- Anyone know where the adjustment for a 2001 A4 headlights is?
- Help! 99.5 2.8QTip Water coming in from above pedals towards the firewall, read on...
- Paging Nate (ETKA+Scumbag)
- Rear Suspension Bolt Question
- B5 starting problem in high ambient temperatures
- Car won't turn over. Was able to drive it home from work just now by....
- Turbo installed... maybe not for good...
- Anyone have tips for installing dynamat under back seats?? Any reason to worry about clearance?
- Ahh, a clean B5. pix!
- paging nunya... question about your gtrs set up..
- $$ Anyone near (w/ in 2 hours) of southwest OH interested in helping with a timing belt job. $$
- well I misdiagnosed the exhaust - turns out its the flange on the down pipe - not the cat
- signed up for the PUREMS test pipe...
- sad... sad... day
- How does this work?
- How hard is it to pull the radio out so I can get the seriel number?
- rim question
- The heating element in the OEM seats isn't something heavy, right? Not like the power motors
- Display light dimmer trouble
- Who knows where to get an inner door handle (drivers side) for less?
- Speedo is acting weird...
- Need a pic of a B5 (long)
- On order = Borla Catback Exhaust
- Setting the clock
- Look at this (not awesome) list of stuff I need.
- Anyone have a writeup for changing the cluster and hvac to blue from the red?
- Thinking of importing a B5 TDI..
- Is it a hard DIY job to change your shocks and struts? Searched couldnt find info
- S4 transmission swap? Possible/Price?
- Can anyone tell me how much is the OEM bose subwoofer?
- ckymike do you have anymore pictures of your car?
- P/N for rear wheel bearing please....1.8t manual quat
- WDS prep... WOOT for cold weather.
- A4 99 2.8 baring was repaired and now the ABS is tempermental
- Just washed at 26 degrees ,had a warm day today 30
- Location of the relay (relays?) for the heated seats? 99.5 Avant 2.8
- Gas Station Woes.......WTF
- when exactly are you not so sane anymore?
- car problem.. electric?? need some advise...
- buhbye sec inj pump, kthnxfornothin'
- Would new snow tires make my car feel less stable since its a softer compound?
- (CHEAP!!!)full reiger kit in ok condition, fused up from cracks, but ready to be sanded and painted
- By the way...I got the tires...
- Question for TANMAN about HID Levelers...
- 1.8t keeps stalling
- Another satisfied customer for the Ebay Short shifter.
- What's this plug for? Just found it as I was doing the short shifter install.
- RS4 Bumper here I come!
- Power/Super flex bushes
- A4 Transmission Problem
- does a 2.8 a4 have the same engine mounting points as an 2.7 s4?
- B5 Testpipes now ready! GB Preorder
- Damn Oettinger stuff is $$$ new
- POLL: -after my 60K mile Q earlier the forum has me paranoid about the TB
- VAG-COM help
- Is there a wire that you do not connect when installing a stereo..
- MBC and n75 troubles...
- RallyVT Joel... send me an email... I don't have yours at work
- Central locking problem - probably not the pump or key
- Need advice on A/C and defrost problem
- anyone have the socket for the giac chip that goes under the chip and connects to the ecu?
- Hit or Skip...I'm thinking we have a hit!
- My car accident... how much does it worth now?
- Chip option with Eliminator GTRS (2871R) for a 1999.5 A4 AEB
- Well last night was fun... went for a drive... saw a taxi sideways on a road .. thought WTF?
- Paging Qfrog: Your toy as arrived! =)
- For those who ordered VVME HID kits..
- retrofitting 2000 center console + double din + hvac ctrl into 97 a4?
- Any idea on what a 96-97 3 spoke steering wheel with airbag is worth?
- X-post B5-S4 Please show your love for teh silver
- Almost time for clutch replacement. A few Q's....
- Forge have in stock the Uprated Silicone Intake Hose ( tip ) A4 B5
- Prepping for weekend suspension fun - Koni Coilovers & Control Arms
- How much did I save?
- i have searched... can someone help me find the maint. intervals for a 2001 A4 1.8T ??
- I'm out, off to Australia for a month, have fun in winter guys
- Suspension question
- Those of you with BS RS4 18" Reps Please post some pics of your cars. Thx.
- Time to Beat up on Barbaro...Looking into tires...
- Car is under the knife
- Just bought a 2000 A4
- What is the vacuum canister used for on the 30V 2.8?
- Can I get some help? Tried searching to no avail....
- Hahahah, had a dream last night that every ricer probably dreams about...
- lights flicker when gas light turns on
- Damn! I want this but he wont ship!
- Need help with fog light mounting... please read
- Great deal on a Borla 1.8TQ Tip
- amp and sub cut out when i turn it up
- STFA but still can't seem to pinpoint my airbag light issue. Light goes on for 5-10mins...
- Has anyone ever replace the PS reservoir with something else that looks better
- secondary air pump won't turn off.
- Looking for ideas how to mount these amps...
- Anyone else try to get AOA to pay for a new display cluster? I'm going to try what this guy did.
- I know it's been covered, but I searched,
- P/N Request: ATW OEM Coilpack puhleez
- If I have a 4 bar FPR that isn't specificaly for my car, would that hurt?
- Nightime pole: What's the coldest weather you've ever washed your car in?
- Improving steering feel?
- update on what i've been up too
- tie rod end help!!
- Paging Mr. NoNonsense to the batphone please...Joe to the batphone pls..
- About to do the Ebay shiffter tonight. Am I going to use all these parts?
- oil pressure
- PSA: Intel Mac + Keyspan USB>DB9 adapter + OBDTool = Easy VAG-COM access. Sweeeet....
- Anyone have a dead/not working nDBW ecu for me?
- Looking for some insight on random misfire issues
- BT coming soon. Items presently in my hands=Greddy FMIC, Spare M Ecu and by Sat a BT......
- Shop help needed....
- Does the stock cluster get its readings from the engine ECU? Or elsewhere?
- Photoshop junkies: i have a challenge
- Some logs from last night... interesting.
- Audi A4 Engine Light
- Riddle me this...
- Reset Service Indicator but No Mileage Countdown
- What is the name of the Audi performance shop in Orange County, CA?
- in line with my reply post below: I'm the top Google result for "oorahh"
- Parasitic battery drain
- Soooooo . . . my seat (yes the one I was sitting in) burst into flame on the interstate
- rear window spoiler
- The moment you've all been waiting for VVME 4300 v. 6000k (bad news for deez tho prob)
- Pulled the trigger!
- suspension needs to change!
- C/F B-pillar strips on a brilliant black....h/s
- Does anyone have a spare driver's side headlight washer cap in light silver (LY7W)?
- OK, is it me or does this remind anyone else of H. R. Giger?
- Just picked up my car from JVR Performance. It's great to have a mech who knows what they're doing!
- Would it be reasonable to pay $12K over the KBB price for a modded car?
- Windshield washer suddenly dead
- anyone got a short shifter layin around? thanks guys. pictures of my broken one hopefully today...
- New A4... B5 or B6?
- I'm going to try and get the "cat" out of the bag today. Does autozone have the O2 wrench I need??
- Paging Point-by: How do you like your Autopower roll bar??
- All hands on deck! I need help searching for some OEM Audi S-line wheels!
- how can i change my signature and pictures on my picture profile?
- How to drain the fuel tank?
- few questions
- Considering the following wheel
- Car is sick :-(
- Hello young sirs....haha
- Giving away 15" steelies & near-new snows w/ hub caps & lugs.
- VALEO B5 Xenon Housings & 50W Xenon kits back in stock
- Does anyone have the fuse box diagram for 97 1.8T?
- PSA: Changing 7 yr old motor mounts makes car feel brand new. That is all.
- Wiring HELP Needed....
- SAI delete for the 30V 2.8
- w00t! I just got my HID kit in the mail from VVME!
- Installed new vac line at fpr, problem persists (longish)
- Anyone with Santorin or Europa Blue have pics of painted lowers?
- What are the potentials?
- Got my catch can today... trying to figure out what way to plumb it
- My left front inner CV is on its way out, can the car stil move under its own power when it fails...
- help me please, i cant decide, coilovers or a spring/shock combo..(caution long)
- Need some help CEL just came on
- Hey Nate, any new reasons in 2007...
- if anyone wants a stock bellypan CHEAP and wants to pick it up near philly let me know!
- Alignment
- anyone by any chance have a cup holder I can take off their hands?
- update: HELP: 1998 A4 2.8 (30v) dies after it wams up, no sputter just dies, after restart it's fine
- Supplemental Air Pump?
- My car after a winter transport up the east coast... Damn road salt
- I am experiencing a huge loss of power on my 1.8t....
- How much should I pay for a used AEB head with a valve cover with ~50K miles?
- Need a driver's door . . .
- Body Molding for a 98 A4
- someone please help me decifer my issue
- Sea Foam/Water decarbonization question....
- Anyone have an AWM or AWM compatable fuel injectors for cheap? Tried classifieds...
- Shocks and struts? 99.5 A4 2.8L 30v
- Ya know....as hard as I want to like it....the new R8 just doesn't do it for me...
- Things I got done this weekend....
- Can someone get me a P# for front wheel bearings on a 2001 1.8t Q A4...
- HID question
- Parting out BT: Worth the time and effort?
- I hit a bump and now my engine makes a grinding noise at 3 thousand rpm, what is the problem?
- Pac1085....you on here today???
- blkperl ygm
- VVME HID KIT
- BRAKE NOISES IN 2.8 quattro????
- Dah jeeze its cold it is! 8 F for our high, 7 F now, and the car alarm just went off
- Does anybody know which size allen wrench is required to tighten the ATP 3" TIP?
- Anybody ever try a MAF->MAP translator on our cars?
- Anyone here running a T3/T04e setup?
- HAHAHAHA My 'replacement' HID's are touring the coutry
- Struts & Alignments
- ETKA diagram needed
- Intermediate Shaft Bearing
- Does fender-bender lower price of car post repair???
- Airbag warning light
- 88k
- A4 problems.Would like input on if I should get a new engine, used engine, or keep trying to sell it
- Awdee or Owdee?
- ABS Control Module
- Help with an air leak....
- Anyone know what that black roundish thing is to the right of the stereo?
- Help: Radio Mute switch from Aux out jack?
- Work begins..........
- Quick question about t-stat
- Can anyone tell me why my iTUNES "skips"?
- only hitting 10lbs of boost in 1st...
- b5 2.8 2001 Headlight just in front of the car ..
- Got my new shiny Valeo HID E-codes.....
- my amateur diagnosis: this torn vacuum line is causing DTC 17544 and this noise (see video)
- ugh crap... I just realized its not tuesday.
- Pics of my buddy's new Hibiscus A4
- OK, once again an update for those that care about my BiG BeaST project......
- ModifiedA4: You have a new CAPS submission on the way (7.21 on 93octane/program)
- HEY WAIT A SECOND.. one of you owes me money... not you dungbeetle.
- blow-off valve
- The Audi is sad now
- Rear axle bolts being lame
- My cold weather idle problem solved ....method...
- Was i raped?
- engine lugging at idle when warm with heater barely on......
- For those that have had a clutch replacement, + resurfaced your DWFW, how is it lasting?
- Inner CV Joint Failure
- heater hoses for a 12V A4. Dealer item only? Can't find them on common parts sites.
- update, first logs with the new injectors
- Can the odo be changed to display to km?
- Anyone running an aftermarket alternator?
- I just came home from the dealer... I can't believe the prices! Where else can I go?
- Need help with PN, will 8D0 920 980 Q fit my '00?
- wtb blown ko-15
- ABS light came on after accident
- Airbag Control Module Installation
- Picture of my Avant
- motor mount?
- Does anyone know where I can buy Sylvania +50% H7 and H1 bulbs from?
- turning problem...
- Poll: How many miles on your stock / 1st Clutch? Year of car?
- Gonna pull the trigger on the timing belt change this weekend
- ***Revo Technik welcomes TD Performance of Cincinnati to our authorized dealer network***
- Trying to sell my wheels on craigslist...
- rs4 grill
- im getting a weird sound when i make sharp turns
- Just got an interesting email from the previous owner of my A4 30v.
- my 1-2 shifts are not smooth. is the jolt from these shifts bad?
- s4 side skirts
- front bumper question
- does anyone have an extra short shifter? mine just snapped... dont ask me how.....
- quick 1.8t B5 performance upgrade. help
- well guys, my time has come. i went into the dark side...
- 2 hours into the 30V V6 upper oil pan re-seal.... it's a b!tch.... more ---->
- cat flange busted off on the downpipe side. Now what?
- Could someone please tell where I can oder a fan bearing? Dealer?
- more 4000 turbo project updates, cuz I know you guys missed them :)
- ? about N75 valve - Code 17956 open circuit - have searched but confused...
- Rear windshield trim problem, please help
- Anyone? On the pre99 A4Q are the sedan and avant rear springs inter-
- What's the diameter of the UR underdrive crank pulley for the 2.8 30V / 2.7T ?
