- 968/944S Calipers look close in pics anyone ever tried fitting them to a
- Cant locate Wiper fluid leak any common areas of concern?
- OT, but ive mentioned the Soobie Brat with custom 8" lift before, heres a video, Offroaders enjoy...
- So here is my question about castrol syntec ...
- Hmm, fixing my heated seat isn't going to cost as much as I thought it would
- Gratuitous clean car pics...
- Coolant temp. sensor popped out
- lamba sensor????
- Next question: 18x8.5 LM's...should I go with 225's or 235's??
- Gas Cap and Meter
- Added another VAG product to the family this weekend.
- Hmm, any 01.5 CH box cars want to swap ECUs? Been running my AMS setup for a while
- POLL: your choices for best three stage wax.. 1. cleaner 2. polish 3. wax
- Sad goodbye...'97 1.8TQM sold last Saturday... to an Ingolstadt worker :))
- I ran into a little issue when changing my control arms. Someone stripped the little bolts on the
- Somewhat productive weekend.. thorough wash, clay bar, wax..
- ModifiedA4: I've been dethroned!!! Think you can beat 103F? That's pretty effing high
- Dealership this morning: "If our computers see your chip, your entire warranty is void"
- Dear lady I passed in traffic this morning...
- Audi mechanic?
- Poll: Why so many n00bs lately?
- Timing belt kit
- Getting S4 Xenons to run H7 Halogen (for now)......need help
- ICM issue?
- Pulled my valve cover over the weekend, how does the engine look after 128k miles.
- Is it possible to get replacement shocks for H&R coilovers....
- Rear driver's side window issue.
- paging Joey..
- ECU P/N Question
- Turn Signal Fuse Blowing Repeatedly
- Suspension squeak
- Got on my Milltek....
- Heated seat conundrum
- just when i thought this forum had gone to the n00bs, i see some old AIDs resurrected
- Educated Opinions....
- Calling all people with Vogtland Sport springs!!! Could you do me a favor...?
- oil pans... DIFFERENT
- Overfill oil, should i siphon it out or it should be fine?
- Pictures from under my valve cover...
- Some clean car pics
- Anyone put charcoal or smoked lamin-x on their headlights? Yay or Nay
- Plastic CV boots. ughh.
- During a test drive today I was pulled over but I'm not complaining
- Free to good home (u come get them in lower CT)...caliper carriers
- Are Koni shocks too wide to fit into the rear shock housing thing?
- Where do you go to get a full carbon fiber hood?
- Secondary Air Flow on a A4 V6/5V
- Where do you guys get your A/C filled????
- Anybody have a quick write up on removing and installing front seats.
- Should i switch from Mobil 1 0W-40 to Castrol Syntec 0W-30?
- Help Needed - how to remove fan (for TB) 99 2.8 V6 30 ONLY
- Cruise control issues. Please help!!!
- *Mike Kim to the courtesy phone*
- xpost from awma: clutch install completed (almost)
- Fixed: 17964 charge pressure control: negative deviation
- Who wants to help me out and give me the torque specs on all of the CA's? : )
- Need help, Blinkers are on the fritz...
- I'd like to introduce you guys to Gizmo....
- Technical Service Bulletins--WARRANTY IS EXTENDED on TB?
- How to paint a stock bumper write-up done...and added to the faq.
- *noob* CEL, DTC 16395&17939
- quattro or not quattro?????? That is my question
- I was just thinking....
- 2nd gear woes...totally sucks!!
- Linkage mod Poll
- Gratuitous STaSIS World Challenge Touring Car pictures.
- will S4 bumper bolt/line right up on 00 A4 avant? (sorry, too lazy to search) and....
- since we're posting random pics
- and another
- PSA: Fel-Pro MS 96151 Intake Manifold does not fit big-port AEB heads...
- pic
- I'm turning into a ricer...
- 99 a4 1.8 no start when hot. cranks but will not fire
- NGK O2 Sensors for AEB
- electrical problems
- How to paint a stock bumper Part 3, 3rd and final:
- Tach and Speedo Stopped Working
- Happy Birthday CURSH!!!
- any pics of B7 RS4 wheels on a B5 avant?
- Chipped ECU appears to be dead. Question about ECU Connectors
- w00t! 70k views on the B5 FAQ!
- Cracked E-Manifold 99 1.8t
- Changing Spark Plugs
- Got about 60k on my K&N, so it's time for a good cleaning. What do you think about WD-40...
- New Audi Parts
- How to paint a stock bumper Part 2:
- You guys think your head lights stolen is the suck? I came back to find my GTI like this:
- FF/FR button isnt working on my symphony radio ...
- 1996 A4 2.8----160k and running strong. What oild and weight is preferred???
- stall of power in 2nd around 4k-5k
- HELP NEEDED - Loss of Power - CEL Blink - After Service
- Anyone know about the US states regulations on importing euro cars? Thinking about a euro Avant...
- AEB TB Stepper Motor maintenance
- Is the MTM stage 2 a good upgrade to buy used on ebay? ....
- anyone in boston area have a pre 99.5 grille that theyre willing to get rid of?
- Well finally tracked down the clunking/rattle noise from my suspension..
- clicking noise while i drive
- Will 18" B6 S4 Avus wheels clear StopTech's?
- oil pan leaked!!
- I'm in the midst of installing a new CV boot, is it ok to wail on the joint while the axle is still
- repost: Exhaust problems, way too loud, anyone with custom exhaust or even exhaust knowledge....
- ecu upgrade
- Hmmm....this isn't looking too good...valve train
- Oil leak?
- What's your idle speed at traffic stops? 1.8t
- price check: Stock A4 front bumper.
- PSA: Mobil 1 on sale at Advanced Auto for $4.77 a quart. decent price.
- 2001 1.8T, Oil Gelling???
- Is it possible to change the ignition switch without removing the steering wheel?
- 2001 Audi A4 1.85 ADVICE NEEDED: Timing Belt
- 16516
- Carfax entry meaning
- Another LED dimming question (for my boost gauge) wire resistors in parallell or series?
- Installed Huco ICM... still gets codes but drives fine?
- Should I change the TB right at 60k?
- so far all good with tp installation, its been 2 days and no cel!!!
- Blown Rear Shock??
- NorCal lunch today
- Weekend mod thread? Im going to finish my fan project.
- Length of SS braided oil supply line for BT from ATP?
- Monday AM, on the way to work. Car hit in rear.
- Deciding on Winter Wheels: Flik Hornet?
- sunglass holder mod
- repost? ebay ad for some 1.8t valves...
- Help Identify this crazy noise...
- control arm enthusiasts e-bay
- Very tempting... stage 3 A4 5 speed - 2000 A6 4.2 Tip
- any OEM suspension components need replacing after 120k and a coilover install?
- One more part number please: the plastic piece show on the right of this pic:
- Part number requests: all 4 lower door moldings for the A4 & the outside air temp. sensor....
- tiptronic, fun, reliable or not?
- Control Arm Reviews ----
- Driveline clunk
- Dead battery
- Door Lock Broken
- looking to upgrade front brakes.....
- New car in the family tomorrow...
- Anyone near Bucks County, PA?
- Good place/price to get front right abs wheel speed sensor? ('98 30v 2.8 5mt)
- Raj, did you ever figure out your A/C problem? Enquiring minds. . .etc.
- need help, car acting up
- Alberta Custom Dyno Tune
- P0238 P0106 and Extremely hot intake
- Cam position sensor fault. (kinda long sorry)
- Anyone know this guy from Ebay?
- Drove my car to college today and I really have to say that I dont miss driving it really
- ko4 turbo..
- mmart6545: muchas gracias! just received that suspension.
- so there are two computers for the locking system? on either side of the trunk..
- I need a parts diagram for the front passenger suspension. THANK
- Custom tune has been rescheduled....Sept 5th here I come!
- new strut mount question
- Trying to stay local instead of going through ECS . . . PN requests.
- PLEASE help with A/C question!
- how much are avant tailights these days?
- HELP - Can't find Cam Tensioner on 1stvwparts.com what is part number I should use?
- What is the CFM rating for stock smic? Friend with a raddo just did a BT and....
- Shifting Problem...
- How long do the 30V spark plug wires typically last?
- does a 12/99 A4 1.8TQA have a ZF- or KOYO-design steering rack?
- Possible end of an era...
- 1.8T or 2.8 01 A4?
- Anyone heard of the turbo being blown out??
- Has anyone had much luck calibrating their trip computer after moving to bigger injectors?
- A8 brake kit problems
- Anyone know WTF happened to that Jess kid? His car was published in a mag then he put it up FS and ?
- Did any of you B5 guys ever have quattro/drivetrain/differential issues after going K04/BT?
- A/C is barely cooling. Definitely the compressor? Anyone know cost to replace incl. labor?
- Exhaust rattle inquiry...
- when you arm the security system and lock the doors.........
- ATF lines. Time to replace?
- Tested the ICM last night for resistance values
- Why hello there Mr. Boost, long time no see. Missing boost problem **SOLVED** (long)
- painting my black moldings....
- headlight adjustments
- Bentley Manual, Hard Copy or CD version?
- Anyone know of a streetable A4 converted to the AAN (20v 5cyl Turbo 2.3l) engine
- CEL on but car is running fine not sure what is wrong?
- Shifting Problem... Bleeding Hydraulic system
- Audi Sport Suspension
- ok. a little help hear with the power steering hoses.
- Do strut mounting brackets need to be replaced in pairs??
- So, Is the S3 coming over here??
- Compressing springs with hand tools takes forever
- door speakers
- too lean
- Ghost rev the whip.
- Anyone used one of these O2 sensor simulators?
- Does anyone have ONE koni shock.
- PCV System Update (or lack of)
- Anyone install B6 alarm beep in their B5. I searched the archives.
- Picture on LCD screen
- Audi S4 6 speed Manual
- just got an abt front spoiler..the add on.....
- My side mirror switch and lock switch are not working. Fuses all look good
- Fix: Reverse after start and brake pedal won't depress
- Car guys can have warm hearts also, good friends helping out a less fortunate one, Lou Gehirg's...
- quwstion about ko4 turbo
- Update on painting my car...blog entry/long winded/slight bww
- Clear Corners on a 99 w/ 2 piece Headlights
- Does anyone know the diameter of the throttle body, i need to order a t-bolt for it...
- I may have to boycott this forum soon if things dont turn around...
- the on-going engine saga continues.....97 aeb auto [long!]
- finally got exhaust installed and way too loud... any ideas... 3"turbo to flex, 2.5 there back,
- rough idle and a blinking CEL
- Confused! What is essential to replace with the timing belt?
- WooTT! My brakes are on teh way and everything came apart nicely. ;)
- Does anyone know what a 65K mile service is? I just got a letter from the dealership reminding me to
- Error with SQL Query
- *sigh* *puts down Wills popcorn, grabs phone* EPL bashing over on Vortex....
- lots of overstear
- has anyone ever seen this before.....
- what tire pressure should i run on eagle f1's (225/45/17)
- 1997 A4, Outer tie rod ends. $325?
- SPP: Ace Lola Blowout
- PSA - Online service manuals
- Difference between 97-99 vs 99.5-2001?
- Transmission Problem After ENGINE Oil Change
- Anyone looking for 17" Anthracite OZ SLs on ebay, 3 available?
- is this surging ??
- Why do I keep getting CEL misfire codes?
- your daily dose of dumb audi modding...
- Soooo.. if the bodyshop manager puts 65 hours instead of $65
- ideling question
- Could this be a bad coilpack number 2?
- Looking to put STaSIS street sport coilovers on my '01 and looking for best price.
- A/C was working, quit for a few mintues started and quit again...
- rpm fluctuating
- Help! A4 1.8T issues
- Another unsuccessful attempt at removing the pinch bolts for TREs and CAs!
- help! stupid hood stuck shut
- Mileage Questions: If I went from 235/45-17 to 225/45-17 would....
- Can anyone give me the P# for the harness that comes with the factory spoiler 8DO-071-645
- noob question... quicker spool log manifold or equal length tubular?
- Electric Window Problems - won't close without manual assistance
- PN for MAF connector on an 01 AWM? I believe you may need to use the ATW connector.
- AC Shot need help
- A/C cuts out at idle, comes back on above 1k rpm
- How big is the turbo lag difference between a 28RS 76 Trim, .86 A/R and a 28RS 76 Trim, .64 A/R.
- Today's installment: "As the clutch turns"
- tire questions...looking for a good sub $100 summer tire 225/45/17
- A4 widebody
- just when you thought u'd had enough.......
- How does the L-hose affect performance?
- Ok, so dealer quoted me about $138 for a replacement maf...
- HVAC LCD
- instrument LCD display is shot; am I screwed?
- Anyone seen this? Garrett turbo kit...
- Brake alert light comes on now...
- Cleaning EGR valve
