- picking up my new plates tomorrow...
- if K03s can handle 20+psi peak boost, and GT2??? handle 20+ psi boost
- 900hp evo?
- maybe cheaply made, but doesnt look too bad. right?
- Fiberglass sub-enclosure pics
- .98 A4 Anyone have the belly pan for sale?
- b6 or b7 to b5 engine swap
- Do B5 S4 seats fit in a B5 A4?
- thinking about getting different software...
- Tire recommedations
- any comments on this kit?
- Anyone have pics of black ASA AR1's?
- Help with Car choice
- i think my turbo is kaput!
- part number request: oil supply line for ATW 1.8t engine
- when i replace tie rod ends.. do i need to pick up new hardware also or can i use the existing...
- What does this code mean?
- Exhaust Mani Questions
- how to tell if a bpv is bad with it not in the car?
- AC going? gone?
- Post your Brilliant Black ride!
- i cant believe none of us grabbed this thing in CT
- Headlight fix and airbag light
- PSA: Top Gear marathon tomorrow (Thur) nite at 7pm - late night on Discovery channel
- maff is hard, ok?
- done with the front shocks, how hard are the rears on a fwd?
- FRONT WHEEL BEARING REPLACEMENT
- are the rings the same from grille to grille?
- Would you buy a 97 1.8t Quattro for $500??
- HID or not? US-S4 1-piece headlights?
- are the passat b5 shifting boots the same as ours?
- Don't you love hit and runs
- As much as I am enjoying the car, I'm actually thinking of demodding it to catch up on bills
- readiness VAG COM issues for emmision test
- How much would it cost to get ecode housings and upgrade to HID?
- So you guys wanna hear a crazy story????? Check it. Kind of long...
- What the best way to refinish rims for powder coating/painting?
- IPOD ADAPTER???
- Found my exhaust leak. Name that part
- 3" Test Pipe In!!! Yay!
- Anyone ever thought about catching up with the Gumball 3000 and playing tag?
- Now I've done it... killed my key FOB in the washing machine
- Cupping tires, need some help
- KO4 and Wetterauer 1 bar on '97 1.8TQM
- NooB question... So Non- Resonated exhausts are louder than resonated, right?
- Got the timing belt job done for my 30V.
- Who came up with the tale that putting odd matched tires on quattro will ruin something in the drive
- Takers? it's still available...
- Paging Mike PureMS
- Xpost for day crew: H&R CO P/N Question
- Clutch Slip & Tranny Noise
- The repair tech admitted to overpricing...
- What is the easiest way to disable the headlight washers? I have a 2001 A4. Thanks.
- repair shop recomendation
- Those Audi drivers - from the local Toronto sun yesterday..
- 2001.5 s4 suspension on 98 2.8
- pls help - How do you upload new pics to your audiworld account...
- Let's play name that noise! Yes I searched...The noise is NOT
- Upgrading headlights to 99.5+. Need wiring kit?
- Dun dun dun!
- EUROPEAN STYLE LISENCE PLATES
- Its about time..
- WOOO-WOOOO....... woooo000-W000000!!!!
- S4 anti-roll (sway) bars on an A4 1.8t?
- Car was repainted and badges weren't put on correctly, any thoughts on painting my new ones . . .
- alarm off if opening the trunk?
- H&R Coilover question.
- blank stare...shakes head...why....runs to the toilet...pukes
- i am debating on removing the middle resonator when i install my testpipe
- here are my (pathetic) dyno graphs from saturday
- Tiptronic mods
- Vag-Com question regarding o2 sensors and DTC (17931)
- How much did you spend for tinting?
- DIY Clear Corner Mod
- Is this bent or is it supposed to be this way
- ticking fuel pump?
- I found out that I can go into work Sundays and learn how to tig weld
- Location of ICM on 2.8 30v
- What to do next?
- Blinking engine light/Rought Idle
- Compressor noises
- Steves little teaser Vid...
- Bulb type for Valeo E-codes
- Some what Audi related...
- FOB case for my remote control!!
- has anybody heard anything from tristanP?
- update on wrong rear rotors....
- The 2 day saga has ended. Car finally started tonight. The FPR can strand you.
- WTF is it with everyone buying these cheap ass VAG-COM cables off eBay
- It was warm out today...
- Just wanted to double check this vag-com cord was ok to use with laptop and $100 vag-com license
- Purems doesnt ship to canada WTF?
- My brother's new engine pictures as promised earlier today
- F*@$!!! The rear sport seats I just bought to go with the fronts I bought last month do not match!
- To all those who participated in the test pipe buy... check your mails
- anyone know where i can get chrome handle grips for an 01 A4....
- post rebuild questions (i.e. why's it smoking a gentle blue???)
- Do any of you have Avon RS4 motor mounts laying around that I can have pretty cheap? E-mail me.
- well there goes 400$
- So what's the true mileage/age the TB should be changed at on 1.8T?
- VAG-COM Question
- anyone have a coilover wrench ?
- Anyone have a prictures/factory diagram of a '98 frame????
- Electrical Troubles
- ***price drop on Dahlback chips first time ever***
- Where to buy Toluene in SoCal? San Diego County? Orange County?
- THERMOSTAT
- timing belt issues
- does anyone have p/n for front driver axle???
- With so many k04 failures recently, in hindsight, I have no idea how mine didnt go BOOM
- need help with a fender
- For those that have been following my engine swap projects, good news!
- Flashing CEL, Cylinder 2 Misfire, advice needed...
- Can't find the FAQ. Need to replace burned out bulbs in instrument cluster
- so this is probably a stupid question but....
- Sooooo.
- 059-919-501A right part# for 2000 1.8T ATW coolant temp sensor?
- where should i look for an ac compressor for an early 99?
- great alternative EBAY boost guage. matches very nicely
- Most expensive BOV ever recorded..
- ET and -ET (why offsets confuse the piss out of me and are probably not my friend)
- Bellypan Cover
- Question of the day... Would you by a Diesel vehicle???
- Correct Tyre Size
- 50k tune up
- chip cel help
- Vag-COM Question
- Does anyone know anything about this short shifter?
- how much are key blades? and can they be replaced??
- OT: Thinking about picking up a Mini for the girlfriend..
- Headlight Lower Pivot Point
- All my pics are up for viewing (thx to photobucket)
- EGR Insufficient Air Flow
- i hate the effin dealership!!!!
- Transmission Seems to slip in 2nd...
- Speaking of brakes...the little pad on the back of the PBR Ceramic pads does not make them quiet
- New Brakes/Rotors
- OT, but too funny not to post.
- So I have a question.... how do you freaking take off the OEM lower door trim???
- Dude, Total am now rocking one of the few NA 1.8 A4's in the US~!
- ACNA 2-day track event @ Buttonwillow Raceway coming up on March 27 & 28th (Mon/Tue)
- anyone of you guys buy off this company?
- YaaHoo! Finally got the Bentley I desperately needed, let the fun begin.
- Need FOB Code for a Canadian 1998 A4 AEB 1.8T ( can't find in archives )
- 30 valve 99-98 owners with GIAC chip - urgent please :)
- I love Ads
- Pulled my DTCs....does this sound like I need a new MAF?
- some pics from today, for absolutely no reason
- buying a greddy FMIC unit...would this work fine if i have a Chipped K03??
- Anyone know the weight of the 16" 10-spoke wheels? the one with RS4 style center cap.
- someone asked for a pic of my lower door trim the other day...
- Does anyone have a B&M shift knob they don't need?
- will floor mats from a 99-01 audi fit a 96-98 audi 1.8t?...
- MAF swap for AEB...
- body shop?
- 17" Audi RS4 wheels on Michelin Pilot Sport A/S
- scheisse! k04 turbo lasted about a whole month.. lovely.. can anything ever go right with this car?
- Reminder: This Sat, 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XXTuning - E. Hartford, CT
- would anyone be interested in a lltek strut tower bar for 130 shipped
- what's included in a major service??
- typical rear speaker issue, replacing with BA mids, any advice?
- Auto 2 post lift opinions...
- Front brake and rotor replacement?
- looking for front & rear carbon fiber spoiler
- Ronal wheel-tire sale
- KEY PROGRAMMING.............
- Looking for a cheap xenon headlamp, passengerside, u.s. spec. Where can I get one cheap? (used)
- shed some wheight of the front end of my car this weekend
- Anyone near Seattle that has Vagcom?
- 2002 A4 Wiper arm
- What do you use to replace the vac hoses?
- Shifter feedback and 01A... is my linkage messed up?
- Cracked oil pan, about 3/4 inch, ok to weld? Or do I need to simply replace?
- Damn karma got me again... Won't Start this morning.
- Headlight switch fix
- Anyone in PA Reading area?
- Gearbox oil and brake fluid
- More on my DBW issues...
- Anyone buy my '98 A4 Q/ 5SP M/pearl white from Allen Cad/GMC...
- I need to get a car loan to purchase a car (private sale)...what are my options? I"ve never done
- *edit* sorry to bother you guys with this question again but i just want to feel more
- Finished the TB job...thanks to AW
- Pics from earlier as promised! Build-up complete and final thoughts...
- Low oil light staying on update for anyone interested...
- Motorola Slvr (itunes phone) i wonder if you could plug it in directly with RCA or ....
- mod day update: a8 brake upgrade....
- hey guys ... i've been noticing this for a while, but just decided to post about it ...
- Time to get new tires eh?
- torque loss at low rpm
- can someone please Pshop this laser red for me?
- Arty Picture Post
- ECS front seat repair kit
- 8 pin on a phatnoise system
- Did some logging of 115 today since I have yet to get a boost guage (on it thanks)...
- Anyone have pics of the greddy intercooler installed on an 00 or 01 with the bumper off ?
- (half sleep) It's done................(sigh)......
- Which "production" FMIC has passenger side hard-pipes that clear the secondary air pump?
- i tightened my oil drain plug and it was semi loose so that should fix the leak
- Can you help identify this leak?
- i so want these wheels
- GIAC K04 (ndbw) dyno chart?
- okay, so butt dyno gives some more approval now
- DBW throttle cut.
- Removing amber headlight tabs
- Paging Imawesome: got to check the lights out finally
- 98.5 A4 2.8 Quattro
- Turbo Boost problem...
- Anybody looking for ICM?..Accidentally bought one from ECS couple months back
- So, I fixed the problem with my brakes shaking alot
- Reconnecting the oil feedline under the intake manifold.
- Robs Audi World, what happened? I can't load the website
- Oil cooler question...
- Is my wheel bearing toast?
- ECU Stolen last night.. uncommon?
- In the shop 2 weeks now....
- so i got a ride in a AWE Stage III S4 today
- further trying to figure out the mystery of the missing hp...
- SUCCESS!!!! IT'S ALIVE!!!! ALIIIIIVEEEEE!!!!!!!! (plus some sh!tty news too....)
- if i have a neuspeed p-chip can i still get a GIAC tip chip?
- VAG-COM?
- Fuel Sending Unit repair didn't work:( It looks like it is covered under CPO, so...
- Has anyone on the forum tried this out?
- Darn it! Some people never learn from the past. Anyone have half a fog light?
- dyno was VERY disappointing
- What is the size and thread pitch of my lug bolts?
- I Have not been around for a while, have any Stage 3+ been on the dyno yet? and has Gapina(?) instal
- anyone know off hand what P/N for 2001 1.8TQM ECU is it the M or CH?
- Does this happen to anyone else?
- Water temp sensor - how the F@$#%#K do you get this thing out???
- 1.8TQ w/Tip - has anyone else had to adjust their idle speed with VAG?
- *Edit* Couldn't find FSU release button for unit, but I did eww gas on the hands.
- nobody seems to be selling used EVO FMIC's , and i need one ....this is horrible
- quick question on removing the amber from the headlights
- will this ac compressor work with my car............>
- i don't know if you guys like/dislike auto spies but ... i came across this article ...
- Trying to find pics of an Armano wheel... I don't know which model it is (more)
- I was wondering if anybody had an old O2 sensor and MAF sitting around in their parts bin
- Low oil light warning light staying on after oil is at normal level...
- Whatis the difference between a VAG COM...
- has anyone removed their push-down shifter feature or have any advice for installing a short shifter
- Should a 99.5 1.8TQS be priced about 1/2 way between a 99 and 00?
- Speaker Wire, Which one's positive? Straight Green or striped yellow green
- Question about turbo...
- misfire gets worse....
- how do i know i have the correct cable for the phatbox?
- long day, all for nothing
- Rieger Body Kits On Sale | North American Motorsports
- 2001 Sport Package
- Wheel bearing life: 2 years
- Question on tie rods and brakes
