but the coolant temp isn't up to temp yet?
- Any progress on the center display replacement?
- RE: we'll be here
- is there a site that more/less tells u what quarter mile times are equivalent for what 0 - 60 times?
- looking for a used abs wheel sensor
- why do I not want a fiberglass RS4 style front bumper?
- lurking in the s4 forum led me to find.. this...
- best choice of brakes for 98 1.8T
- I have a strange electrical problem regarding an aftermarket stereo...
- Rear Headrest Screens
- No heat!! (repost from 12v forum)
- Tips on installing an APR Stage 3?
- Just replaced thermostat, car warms up so fast now...
- VAG problem HELP!
- Does anybody know what kind of hose comes with the awe boost gauge kit?
- Can I get some part numbers for the turbo gasket?
- replaced intercooler, no car is hesistant
- BWAHAHAHA! i love audizine
- can anyone give me the location for the fuse for the
- Does my problem fall under the Ignition Switch recall pgm?
- well among other problems.. I have some serious injector blow by issues..
- Automatic Transmission Fundamentals
- Lol... Neuspeed sells ecodes on their website for $1,400.
- LMAO... pot calling the kettle black!
- semi OT: I'm digging the new ipod integration in the higher-end Audis...
- Poll: What winter tires do use?
- The U clip refuses to catch the coolant temp sensor.. the sensor keeps popping up. Now what?
- Question, if Audi missed a DIY body work and certifies the A4 and I found
- Hopefully I don't get flamed! I'll give this a try------
- Instructions for APR Stage 3 install?
- ATW and AEB swappable?
- Any tricks on replacing the coolant temp. sensor on a 2001? I'm currently having a really hard time
- Help with programming of keyless entry.
- Looking for a non-sport front sway bar...
- Need some help quick!! Sunroof!!!!
- Stealership is trying to screw me...
- Wheel Oppinions.
- Friend of Fast ------->>>
- Anyone know of a source for new Central Lock Pumps other than the $tealer$hip?
- SMASH!
- must i remove the caliper to change rear rotors?
- Anyone need 5 X 100 wheels/ winter tires for their other car?
- Any good links/books to recommend for understanding engine internals?
- TRE ball joint level concern after alignment
- stasis just got back to me and they are telling me something different guys
- Snub mount in the UK?
- Module masters to the rescue again... (ABS module failure)
- 18 inch rims?
- PSA!!!! For everyone with a '00 or '01 or '01.5 1.8t that is chipped, Replace your Suction Jet Pump
- Changing the Rear Rotors
- OT: My weekend modding on the bike was a success! BWW
- Keep blowing my dv off the piping
- Does my car have keyless entry?
- now that i changed my MAF sensor...
- Found a small tear (Prolly 1/2") in one of my front-outer CV Boots. Can I go a week and a half
- To all those who told me UUC would never make good on their promise to send me shifter inserts
- T-Bolts from the turbo outlet to the throttle body what a comforting feeling...
- And my personal nightmare has come to a conclusion, with sucess,
- Trunk gas strut not opening like it used to... can it be lubed?
- the chicago audi club is having a fall drive this saturday....details------->
- Quattro security system 1997 schematic
- The clutch has arrived!
- Specialized German '01 1.8t oil pan $150 used... what a joke!!! found new for ~$130 multiple sources
- does anyone have a rns-c navi system and want to burn me disk 6?
- Will OEM US-spec xenons plug/play into a factory non-xenon B5?
- Daryl Or Paul @ Tantrumwerks.com I've emailed both with no response over a week.
- i'm an idiot...broke off the clip connectors in the 6 pin wire harness for rear tailight upgrade
- Where is the water temp sensor?
- Anyone else not driven their car in a few months?
- How much time should i set aside for a fuel filter replacement?
- Is 06B 905 115 R the current coilpack version? cyl 1 coilpack (H version) decide to go last night
- Custom Intercooler Piping.
- Power Steering Hose
- 2001 A4 Audi heated mirror
- best timing belt kit / service kit to purchase for the money?
- GO JIFFY LUBE - Must see
- B5 S4 parts for sale....crashed car
- Ignition switch recall 00V317000
- $200 for a new passenger side auto-dimming/heated side view mirror from ECS
- Oh good.. my radiator is leaking
- Any online source of cheap 17" steelies?
- Just bought pair of H7's & got free pair W5W bulbs. Where r they used besides Ecode housings?
- My bad experience with Velvet Touch wheel repair in San Diego (rant)
- Ill find out tommorrow but do you guys think its totaled?
- 100K miles worth chipping
- What does everyone think about the 07 subaru legacy gt interior?
- to properly flush and bleed brake system do I use my vag-com to activate ABS pump or pressure bleed?
- CONTROL ARMS
- Alright, w00t! I finally got my car to the point where I can call it "done"
- hmm...boost leak??
- Flushed my cooling system with Texaco lifetime antifreeze. Should I be concerned?
- This need to be fixed.... and I need your help
- I didn't know APR made a stage3+ with a gt25...
- CEL help - I just got a CEL 17536
- This golden nugget of wisdom brought to you by vortex
- Baller Status
- New England/cold weather 1.8T's, what oil will you be running by the time snow hits? miles on car?
- Does anyone have a silver trunk lid they would like to part with?????
- thinking about these wheels...
- Having difficulty need some help plz......
- im new here
- Well long time no see everyone. Just stoppin in to say hello and that I miss you guys....
- power stearing pump/belt bad, loud buzzing noise when turning, okay to drive 45 miles to get fixed?
- Damn, upcoming dyno day @ Champion in Pompano, FL. Looking forward to some BT 1.8T results :)
- Looked through ETKA cannot find the part numbers for the windshield wipers with the dots that turn
- 96 A4 2.8 -- Blinking Oil Light
- Here we go; my door ajar warning is now always on. (archives no help)
- Car pulls from left/right on uneven pavement....bad TREs or tramlining?
- Pic from the weekend..
- Car was smoking today, white smoke from drivers engine side
- paging mmart to the red emergency phone!
- Anyone doing TREs anytime soon?
- While fixing my exhaust clamps, I have seen an oil leak from the transmission... looks like oozing
- So i just went for a ride and...
- '01 1.8t oil pan replacement... what's involved
- spark plug recommendations... is this one pictured still the best?
- Don't waste your time with Fel-Pro gaskets.
- Brakes make funny sound but
- My windshield got a crack from a golf ball-sized rock that flew off the back tire of a car in front
- BT Oil line question.
- how often do you need to change the air filter and pollen filter?
- Looks like i hafta go back to the TB......
- w00t! New t-stat and o-ring are in and my temps are perfect. The oil gets nice and warm
- 2001.b5 Prestone holder... Anyone has one used for sale? Or where can I get one for cheap?
- Brake bleeding confusion/quagmire
- how much are my HID xenons worth, stock?
- Vag-Com help needed in Eastern North Carolina??
- anyone know how to remove th armrest?
- HID issue...
- Check out the new ride...
- Will a 5v 98 or newer head fit on my 97 4v head?
- did someone link my rusty hood pic?
- STFA K04 on GIAC K03 software (ATW)
- braking "judder"....
- aftermarket mirrors
- STFA... will an EVO VII IC fit behind the stock bumper on our cars?
- got a 96 a4 2.8 how to replace the starter.seems like no clearance. is there a easier way.help.
- Rear Sway Bar
- How to reseal your headlights
- fuel pressure... need some help
- Strange issue: startup problem after refill.
- 2001 stereo upgrade
- my AWE dyno day plot
- New wheels on the Wifey's TT:
- how do you figure out which switchblade key you should buy if you dont have the FCC off the old one?
- Just added a new tool to my arsenal: Rear caliper piston retractor tool from Germanautoparts.com
- It's official.. Driver side front Wheel is bent..great
- Center console lights not turning on occasionally...
- I noticed yesterday that my subframe is out of alignment. Is this a DIY or if not, what kind of cost
- My hood latch broke. Search comes up with two similar part numbers. Anyone know the difference....
- Crazy hair pulling coolant temperature oddness, expert advice needed!
- Any ATP or Renn-art Eliminator kit owners here?
- DIY Painted a rear window spoiler I bought used a couple weeks ago.
- RESULTS: 4th Annual AWE/EPQC Dyno Day - 10/7
- *Starts playing Herbie Hancock's Rockit*
- traded track wheels with Jon1.8t last night temporarily (or so he says (thinks...))
- Please god don't let this be synchros.. I don't want to rebuild the tranny right now
- If going above and beyond the A8 upgrade...
- Shot of the Hella Optilux that I installed tuesday and MAF question .
- any schematics of the the wherabouts of the grounds on a 1997 2wd a4
- 1997 a4 oil leaks how do i replace the sending unit
- I'm offically the proud owner of a 2000 A4 2.8 Avant. :)
- Any Socal folks heading up to Laguna Seca for ALMS finale?
- leaking fuel line
- Odd noise when under WOT...
- The wheel gods were with us at Road Atlanta.
- clutch problem on incline only?
- Washer Fluid Light On?
- Armrest finally fixed!!!!! BWW LONG
- Went to show and go today...didn't even place
- Quickly: What's the fvckin' trick to get the caliper retaining spring on? I can't get it to snap
- To Audiworld.
- does anyone with CF trim want to trade for piano black?
- suspension q: i have koni/vogtlands. when i bounce the car up and down by hand, the pass. side
- does the display alert us when the hood is open? i drove 20 miles with my hood popped
- is there a major difference between these 2 kits? i ask because purems has red/orange and the other
- Yay for ebay....
- Can anyone identify this leak?
- k04 in the house ... props to the guys at ctsturbo.com for fast shipping
- i found the problem with...
- Anyone know the 1pc headlight in oven trick to seperate them? more..
- 200miles and 13 gallons.....
- A visual compare and contrast B7/B5
- Can I use an optima 35 battery vs the 34r most people use? Or would a 34r fit better?
- Vag-Com or OBD-Tool? Advantages/Disadvantages of both?
- Just took the A4 from my brother and it has some issues, any comments
- burned out 3 new ect sensor (dark green now) in less than 1 hr
- Coolent sign in dash blinking all the time!
- Temperature gauge readings
- Window squeak when rolled up. (already searched)
- Well went back over all my turbo outlet -> intercooler plumbing and found that...
- Oil problem advice on diagnostics
- Pics of my new ASA AR2s in 18 x 8... what do we think?
- Opinions?
- 5 bar is how many psi?
- So ive decided against a 540i, or another fast/expensive daily driver in general....
- A4 1.8 auto gear changing problems - thoughts?
- just replaced spark plugs.....
- Pics of Valvetrain
- SpeedyDTP247 SC'd+CQ to the courtesy phone
- Trying to take off the steering wheel...
- modifieda4, what did you dyno at awe
- where is a good place to get gauge faces that are simlirar to stock for a A4 99.5 A
- My best run @ AWE dyno day w/ GIAC X-chip > 175whp/190wtq
- quick question......
- Ok, stupid noob question: how do you get the front bumper off?
- How hard should it be to remove the ABS sensors?
- i bought a concert I from ebay. didn't include the code. any way other than the dealer to obtain?
- '96 A4 Frustrating Ignition Electrical Problem
- Folding key help
- Which car cover would you buy? or do u have one laying around?
- Anyone Pls Help!? "Timing Belt Situation"
- Timing belt issues (on 1.8T) limited to specific years or all years?
- is the dealership the only way??
- so I was a bit disappointed with my dyno yesterday
- Front drivers side wheel has a wobble to it.. argh!
- So yeah, im pretty sure its totaled...
