View Full Version : A4 (B5 Platform) Discussion
- Bogging Problem??
- A4 2.8.. owned one week, bad transmission?
- idling problem HELP
- anyone have an ipod touch 3rd gen working in there car?
- FS in Classifieds : 1996-2001 E-Code Projector Xenons, plug-n-play, bulbs & ballasts
- Audi 2.8 STARTING ISSUES
- Widebody / Grill Conversion PROJECT (b5 tp b7)
- Where to get suede shift boot and knob cover?
- Craziest problem I've ever seen!
- Northern VA - Manassas - Recommend a good mechanic
- Annoying Buzzing in Panel Causing Radio Interference
- Instructions for removing the front pipe w/flex joint on a 99.5?
- engine performance
- Nice B5 Avant available - MA
- What does "To VIN X-199999" mean?
- 2.8 Air-box
- Steering noises
- Did the headlight switch repair now a new problem
- turn signals stopped working: 01 A4 2.8
- Front Hub Assembley
- Changing Shocks in Front & Rear Need Info.
- hey guys, 2.8 issues
- Cold Air Intake Complications.
- turbo replacement 1.8t
- Control Arm Kits
- Crankcase Breather Hose
- 99 A4 ABS issues, No Vag interface?
- Steering fluid return hose, please help with choosing
- Overheating
- Cruise Control Module - Help Please
- Unique Sunroof Problem
- Loud clunky/squeaky noise from front passenger side
- Greetings! Here is my SWEET VIDEO
- A4 Engine Leaks
- Intermittent Cruise Control
- Which Vag-Com
- Wheel Refinishing???
- Engine Coolant Temperature Sensor
- Potential buyer questions.
- boost gauges
- Front wheel well tire location
- Headlight protection Lamin-X
- just swapped a 97 12v into a 96 body now no spark or injector pulse
- Odometer, speedometer, cruise control and fuel gauge do not work... ?
- Anybody has a torsen for sale????
- Car cranks up but won't start, what's the problem?
- broken neuspeed 19mm rear sway bar
- WTB: Left front lower rear control arm
- 288k miles on car . are there any oil hoses that can get clogged?
- Center vent lights
- Will a LUK Release bearing be compatible with a SACHS Clutch disk and PP ?
- Helicoils ok for cast turbo manifold?
- Turn Signal Relay Fix!
- Hooking up subs
- GIAC Chip of APR
- 1999 A4 Quattro 1.8T Bad bucking under high boost
- Engine seems to misfire under hard acceleration in 2nd
- Instrument panel
- Bad Gas, Water in the Tank, Fuel Pump Dying?????
- How much is too much oil in IC tube
- I need a k03 for a 1999 A4
- No electrical after TB replaced
- Engine hesitating when accelerating. 1997 2.8. Manual trans.
- alternator bracket?
- motor out of time??
- Coolant Temperature problem - need help verifying
- A curious question about rear differential
- Odd noise coming from the interior fan.
- Time for Spark Plugs
- Control Arm Bushings
- Wiring in Pioneer Deck to Delta BOSE system.
- Anyone for power steering pumps?
- control arms
- WANTED! Turbo for 99 A4 1.8T
- help stuck in neutral
- rear diff oil change?
- engine won't start
- need help obd port not working
- Temperature Gauge says its -58 degrees? WTF
- Backfiring pulled 8 codes!!!
- Fuel Filter Replacement Issue
- will this ipod adapter work with a bose systen?
- Coolant leaking from hole behind pully.
- My project for the next months
- Bose "subwoofer" amp, XO'd or full range?
- Question regarding Vacuum hoses/lines.
- AIM MXL PISTA install in an Audi A4 B5 - help!
- A/C problem
- B5 camber Issues
- Couple problems come up
- Engine Floods in On-Position
- Interesting noise from my '96 A4Q engine, need to remove plastic cover BUT how?....
- no start issues on '96 A4 2.8L
- Heavy missing/hesitation under very small and very large load/rough idle
- Camshaft alignment and compression test
- coilovers on my 96Q
- Brake Light Warning Problem
- :: ECS Tuning :: 3M Di-Noc Carbon Fiber Wrap Now Available for LESS
- Needs tires, but clears the ST's with tons of room and runs flush with the fender
- audi camber issues
- How to change the Clutch?
- Coolant drain points in 2.8V6-12V block????
- code p1545 help
- '96 A4 v6 starting problem - should CKP have tranny fluid on it?
- "Fan" noise (?) when car is off draining battery over night
- Audi A4 2.8 transmission problem
- '01 Rear Wheel Bearing - Circle Clips?
- Access to the boot
- Carwash broke off my antenna.. shark fin?
- What yrs of Steering columns can be swapped....
- Swap out a 1999 audi a4 steering?
- Vag-com to remove brake wear indicator light
- can I drive with a broken rear coil spring?
- New Clutch, Southbend Stage 2 A4 2.8
- elyte
- Lights! (I want to drive at night too!!!!)
- fuel Economy
- Hoepad
- Inconsistent Starting
- Cyl 4 & 5 misfires
- Fuel Venting problems
- Airbag light question.
- No power to fuel pump
- painting front grill?
- A4 Automatic Transmission Range Sensor: Low Input Code
- Possible head gasket failure!
- Bentley instructions for replacing and adjusting wiper motor?
- Alarm doesn't work....Vag
- Run Away or Run and Grab It?
- p0455
- Oil Gauge
- A/C Condenser Fan Not Working!
- $1000 bet
- K-Seal, Innostop, Headgasket problems
- going round corner and traction control kicks in at slow speed!!?
- OIL
- rear o2 sensor delete
- Audi to climb peaks without a driver?
- radio removal troubles!!!HELP PLEASE!!!
- 2001 S4 Springs on a 2001 A4 1.8T
- Electrical Question?
- My wife put oil in the coolant tank
- fuel system cleaning
- Rear spring cracked
- Sunroof motor available?
- B5 A4
- Lamborghini Gallardo wheels on the A4.. coming soon.
- Seat swap
- Rattling noise from front tire pls help!
- Clutch or Slave Cylinder
- control arm kit and suspension
- X-post: Anyone with a ball joint separator in DC area?
- Need
- Anyone have the Thermal R&D CL Exhaust System?
- universal O2 sensor wires
- Mounting fire extinguisher in B5 A4
- rear wheel bearing dilemma !!!
- Radio on Safe?
- Whats wrong?
- 2DIN upgrade
- Climate Control Panel
- Highway RPMs?
- Soon to be owner...
- Power window noise
- Power Steering Fluid
- loud noise from engine that starts when sitting at street light
- Anyone have parts for a 2 din upgrade?
- Replace coils as a set????
- Can I run wire through the AC unit grommet?
- Turn Signal and wipers not working
- Looking to buy an Audi, need advice
- my car seems to being consuming fuel at an alarming rate! also... other things...
- charcoal cannister
- "Readiness" and VAG-COM Question.
- Battery Self Destructed
- Front Inner CV sticking problem
- failed tbelt tensioner
- 2000 a4 climate control shutdown
- 150,000 mile oil change
- noise from trunk area
- Intermittent oil temp guage
- Key-fob Separating
- Weird clunking and revving
- V-Checker Scanner Pro
- Anyone put a rear spoiler on their 99.5 A4
- Overheating help!!!
- Inside door release has gone 'floppy'.
- New member, transmission question
- heater problem?
- key & navi from a 03' b7 a4 for a 96' b5 a4?
- Speedometer Off by 2mph - VAG sensor G196
- Speedometer Off by 2mph - VAG senor G196
- wont idle on start up
- Summer tires and rims on! Finally.
- what size are inner cv joint to tranny bolts .
- which control arm sqeaks
- What is this? (2.8L V6)
- **HELP!!!**: p1260 p1136 p0134
- 2001 intermittent oil light
- NO fuel and no ignition, WTF?
- ok, Iam officiay lost now.
- Tire Size on Quattro
- VAG-COM scanner
- A damn shame
- Combination Switch or Ignition Switch
- t-belt tensoiner failing,
- Which maintenance parts to buy? (Oil filter, air filter, etc.)
- Speed control doesn't work
- Interior lights not working
- CAN bus loop help
- A4 Rear Coilovers
- water in back seat, alarm missfire, now no start
- HELP-My door won't open on my '00 Passat
- Need help with upperl control arm replacement
- 01 to 97 sport cloth seat
- Revo Technik Spring Sale Marth 27th - April 11th 2010
- rear door panel replacement
- looking for bushing reviews
- Left suspension vibration
- best b5 lowering spring
- First time buyer... A4 or S4 (already STFA)
- Broke bolt in cylinder head!
- 2001 audi a4 windows/sunroof/power locks wont work need answers please
- Is there a way to tell when my timing belt was replaced?
- How do I know if my clutch is bad?
- Super low mileage, Help..
- 2000 a4 quattro, orrrr, 2001 VW passat
- 1999 Audi A4 for sale
- Please help: Windows went "KA-CHUNK"
- Huge problem, need help.
- Pictures of my 1.8T and a few questions
- How to install an aftermarket radio without a wiring harness
- How to Clear False Errors on Driver Information Display
- Innovation? Putting a cup holder in place of the dash ashtray
- o2 sensors
- Failed Inspection P0134 P1408 P1504 P0401
- Problem with Turbo
- Power Steering Issue
- (1.8T) 5 wire pre-cat O2 sensor $52 at Advance Auto Parts!
- 2001 A4 $3,500
- service warning light-turnoff
- swap heater core and only luke warm air
- Recently bought 2001 A4 question on fuel economy
- engine sputtering
- B5 timing belt writeup?
- Horn doesn't honk when doors are locked - fuses?
- How do you Reset the Oil Change Service Flashing OIL code?
- Memoscan Problem
- Just Got 1997 A4 2.7 Quattro - Daily Driver
