- nyc: estimate to blend front fender with door? [long]
- Oh BTW if any of you ever grab a JL Stealthbox the bolts are 1/4" course thread.....
- Did some searching, decided to go with the Huco ICM. Best place to purchase from is?
- changed all fluids-comments
- block
- I had to post this... I love old school Audi's
- bitjockey this is for you =)
- windshield washer pump
- Repair shops on Long Island
- After some searching I am unsure if primer should be used when painting side skirts..
- My birthday present- new mod:
- Found a tear in the hose that runs from my Evoms FMIC pipe to the throttle body
- my old school
- IBG/JoeyT - Regarding the engine mounts
- Tweaking my Race Tec FMIC this weekend, Quick question:
- Anyone else care to join me in creating a B5 A4 pact
- Headlight/Key Buzzer vs. Cold Weather
- Well, I should have had a test pipe to install this weekend, but the seller's problems are now mine
- For those that have helped me to try and diagnose the ungodly sounds my car has been making...
- I know it's a little OT, but question about the heater on a 2001 V6 Passat..
- after reading search results, is there a specific mix ratio for fuel and toluene or no?
- Another question in regards to my V6 tranny question from earlier....
- Does anyone have a modded B5 avant they are looking to sell?
- AWE Tuning Holiday Sale update
- need parts fast, where do i go?
- CENTRAL LOCKING!!! ARG!!
- Is this normal boost/vacuum behavior in cold weather (~15 f)
- Where exactly is the post cat sensor located on an AEB engine?
- winter is here
- So, I thought the A4 V6 gearing was supposed to be better?????-->
- Does my damaged A4 have any resale value?
- OK, I am a little rusty since I no longer had the A4. Question inside
- Greetings from Aruba.
- what spark plugs come with awe k04 kit?
- Kris 1. Stuck Lugnuts 0.
- Rear differential L and R flange seal change help
- Got new cats in now code Code P0161
- I have an RS4 grill and wanted to paint the chrome black.....
- High pitch grinding sound...
- changing air filter-don't pull the intake pipe or 'wiggle' it out
- So here are the pictures.....how could this have happened
- Faint buzzing noise and headlights dim in a slide???
- any photo shop wiz's want to help me really quick?!?!
- Anyone know of anyone running Megasquirt on an A4?
- Lug-Bolts for Sportecs
- so i tried to order K04 kit from AWE and ...
- Alternator is off - Blog entry #762
- I just searched and found no HID's to fit a 96/7 1.8t, is this correct.
- iPod Adapter
- Gas problems..... help!!!
- PES turbo to manifold studs.... paging mAd1(gt3071r) too
- Help with DV debate with co-worker, am I right or wrong on this one?
- The head is off
- IBG: All of Darwin's scarring is hidden if it's there at all. All of his hair grew back...
- Save big with the STaSIS Race Down the Chimney Holiday Sale...
- paging cursh, need info on rusting my paint....
- APR Stage 3 Raffle change
- Car stalling at idle....
- anyone else have xenon issues....?
- Mesh lowers on 1999 B5 A4 w/ stock bumper?
- Quick question, i want to upgrade my tre's with s4's, are they different from....
- Rear diff question. What do you guys think?
- IBG LOVE the new siggy:)
- Service position help, bolt size???
- Lowering Springs
- Paging: Iamawesome!
- APR Stage 3 Raffle Today!
- Guess the size
- H&R... the most irritating warranty policy.
- strange electronic boost cut off in the middle of driving
- Is this right? Bosch Super Plus yttrium +7
- Ecodes
- Bam goes office space on a guys peugeot for doing donuts in his lambo.
- Oops!
- Can Valeo 90A alternator be rebuilt???
- Does the oil temp sensor go bad?
- Poll: A-Pillar Boost gauge(VDO with red needle) backlight, Red or White
- Re-post Tool Help needed
- APR Holiday Sale Update: Motorsport Hoses and Exhausts 15% Off!
- Follow up on A4 2.8Q and maintenance question ..
- For those interested... my 4000 turbo project continued... more wiring to go!
- Time to bring out the dead horse...
- HID Kit
- T-Stat replacement ->
- Any other 96/97 owners get the latest recal information on the ignition switch?
- Help---low boost
- Any DIY'ers in the S.F. Bay Area to help with a T-belt Change?
- buying the used cluster
- Random question. Is there any extra support or benefit from using the 2.8 subframe...
- Reiger bumper quest
- Dension ice links on ebay all sold out?! I dont even see auctions for it starting at low price like
- nunya if you are around could you get on aim real quick? Or anybody else running the ATP
- So, who's going to spring for the invisible wheels?
- Does anyone have suggestions for some nice carpeted floor mats for <99.5?
- so lately the abs light on my dash has been on with the blinking brake light. does anyone
- Looking For Two New Front Axels
- Modding the Fog light switch...Help
- Oh no ... here comes the drama lama... Madan please get in contact with me
- CAPS time ...finally...
- So finaly got my light wiring figured out. And its such an amazing improvement.
- AEB - which is cylinder #1 looking from the front of vehicle?
- Stripped Headlamp Adjustment Mechanism
- For future reference : If i sell you something i mean canadian funds... THANKS DUNGBEETLE!!
- 18062 P1654 Please check DTC Memory of control panel ECU
- Fmic and Front Mount Oil Cooler group buy
- paging joey t....
- Feeler - May be getting new car - parting out or selling my current A4 TQM
- Never did get a chance to show you guys the intake manifold on the car
- my mirrors dont work any ideas how to fix?
- Follow Up: Won't order from autoparts warehouse again.
- Strange problem....premature clutch slippage???
- Can anyone tell me how this is an upgrade? K04?
- Anybody else have problems with ATP returning e-mails?
- Foglights not functional
- how could a valve head break off?
- Check engine ligth is on
- Tool Help Needed
- Part Number Request 96 2.8
- Funky voltage readings...
- boosting problem... giac chipped 01. spikes about 20psi, then immediately drops to 12psi...(more)
- Holiday Free Shipping!
- Do the AC fans go bad often? I have one that makes a funny noise (bad bearing on a fan type) and I
- reseting climate control with vag tool
- Is this the right tool for 2001 manual transmission?
- so anybody planning on doing the Canadian NEQ winter driving school this year?
- Weird clicking noise on the driver side wheels....did a search but still not sure...need advice...
- BT Guys, what spark plugs would you suggest.
- ABS control module quote from mechanic at $950. Extended warranty is covering, price sound right?
- Officially been on AW for over ten years now...wow...
- changing rear diff seals ?
- Transmission 2.8 manual 1996
- it's OK to spray WD-40 on my door hinge, right?
- Please help. problem wit my A4
- How much would you pay/sell a used EvoMs intake for?
- Goodbye
- n00b question.. why can't I run full boost ALL the time?
- so who is going to go the distance in an A4?
- Which of you guys did I follow (91 S and 9 S in CT) Bamboo 2.8, w/blacked out tails, Mass plate?
- AHA vs. ATQ 30v 2.8?
- FYI - Rob knobs sting like hell when it's 18 degrees outside
- will 4 rims/tires fit in our car without taking off the back bench? no use of the trunk
- Ran some logs with the Carbonio...SIII/BT gurus please read!
- I have received emails from both Mark@ASP and Javad@034 regarding tranny mounts...
- Poll: Do you work on your car/ if so what car did you learn how to wrench on?
- Someone with the repair manual if i could get a sec please
- Neither front seat heaters seem to be working, most likely a fuse?? I would expect some heat out of
- seeing the SPP FMICs below, is it possible or what options are there to make an FMIC anodized black?
- SPP/RACETEC B5 FMIC SPECIAL
- Just for the emokid crap below.... today I went to the depot (again)
- Ever wondered how alloy wheel are made? Rays in Japan tells it all...
- went to Circuit city came out and car wouldnt start
- Hall Sender on VW 2.0 Digifant, pops right in???
- Can the DBW gas pedal be swapped with the DBC gas pedal?
- caps time is in - thx ModifiedA4
- Opinion
- TRIVIA Question... while I watch "Who wants to be a Millionaire"
- Progress Report: So far my opinion of the 034 clutch kit is it's a big hit...
- ROFLMAO! This is one of the best shipments evAr! ;-P ~~~ 56K warning.....
- Tire issue.
- BLack Anodized Engine Caps
- APR Anual Holiday Sale On Software & Hardware
- Common causes of Limp Mode accompanied by Negative Deviation DTC?
- Anybody know if 034 of ASP will produce a beefier driver side tranny mount soon?
- Radio displays Phone
- Poll: Seats or Navi
- one running light out but it's not the bulb
- Hypothetical boosting question...
- Fair price or not?
- car really loud
- Part # for the 2 hoses coming off n75
- Clutch adjustment?
- Driveline mounts, how many total??? --->
- Torque Converter
- looking for a new RS4 or Kamei grill for a B5 A4 :-/
- suspension advice for a 2000 1.8T FWD A4.
- coilovers
- Looking for a used stock turbo or upgraded one that requires no modifications to the engine.........
- Would colder temps affect my my boost levels at all?
- where is the best place to find a used a4 motor
- CEL Code Help
- a4 genius needed
- Has anyone gone from 2.8/S4 to RS4 motor mounts?
- Ohhh so nice I think I may have to grab one in my BT preperation....
- Ignition Switch Recall
- I've been rolling around like this since Saturday:)
- Battery alternator question
- PSA:Gldnrkt moment of Zen....
- Question for N-DBW installers of AWE pedals
- Anyone have remote start on a manual? Is it possible?
- Can I gut out my Cat? Will is throw codes? Is it a bad idea? Thanks.
- APR Holiday Sale Update: Carbonio Intakes, Bipipes and Intercoolers 10-15% OFF!
- CV boot leak
- Battery drained after sitting for a week
- a look at the CAPS data so far...
- Left Main Drive Seal
- Dismount strips(?) on my A4 -99
- Mr.Hansen YGM!
- Ebay Audi Parts
- MADAN!! PLEASE GET IN TOUCH WITH ME!! LOUD NOISES!!
- Well I put the RS4 replicas up for sale...
- those w/ wheels- does everyone want to race you?!
- I found myself another summer project...
- why you should brake before the corner!
- Anybody running the Innovate Motorsports LC-1 wideband?
- Suspension upgrade it is..but I have another Q...
- Borla cat-back OR HR springs+Bilstiens shocks? Both about $700.....
- Guys, I need your collective brain: intermittent hesitation/dying idle
- Did rear pads tonight...
- S4 side skirts
- O2 Sensors
- Flywheel bolt torque specs?
- Finished dad's clutch master & slave
- On a scale of 1-10, 1 being brakes, 10 being transmission/engine swap - I'd rate the gas pedal a 15
- 96 a4 the headlight question
- Pelican Head - I sent grilles out today, emailed you as well.
- Joe@AxisMotorsport is the Mike Kim of the east coast...
- Is there any difference between a K04 and a K03 visually?
- CF interior trim panels. Anyone have part #'s?
- Boost normal??
- Log 114 Wastgate Duty Cycle question.
- Alright guys tell me what you think..... Car is running --leaking oil machine shop error
- Bahleete
- Hopefully not a repost... Tirerack is selling their valeo ultimate wipers BOGO.
- Waterfest winners!
- car is driving bad
- Front passenger handle stopped working, I found tech article, but always necessary to replace handle
- Who's the carputer user?
- :: ECS Tuning :: 2nd Annual Holiday Give-A-Way !!!
- Join us in our Open House this Saturday! 12PM-5PM in Orange County. Food, Fun, and Fast Cars!
- FMIC (Race Tec) installed pics
- Anyone with an extra audiworld.com 6 3/4" x 5/8" decal they don't need--
- Having some misfiring/shaking problems ..Here are the symptoms.. Any Ideas of what could be wrong?
- Starting: Idle jump Question
- who wanted an extra swing wheel?
- a4 mirror??
- K03 from ebay (ne one w/ turbo experience pls read)
- Troubles starting...
- ABS and Brake Lights
- The AWE Tuning Holiday Sale is officially on!
- I figure once I move, have to face NH inspections, gonna order the following.
- test pipe questin where can i get one
- cheapest place to by throttle body for 99.5 1.8t
- anyone want to trade their stock grille for my LLTEK grill?
- Anyone know what size torx is used on the upper manual trans fill plug?
- illbill still around? Been a while since i have seen him post..
- Grr...valet lost the door opener part of my key. Can I buy just this part? How does a recode work?
- 98.5 a4 1.8t with s4 tranny swap.. reverse lights dont work..
- Vortex post of the night...(sh!t, and I though OUR n00bs were bad...)
- Paging FMIC owners (Race Tec), finished my install and I have a question or two and thanks to all ..
