- A4 For Sale
- I painted my Lowers today
- Could it be the wheel bearings??? Help!!!
- how do you install a rear bumper lip???
- Ok now, what to do?
- new or old?
- anyone know an approximate 0-60 time for an APR stage 3?
- 1.8 tiptronic help plz? looking to buy tip soon. any issues, leaks, wear, problems? (82k on....
- How much do the sport wheels on a 99.5 weigh?
- Carbon Fiber Pillar Covers
- K and N 57i intake upgrade
- 96 A4 control arm
- cause of my creaking steering...
- Anyone here drink scotch? if so what kind? and how much do you pay?
- how do you know if your car is running rich...
- How many here are running BOV's. What are the downsides of running one? More...
- MAF wiring map for '96 A4
- PS Sig Request
- Tail light replacement
- Wires on Oxygen sensor?
- ALMS Race on Speed
- Armed robbers make getaway in an Audi A6...
- Corner Balancing - how low is too low?
- New drag racing tip
- Control arm recall
- Waters Bad mmmkay <kinda long>
- STFA --- can't find anything ---- Stuck Glovebox ----help
- tip plate brushed aluminum mod pics...
- Lock Carrier extension pins vs. removing front end
- dash lights
- by blowing the vac line off the blow off would that cause you to run low boost??
- So it looks like Audi is the preferred choice in get-away cars.
- Anyone here have a problem with 1st gear making noise?
- Looking for Oettinger front lip. Anyone have a hook up?
- Warning: Steel gaskets are sharp enough to take your pinky clean off (GROSS!)
- Got denso standard plugs at .032, ran fine for a week...
- I say Bighuges should change his name to GoldRinger till he de-badges
- Need a favor from you guys. Need a new sig for those who have PS.
- Just uploaded first pics of my new Audi...here they go :)
- YGM Qfrog
- Bad Luck
- True or false: aftermarket lowering springs like H&R or vogtland will lower ride height on sport
- pics of the Achtuning Oil Cooler Kit setup?
- 13.35@103.6
- Crazy Revving Problem
- Do you guys think its okay to drive 10 miles with bad ignition control module?
- Trying to sort out CF hood issue (more)
- my air compressor is sending oil through the air lines - what should i check?
- For future STFA: PES G1 supercharger install instructions
- New Audi Owner- Any Advice/Tips
- Anyone Know how to get a hold of someone from La Bree.... Tantrumwerks,
- Will running 17" S4 Avus wheels with Michilen Sport Pilots on my 99 1.8tqm affect my spedo?
- OT, not even a week and guess what happened to my m3......
- what do you guys think?
- It is done!! New control arms insttalled and working!
- b5'ers show me your front!
- Where I can get Fog Lights and lower Valence for VW Passat B5
- anyone have dyno results from dahlback intake?
- Help! My 98' 2.8 30v is running rich, what could be causing it? A list of things would help.
- anyone in the mid-atlantic area want a neuspeed short-shifter
- Faint/muffled knocking noise when going up/down driveways ?
- I thought it's ok to tow an AWD car with 2 wheels on a dolly and the other two lifted by the truck?
- this forum rocks
- blown pass. side engine mount?
- Pics of Avus 17" S4 rims with non-sport A4 suspension please!
- XPost: Chipstar's TB pics
- Well, sooner or later, I had to show what was keeping me from AW of late...
- Oil leakage issue
- where can i get prints of paintngs of A4's or any Audis. Race cars or not
- My cat is shot, should I go with a high flow cat from random technology or stick with OEM?? TIA!!
- check out this rs4 racing a m5
- Cylinder #2 misfire
- took out the kamei grill and installed back the oem grill but hood doesn't open
- Will the 6speed trans from the b6 1.8t work with our cars?
- Considering buying 2000 A4
- antilock disengage
- who likes this sub cover
- STFA: Supercharger with Tiptronic???
- 18" BBS RC or DTM RS4 replica
- Can someone fill me in on the oil sludge thing? 2001 Audi A4 1.8T..
- Help needed to replace water temp sensor on a 2.8
- Sold my car
- shocks? 1996 A4 with 20,000 miles.
- Bailey Diverter Valve upgrade - yay or nay?
- Strange noise from front of 30V motor
- What is this hose/plug?
- 96 12v, clutch chatter
- Help: Anyone worked on window regulator before?
- Adjusting Koni Coilovers . . . which way to turn which side of the car to raise and to lower...
- Photos of A4 b5 hood extension please
- Photos of my new RS4 wheels mounted...
- ABS Light On/Flashing
- Vehicle Speed on Concert ll
- Anyone have swing for sale...?
- Don't know if its been done, but has AudiWorld ever done an open letter to Audi of America......
- PLEASE HELP CHECK ENGINE FLASHING
- Night pics
- has anyone ever encountered a moaning/groaning sound from the Power Steering?
- 1999 A4 quattro 2.8 sport package being parted out
- i like how rosstech vag-com ppl tell me i have to buy a new version of there product because
- Question about fuel injectors..
- anyone install their V&S shifter yet?
- Quattro driveline shudder
- GIAC chip socketed ECU question
- So is everyone using Amsoil oil or what?
- ne1 use either extreme vision or euro dezigns blubs?
- Brakes vibrate when slowing down from 50+ mph....whats wrong?!?!
- Could anyone give me a ride in his Pes'd turboed or apr stage 3+ A4 around/in Chicago area?
- Good online source for Audi parts?
- Electrical problems
- Intercooler
- new clip in sig, opinions
- Anyone in Gloucester, MA have a marroon A4?
- APR Chip codes and front seat issues
- what would cause rough /bouncy idle and bogging during excelleration .. i hear my intake sucking air
- i STFA. Any pics of HP EVO wheels on B5's?
- (Repost? Definite) But those guys at Dahlback are hilarious
- Audi A4 bently manual
- Hi, question about center resonator...
- I need directions for the EVO intake....anybody want to fax them to me or email me a scan?
- Fog Light and Police
- Where can I get a borla exhaust installed near central Jersey?
- Ram Air Headlight: Completed, tested, mother approved... lots 'o pix
- 98 a4 2.8 quattro re: mirrors drivers side is larger?
- how much for a new drive shaft?
- Paging Mmart6546(Matt) CAPS times are in.
- Koni Coilover difference between Stasis & PureMS
- Ok, I need people's opinion
- Lip spoiler question...
- How do I get my exhaust off??? I am stuck
- 99 A4 QTip 2.8 Brake Question
- got a new toy today BWW MSRR
- Oil Plug after oil change (more)
- Rims
- Ignorant mechanical question: What is the benefit of interference design engines?
- How hard would it be to put a 2.7t in a 2001 1.8t A4-->
- My friend might have got ripped off
- What's that stuff dripping?
- Are shocks and strut the same thing? Whats the difference exactly?
- Has anyone bought a spoiler from this vendor?
- Paging kennyc
- STFA, but didn't find out what exactly an N75 race valve does. Is it a good mod? Help.
- Oil Sludge: Any reason to switch from M1 5w30 to M1 0w40?
- There's a petition to draft a bill removing Raceway Parks's exemption from noise law. As a racer and
- Offiicial url link to extended sludge warranty?
- Searched and searched...where can I purchase a V&S shifter?
- switching to synth. oil
- Scam in the classifieds again?
- Are instrument clusters a straight swap?
- Intermitant trouble starting car.
- Exhaust Manifold Revisited
- Anyone in boston area w/vag com,need to reset airbag light
- Distance between the headliner and the rearview mirror?
- So what's the !@#$!@ trick to pulling a non-symph Bose headunit from a 99.5 A4?
- Updated an old avant sig file if anyone needs one.
- Kudos to Hartmann Wheels (got my 17" DTM's. Love um!)
- Aside from Mark who I've seen just recieved his wheels from Achtuning....
- anyone know where I can get remanufactured right front axle shaft w/ cv's for cheap???tks in advance
- How long does cross drilled rotors last??
- Las Vegas Area Mechanic
- My new wheels are here! Thanks Josh/Achtuning!
- low boost...replace DV....still low boost...help
- Help with a part name, please. What is the name of the black lower portion that's attached to...
- RS4 owns M5 (repost?)
- Scary cutting into your car, especially when you slip!! New style repeaters fitted.
- will an a6 license plate bracket fit an a4? only reason i ask is because
- freakin airbag light
- Dude, where's my car? [long]
- anyone selling Borbet Type E's??
- My New Sig (this one is audi related)
- AW crowd, anyone know where can I find torque spec for brake job on a Mercerdes?
- Anyone know of a goo dplace to buy intake/exhaust valves?
- Well, Chimpzilla was right...my pics came out blurry...here is the best one...
- Question about Xenons...
- Whats the best spring & shock combo???
- Removing rear door panel?
- Somebody should jump on this...almost new stoptech kit for $1200
- Some pics from our Euro car gathering here in Arizona.
- i for one am loving the dream cruise on woodward
- will vw mk4 remote work on 1999 a4?
- Flex Line to Boxster Caliper Adapter
- results from eastwood co's headlight polishing kit...
- Anyone with Flik Justice High Gloss wheels having paint peeling issues? Just curious.
- how screwed am I? (radio in safe mode)
- GIAC chip questions for a 98 2.8 30v
- Where can I find those small 'scanning motion' lights like on KNIGHT RIDER's car?
- Just had my Oettinger RE powder coated black, he machined the lip on his lathe......
- front wheel bearing problems
- I drove Shine Racing's new spring setup today. Review tomorrow if anyone is interested.
- Oil Pressure light
- Where can a buy newer tail lights for my 97?
- CarFax or AutoCheck PLEASE
- What is the best chip to get for a 1.8T that is easy for a beginer to install?
- Chip question and service?
- Little help with code 16884/16885
- Woodward Dream Cruise this weekend...anyone going to be in Detroit from out of town?
- For those unfortunate owners who used dino oil in 1.8t this'll solve sludge problems.Synth users too
- fuba antenna
- **How much to get M3 Lip Spoiler Painted? (its silver now and needs to be black)
- my $25 intake
- problem with hydrolic fluid i think..
- Pics of car semi-cleaned, new H&R cup kit and FLIK Wasps
- There are 18 RS4's on Autotrader UK and only one isnt Avus silver and its a german import.
- Remus universal
- anybody near Ontario CA
- I need help...I have STFA, but keep getting 16687...
- bolt removal
- Anyone Know PES's Local Phone #
- has anyone ordered a hiflow cat from random technologies?
- And now my homemade HiFi setup [BWW]
- Anyone have pics of silver RS4 knob on gray interior? My OEM knob leather is worn down and am...
- Getting Timing Belt Changed Monday... I have the Ultimate Kit from ECS... What else should I get...
- Just bought '99 2.8Q, will my apex springs and bilstens shocks off my '98 1.8TQ fit?
- kaltemittelkompressorenol
- any advice on replacing my windshield?
- where to look if i wanted to purchase an rs4?
- Audi drain plug tool
- so it dosent seen like anyone has the ATP GT28 kit...why? crap tunning?
- Suspension question
- Paging Yourk...
- Part # confirmation...please!
- Giac or APR ? and why?
- Good places to buy speakers for my car? Anyone have any for sale? Retail is teh suck!
- What kind of head unit did a '97 A4 come with? anyone have pictures?
- what do you think of m3 mirrors?
- NEED HELP! Looking for the Central Locking Pump
- Hi, should I use Magnaflow round body muffler or Magnapack as my center resonator?
- so keep it black of polish it up?
- Want a nice Pelican Blue A4
- Help - New A4 / 2.8 owner really confused about oil (lite rant)
- Did Wysiwyg ever do a writeup for his ashtray gauge set up?
- What's wrong with this car that it's only $16,900? I should sell my A4 for $14,000 and get it.
- XM using factory radio buttons?
- PEB Tuning
- What do you think about the Griffin iTrip FM Transmitter for the car ??? it's good ???
- Mad, mad, mad RS4 in Russian chase with M5
- Removing plastic backing on seats, anyone know how? (i already searched)
- Threats running 93 octane gas on a 100 octane GIAC chip?
- Does someone want to back me up with this guy selling a "true" k04-23 for the B5 on vortex...
- Anybody make a custom mount for fog-lights on a non-fog-light equipped bumper?
- Replacing the side blinkers??
- Looking for 1998 5 speed A4 2.8 avant quattro...
- Cup Holder Jammed!
- Wheel Repair Places in MA?
- Difference btw audi avant 1.8-00 and Passat-00
- How clean does an accessory pulley need to be? I got a used alternator with the pulley...
- Does anyone here play Tzones' Shade?
- speaking of oil
- oem parts...
- Synthetic Oil bad for VW/Audi engines?
