- Ahahaha!!! A legendary post is on the top of Digg right now...
- Gas Mileage Woes Part 2 (MAF and Coolant Temp readings)
- 98.5 30V Engine/Auto Transmission Longevity
- Finally made a sig.. not to bad for Paint and MS Word I hope lol..
- Amazing accident with a Corvette and A4. A4 took it like a tank. LINK
- Ideal transmission for track and BAT? 2.8, 2.7T, S2? I am going to need....
- i am doing a diy catch can with one of those toxic nagle bottles
- those with BBK expeically the porsches upgrades
- A 2001 A4 for son please advise!!!
- What's Everyone Paying for 93 Octane these days? $3.999 outside Holland Tunnel NJ
- BSK (or any ATW driver w/ HFC or TP): Any success with Waynes 02 sensor angle box?? or
- Just found a complete S4 rear brake upgrade for $115 shipped!
- Time to replace the brake pads and maybe rotors, any suggestions? Budget around $200
- Non-Fouler writeup
- So eh... Who here's got a 2000 ATW and running a MAF delete on a Motronic tune?
- AC blows hot/cold/hot/cold
- PES g2 maintenance questions
- So I want to replace both of my front cv shafts
- How heavy a press do I need for a whl bearing job? 10 or 12 ton do the job?
- A.W.E. Tuning partners with StopTech
- Any reason I should not pick up a set of used Intrax swaybars?
- AC Compressor help!
- Place to get ABS Plastic that goes with Audi interior well?
- Upgrade
- Rough start of cold engine at first time (A4 2.8 2001)
- Old school crew: What headlight did JustDave have?? Holfe or something like that?
- Which tool is used to hold the crankshaft on 1.8t when tightening the crank bolt?
- Those of you near Englishtown:
- suspension installation question about alignment
- how to remove it or lift it up higher...see pic.
- a better engine cover for the 30V?
- going to make an intake light - any thing i should be aware of
- do you really turn crank bolt 200Nm + 180degree????
- H/S catch can
- it was a nice day sunday
- Will 2008 Jetta 5x112 16" rims with a 50mm offset fit without issues?
- Some recent pics from working on the car... (BWW)
- Anyone running those 17's on their car?
- Blue light special...
- i didn't know my front bumper in my garage was worth so much
- Made it through the weekend without a trip to the hospital, so it was a good one.
- Where can I find the torque specs for suspension components?
- hard to reach vac line on front right side need advice (30V AHA)
- Question about HID's for 2 piece headlights
- Im going to Europe for a couple months for work, Im thinking a A4 diesel avant.
- Parts, parts, and more parts.....
- OK so I took a week off, am knee-deep into the PES G2 install, already a few snags...
- Pull up to local store to get a sub, random guy outside goes "Nice Car!"
- deciding a steel strut bar or alum - steel is stronger so it should be better right
- anyone else having trouble getting onto the riverside online ordering website??
- ECU Interchangability: My stock ECU ends in 557 P, would a 558 M be interchangable? If not, what
- what hardware comes with an APR cat back? none?
- Are the catalytic converters clamped to the muffler pipes on the 2.8L quattors?
- How to change the front axle on a B5...
- Another stupid clutch job question....
- Anyone have a picture of a diagram of 1.8T exhaust?
- Actually worked on the a4 this weekend!
- FYI - The SAIS delete write up has been updated.
- Sluggishness, vibration, probable misfiring, but intermittent -- 99.5 1.8Tqm
- Anyone have any personal knowledge of this wheel, looks good and maybe strong but dont know weight
- What's a fair price for a chipped ECU in a trade for a stock one?
- Clutch shot 01 1.8t
- Update on my genuineaudiparts / valve cover gasket issue
- Will start Timing Belt Job and Cam Tensioner Seal this weekend. Which one should I sta
- Where is the sunroof drain on an avant???
- Anyone ever get wheel hop in their quattro? I did this morning in the wet, thought it was odd.
- best place to buy contorl arms these days??
- Do I need to REMOVE the cat, or can I just "free it up"....
- this is interesting DIY exhaust manifold
- Free OEM Cat (the exhaust type, not the meow type!) to a good home...
- Need a new front bumper, Are there any differences between between pre and post 99.5 models?
- 2.8 30v cam plug replacement.. does rtv need? or just replacing?
- Hit or skip?
- please see the picture. it looks like a new seal...
- any consensus as to front strut bars and do they work
- Is there a way to look up options on a car just using the VIN number?
- 99.5 1.8T Tip, realistic mpg expectation? Whatchu gettin?
- just my curiosity... what's the role of crank sealing plug?
- which is harder - auto x or track
- What is the preferred rear brake upgrade these days?
- in a week or so im starting my suspension job. any tips???
- How do I rotate the quattro shaft?
- ok..I screw up TB job!!! do I need to call towing car to take mine to shop??
- PCV System: Check Valve locations. Where do they all go. I got 3 of 4 in, 1 by air box, 2 under int,
- EDL causing vibration?
- How do I remove the bolt on the heatshield....
- Anyone know where I might find a trans drain plug wrench on short order?
- where the cam plug located? is this a different name in bentley??
- Should i fix my car or upgrade?
- Thoughts? I need wheels on a budget (two of mine are out of round)
- Another 'Please Help' regarding the coolant level sensor on the
- Timing belt and cam seal trouble - please help
- Koni adjusterable coilovers
- Replacing Control Arms ...should I move to coilovers?
- I think I made a really big mistake yesterday.
- poor milage, do you see anything wrong with this log?
- I dont like boats...
- Not having much luck searching but looking for the updated part # for a 97 1.8t MAF...
- how to turn the crank? it's probably stupid question, but...
- So I'm starting my clutch job... and I have questions!
- New Helmet....
- Did an Impromptu Photoshoot today on the way to the theater to see "Dr. Jones!"....
- Please tell me a sport suspension from a b7 will fit in my 97 1.8?
- please help! how to get this bolt out!!!!
- could someone please explain to me how to get the e-brake cable out of the rear CA?
- Is there a resource to help ID a Turbo? I STFA and I am going cross-eyed.
- Vag-Com Blocks: Coolant Temperature and others
- Just ordered my first pair of proper driving shoes , Piloti...
- Catalytic Efficienciy CEL (Anti-fouler question!)
- ESS Help
- Pole: If you were going 100mph down a highway. No one around. And you hit a person...
- Just got done swapping alternator..
- pls check out the pics..oil leaks
- Any one ever used this Ctrl Arm Kit? S4 upgraded Kit
- I picked up a new (to me) car yesterday. It is a 1970 Audi 100LS 2 door sedan w/ about 50K miles...
- DTC 17584
- TB&WP DIYers: How did you remove the 10mm nut holding on the lower TB cover without removing the
- Changed plugs on 30V last night and want to tackle the old vacuum lines today
- Reddish Oil spil coming from a mount, passenger side.
- 3k.
- Experienced a tire failure at 100+ on the way back from FL coming through Georgia
- Can I use Mobil synthetic grease for the brake guide bushings?
- ECU Testing in MA or NH
- Wheel Borg- resistance is futile!
- just won this item - what else do i need for the install
- One heck of a busy day...
- Should I?
- Help , No Spark
- PSA: Keep a fire extinguisher in your car, especially after doing work to it!
- So uhh... I'm probably going to get the crap flamed out of me for this question...
- Few more pics of the casavant....
- FRAUD ALERT: Don't Sell Anything to Philip Gorianne in Southern CA
- Help w/ Starter Wiring 1.8T AWD
- Quattro squeaking, creeking from rear differential
- Does anyone have a good picture/diagram of the N75/wastegate etc hose hookups?
- Anyone have an '01 4B0 906 018 CH ECU they want to trade for a fully loaded APR Tuned ECU?
- front suspension squeaking when hitting bumps and when turning wheel at stop
- Hey guys, been a fun 6 yrs, but the Audi is up for grabs-->
- Meh... i'll admit it ... im curious
- So, how accurate do you think OBDII horsepower readings are?
- ABS light question
- 1st time CEL has ever gone off on drive to Sears Auto no less. Pulled codes...
- How do I tell whether I have a ZF or Koyo Power steering rack? Thoughts on rebuilt racks?
- Still...no reverse with new MFS.
- Ebay KO3/KO4 tubular exhaust manifold
- Paging Audi Junkie (or anyone else)... Need your expert know on this oil report
- Couple codes and a CEL, some help or ideas would be appreciated.
- Official Memorial Day WEMMT: Anyone going to be turning wrenches?
- Lower dash relay carrier question, I have 8 relays under the dash in my 96 A4Q but the carrier has
- I can't do it... I'm keeping the avant.
- NAMOTORSPORTS | Memorial Day Weekend Holiday Coupon
- keep Getting code p0131 any idea's of what might be causing it?
- Power Locks/Central Locking System electrical short
- Another WWAWD thread...
- Compressor
- Had a CEL over the weekend and dropped the car off at the shop yesterday
- I noticed I have a broken piece of plastic that looks like a T. It goes on the end of the hard metal
- Anyone have a spare non bose head unit?
- Love my job sometimes:
- Anyone had trouble aiming Euro-spec HID housings (Valeo)?
- anyone have the tyrol smic?
- A4 Headlight options
- eibach lowering springs A4 2.8l = 1.8l?
- What thinks AWB5? Nogaro blue content. ebay.
- 50 series tires on 16" swing wheels? Didn't I see someone...
- who's got the pic of the jack stand turned 90 that sits inside the pinch weld
- main bearings
- When buying a car out of state, does one have to pay taxes to both states?
- question about running lean ..... see inside
- anyone have any thoughts on the 'Dunlop Direzza Sport Z1 Star Spec's? good or not so much?
- Seafoam Question (Possible Exhaust Leak?)
- Loudest exhaust??
- What's the dealer charge to replace both cats on 2000 A4 2.8?
- HID Problems
- :: ECS Tuning :: UPS 2nd Day Air Special Rate - Save up to 40% !!!
- Sunroof drain replacement question
- Sun Visors
- Recomended downpipe??
- 034 tranny mount users... How do you like them? pros+cons please.
- Engine Speed Sensor tooth missing on Automatic Transmission Flywheel
- Clutch Trouble
- 1.8T A4 (2001) owners PLEASE HELP with a couple of connectors
- Today was a very happy day for me. My friend let me drive his Subaru STI.
- I'm going to be near some APR tuners this weekend and am thinking about having my software updated
- project rig yo exhaust is complete. the noise is much reduced...still burbles though :)
- HELLO EVERYONE, I'm back!!!
- creaking noise from steering column
- so just picked up a couple window regulator clips(carrier) per audi from the local dealer..
- Hrm... Is this the truth?
- Ouch!
- First test drive with Apikol red(firm) rear diff mount. My thoughts...(long)
- anyone looking for low mile STaSIS Tracksports 700/800?
- btw - is kero a better flush or diesel
- just bought 7 bottles of auto-rx - i am going to start drinking it
- headlight conversion question
- Are the injector gaskets the same on top as the bottom ones?
- 034 Clutch Kit 30,000 mile report
- Went to go lower my car a bit more and the car did it on its own! YEAH!!
- I think I've reached my final verdict on my A4s...any insights into long-term car storage prep?
- Anyone have a rear sway bar they'd like to sell? or a set of H-Sports?
- I need a new starter for my beater Accord...
- For those looking for ecodes
- Switching out the rear suspension on the avant this weekend.
- Joey T 1, pinch bolt 0
- yes! the flex pipe fully separated on the way to the yankee game last night.
- anyone know if a w8 passat engine will mate to a 2.8 5speed tranny?
- About to pick up used OMP or LLTEK strut bar. Look same, both say will not fit 2001. Windshield
- Anyone every replace a window rolling motor?
- For the qfrog.....
- Joe, the shirt was a little small...
- couple new cosmetic additions to the casa avant
- turn signal flasher/relay???
- Anyone know if adapter 8E0-051-444 for iPods would work with my Delta CC/tape deck?
- Anyone take apart the key half of our fobs?
- Is my Turbo going out??? 99.5 a4 Quatro 1.8t 75K rebuilt engine. 145K Turbo
- click here to find out how leaving your dome light on can cost you $60
- Pff...check engine light
- Reprogramming Keyless
- Which forged internals to get?
- Manual SunShades
- Thoughts or tips for cleaning out 12v cig lighter? Phone charge does not make solid contact when
- 12v timing belt help...
- What's the best materials to use to divert my intake/air filter from its current location. This is t
- 1999 A4 alarm keeps going off
- Just found frayed hose
- what brand of oil do audi dealerships use
- Anyone interested in cigarette lighter assembly from a 2000 A4?
- Anyone replace the pre-facelift knob with post knob?
- PSA....the interior door handle replacement (tech article) can be
- Yay / Nay?
- trying to figure out psi / ft-lb torques specs. which forum or where should i be looking. cant seem
- Anyone know where I can get front bumper grille cutouts?
- My car is live on Joey-Cam if anyone wants to watch CA's...
- AZ classifieds POTD
- Cheap 2.8 dp to cat?
- Timing *chain* for new 2.0T
- Searched but i am confused. what size is the axel bolt for a 2001 1.8t quat avant?...
- 2001 Bose speaker adapters
- I wonder if he is on AudiZine.
- Bent rear lower control arm. Input would be appreciated.
- Can you Change your boost value with a Vag Com?
- Pancake Valve: Clean it w/brake cleaner and let dry...done? or rinse out brake cleaner w/sumthing?
- Video from coming back from Southern Wurthsee in which me car pulls on a R32 Skyline:)
- VVME HID Installed: Woohoo! I can see again!
- Had a chance to be one of the first to install Axis Motorsport's new PCV blockoff adapters.
- For those doing DIY waterpumps, a PSA....
- Got finished with a new custom mod I've been meaning to do for a while: Brushed Aluminum Mirrors
- LOL, my car is buzzing like a WW2 buzz bomb
- Ok so finally got my DTS in
