- Quick Question: what's the easiest way to remove front ABS sensors
- Cactus curse strikes again...I have an excuse to go RS4 widebody...
- Headlight switch assemblies on a 96 A4 are a pain in the @3@..
- Just bought pair of H7's & got free pair W5W bulbs. Where r they used besides Ecode housings?
- Anyone want to sell a Vag-Com???
- So Christmas came in October around these parts...
- can someone do a good deed really quick?
- Need help with airbag resistor mod
- Quick testament to DIY... Saved $1100 on a $1200 quote from stealership.
- '02 Passat 1.8t...loud wooosh sound under dash/pedal area during acceleration
- B5 where you living poll
- Does this look correct?
- building custom intake, i need the size diameter our MAF is to buy the right cone filter
- Got VAGCOM working and here's the deal
- 2nd gear poping into Neutral when i let off the gas
- anyone interested in doing a group buy on meyle heavy duty control arm kit?
- Where to buy a new rear bumper cover (besides dealer)??
- rally ready.....
- anyone know the part #'s for the following ? cam seal, half moon seal, cam chain tensioner gasket
- X-Post... one badass looking motor...
- your B6 A4 forum post of the day
- tein basic vs. tein ss
- Please clarify something for me....If I go with a test pipe -
- Paging Kris Hansen
- engine knocking fixed easy!
- Anyone runnin "aromatics" in their fuel regularly?
- Do bad spark plug connectors take out ICM???
- m3 lip spoiler painted.....any tips on installation?
- Hit or Skip: Pure Motorsport Front Stress Bar
- your vortex post of the day...
- Ordered "Huco" ICM.... Got "Meyle" Instead?
- Broke my exhaust recently so I'm getting some custom work done..........
- Replace lifters as a set?
- Someboy seriously needs to do a Catch Can Setup
- *** Warm Start Up Issues ***
- BOOYAH! Lunchtime parts run to vw dealership...
- Here's a VW I'd love to own!! Video inside!
- Losing connection to ABS controller
- Weekend Mod Thread: What's on your plate?
- Stratmosphere front mats installed ... +10 whp
- climate control code question
- damnit! car is weak
- Well.. the new wheels are on =)
- just did an oil change last night...
- drivetrain noise??
- couple dumb questions
- Need quick advise please...
- Need a new engine.. anyone got??
- WH000T.. I'M drunk in vancouver airport.. i'd post in OT.. but it is blocked on this comp
- Finally LIGHT ..got Hella driving lamps wired ..some details..pic on weekend
- So.... I have made it from Cali to CO so far. 5300 RPM @ 105mph.. Honda PoWa' Yo.
- Is abs light on / brake light blinking *ALWAYS* abs controller module on the pump?
- Purge Valve??....maybe Little help please.
- Turn signals won't work but Hazards do
- smog
- Finished painting switches....
- Someone have a link to accessory belt replacement?
- So I have come to a crossroads.
- Pics of my new-to-me 1999.0 A4 1.8tq
- Brake decision quandary
- Ok, I STFA for the last 5 minutes. Someone explain something to a guy whos car is antiquated...
- Stock AEB MAF maxes at 187g/s right? I hit 216.06g/s today during my CAPS run...
- While ago I was looking for a projector & I gave a guy my addy to have him ship me one..you here
- What's a good way to test the electric cooling fan?
- Bitjockey - question about your clutch
- Is $375 a reasonable price for an airbag control module from shokan? Audi wanted $750...
- Nothing is cooler than the BAT Mobile!!!
- How much can I get for my A4
- your vortex quote of the day: "so glad I don't have quattro"
- Woot! 8mm spacers all around... stud kit and nuts...
- Nate (ETKA+Scumbag) where is this part located...
- OEM metal hose clamps are teh major SUCK
- prestone commercial: "good for any make and model car, mixes with any color antifreeze"
- noob 17939 update
- Need name of this part...............
- vibration from front end with wheel clocked slightly right - thrown weights?
- Quick poll S4 or TT
- Help Please finding a Flywheel for a '99 2.8 30v...
- Those running test pipes, what kind of O2 simulators are you running?
- New sig, what do you think?.
- So I replaced my oil pan yesterday after crossing 111,111 miles...
- injectors & fpr j31setup...
- rims check: what are those?!
- FS post in classifieds: APR Stage 3 Turbo kit B5 NDBW
- Anyone know of a Audi Specialist in NY-Long Island
- Timing Belt broke on me!!!
- I'm pretty sure my engine mounts are shot but I have a crack in my oil pan...how can I support the
- Just ran my first CAPS, im not completely pleased with the time.
- *Flame suit on* Question about dynoing.
- What do you guys idle at?
- I love my car, but I'm driving too much
- PAGING: BITJOCKEY... any update on grooved bilstein replacement w/ ECS?
- first week with B5 A4.... first 3 questions
- I was searching the tech section because I remember seeing a how-to, but can't find it now...
- Need ETKA on where a high pressure switch goes.
- control arm kit
- PSA: my wheels are mostly clean...
- LOL...30V question
- Paint help needed...
- Anyone got some 5 star wheels that will look clean/real nice on my B5 that they would want to sell?
- so are there any aftermarket 1.8t ECU/chip options that lets the user tweak engine parameters
- The ABS Myth. Do you need it?
- if you unplug the outside temp sensor in front of the rad, what should display?
- OT: ABS saved me again on the bike
- probably a respost but who cares...whos going to hit this
- Leaking interior
- I decided not to be cheap and finally install a boost gauge before any other upgrades., but ....
- smog problems
- HELP!!!!!!: AC not working, ran the VAG and got these codes:
- When was the last time you looked at your injector seats? They're made of plastic
- how long can I expect stock sport shocks to last?
- Woot!!!! Found a 2.8 transmission...
- Can some one do me a favor and read a couple part numbers off the intake manifold (aeb)
- I want I want.. oh yes I want =)
- Anyone know what this could be?
- the adjustment screws for the bumper shock are stuck
- just finished doing a pre-cat o2 sensor on my 99 aeb and im still a little confused about something.
- I love the Castrol GTX commercial when they just dump "sludge" onto the cars.
- Can you test to see spark while crank with coil pack spark plug setups... or do they work on a seal
- Update on battery replacement for my 01.5 A4.
- B7 RS4 reps that clear stoptechs
- So...tried to do a TBA tonight which failed.....
- Static from front speakers - audio questions
- Axle shaft slides side to side... is it normal?
- Need a favor. Wiring diagram for 00' A4 Audi Symphony Head Unit....
- USP wheels
- What is the right timing for timing belt replacement?
- ABS Dramatic failure?
- At work and car is leaking a pink/redish fluid, a pretty large leak, but seems to have stopped
- Need some help regarding painting/clearcoat problems....
- Hey guys, I have a question regarding a 96 2.8 12V....................
- B5 RS4 Sedan Conversion side skirts
- Has anyone tried the $30 VW O2 sensor from the dealer on their AEB for a pre-cat sensor?
- Does anyone know if the valve ceats on the head can be replaced and if so how hard?
- Can anyone touch this price for a front ABS sensor?
- My one year old turns two in about 30 minutes.
- anyone aware of where I might be able to get silver paint for MY2000 in larger than touch up size??
- Was there a group buy thread for AZ on here a lil bit ago. or am i losing my mind??
- Poll: Why do people try to work on their car without a VAG-Com and a Bentley?
- Suspension upgrade questions...
- Anyone have one peice halogen headlights they want to sell? I need something to tie me over untill
- Just got back from a drive, FINALLY! K04 sounds great , engine runs smooth but leaks a bit of oil
- Got my new cat welded up yesterday. Much better job overall, all the welds look good. Tonight I am
- Wow, Bassed just got pwnd right as I posted. LOL!
- Has anyone dealt with Spoolin Performance? more specifically with this fmic core:
- what speakers you guys put in the front doors?
- Bleeding brakes Poll: Motiv power bleeder or old fashioned way
- I'll try again - has anyone replaced the voltage regulator in their alternator?
- b5 2871r upgrade
- Someone with a Bentley--Please Help
- ABS and dyno'ing question...
- Started it up , added about 80 percent./quart (sry) of Dino oil and the main leak stopped......,....
- Well, I got my laptop rigged for WiFi now
- This might explain the why the "BRAKE/ABS" warning light is on:
- Since we have established that I cant run ETKA until I make some things happen . . . PN request.
- just got a new computer. (mac) does ETKA work on macs?
- Do the (new) turbo oil feed lines come w/ a swivel head for the Oil filter base as well??
- pulleys for a '96 2.8
- ATP GT2X + APR chip + Borla exhaust + stock fueling...
- So buying a B5 Avant rear bumper and S4 lower valence costs the same as importing a Euro S4 bumper
- Option code look-up....
- Odd request
- Do these look like standalone Vogtland springs to anyone?
- Electric fan or no electric fan?
- Just picked up my A4!
- Question about Chipped ECU
- No interior lights, No alarm light flash with remote unlock, no vanity mirror lights
- killaxova PLEASE DELETE YOUR POSTS IN THE FAQ!!!!!!! PLEASE READ THE 2 RULES!!!!!!!!!!
- Need help with headlights
- trans oil..
- 1st leak ...rh cam adjuster dripped on manifold...... Phil please read this.
- oil change,...
- I was trying to take off the cover over the speaker in the trunk ...
- Reaching goals.....
- Watching Southpark is making me think (catholic law stuff, dont mean to offend)
- Good Evening ...
- CHANGING TRANS. OIL
- I'm stumped guys... car still won't start.
- Just replaced my dead battery, with a new Bosch one from Pep Boys....
- S4 sidekirt mod...
- Paging Paul858: heard you had an FJ cruiser and Im looing for your opinion on it.
- Uhhem.
- Where is the best place to buy some replacement interior trim?
- anyone have pis of a 17x8x40mm on a B5 with the sport set up
- Quick Qs about CLP
- Anyone familar with these Bosch Super plugs? One hellva' ground implementation there
- will a 99.5 exhaust fit on a 97...both manuals?
- New floor mats for 98.5? Options
- bad wastegate.. time to upgrade??
- Central Locking Pump part numbers for 96 A4???
- Wheel BT: 17" B7 RS4 reproduction weight?
- emergency flasher
- Paging blkperl....
- Anyone successfuly change the service interval?
- The car started, Sounded like a diesel. Then oil spilled everywhere..... what could it have been
- AWE Tuning has received our Borla shipment.
- Clutch/transmission replacement...
- That's just great, my mileage went from 22 to 12 mpg in the last tank.
- So I'm quite amazed what $1000+ can get me for my car...
- Does the Sachs OEM replacement clutch require break-in period?
- How hard is the exhaust manifold to pull on a 99.5?
- Is it OK to spray a small amount of WD40 into the ignition?
- Torque specs for knock senser on 1.8t?
- Greetings
- Need More Details: S4 bumper on 1998 A4 2.8 Avant Q
- My flex pipe is shot. My car sounds pretty mean but its starting to sound more raspy
- Synching Mac and PC?
- At the TB... Belt marks are dead on. But the belt is recessed over the cam sprocket.......
- O2 Sensor Vag output question
- Anyone know where I can get my hands on a new insert for a Rob Knob II?
- Is this for real?
- B5 A4 seat transplant
- 99 Projector lights into 97?
- Stock A4 Front bumper anyone?
- Just installed the RC engineering 550cc injectors and the Mika file tuned for them...
- Anyone have info on hooking up OEM heated seats in a car that didn't have them originally?
- Anyone running the Southbend DXD Stage 1 or stage 2 clutch with stock flywheel?
- Alternator light flickered on/off during drive to work this morning...
- Is the Audi 1.8T oil filter the same as a VW 1.8T? Does Fram make the correct size?
- Is it really in "limp-mode"?...Need a Vag-Com in MD.
- Starting Problems (engine starts fine dies after 2 secs)
- Here's the plan for tonight...
- looking for opinions.. spend $300 on spacers, studs/nuts, center caps for the B6 Avus or go new...
- Revo chip loaded yesterday 2001 A4 1.8T
- Side air bag
- how to replace engine mount on 12v?
- Incremental upgrade ideas...
- so.. can any of you Cad guys (or anyone) make me a template for a Symphony radio?
- engine vibration at 4K and above....
- So . . . I keep expecting my engine to be toast because I did my own TB.
- Exhaust options for my a4...
- A little SPEED TV video *SPOILER*
- Can someone help me ID this part? Cage holding the Symphony/HVAC/ashtray/hazard buttons
- Just changed my intake manifold, now having issue with car not starting
- Cyl. 4,5,6 Misfiring.... How come???
- ignition problem
- Best place to get RS4 mesh?
- changing spark plugs and found this
- Is Andrew Sprague still around? Trying to get some grills made....
- Trying to eliminate an annoying exhaust leak...
- "captured snub mount"
- Cant storm fly?
- And now it's time for.......
- Rieger Body Kit
- fault codes
- 1999 A4 1.8T Quattro Rear grinding problem - Very Long
- What's the general consensus between APR and PureMS snub mounts? Which one do you prefer/use?
- Hartmann Wheels Blem Sale! 17s for A4s
- Anyone Have Sunroof Wiring Diagram?? Trying to Hardwire a V1
- Really weird engine problem... NO idea what might be wrong (semi long)
