- Anybody got a broken ABS module laying around?
- Non-ebay xenon bulb source?
- Just joined the club, thought I should introduce myself (long)
- *searches for a crash helmet to fit the B5* --------->>>>
- Are there any worthwhile windshield wiper upgrades I should do?
- saw someone post pics of recaros from a Mitsu Evo X in here...
- Rear deck lid on B8 is quite a bit more B5-ish than B7. Agree?
- *EDIT w/ crappy PICS* Fluck Fluck Fluck Fluck......
- I drove my A4 2.8 from Texas to MA. I crashed at the very last turn.
- Headlights
- Wierd problem with serp belt and fan pulley
- Timing Belt Kit
- Anyone have a 96 trunk they're looking to unload?
- Thanks Guys!
- drivetrain slop - cont'd (close to giving up)
- Paging Roger.....Please tell me you got my joke the other day about my new hood LED lite?
- Vaccum Leak help
- 1.8t cylinder head differences? I need an AEB
- I could use the help of the B5 forum too....
- An FYI to those doing the S4 euro rear. The US brackets are different then the euro ones...
- Anyone looking for a good cheap seat?
- Paging B5Davem...package received...thank you kind sir! :)
- S4 body kit
- Going to be helping a friend with a 1.8T (replacing coil pack BTDT?)
- Rabble rabble rabble rabble: got pulled over, cop was cool. Guess it was inevitable
- Need a part number, or suggested solution
- Can someone please confirm the non-sport A4 2.8 tip quattro rear spring paint dot codes?
- Radio interference from spark plugs
- Whether you're looking or not: What's a bigger turn off when buying an A4; Tiptronic Trans or FWD?
- Hard to start after filling up gas tank
- so my steering rack crapped out on me.. can I cause any more damage by driving it to work today?
- BANGS HEAD AGAINST WALL!!!! THE DO NOT LET THIS HAPPEN TO YOU POST!
- is this a good deal?
- Cold engine stalling problem... STFA with no luck...
- ETKA Pimps: 035-906-149-A is AWM injector seat? Or is there an updated one?
- would a dead alternator stop the engine from firing?
- anyone know why the engine and tranny code would be painted in the spare tire well..
- I did a couple pulls with this car the other afternoon....
- whining noise after getting abs module replaced
- Need help finding "correct" cv boot clamp pliers
- Anyone ever heard of the CRecorder?
- Classic B5 A4 rear spring problem that needs replacement...suggestions?
- Anyone have a 2001 a4 parts car
- Does any1 have a K&N set up on a 2.8-v6? any tips or pics?
- anybody have used this??
- Stepping on the scale for the first time......Not bad kids!!
- Cicada sound solution - JAFO wins! (Center Driveshaft Support Bearing)
- Key ReProgram after clp replaced 99 2.8
- Hood
- OT: Overheat light on 2.0L VW Beetle- anyone familiar?
- FS: 2000 A4 1.8T ECU with GIAC chip for ATW motor
- What kind of mods do I need to make a 99 1.8T as fast as a stock B5 S4?
- VAG-COM does not test speakers
- Alright...
- Ignition coil debug question
- Water Pump PN#'s
- Castrol Edge vs. Euro GC ?
- where can i find a E T K A diagram ?
- Display says "Brake Light"
- My New Car, your tips and help
- what is the best exhaust for its cost
- Finally, everything is mounted + lined up. Need to figure out one thing though
- Need a cheap quiet exhaust
- Car smokes after heating up. Any ideas? Oil Leak?
- 2nd weekend in a row someone damages my car.
- Anyone ever change a brake light?
- Engine misfiring, might be because of NGK BKR6E
- Replacing the secondary air pump...
- Heated seats not work'n
- Name that part.
- could this be a fried alternator?
- What would a dual-k vag-com key-usb dongle interface rev b be worth?
- Is the hood and the front bumper the same from 96-01? If any changes, will it still fit?
- Front CV joint issues
- if you need me i'll be in mah lab
- Close to the Edge.
- tie rod ends
- Dash beltline removal.....
- Just another thanks to Joey T.
- 2.8 AHA Q: Which plugs on the firewall are the post-cat O2 sensors?
- Varying Idle
- Does anyone get any of these 'special' tools that Audi
- Car won't pass emissions b/c of VAG connection port
- Need help getting the rear window switch out of the door panel.
- Has anyone changed the bulbs on the driving lights in the lltek RSR bumper?
- rear CV axle gremlin?
- headlight removal - there are 3 screws, I found the 2 on the top... Where's the 3rd?
- need to reset my ABS sensor... how?
- Xenon low beam replacement
- Since I'm having the bumper resprayed (S4 bumper)....I ordered this from LLtek
- Anyone have spare front chrome grill rings from a salvaged grill they can part with?
- Anyone go from Redline MT90 tranny fluid to Amsoil 75w-90? alot more gear change noise
- Help with ABS Sensor
- for whoever was wondering about the fuel supply hose i got from audi...
- what tire pressure do yall run for winter?
- Also...
- Does this make me a bad person.....
- hanging plug below radiator behind bumper?????
- Koni SA setting with OEM Sport springs
- Changed the coolant temp sensor...but
- New to B5s, just purchased a 2000 A4 Avant 30V and have a couple questions.
- Cold start issue 1.8 T
- Post a picture. Just because.
- BT: Selling my ECU to a fellow AWer; a CH-box ECU is compatible with M-box cars, correct?
- Quattro stuck
- TRE safe to drive on?
- Considering picking up a 99 A4 with a bad clutch, suggestions please?
- Really thinking about picking this up.
- coolant temperature sensor troubles
- VAG com demo limitations. Can I not scan my central locking module? I can get to the menu shown
- I can haz bumper and flarez? Work on the Mazdog is just about done.....
- MPG going down
- badge fail.
- My brakes...
- Those with an oil pressure gauge, quick question
- Where to find some interior trunk LED bulbs? Need more light in there.
- aftermarket coolant temperature gauge
- gear ratios..
- Button inbetween driver and rear driver doors?.....
- Ross-Tech order completed...*sigh* $260...but I will be able to fix mah car more better!
- Anyone have a working/good condition K03 they want to unload?
- Whats this wire from.
- Audi events in upstate NY anytime soon??
- VVME Install which wire goes in which plug?
- Kris Hansen YGM x2
- Nav+ and iPhone...options?
- Spark Plug Suggestions
- 6 x 9 seakers - anyone installed in A4 b5??
- My car is back in for clutch work again.....Anyone else ever experience this?
- Bummer (CEL) end to a perfect day...Paging "GTA" *edit*
- EGR valve location??
- Some nasty piece of nastiness punctured a hole in the sidewall of my tire.
- Delta CC to Concert I head unit swap?
- Innovate WB users... Do any of you also have to re-calibrate each time you turn your car on?
- Transmission mount and Sway link.
- Audi R8 "BLACKBIRD" video
- Can anyone ID this boost gauge?
- New Bulbs..Osram Nighbreaker
- Part # for 1.8T
- Why when its real cold out and i do a cold start, it doesn't always idle where it normally does
- Play in wheel, but no play in upright or control arms...
- QUICK question,, want to do my fuel filter soon,,Avant removal same as Sedan??? anything different??
- Squeaking supsension- possible reasons?
- What ECU do I have?
- Help please - what do these central locking codes really mean?
- can you buy replacement radiator hose clips or do you have to buy the whole hose?..
- New sig...
- Geez, anyone else getting any snow today?
- Introducing our PureMS.com Blog
- Vag-com from ebay?
- Cooling system problem.... Suggestions?
- will B6 A4 steering wheel fit in B5 A4?
- Paging KingFK04.. what was your Aerocatch question that you deleted?
- I, once again, completely forgot to order a drain plug gasket. Anyone got one?
- P0441 & P1128 CEL codes (Updated)
- Does the 99.5 A4 1.8T have brake wear sensors?
- Some mirror questions...
- Is this an Audi they were trying to fly?
- No snow pics yet from the East Coasters? Post em up...
- should i scrap it and go for a newer A4...? Opinions please!
- Paging D1rtJr
- Check Engine Light
- Sometimes I can't unlock my driver's door with the key...
- Just for the hell of it, how much weight could be shaved from a b5 without doing panels and sunroof.
- Climate Control
- Gas mileage experiment, Stage 2 Results, Conclusion
- Variable Assist Steering?
- where is the bolts that hold down the car battery?
- Front control arm sets on Ebay--Anyone tried them?
- WTB: Side Mirror Glass (both sides) for 99.5 B5 with Symetrical Mirrors
- What Else? My 120K mega tune up...
- PSA - VAG code 17748 or P1340 turned out to be timing belt off by @2 teeth
- Ouch.
- Whats the best way to degrease a pair of used heads? Cheap DIY solutions?
- Help! How do I fix a fuel leak at this fitting?
- Angry Cicada noise - continued (still looking for the cause)
- Anyone ever use a 2.7t built and bored block with a pes SC in an A4?
- Been gone awhile, is Carson still the go to guy for parts??
- Big Brake BT: Anyone ever hear of an SRT8 Brambo caliper + C230 sport rotor?
- I got a lowering kit should I do anything before I put it in????
- Anyone familiar with the rear suspension of 2001 FWD A4
- Clutch on a '98 2.8 Quattro 5-speed...how many hours (flat rate)?
- Ticking from transmission when coasting in gear... lil insight please.
- Legality of chainging the airbag control module?
- Transmission Trouble
- anybody want to post some clean b5's to give me some ideas/???
- Engine cannot start
- question on which amp alternator to get for 99.5 aeb 1.8
- In-car vid of the snow cross last week is finally up!
- WTB: Silver hood and/or Silver front bumper in the Chicago/Milwaukee area
- Looking for more suggestions:
- Cleaning interior this am & spoiler(Daytona)....
- Since we seem to have a common theme going on: Post up pics of your totalled a4
- anyone have a vent sitting around that is this color? Want to let it go?
- No fog lights, no passenger side running lights
- is the radiator core support the same for a 1.8T and a 2.8?
- Replacing Engine and Transmission mounts
- So ABS light may be more than just a blinking light? Totalled my car yesterday. Long..
- Suggestions where to look?
- ABS Followup - VAG-COM communicates just fine, but still gives a code
- I think she has a nice butt [work safe + B5 content]
- got tired of looking at the dirt....
- Anyone know of a shop near Mammoth Mtn, CA
- What's this additional electronics part on the back of the new mirror?
- Removing air conditioner control unit
- UGHHH Someone backed into my car and didn't leave a note....
- I'm back in the B5 World! Yay!
- Near Bozeman? Have camshaft locking bar & pin to loan? Easy $50
- Thought you guys might find this intertesting, I own one and its been very good to me so far but I
- A4 B5 Quattro Rear Differential
- 98 A4 2.8 Suddenly Loses Power and Needs to be Restarted
- FYI Advanced Auto can special order lots of goodies.....
- 2000A4 ABS
- Any 1.8T motors out there
- Wierd exhaust noise?
- Hey do you guys think these would work well on my brothers 2.8qm? I think the 2.8 is heavy enough up
- Anyone have a oem passenger side balast?
- velosouljah posting from over at Trevor's. So the *new* Throttle Body is a bust...WTF?!
- Well, here's the damage. They want to do both sides as a precaution. Let me know if...
- repost?
- This just brake chirp (worn pads) or something else?
- Can someone tell me if this is a 1999 or a 1999.5
- T/F - have to physically go to dealer for radio code lookup
- I really want to go to at most 17" for wheels come summer. I know I'm vain for that as
- What is this?
- There a way to test how my turbo is running without a boost gauge?...
- Hit or Skip? : Used H&R Coilovers w/100K miles?
- Interesting boost issue...
- Another ABS question - VAG cannot communicate with my ABS module, but I don't get a light and ABS...
- If you had $25000 in your pocket, which car would you buy and why?...
- ABS control module question,, Is there anyway to have Modulemasters, or whoever,....
- VAG can't communicate with my ABS module...
- 1.8t downpipe??? tristan hows that sig lookin?.....
- ebay wastegate????
- goodbye a4... hello 335xi
- Someone should snag this: VAG content.....
- 2nd day with the a4 registered and all i've gotta say is..
- Does the AIR system inject through the Kombi valves?
- What do you think about brand of snub?
- So I am officially at the five year mark of ownership of my A4
- Chrome trim around windows ?
- sig???
- ABS turns on every time i stop!
- Small Review on Hankook Icebear W-300i
- passenger corner of bumper [under headlight] won't stay attached
- New camera mount testing...no not my 5 y/o holding it this time ;-) & WW for tupac song playing
- VMR Wheels | 18" and 19" V708 - In stock!
- OUCH! Audi A4 listed as one of the top ticket magnets, so beware
- Battery Draining quickly
