- crap...just did two CAPS runs and the data is all F'd...
- I have an a6 question ... figured I'd ask the b5 forum b/c the rest are usually somewhat slow.
- Turbo in need of replacement? How difficult?
- I really like these - or am I going to get flame
- Vogtland springs with bilstein shock people - is the front of the suppose to be a little bit higher
- front and rear diff.
- DBW question, if the ECU sees the correct load(maf) before it sees the requested boost...
- Bilstein or Koni shocks and a question about springs....
- just browsing through some different rides.. check out this install
- Finally pulled the trigger on the GT2871R! Time to clean out the shop :)
- So I washed my car with dishsoap today and am amazed at all the gunk it took off (mBWW)
- ETKA GUYS ! Where is the fuel pump relay ?
- PureMS :-: Preorder Sale on Vogtland Coilovers! *LAST CALL*
- I just scored some MSdesign side skirts......need some advise/info...
- broken belt??
- which oil drain plug should I use?
- A4 seat?
- FREE to a good home: Bilstein SPORT shocks, grooved
- Decisions... decisions. And opinion needed
- For those that doubt the B5A4's auto-x ability....
- 17965 - Charge Pressure Control: Positive Deviation <--- I hate this
- ABS indicator light on and blinking BRAKE indicator
- Remove Inner Tie Rod
- so who has played with lemmi and what did you change?
- Need new exhaust
- Do I actually get to start the WEEKEND MOD/MAINTENANCE THREAD???
- Any write-ups on removing the entire dash? The complete padded dash top.
- I put my in car camera mount together. Does anyone elses k03 sound this loud?
- Anyone have a Rearview Mirror (non-dimming) for an B5 A4 they want to part with?
- Update on Rosati's car
- Bose Symphony HU is good for something afterall...
- coolant temp gauge is acting strange
- Temp seems to be a little erratic. Tick and a half in about 1 min u pand down. Thermostat or sensor?
- Something terrible is going to happen to me soon. Tonight's wreching went flawless.
- So, CAPS time gets worse after a larger SMIC install.....
- BQPW.. bad quality pic warning
- Inner CV boot torn - options?
- Anyone have pics of installed hitches on an Avant?
- where can i find what ECU i have?
- Headlamp washer fixed themselves ,started working again . (more)
- anyone who has painted their lowers.
- Starting Issue
- New or Used Engine and Transmission
- Why do they put this stuff on their test cars? To disguise them?
- Vehicle Speed Sensor Problem (*Pictures*)
- 1998 A4 B5 2.8 Bleeding the air from coolant lines?
- airbag light , abs light are on and brake light is blinking. searched already..
- Talked to a few guys, I might have tripped the Fuel over-run cutoff valve Anyone know how to reset?
- The end...
- Thinkin about trading in my
- 1213KM done today... tomorrow = 1331km... I RULE
- Hit and run update! Pics coming.
- This post will carry on to tomorrow so I might as well ask now : what have I missed B5'ers?
- Just got my t03/t04 kit
- My first VAG-COM scan 1 Fault found
- Need advice on 2001.5 PES t-28 car.
- Washed the A4 today...pics for your enjoyment :P
- New Bay Area Performance Shop
- Long day, Installed turbo and everything else Started it up before, now its not starting
- Trying to remove Lower Door Trim.........
- oil drain plug on 96 A4 B5 2.8 FWD
- Question on CEL's...
- Heading out to the Pittsburgh Auto Show........Semi OT I guess.
- When should i replace my stock sport suspension?....
- replacing electric fan, found few posts that direct to pull bumper, any one found a better way ?
- ABS help!
- just took my throttle body and ic-tb hose off and both have tons of oil in them!!! what could be the
- Hey Kris:
- APR CH BOX
- WD40 for cleaning wax residue off of tires? My tires still have a yellowish residue on them.
- engine whining noise
- Whoo! Code! 00792.
- HLP: can some one lookup a part number for me...thx
- Is this what the rear driveshaft seal looks like?
- Koni Coilover problem (broken spring) Update
- Jumperbox.... delivers 12V cont 12V switched and fused 5V to the rj45 in the
- 96 A4 Starter Wiring Problems
- ***Group Buy For Zender B5 Avant Roof Spoiler***
- Just got done with the trans mounts. 034 solid passenger side, Stern driver side. Wow
- Audi A4 Headlights
- looks like the auto lock feature was activated on this b5
- So the mechanic doing my clutch replacement has told me that my flywheel is toast on my 1.8t2000
- Anyone know who makes this engine cover?
- anyone have bad experience with South Bend clutch ?
- Sexy....
- Frustrated ->
- Anyone know the inner diameter needed when ordering hub centric rings?
- Rear springs sagging
- I need some help with my HID lights.
- Excepting rim size, what are the exact parameters that make rotors compatible/incompatible (long)?
- Odd thing I need help with: So my speaker work fine with radio and CD but pop in a tape
- the 4 TB bolts that hold it on are they supposed to be torqued to spec and what is it?
- How many would have interest in OEM finished Carbon Fiber or Carbon Kevlar Int. trim kits?
- Anyone upgrade Cams?
- Anyone have Aftermarket (thin) Lugs they dont need?
- will these fit my a4?
- Need new rear wheel bearings, Worth it to go used?
- Can this be? A true replacement for 1stvwparts.com for ordering Audi parts at cheap prices?
- Trim around shifter question
- is there a max HP/Tq rating for the stock rods for the 1.8T recommended by audi?
- *Update Stg IV SB clutch* Well turns out ot be a bad TOB...
- a reminder of the weekly Philly area MRSCC meets 4/29
- Looking for some high res pics of APR and AWE Boost guages...
- So, I've had the car for 3 days and....
- Would anyone anyone be interested in a RS4 tranny mount?. I have an extra one.
- OT...Has anyone ever worked on the front suspension of an '01 golf? I have a Q.
- i saw this pic of a valve train off a 2.8, what are the tubes running over each cam bank?
- 98 Audi A4 2.8 Tiptronic Problem
- oil....
- Has anyone built a stout NA 2.8 30v? I STFA and found very little info.
- Is it possible to get power from the rj-45 connector (phone) under the arm rest?
- Call me a complete ass: How the hell do you get the wiper arms off the motor splices.
- Recomended Brake upgrades...currently have OEM now
- Any way to reduce the heat or hi temps of the PC-16 setup?
- For the PC-16 users, what N75 do you use, and what is your max, constant psi?
- one of my last posts for awhile :P.. back to work tomorrow
- Compass mirror in my 2000 A4?
- Dungblog #? Avant full reconstruction ---> WITH pics, since everyone b!tched "TPIWWP" whine whine
- A4 2.8 Tranny
- Opinions on t03/t04 hybrid---->
- Hey all. Anyone have one of these they dont need? Ill buy it. pt # is 058 129 617d (pic)
- Eibach Pro System installation question
- What should my next mod be........torn between a few options. WWAWD?
- Howto: Drilling 5x100 wheels for our cars?
- how can you diagnose if your cv joint is gone
- Hesitation???
- harness connectors driver side firewall.
- Well cleaning up the old throttle body solved everything. The p1559 was cleared,
- Check Engine Code
- (32/22mm) HSports or 32mm front H&R/19mm rear Neuspeed for neutrality?
- looking for 17" Avus wheels in Denver
- STFA fails at life...anyone care to edumacate me on the K03 sport vs. standard K03s?
- Worth upgrading to S4 engine & tranny?
- Which one do you guys like best...?
- Anyone parting with a rear Neuspeed 19mm Swaybar for an early 98 B5 1.8TQuattro?
- Is this wheel fixable, estimate on cost? (cracked) and a few pics of car towed the other night...
- Sick of limp mode - Going to replace all the small vac lines... Some #'s help, please?
- Not having much luck programming my remotes. Someone tell me what I'm doing wrong.
- 2004 S4 18" Avus wheels.... Do I need spacers? ET 43 18x8
- Do upgraded throttle body hoses make much of an improvement? Like APR's silicone hose
- Dealer help needed!
- Help needed w/IC and alternator question!
- Does anyone need any of these spare parts left over from my S3 instal? *For FREE post*
- Part Number for woodgrain shifter surround trim piece?
- QMS?
- lean condition....HELP!
- How Crappy Different Car Bumpers Are Today
- Sad Day Nears Selling 98 A4 for 04 M3
- Removal of Climate Control
- Is it possible to put 8d0 920 980 Q in place of 8D0 920 980 C cluster?
- Pissed and Need Advice!!!
- right headlight out on old school halogens...which bulb should i get?
- Borbet rims soft?
- What numbers to the wheel or crank can I expect from this set up with custom tuning?
- 18041 - Accelerator Position Sensor 2 (G185): Signal too Low P1633 - 35-00 - -
- FMIC Core size - bigger the better or whatever fits your application
- Sent my turbo to Gpop shop. They told me its not worth upgrading to k04 because...
- PN Request (also what the hell is this part called/use)
- Rims for sale in classifieds....
- Xenon headlight issue
- This may be why I'm having codes with my throttle body
- success!!! ha it wasnt a dumb idea. *EDITED*
- What sides look good with stock front and rear bumpers?
- Thinking about getting an Audi
- Pic of knockoff RS4 engine mount...
- Video clips of the 3" cat back...
- Thinking of buying a 2001.5 A4
- I think i have a problem with my ABS
- Hey bishes...I 've been away what all did I miss?
- Fuel Leak
- what are your foughts on blua parts slotted rotor brake kits?
- Hot DANG! These A4's REALLY hold their value over the years.
- Bent Wheels and Upper TRE question
- Anyone ever do a SERIOUS refinishing of their headlights? (sandpaper)
- Air flow flap motor going crazy...
- once the cv joint is clicking, there's no point in repacking it correct?
- Anyone know if the 1.8t sport seats are interchangeable?
- What say AW? Price of an '00 A4 1.8TQM with 60k miles and a bad turbo, timing belt not done yet.
- broken wiper arm on a 98 1.8t
- Catalytic popped off..
- A4Q drooping rear suspension
- anyone have one lowly OZ SL lug bolt hanging around they could send me?!
- xpost from the vag-com forum: wierd connection problem
- Dungblog #? - Avant full reconstruction -----> Almost back together!!
- Just got home... what a long a$$ day... dungbeetle.. thanks for the package.. euro rear + new front
- Diagnotisic code query
- 3" Custom cat back installed! Impressions/pics...
- OMFG LMFAO. I'm in tears here... IamAwesome are these really your parodies...
- Will removing the ski sack improve bass from a sub in the trunk enough to be worth the hassle?
- What injectors to run to get numbers around 300 crank with fmic, k04, and turbo back
- Front sway bar bolts
- Who was it on here that bought the Tein SS C/O's recently? Installed yet? First imperssions?
- CEL #1136
- I lost my only key. How can I have my car back? Help. Help. Help
- well I finally got the car towed. I spent an afternoon searching for a local (oxford) shop who was
- Anyone know anything about Beach House Imports in Costa Mesa
- Bad CA in brand new kit...should I go through dealer or actually call Lemforder? Cont...
- 1.8T BOV
- I have a p1559 code that will not clear. Does this mean my throttle body is toast?
- Thank you (again), AudiWorld
- does anybody have a flow comparison of aftermarket exhaust mani's? i thought id seen one
- How to ruin an A8 in a hurry.
- selling my car
- X-Post from Ross-Tech forum... help please!
- ATP manifold problems please help: : : Bad thread made even worse.....
- Audi Antenna
- .. yawn... just a pic .. i guess i'll post more later
- labor quote wheel bearing replace in baltimore MD
- Anyone have a VW phatbox to Audi cable? Looking for a good used cable that will work ...
- WORK WITS wheels for sale - New - 18 x 8.5 et32
- how do i get unlock code for stock radio
- Concert I radio Dice ipod link
- I had a bad solder joint on my chip which caused my car to shut down, now it feels stock
- Retarded Problem....please help.
- does anyone have shipping plugs for ecodes?
- Aftermath of first Penske Audi GTG/BBQ
- Is the Bosch F7LTCR spark plug discontinued? If so what's a good replacement? TIA
- Is there a writeup on replacing rear rotors & pads?
- Got a B7 Loaner today
- Ex-post from regional forum... please help with AC repair
- ABS sensor question
- PureMS :-: Preorder Sale on Vogtland Coilovers! *Last week*
- 450hp 1.8t?.....Is this possible?
- A4: 1 , Me: 1
- Anyone over here running oz chrono's?
- anyone have a hood release assembly they want to part with?
- Back from Vegas ...
- What are the manual transmission codes?
- Car won't start? Replaced starter same problem, need suggestions!
- Oil Pan Problem
- CV Boot Replacement
- I was unaware that B5s were capable of mitotic cell division
- Duraflex???
- Look at them shiny tits!
- Any advice on removing the lower rear CA?
- I was thinking about....
- So after talkng junk about the 2.7T alot recently, I find myself looking at 2.7T 6-speed A6's....
- Stasis Street Coilovers Finally on....No More Truck Suspension....
- Got my new downpipe in today, shop is going to run custom the rest..
- Paging MICA : Many results for A4's at this week's sales, All manual as well
- a4 is safe!
- Need some advice on possible causes
- whoohooo the A4s front is now sitting at stock sport height. Don't have to worry as much
- need help buying 1999 audi a4
- Help! vibrating coolant tempreature gauge
- Rear grinding noise, replaced wheel bearing, checked rotors...
- OK i searched! and this is wat i got...please confirm
- Perfect tool for a car/engine with a known sludge issue..
- just got my ecodes in the mail today WOOT! questions inside
- So while we're waiting for the oil pan parts, the shop is going to build me a custom 3" exhaust...
