- Rear widebody update:
- Brake pad recommendations
- Moving downpipe Pics and help needed
- Does anyone know where I can purchase the small molding on the quarter panel?
- Today, I made this pile o stuff:
- tire size
- Is there a way to adjust the door on a 98 a4 2.8?
- Suspenion suspicions...
- Oil in intake system - how long until turbo takes a crap?
- 1996 A4 Factory alarm Spazzing out! Please help!
- ETKA Part Number Request... STA but couldn't find anything
- Time to ask a question before anything happens
- Tried to track down an old post....about things to check when buying a used B5 A4...
- Hit or Skip
- Sym I to Sym II - I am following the instructions on the nsxjr.com site
- Hooray for new winter tires...pictures included
- Snow tires for Winter Driving School; which of two sets to run and which to sell?
- Dual Mass Flywheel - slipping?
- Good news and bad news. I did another compression test, but more carefully
- Question about the inner CV boots. Is something missing on my passenger side boot?
- If I set up a public FTP site for you all... would you guys find that helpful?
- 7:00am. What am I doing?
- Still Hot - New TB.WP/Thermostat/hoses/fluid/etc just today and it's still overheating
- Buyin a car
- Hate to ask, but search was no help. Car won't start, dash is dark
- what a F150 does to an A4...
- Who else is with me when I say - The B5 still just makes me go "oooo"
- Transmission/Diff. Question
- I'm glad I get ambitious on Friday evenings. Found a coolant and inner CV boot leak
- washer motor
- Anti-theft alarm question
- Anyone here have any knowledge of Land Rovers? Namely the '95 and later County or Disco's?
- Archives searched but inconclusive - anybody add OEM heated seats?
- AWM have a history log of codes? (oxygen sensor content)
- Instrument Cluster dead pixels - New LCDs available
- I have HKS intake/green filter that came with it. Short of sourcing and re-installing stock air box
- anyone using these new airfilters?
- Pictures of panel R/R for turn signal flasher relay?
- BRAKE/TAIL LIGHT PROBLEM help meeee 2001 A4
- Center cap needed for a 98 a4 w/16" 5-spokers
- Opinion needed please...... (headlights)
- Found It! The cause of my Fuel Trim (17544) CEL Issue and groaning
- your vortex POTD
- A.W.E. Pedals and installation while you wait
- is there only 1 diff mount (rear) cause i got the my 'rear diff mont' put in the shop said
- Mica: All your parts are here.
- Poll: Neuspeed SS... Thumbs up? Thumbs down?
- anyone know the part no for the water pump for 01 1.8 awm motor?
- I've stfa but not getting a definite answer. Does 225 width tires cause sidewall rubbing?
- Pure MS.....
- got my ugraded rear diff mount installed yesterday as well as
- Mounting CD Changer in '96 A4 with Bose Delta
- oil pressure warning light came on for 2 or 3 seconds yesterday
- Who's A4 is going to show up the VWs and S4s this Sunday at Etown (NJ) for VW/Audi Show N Go?
- OK, everyone please "school me" on some TDI block issues - Jetta vs Passat 1.9 differences.
- Change 1999 Passenger Door handle to Keyless Door Handle?
- anyone know the dimensions of the bolts that attach the elbow joint to the APR S3 turbo inlet?
- ok can someone please set me straight on this....
- k04 lagging help!!!
- I am officially a moron...I think...7 hours wasted.
- i have quick question about offset!!
- Car wont move/go into gear. Help please.
- Symphony II radio question
- Merge Collector Complete
- Can I replace bulbs in the instrument cluster??
- Curious question....
- thoughts on 18" Hartmann B7 RS4 reps for a B5. I stfa and found one example
- Can ECUx alter timing, fueling, rev limiter?
- i havent seen many "woohoo, cold air" posts lately :)
- Does anybody know ::Relapse:: @ IW ?
- Could I get your opinion about Falken vs Nitto tires
- does anyone have the vagcom codes to check/recode my multi funct. steering wheel? Its not working??
- For those jumping ship, this seller has 7 B5 S4s
- So, 9 miles out from our new home in Reading, PA and we almost got side swiped by an A4!!!
- Posted some 17" RS4 reps and spacers in the classifieds
- Another sunroof drain question:
- Damn, I had a tear in my eye this morning after seeing a B5 crashed...
- Poll: LaBree HFC or Techtonics tuning HFC?
- B5 A4 reliability
- Two for the price of one?
- Welding begins!
- CEL on engine sputtering, ideas?
- Name these lines--->
- Update to Fuel Trim (17544) CEL Issue
- Exhaust question...Those of you with custom 3" what type of rear mufflers (if any) are you running..
- This is NOT repeat NOT a K03 Sport for the awm block, correct?
- Anybody have a spare handbrake cover? 98 A4 Avant.
- Just so you guys know, Discount tire direct has $100 off any set of 4 tires purchased
- ISTF Tech Articles and couldn't find any kind of write up on how to find/clear the sunroof drains...
- Having a hard time finding wheels....
- If you had this fault code, what part would you replace?
- Found these Boxster calipers (not mine) on EBay if any of you guys are looking
- Cam Cover Gasket on '98 A4 2.8 engine
- 01 A4 1.8TQMS tranny is SHOT @ 60K
- As a follow up to my TDI in a B5 Avant I did some wrenching today =
- even my mechanic says he's never seen it happen, all the lugnuts on front right wheel broke
- Avant rear cargo cover (shade)
- If my upper control arms are shot, does that mean the lower ones are probably bad too
- Posted my Penskes in the classifieds
- in other news.. put the car up for sale today
- Which panel do I pull off to access and replace the turn signal flasher??
- Damn its hard to find a bentley paperback manual these days...
- Anyone wanna sell their fog light grills? or gimme their part numbers?
- i'm not trying to look desperate or anything.
- Quick question: Just got my TB kit for a 2.8...When i shake my thermostat it rattles, is this normal
- Are the sunroofs the same across all B5 A4s?
- Since some "engineers" couldn't handle being wrong Here is even more information
- MAF replacement
- Anyone else going to the Audi Driving Experience tomorrow?
- STFA, stereo is receiving no power...
- Manual to power seats, possible?
- Is this crap really the coolant flange?
- Help with installation of Rieger V1 Side Skirts!
- NGK BKR6E, is this the consensus for spark-plugs on the stock 1.8t's?
- Progress on the latest project
- Is it worth it for me to sell?
- OIL OIL OILb . GET YOUR OIL.
- where to buy interior carpet for 97 a4?reasonable price?
- Nate, I didn't know you were this far along with the Golf. Nice project.
- Alright...Jr. needs some help. We need to wrap the 19"s in some new skin...cont...
- Question about computer displaying pics, sure its a setting
- 98, A4, 1.8T Q, Motor AEB, transmission Auto. Exhaust leak at the flexpipe.
- Sell my Avant and buy a TDI poonetta Wagon *or* swap a TDI into my Avant - discuss please! ;-)
- Tire issues... What do I tell my girl?
- Please tell me where is the snub mount?
- 034 Motorsport AP Racing bbk vs Porsche Boxster upgrade
- anyone have a writeup on how to change out calipers and properly refill brake fluid?
- im thinking buying 15mm wheel spacers for front and rear what do u guys think??
- 96 A4 CD Changer connection pin type
- I have listed my car for sale in the classifieds.
- Would this be a good upgrade?
- I am having trouble comprehending this type of speed.
- SAFE Stereo - Have code, Can't get back to unlock feature
- what block shows actual boost vs. requested?
- I'm bored. Everyone post a picture of yourself (Updated B5 Mugshots)
- Looking for a concert headunit with code
- Widebody update: Spent the day playing with tape figuring out the rear lines.
- Broken OEM spring
- Paging pac1085 : Please check your mail. I need to know where to send teh payment =)
- HID? Do all the HID guys just run single beam xenons?
- Cheap plastic on the window regulator?
- HREdizzles...back from powdercoating.
- Look at used 2000 B5 A4 1.8t - need advice!
- OK, here's the pic of the painted FMIC...
- What are your recommendations for an all season tire?
- MWAHAHAHAHA... Brian@avalon is a fvcking pimp!.. check what came in the mail
- paging silver streaking... if you want that n75f.. i need to knoes your mailing addy
- Do our motors have any timing marks other than the TDC one on the timing cover?
- Hooray... Car finally threw some codes.
- Brake Rotors ... Replacement Upgrade
- 2000 a4 2.8 quattro avant front door speakers size?
- Questions about compression testing. Do you have to really crank down the hose connection?
- HREs for sale... 18x8.5 ET39 Brand new in the boxes
- Andy: got the wastegate today...also thanks for the gift
- 1998 A4 Quattro Wagon 2.8
- How much will a light coat of spray paint hurt the performance of my FMIC?
- Another Question about the RS4 clutch. I ask here cuz S4 forum is a little pretentious.
- large turbo upgrades whats best gt28rs?
- STFA: nothing. Spool but zero boost?
- Please help, Need part number and price for driver side Valve cover on a 2001 2.8.
- How do I remove the crank gear after removing the bolt to change the crank seal?
- Almost stock A4 FWD on track.......
- Any point to buying a new flashed CPU?
- Where can I buy an upper control arm pinch bolt locally? Will the dealer sell it to me...
- what is 058-145-710. thanks
- conflicting information on location of Altitude/barometric pressure sensor..
- Replaced tie rod ends, "loose" steering..
- Barometric pressure sensor: what it is, where it is, what it does
- A series of unfortunate events.... why my car has been running like sh!t =)
- The beast has awoken.......
- Code 17544 - fuel trim bank 1 system too rich
- Stock air duct part
- Heater isn't working
- New toy...
- changed cylinder head.But feel the engine shaking
- need some parts that I busted last weekend, CV joint basket + wheel stuff, any spares in your garage
- So..... lets say "someone" has been having thoughts of a *cough* powerful diesel in a B5--->
- What does this wire do?
- Anybody got a set of stock corner lights they'd like to lose?
- What spacers do i need to clear S4 brakes with A4 swing wheels?
- Need a little advise. A4 or S4? Please Help.
- Anyone looking for used Tracksports?
- Headlight problem. Nate, you diagnosed my problem last time really well... input?
- if you have 235 45 17's can u put 235 55 17's on the same wheel for a a4?
- How to disconnect transmission MFS-TCU connector?
- What VAG blocks can I log for you guys, PC16 running PIG rich, tons >>
- Hey, I found out who the guy is that kept spamming the RS4 grill all over!
- Paging: bassed. --- I need your mailing address.
- Next FREE item: Santorin A4 front bumper cover.
- Question regarding Fuel Filters replacement
- Swing wheels & winter tires in AW Classifieds:
- don't you hate waking up and realizing you forgot to finish putting your bumper back on?
- FREE!!! Anyone want a pass. side front seat from a '98.5 in gray leatherette? Also...
- what is different about a '96 fuel tank......
- audi a4 ac compressor problems!
- What are your views on duraflex body kits from extremedimensions.com
- Notches on the bilstein shocks
- H&R suspension products are available at A.W.E. Tuning:
- To those who have replaced Windshield(s).......need some help.
- Why I need to sell the A4:
- what happens when you click on the wrong forum
- Just listed my 2000 A4 1.8t Quattro Tip for sale in the AW Classifieds.
- Air Bag light A4 2000 ATW, Vag Com wont communicate
- What is a set of swing wheels with Graspic DS-2's with 9/32nds worth?
- decent deal on boston craigslist for an 01 1.8t with 76k miles (not mine and never looked at it)
- control arm replacement issue
- Hmmm. Didn't VAG yet but scanner gave me code P1338. STFA'd: Cam Position Sensor. Ideas?Suggestions?
- mmart/psycheoverdrive and a few others have had this problem.. and it seems to point too
- location of barometric pressure sensor on awm ? search says
- Paging psycheoverdrive!! what was your solution to this?
- Well guys, tomorrow is the day. The Moving Truck will be here to pack up our stuff to take to PA..
- im wondering if my car is OK to drive with this piece in this condition :(
- SIII+
- Quick hello and intro....
- A arm broke at ball joint at 70 mph - pulled transmission flange out - any
- Weird noise from pullies I think....
- I will probably end up selling my current IC.
- etka boys...
- just got home from the Steelcities region, SCCA Solo event #10.
- DIY camera mount seems to be a success!
- Widebody day something: Almost done with both front fenders...
- Is that blood on Joey's Web Cam?
- Oh yeah, so that avalon motorsports rear driveline mount
- I need help please...I have a bunch of codes...
- ekta page lookup 12v a4 qm starter bolts please!
- 2 hrs and no new post... not good... here.. the car i really miss i wish i had both :(
- where can i buy MTM ecu?`
- Does anyone have a single used Dunlop SP 9000 225-45-17?
- Dyno update and MAF issues...
- stock sport springs and Nuespeed/Bilstein shocks...
- My newest mod, thanks to Chip Herr.
- iPhone update now let's you use your iPhone with the Alpine IDA-X001!
- Man, this guy even LOOKS like a scumbag
- Didn't want to spend $250 on a vent gauge, here's how mine turned out.
- IceLink question.
- is there a way to disable the bulb warning lamp? searching has led to nothing
- Crazy idle problems - even with TBA - i got the wideband installed
- K03 sport: Hot side 0wn3d
- Dilemma --- Need Advise
- One more P/N request: ATW Oil Pressure Switch. Thanks much.
- HELP Bad idle after tubo timer install
- Ok so I VAG'd my car regarding what I thought was a bad ABS module...
- Just finished doing rear wheel bearing, now steering wheel is out of alignment...
- Well...bigger and better tools means bigger and better projects... Another project begins
- Just did valve cover gasket and am quite suprised
- Weird problem after BT - recently the car required a little gas to start up
- Turbo Upgrade on an A4 Tip
- pentosinjunky.....
- anyone in northern jersey with an 01.5 a4?
- What temp should egt be - if i mount my egt 2-3 inches away from the turbo
