- .....I hit a curb
- let there be light
- Gas mileage experiment
- Cat flange cracked open tonight... 109,000 miles on a 99 A4
- Well, had a sit down conversation with the wifey today about the car situation....
- Anyone parting out an A4 in the IDAHO area or nearby states?
- Are there (2) type of intercoolers for a 99 1.8T?
- Vermonters! I have a question for you
- Air con blower question
- Hey beejohn - nice "meeting" you today! :-)
- Grumble grumble... Avoided a big crash on I90/94 in Chicago this morning....
- Turns over but won't start - no codes
- ah, battery is dead again. Can I watch it charge with a multimeter?
- I figured out the problem with the starting issue....
- So i was able to change my thermostat without doing the timing job..
- Installed S4 rear calipers and brackets - do I need 2mm washers as spacers as in the tech sect w/...
- omghi2me! and a clutch question to boot
- quick question, im changing my inner tie rods and i noticed theres a
- X-POST ..for Tony , so you don't feel as bad about not making the rally ..X-POST
- 96 Audi A4 2.8L oil pressure issue... driving me crazy
- My dad just sent me this....Ford Probe R8 Kit car....
- Am I'm crazy for thinking this makes for a perfect night?
- ive got what sounds like a thud when releasing the throttle under hard acceleration...
- Boost leaks are teh suck......
- If I would buy back my car from insurance to part out, who'd want what and for what price?
- Remote question.
- Feeler: My current winter wheels... 18" Krimson K6's...
- 2001.5 A4 1.8T Won't start
- Blow Out Sale Update
- Installing OEM factory fogs (lower) on a 98.5 A4
- VVME 5000k's are well worth the extra $15 over 6000k.
- Forum Stats are Up: Nate, Jeff, Mandeep, Kris and Mica; congrats
- headlight washer nozzle cap/cover?
- I'm hoping someone might still have on file the pics of this CC write up>>
- Anyone have the P/N of the central locking pump for a '99 A4? TIA
- is it hard to change the thermostat without removing the timing belt?
- Want to put fog on a 1996 A4
- Difference in ABS modules.
- Taking the TB out of a 30V is fun, fun, fun.
- Timing belt job suddenly needed at 126k
- Poll: price for premium gas | city, state
- Need some after market keyless entry help
- Car cranks sometimes and sometimes not....
- A4 1.8t upkeep
- About to grab torque wrench finally. $30 beam type, or $70 for kind you set..
- Approx cost for new alternator in '00 A6? Friend's mechanic quoted him $1000!
- VMR Wheels | 19x8.5" V715
- Are there any springs on the market that are firmer than stock but do NOT lower the car?
- Wierd brake issue
- Car sounds like a diesel at idle
- Just installed 4 new Type R cp's and cylinder 3 wont seat flush like the others...
- Bushing kit for rear suspension
- My GIAC ECU is still for sale if anyone needs it or knows someone who is looking...
- Oil pump? 1999 a4 1.8t
- Is it possible to completely disable the brake pad warning light?
- Hmm...looks like Stasis isn't offering the rear LSD for the A4 anymore....
- A4 will not start after cold weather
- dome light dosent work when door open .....
- Post your best winter picture showing the kahr!
- Sway bar hangers???
- I wish this was a closed course...
- timing belt tomorrow.
- Seats are both in; cleaned plugs and car is running alot better going to switch to 6e's
- RIP: My 98 A4 was totalled out today from a >5mph crash.
- OT: Vanity Plate ideas for the Truck?
- B5 A4 = FS forum now?
- FS: <in classifieds> B5 A4/S4 OEM (ZAW 334 001) car cover, barely used.
- FS: B5 A4 chassis OEM bra (Autobahn ZAW 193 015) in like new condition (box, paper work, etc).
- ECU question
- Does anyone know...
- head lights
- Car is feeling a bit drifty on the highway over bumps, lighter steering left then right + clunking
- New surging and spark plug woes.
- How easy to transplant a 3 spoke steering wheel onto a column that currently has the 4 spoke wheel.
- Man....still one of the best looking wheels Audi Ever Made...Bolero S6 10 spokes, $799
- bosch vs audi 710N diverter valve
- Definitive B5 A4 Coolant/Antifreeze Use Thread
- need to replace heater core
- what type of fluid is best to be used for the automatic trans?
- THANKS KRIS!!!!!!!!!!!!!!! Got the package...... you're the man! :-D
- I suggest that anyone needing any custom aluminum work (piping etc....).....,
- Attaching the transmission lines to the radiator....how?
- Heated screen washer jets
- I found 104 octane at a gas station by work!! w00t. Time to make a new map.
- Starting from scratch...
- Anyone get good Audi Related Xmas gifts? Mine:
- Blew a hose on the way to class; thought I might as well figure out my misfire issue on #4
- DIY Timing Belt Instuctions
- Parts car anyone?
- Disabling headlight washers
- Alignment problems...
- '99 2.8Q Cam Seal troubles....Should changing it be this difficult?
- Pretty nasty... TT Hill climb car powered by V8 TT...
- Mixing fuel grades
- 01 1.8TM turbo lag question 1st vs. 2nd gear
- Tips for installing the AWE DTS?
- While I was fixing oil pan, I noticed these two pipes damaged from the bump, what are they?
- Fixed Oil Pan finally.....here are the results
- Adjustable Control arms all back in stock!
- Anyone need a Fiber Images vented hood... there's one ending shortly...
- Ugg Time for Rear Wheel Bearing Replacement
- Unitronics stage 1+ chip question
- Brake Disc and Pad problem
- 1999 B5 1.8T Front End Height?
- There might be a Philly area B5 A4 photo shoot going down if anyone wants in.....
- Coolant Temp
- Rear end roaring - brakes?
- Anyone have Jeff Moss's current email addy?
- The GTI went on eBay last night guys.
- Audi A4 B5 - LED/Xenon kit demonstration
- Here is the TB I scored for MtnA4Quattro's car (His car is a 1999 AHA 30V Tip)
- Hard to find out where this leaks are coming from....
- Oil Pan leak...HELP!
- Adam/TighTT in PVW H20 coverage...... ohhhhh....
- Timing belt change almost done, but one problem...
- A4 Wheels Offset Question: Jetta GLI 17x7 54mm Offset...Will they work?
- Things I need to have done by tonight:
- Lowering my buddy's MK4 Jetta later this week.........pita install?
- Avic-D3 gentleman.... question for you
- Trade it or Keep it ?
- Shift Surround refinish option...
- Starting off 2009 with some new pics and a new lens.....oh it's wide.......
- Does anyone have an extra driver's side halogen e-code?
- Updating A Tech Article (or amending one) ??
- *pokes head in* holy cow this place is dead
- Blah, I miss the A4 clear corner mod days
- Avant rear license plate mounting ideas
- 3 spokes sport steering wheel on audifans.com
- Best spring compressor?
- projector alignment messed up after removing headlights?
- How much do you guys think I can get for my 98 A4 w/ 140,000 miles?
- Preparing for cold temps
- Turbo Problem?
- so i think my ecu is bad - i have bt - can i use a k03 ecu and try to start my car
- Does anyone know the part number for the wiring pig tail harness for the funk switch?
- What am I looking at?
- Auto trans code 00268 and trans goes into after a short drive. Anyone seen this?
- The original Turbo & mileage thread >> K03 sport (X-chip) + 155K
- inner tie rod end replacement - happening now - need help with boot removal
- A present for my car tonight, HP dv1000 used with brand new HD
- Broken water temp sensor x2?
- Rough Idle
- Hey @wesome,
- Who's in? (Mica, your not invited)
- Would you use an 87c thermostat in an ATQ? (calls for 92c)
- Anyone know if the ( O ) light on the dash will store a DTC?
- Thanks to the forum
- FINALLY, got the Audi running again and passed for smog!
- FYI oil cooler o-ring failure
- So the TBA didn't do anything to Trevor's AHA 30V; Code, etc. inside...
- FYI HID ballasts and bulbs
- part number needed for license plate light holder... the common corner
- hmm good purchase?
- can someone take a quick look at their bentley to see which vacuum line goes where on the lock pump
- Oil Consumption
- I love my wifes 2001 2.8 tip. She hates it. But its a great car. Just got my Blackstone report back
- Grease Fittings in Rear Upper Control Arms when installing Powerflex Bushings?
- I'm leaving on a jet plane... don't know when i'll be back again ...
- How difficult is a full front suspension change by the at-home mechanic?
- Can a cracked coilpack cause instrument cluster gremlins? The answer is an emphatic yes!
- whats the largest amount of gas you've put in your tank at one time?
- wiring diagram request from ecu to fuel pump relay
- Surging atw at WOT. Sick of living with it.
- Things not to do on New Years - B5 A4 1.8TQM w/ 87k totalled - 65mph roll-over 4X
- Ok new problems, even a CEL!!
- pls estimate used sports suspension
- Nuespeed race spring install
- Trip computer and odometer have gone completely bezerk
- What happens to a wheel bearing making noise for 1.5 years?
- Window Switch Light
- will a 16v thermostat work in an 058 1.8t?..
- Holy crap. This is NOT my night. Just borrowed my neighbors Acura to get a snack...
- Kris, I'm sorry, I have to post this. I'm sick of ECS sending me emails when I've unsubscribed...
- Who is the guy on here that can get us the cheap oem parts?
- 5 years ago today i bought my 1st audi. lets see who remembers my silver beast.
- Ergh. Quattro + decent-at-best all season tires = fail. Note to self: Get snow tires.
- Happy New Year YFFs!
- Dave didn't you say you had a Zune? Yours freeze too today? LOL. Sorry about that ;-)
- 01 A4
- Need a S4 bumper ASAP anyone have one or know where I can get a new or used one the cheapest?!
- x-post: can you guys help me out with engine machine work questions?
- Hey guys, I just wanted to thank everyone who voted for me these past few weeks!
- Does anyone here still make those alcantara shift boots?
- Help please, logged misfires but no codes or CEL...
- So clutch is going to be something I do pretty soon on my Avant that is about to hit 135K. 6MT too?
- Rear strut squeeks
- Funk Switch 15EUR (I didnt get the cable though)
- MAF/IAT Sensors...
- Anyone have a complete 99.5 AEB engine harness for sale? There was none posted in the classifieds.
- If its not one thing its another!!!!!
- FU side streets that have tall icy snow!!!!!!!!!!!!!!!!!!!!!!!!!1
- Massive Year End Inventory Clearance
- Power Locks / Alarm Problem
- anyone with a vag com in Boston? or Providence, or anywhere in between
- Post the best pic you can find on your work or home PC, Audi Related of course...
- Bit the bullet and ordered a milltek exhaust...if that shyte sounds like my old honda then its going
- I let my brother in law borrow my A4 this morning and now we've got a problem...
- drive train slop - still trying to solve the problem... would these help?
- inner tie rod end procedure - Bentley manual?
- Slow day here at work.... My right hand work monitor is getting some cheezy mods =)
- is anyone here running a 255.35.18 that does not rub?
- 2000 A4 General Reliability
- Wheel Bearing
- it's minus 36 celcius... and i voted for tim! clik mah sig
- Repost: Engine is missing at wide open throttle, no codes or CEL...
- ***Big Savings on everything A.W.E. Tuning Sells with our Week 4 Holiday Special***
- The ball of my left foot is killing me from using my clutch in traffic, any insole recommendations?
- airbag light
- EGR Valve Insufficient Air flow 1997 A4 quattro
- HELP! need to figure out alarm problem before I go to sleep tonight!!
- Replaced Tie rod ends today....
- Vag-Com in Philadelphia Area
- '98 Avant Quattro suspension
- p1136 and p1138, any ideas? did a little research, couldent find much
- Engine occasionally refuses to start
- I found a 2000 B5 thats in good shape but needs a motor
- Jack Points, tried searching couldn't find any help....
- FYI if anyone has a radio with broken clips, it is possible to remove.
- stalling after pumping gas
- :: ECS Tuning :: Annual ECS Tuning Holiday Sale and Holiday Give-A-Way :: Final Week !!!
- Oil sensor error, exactly WHICH sensors could this be reffering to...
- Xmas present: motor apparently popped whilst car was @ Induktion [not their fault]
- what is actually involved when placing the carrier into service position?
- HID experts - adding to '00 projector lens
- O2 Sensor
- what do you guys think?..
- How to totally disable airbags?
- Smoke and odor coming up from under bank 1
- What is the difference between "Energy Saving" and "multi-grade" oil?
- Drivers side axle flange leaking at seal... is it possible to replace this seal without
- Need HELP car does not start
- X-POST: Going with my dad in the morning to look at an '02 A6 3.0qstip and was wondering...
- I've mounted A6 17" BBS RC wheels yesterday with 235-45-17 Fuzion ZRi tires
- Secondary Air Pump - Corrugated hose part #?
- Does anyone else have Fick Justice Gunmetal 18" on their car?
- Front left speaker blew out, what are my options?
- "Audi's are a rip off. Don't buy one, pass it on."
- Random CL find
- heater display out + inop on 96 A4
- Update on the flooded a4 that wont start.
- Do the rear CV shafts on a 98 A4 1.8T have a snap ring?
- anyone know the max tow capacity of a 99 1.8T auto?
- Anyone w/a set of 17" clunkers for sale, PA/NJ?
- Diagnostic Issue - Cannot connect to car...
- For those interested in wading through it all and looking for European/German junkyards, used parts.
- Old school fans take a look, big VW/Porsche collection on eBay right now...
- CV Boot Temp Fix
- Germany III: While I went to a night club as well here are some AWESOME things to see in Berlin
- Some people go out on a Friday night and get drunk at the bar...
- Questions about P0431/16815 Warm Up Catalyst
