View Full Version : A4 (B5 Platform) Discussion
- Hanging wire
- Noob Saying Hi
- Jump back into the family...
- cluster question?
- 8d0 920 980cx cluster eeprom dump + other info.
- tape stucked & what is these butens?
- ABS Wierdness
- shock replacement
- Serious light cluster issue past the cluster!!!!!
- Are these symptoms of a bad alternator ?
- *EMERGENCY* advice needed
- Replacement bulbs for Instrument cluster/climate control
- Sludge buildup repair kit - $2,884
- Suspension Question?
- fog lights
- Sitting at the DMV FTMFL. Thoughts on fun plates for the AR?
- Anybody know if a B5 S4 set of Sway-Bars will be woth putting on a B5 A4 1.8T?
- What say you AW - paint my intercooler and piping black or keep aluminum?
- Brightest fog light ???
- A4 vs Passat
- My car is not well, advise please.
- Is it me
- Driver Information System
- car wont start! flashing hazards
- Child Seat
- what happened to the old threads?
- New Guy!
- Shudder in Reverse ONLY - Transmission Problem?
- Please help ... running rough, pulled codes
- Fog Lights?
- Help, still no heat....
- Some turbo/fabrication stuffs
- Can the Concert radio code be changed?
- 1.8T downpipe - oem or Bosal
- cyl miss fire 1.8t #2 cyl
- Electrical Problem: Turn on headlights and the wipers and turn signals quit working
- Overstock TRE Sale!
- A8/Boxster Brake Upgrade - Will it Work?
- Rear Shock Replacement Question
- abs module rebuild
- How is the side door trim removed/attached? Not the lower door trim...
- signs of a clutch goin out??
- '98 A4 1.8T Mystery Oil Leak..
- 97 audi 2.8 v6 swap help
- 97 audi 2.8 V6 'NO OIL"
- 97 audi a4 gauge cluster?
- Transmission Stuck!!
- Turbo woes continue.
- Power Steering
- newb, is finished I found the wire :P
- Problems with accelerating. Help!
- 1996 A4 V-6 SOHC, CODE P1505??
- clutch sliped, trans broke!
- cluster lcd problem
- does my 99 1.8T have oval or round pad sensors, are all B5s brakes the same?
- Got the B5 Bible today.
- 12v 2.8L V6 valve cover gasket replacement.
- Crazy, haven't had this in awhile
- 2.8 change cam plug w/o removing valve cover?
- How to get a hub bolt out
- Climate fan
- V-crap removal...need PNconfirmation
- coolant antifreeze dilema
- Loud bang
- Transmission.
- Will S4 upper control arms work for my A4, link inside
- Part number for coolant temp sensor?
- Air/Fuel Gauge install!??
- My alignment #'s
- Increase preview lines???
- A4 cabrio won't start after winter storage.
- Internally WG GT28 people - how did you clock the turbo?
- a4 avant rear seat release handles
- Northeast A4 owners........
- 98 a4 quattro question
- 99.5 A4 2.8QM Trade-in Value?
- !%!%!%! CHECK ENGINE MOUNT !%!%!%!
- 1996 A4 2.8L EGR Valve issues.
- Coolent Temp while stationary in traffic
- Must the springs/shocks be removed when changing upper control arms?
- Rear wheel bearing toast in 5 months??
- short throw shifter 99 a4
- intercooler mounting
- 1996 Audi A4 Mechanic in New Jersey
- Advice needed (rotor upgrade)
- Stern Adjustable Upper Control Arms Group Buy
- WWAW do? Need to figure out how I want to approach the repair of my fan wheel bearing
- HELP GAS GAUGE!!!
- *Announcing Revo Techniks Forum Member Discount*
- 99.5 Audi A4 Avant Quattro 2.8L
- Lights on the dash?
- weird rubbing while drivin on drivers side.
- Audi engineering question
- WOW, Did anyone else see this.
- 2005 b6 6spd tranny
- Problems Starting Car
- How is it possible to have a post at "Today 02:16 PM" ?
- Forum use question
- One piece headlights electrical gurus
- OT: Happy Birfday to me!
- Sudden Bad Oil Leak??
- is the motor mount for a 99 1.8T the came as a 2.8V6 and all B5s?
- Will bad control arms cause "clicking" sound when turning hard?
- Looking to buy a complete AWM engine
- A4 Quattro Rear Speed/ABS Axle sensor question
- Help with central locking pump
- Power steering pump
- Water/coolnat in Plug well
- Final Gear Help NEEDED
- ABS Speed Sensor
- To paint or not to paint...
- APR Stage III Question
- 99.5 A4 1.8t Q TIP will not move, i need some help
- 1998 A4 2.8 Heater questions...
- Parting out 2001 1.8T in Central CT...
- Wiper blade orientation?
- Paging SilverStreakin' - Mah TP is out and wants a new owner :)
- need help!!! i want a chip for my ecu an am sick of searching no name promise makers
- Power Steering Leak?
- Single mass flywheel
- newb, with wiring question tip to 5spd conv.
- TRACK DAYS at Monticello, NY May 7th,8th
- OT: So my 12,000th post came and went. That was fun.
- a4 problem
- I keep getting 17536 any ideas?
- Hello Gentlemen
- How to remove passenger door panel to access window button?
- Looking for a non-Bose Avant sub/amp and a passenger's side sun visor
- Help with a 98 Quattro a4.
- brake light question
- B7 Steering wheel into B5
- B5 with CEL (Coolant Temperature Sensor)
- INSPECTION light came on, how do I reset it?
- "Help, Audi Fixed My Car And Now The Trunk Fills With Water Whenever It Rains"
- Newbie w/ ride height question
- Remote start/keyless entry system for 1996 A4
- Houston we have an epic fail.
- transmission problems??
- Car shut down on the highway and now will not start :(
- Car wont run after battery died, need help fast, urgent
- Door latch problems
- Dremel + patience =
- a4 brake help
- A crunching binding noise when turning the steering wheel all the way
- S4 shocks on A4?
- Help to Install Remote Locking
- Paging JustA4-Matt...
- Internet dealer w/best pricing
- broke down an hour ago... my story
- Anyone own a A4 sedan maroon.Weymouth
- Need some advice on rear alignment & tire wear
- plastic bits in oil on dipstick
- A4 B5 Brake Upgrad Suggestions - A8 Brakes?
- Loud constant squeak/scream coming from the center of engine?? HELP! 2006 A4
- oil cooler
- Stupid question: Is my Coolant expansion tank overflow drain
- Bose amplifier?
- AC Compressor - pulley/clutch
- Never thought I'd get rid of the B5, but I did, sad day!
- Brake Power Booster
- what should the oil pressure be for 1.8T
- Noise when turning Steering wheel - getting louder
- what intake is this and is it good?
- Sun roof adjustment
- Ball Joint
- a4 exhaust
- RS4 Brake Upgrade... POSSIBLE?
- Car keeps dying.
- Possibly getting an A4
- Any suggestions for a custom/aftermarket trans cooler? Need help trying to figure
- Leather seat help?
- Some pics from Show and Go
- Timing belt tool kit
- Cruise Control dead.
- Front cam seal leak (cam sprocket side)
- RS4 17x7.5 ET35 & tire wear
- Difference in ECU?
- What's this??
- Beyond frustred with the Test Pipe to DP flange bolts.
- Just a question.
- Test Pipe and Air Intake Discussion
- Help with removing rear pillar trim to find rattling noise...'96 A4Q.
- Anyone know where to get a door lock vacuum pump for a reasonable price?
- Timing belt is done, car is running good.
- Lug Bolt question
- Fog light & drl fixed
- HELP!! 2001 A4 1.8 VAC leak "See Pic"
- Help with Part No - AC Comprssor
- Really Inexpensive Control Arm Kit
- Removing carpet
- Brake caliper binding
- Recommended Mechanic in NJ
- Will a bad ECT sensor throw a coolant light?
- Is ModuleMaster the best option for ABS computer rebuild?
- crank but not start
- Looking for a car bra
- Where to but ecodes?
- Why have I lost the ability to edit my posts?
- Is the B5 FAQ ever going to be useful again???
- Windsheild wahser nozzles.
- Bose Upgrade Question
- Help with code Rough Road/Engine Torque signal from ABS
- Thought I would add a new mod while the car is in the garage apart..
- dirt in air intake
- Updated Europrice Sale - STaSIS Engineering Parts 10-15% off...
- Loud slam when change hvac settings
- The man in brown just came by.
- If I'm buying used interior wood trim, should the clips be intact?
- Auto-Rx?
- Anyone have any ideas
- Audi A8 Rims?
- Best price on a PCM for '97 1.8T Quattro?
- AC compressor belt on A4 1.9TDi (2000)
- euro rear gb
- 2001 Bilsteins fit on 1999?
- Moaning and clicking from back right
- First cosmetic mod
- EPC Light Issues
- It's official. Have buyer for the car coming tomorrow. I'm done.
- What is the average lifespan of HID bulbs before the light output is diminished?
- Removed & replaced driver side seat, now airbag light on. Must be cleared by VAGCOM?
- Cylinder 3 Misfire
- body work in NoVa
- Satellite Radio.... whats best and recommendations...for the Audi....XM /Sirius
- New Stern Pro-Mount Motor Mount Presale Ends Today!
- my wife's at it again---added syn. oil to radiator
- Parting out 1998 A4 BLack on Black WHole car in Parts 1.8 T M/t 69k Miles
- Brace work for the gt28r begins..
- A4 Shock Upgrade
- Instrument cluster random lights
- 2001 Audi S4 - Warning Indicators Popping Up - HELP
- No turnsignals Problem with Switch
- Clearing "check engine" light
- Multiple Problems Please read if you know anything about sensors
- RS4 Front bumper
- Hard to get it in gear....
- small coolant leak dripping down AC unit...DIT
- 38 Offset
- x-post - engine finally going in...
- Buzzer in instrustment cluster.
- Valve cover gasket sealant questions
- H&R Coilovers....how low or high
- PSA - stage 3 B5 S4 with aquamist = woah.
- Part #'s for motor mount bolts 2001 1.8 AWM
- Sadly, Newbie turbo question
- Code help...
- CD changer skips on every little bump
- autocrossing A4 in G stock
- Anyone have used control arms? I really need some help.
