- Car pulls left
- Is seafoam available at big box part stores or do you have to order it online?
- a4 xenon headlights
- Turbo users: what would you say is "hard driving" do you
- Lower Passenger Side Grill
- I'm gonna do a power steering flush tonight...need input
- last ditch effort. about to go to the dealer
- Is there a difference in RS4 wheel manufacturers? Hartmann, FM brand, PA brand???
- Ǿ 25Mph Showing where fuel countdown should be
- Search turned up a million results too many to look through
- Bilstein Shocks
- Girlfriend call this am and her early 99 avant will not start>
- Help please
- another p/n request... crush washers for the 22mm and 19mm banjo bolts on ps rack
- k40 rd850 radar good? or escort 8500 better?
- Did I miss something? What happened to the Z-flow FMIC from SPP that was ~$750?
- Need the codes for VAG-COM to enable cruise control.
- bigger tourbo bigger clutch???
- Installing new stabilizer links, should I just go with the updated OEM.....
- I retrofitted a B6 shift knob and boot into my car...
- Reverse not working
- where is best place to get a new s4 bumper?
- 97 tiptronic conversion help please
- picture from today.. tons of pics
- Koni Suspension Kit questions.
- I know where you all are right now! lol
- Pics needed
- i got a neuspeed chip today, actually went to headquarters...
- do you think I could use header wrap or thermal wrap...to protect my oil lines...
- Clutch wont engage
- just debadged my audi trunk rings, dunno if i like it
- anyone want to get rid of an RS4 grill?
- Fog Light Mod for pre 99.5 question.
- how anonymous are those dealer service follow up calls?
- pics of city lights "lighted" up at night?? especially any LED versions.
- Yeesh, lurking over at evolutionm.net make me feel like a rocket scientist.
- Attn K04 GIAC owners...
- so i need to start looking for a boost leak. i could sometimes hear air
- Loss of Cruise Control ???
- Anyone running this exhaust? Any opinions? Or go for something better?
- clutch problem...
- To get to the ECU...do you have to take off the wipers to remove the rain guard or whatever that is?
- Bad Ball Joint?
- Easiest, best way way to remove tint from windows?
- another issue: when I put the key in a turn it to on...
- suspension is squeaking...anything i can do to spray anything
- How do you guys attach body kits? thinking of buying from somewhere, no attachment..tape???
- I feel a bad slipping?
- chipped 1.8T boost problem
- Any events goin on in the DC/MD/VA area anytime?
- 97 12v catalytic converters
- Eibach Sportlines for a B5?
- Anyone ever installed the Stasis LSD and/or their Center Differential?
- when I shut the door on my A4 it keeps chiming help!!!!!!
- alright guys, i'm thinking of doing another run of Valentine One remote mute switches...
- Easiest, cheapest way to get some extra HP??
- does the 98.5 Audi have a boost pressure sensor
- what do you guys do when detailing?
- Need help removing intercooler shroud.
- leaky valve cover gasket question...
- OPINIONS WANTED ... What would look best for tail light tint ...
- ABS and BRAKE light comes on
- You know you want it...another L.A. GTG @ The Stand (SFV) - Tuesday, May 31st 7:30pm
- B6 shift knob on B5?
- Anyone have pics of double navs or screens on double din consoles (s4 & a4)
- YEAAA...just got my 2001 1.8t back from the shop 2 days ago...
- I need your rear valence
- Argh, my center armrest is now stuck upright
- Generic O2 sensor for 98.5 1.8t?
- Newbie
- Wife was just told by dealership that to take the slack out of the parking brake cable............
- Where can I buy an OEM lower left grill for a 98.5 2.8Q?
- final, final clutch question: what's the pedal feel compared to stock of the southbend clutches?
- Rear tail light tint
- Need help with a p/n guys... power steering rack
- Neuspeed Exhaust?
- final clutch decision: which southbend clutch to get? tz?
- fog light mod
- Would this 2003 Passat sunroof console fit my 96 A4?
- 22mpg...?!
- Changing bulbs in the cluster?
- turbo dying?
- How much will going from 15" rims to 18" rims throw your speedometer off?
- A/C has freaked out
- What do you think of the new BBS rims ?
- X-post: Contemplating selling my engine....
- went out to try and take some pictures of my new headlights...
- Cool shot of my buddy's car
- Hey RiegerAudiA4 how do you like your black two piece headlights?
- s4 h&r COs vs Billstein PSS9s
- What should I use as a sig for now?
- Radio Question
- Dung Beetle please email me about selling your Level 10 tranny!
- Hi, replaced a V-hose, the CE light still on, does it require VAG to delete it??
- Need new exhaust...
- recent pic of the car..
- why is this so damn much?
- I know someone somewhere sells those little tools used to clamp the OEM hose clamps, and I'm sure if
- DIY e-codes for $150, should I try it?
- bleeer valve for cooling system
- Anyone knows where to resurface dual mass flywheel around NJ ??
- poll: state your age in years | days me -> 22 | 8.288
- last day!!!!!!!!
- PA/NJ/NY peeps: Etown tomorrow at 6:30pm. If it doesn't r-a-i-n. I'd like to at least be in the
- fender rolling question....
- X-Post on weird noise coming from motor...
- OZ SL or RS4 Rep
- Has anyone tried to repair their crankcase breather hoses?...
- Front noise, need help
- What MAF do I need to get for KO4?
- Ice Link Plus Question
- Passed the 200,000 km barrier today.....'97 A4 1.8TQM
- Looks like it's finally happened to me... steering rack failure... need some help guys! (long)
- Am I correct...that you cannot adjust the clutch on a 99.5 1.8TQM?
- Anyone know if the ATQ engine flywheel is the same part for both auto and manual transmission?....
- Check out my new wheels...I'm very happy with the look...
- can someone tell me what this is a picture of?
- Ace Zeus Rims
- Help!! 96 2.8qm front pass. caliper drags
- what's the most I can do with rear brakes while keeping stock calipers (99.5 2.8Q)..
- 50k coming up, what else should i have the dealer check?
- ABS Control Unit Failure POLL
- intrigued by this ATP kit...
- Anyone have an Uberhaus kit
- bank 1 running too rich/car is stalling?? Why could that be?
- Should have no problem mounting 16" Swings from my A4 onto 03 Passat Wagon, right? Both being B5 and
- car is ridiing like sh**t... 87 2.8qm (kinda long)
- New Porsche (repost?)
- Clean car pics
- found these chrome mirror caps with turn signal on yabe
- air conditioning problems
- notorious fog light mod
- apparently sachs discontinued the sport clutch, what are other good options? thanks.
- Are cordless electric impact wrenches worth a damn?
- UPDATE- Just Got Rear Ended!
- Suggestions on new Injectors..?
- My tint sucks, its fading and getting splotchy. Need to have it replaced, but
- qfrog@work: Can you tell me my car's bday? Please....
- Anybody have any experience with Firestone's "$99 Lifetime Alignment"?
- New shift boot
- Replacement front passenger rotor does not clear the hub?
- Hey guys another brake question ...
- 99.5 speaker adapters for sale...brand new...
- silver streakin or other DIY'ers
- Has anyone used "Circuit Solutions" for ABS rebuild?
- *Feeler post* Anyone interested in my Level 10 Tip trans? I am thinking about a 6 speed conv...
- 1996 A4 Door Lock/Keyless Entry Question
- Where's the love?
- Some pics from Mosport
- dual exhaust on a a4-b5
- PSA forget to post: driving without the lower belly pan can cause your ac lines
- tints on silver a4
- Ronal Wheel-Tire Packages
- $430 for AC repair - long boring story inside :-(
- Would an exhaust leak = Loss of boost?
- Getting ready to buy a new clutch. Have a couple of questions....
- I have to give ATP credit
- Did Rieger ever make a fiberglass RS4 Rep. front bumper?
- suspension
- What chip is the best?
- Here is a good link.
- advertisers: who can hook me up with a sachs sport clutch? thanks.
- Whats a safe drop for a 96 A4 FWD
- does anyone have a stock bypass valve they want to part with?????
- SAFC Setup Question A4 V6 B5
- Need some help here ...
- b7 rs4 replicas
- Hot Import Nights!!!!
- Mod List...
- Coilover opinion...
- Anyone know anything about the Reiger RS4 bumper that was for sale in the.....
- Confused as can be about 2001 1.8T spark plugs...
- Night guys - My rear wheel bearings are bad and I need some advice and direction...
- Paging mAd1(gt28rs) to teh red courtesy phone please, mAd1(gt28rs) to the red phone please-->
- Did anyone go to import madness in State College this weekend?
- Did timing belt yesturday,car runs great,exhaust seems louder at idle...
- Problem installing Bosch charcoal cabin filter (C3740)
- A/c Condenser hoses.
- Anyone know where I can get a throttle body and a
- pic request- Painted Black metallic S4 Rims on A4
- Detailing question
- anyone ordered from http://www.specializedgerman.com
- I have a k03 lying around, if anyone is in need... </baleet me>
- Note to AW admins: It's Production, not "Proudction"
- Possible Sig Converts
- is my a4 blessed?
- Looking for an exhaust have heard milltek is nice....any suggestions?
- Anyone know if the updated oil supply line heat sheild (for the turbo) can....
- I know it's been asked... but Eibach pro-kit springs on Avant...
- who makes those b6 style taillights for the b5? the tail have the white turns all the way up top
- Tip peeps...
- Just got rear ended!!
- Teh "silver beast"
- Pictures from "Gatebil" in Norway
- how well would the revo BT software work with the new ATP k03 eliminators?
- s4 wheel house liners- buy audi ones or make them (long)
- paging shrtbus, whats your email, re: OZ SL plus cash x BBS CH trade
- Boost gauge istalled in dash
- where can i buy new fog lights online?
- qfrog: armrest lid falling apart... whats the part number
- Anyone have clear side markers laying around that fit a 98?
- I eat bugs:Cross Post pic from OT
- Bilstein Sport Shocks....To groove or not to groove...
- Gas attendant put 3 gal of 87 in my car yesterday have a few questions--------->
- Driver's door mirror busted. Need help! What is 6XK-U?
- high flow cat-? worth it?
- Wanna install my buddy's fmic, 99 1.8t A4...No pipe kit available:
- Can someone tell me about how much parts and labor would be....
- Parts Needed for a 97 A4 Black Quattro 1.8
- Has anyone purchased the Hella "teardrop" side marker lights from ecs???
- Anyone know where to send Audi Internernship Apps?
- Stumped with battery
- Phatnoise owners
- Are there any gains from adding another SMIC on a chipped 01 in FL?
- noobish question regarding front anti-roll (sway) bar...
- is there anything to look out for?
- think I'll have better luck trying to sell my GIAC K04 n-dbw chip on ebay?
- Qfrog, part number request. TCU for a 99.5 Frontrac TIP and Quattro TIP?
- Need direction/assistance is finding/purchasing rear wheel bearings...
- So last night my car was possessed, revving on its own
- A4 Vibration Problem Revisited - Need Help.
- golf ball at 80mph
- It was a fun and painful weekend.
- metallic rattle when going over bumps
- 97 1.8T Clutch kits
- coilpack question
- Does anyone have a front license holder that they want to get rid of?
- Wheel bearing? Need help….
- i have a fog light out.... help please
- Loss of Power to HVAC, Radio, Fogs, Etc....
- Hello from Europe!
- link for free carfax
- Why my life sucks
- Anyone have suggestions on what chip to get for..
- NEED HELP PLEASE ~ window problem
- A4 Suspension Knocking
- overboosting - if my wastegate is stuck closed...
- Need help removing the glove box on a 98.5 A4
- For anyone thats intrested ATP GTRS/GTXX k03/k04 eliminator dynos:
- attempted to top end the car out tonight, backed off and got scared
- Any tricks to getting the oil filter off?
- Some pics from Roebling Road this weekend...(bww)
- Bored, random Pshop of Brock B1's...
- I suck at life.
- Can someone help me find the TSB's for a 97 1.8tQ?
- I'd still trade several noobs for an UrQ
- back seat floor wet, where to start
- suspension problems please help!
- Has anybody ever orderd parts from lltek.com? Cuz it's been 2months and my rs4 front bump aint here.
- "Oil temps of 250°F+ possible, but not recommended, captain."
