- Boost being cutback, looking for suggestions why?
- Q about snd fan on a 98 a4 1.8t Q
- Anyone in Socal Looking for a 2001 Audi A4 1.8TQM?
- Just replaced rotors and finally got to do a bed-in procedure on them, but...
- Any way to test the high speed a/c fan relay?
- Is there a Bosch 3 bar FPR that fits our rail? PN perhaps?
- BMC CDA FOR A4 (for sale)
- Started on frozen trunk cylinder at 11 pm, fixed and ready to go back in...
- 98 A4 extra keys
- Buncha questions...thanks Mike, I'll order some things after my next paycheck. :)
- Need brake help, 98.5 A4 QMS (Xpost brake forum)
- OEM S4 side skirts silver - what are they going for these days?
- Trying to diagnose weak starter issue...
- Anyone know where I can purchase these older Euro S8 rims?
- noob to noob mods report (chip, ecodes, sways)
- just cuz I know you guys love to see engines torn down to the block... 10vt rebuild...
- just got back from the dyno
- gonna do the rear door handle mod when i paint my car...anyone have the part numbers?
- Coolant Flange is a beotch to replace
- im going to make a complete cruise control contact cleaning post/tech article for you guys asap
- is there any way to reset from "safe" mode and to reset the airbag warning w/o VAG?
- OK, so the ABS light/Brake light have been lit/blinking for almost three years now.
- Where can I get a passenger/right fender for a 98.5 for a good price?
- Just did A8 Upgrade. I now have the bug. Should I do the stainless steel brake lines next or..
- new fuel filter and air filter= worse gas milage
- My Wastegate Is Blown ---- New Turbo Recommendations?
- CALLING DVS27t Greddy Intercooler Install help would be appreciated
- Just saved about half the time changing my fuel filter!!!! Dont have the drop the tank!
- normal gap after 1piece headlight install on 97?
- Should you change your oil after replacing the valve cover gasket?
- All the windows except the driver window will go down in one push of the button
- How to remove stock smic?
- Problem with my A6 but relevant to A4 : wheel bearing noise
- Thinking about trading/selling my A4 for this really nice UrS6
- will a bad O2 sensor cause my engine to run lean?
- Feeler: How much is a PES equipped 99.5 1.8t (motor) with 72k miles worth if sold complete?
- looking at the 1.8T GT2X Eliminator Hardware Kit
- 99 A4 Timing Belt-Sympathy Wanted
- Ignition Amplifier (Power Output Stage) replacement. PSA
- Water injection question
- wheel bearing: try using HubShark v pull knuckle and take it to have it pressed out/in v pay someone
- Is the DTS my only option left?
- PhatNoise or other Music System
- Powdercoated intake manifold in Classifieds...
- Anyone have pics of a silver 1.8T w/painted lowers and black wheels or the photoshop skills to...
- looking to resolve the SAI problem
- NE Ohio -- Where can I get my timing belt replaced? (also posted in midwest forums)
- Vogtland C/Os or STaSIS Street Sport C/Os?
- "B5 Panzer Plate" Heavy Duty Aluminum Skid Plate
- Good news and bad news.
- Raxles axle installed last night. Need a part number for a not so common part...
- too much attention.. i know our cars are hot but...
- What kind of wheel is this?
- Any Audi techs here want to move to NY?
- just saw Superman Returns, Louis Lane has an audi...
- somebody help me need an guide where can i find parts for my car in german
- interior : seats and door panels
- Trade a Trunk Lid ?
- Well this is no fun...got my PC16 flash today and now no fuel or spark. Cranks but I can't even
- Rear Diff Fluid Change
- flik wheels and all weather tires on stock suspension?
- Just pulled the alternator out, what a bad design to have to pull the fan....
- Finally have all the parts for my A8 rotor upgrade, now I just need the time...
- ouch. it costs 776.xx dollars to replace a central locking vacuum pump at the stealer
- Please Help! Chirping noise, clatter under deceleration, throwing 17912 P1504 - 95-00
- My tires front tires are bald on both sides of each tire...
- Check out what I just pillaged off eBay for the 80
- My seat is pretty clean, gunna clean the rest of the interior nice-nice n post pics.
- No Boost
- Can you help me out to get a quote for my friend plz?
- which turbo would be a good replacement for pes t 28?
- Picture of the damage ,not bad ,only $641 ,sorry no picture of the girl..
- 2.8 2001 stock ATQ Quattro, 1/4 miles in how many seconds?
- Racetec or Greddy intercooler w/ a k04'd b5??
- So I am not completely useless afterall.. Did the A8 Rotor swap within 2 hours..
- Do i need to reset the ECU to get rid of CEL? or should it go off by itself when problem is fixed?
- How are would it be to setup a local club shop to work on cars together.
- Does it seem odd that there is a Q7.audiworld, but the Q7 forum only has 4 post per day?
- Daytime pic of the car on new suspension...
- I love the big brown truck!
- NOT A FOR SALE POST!! But how much do you guys think my DPE R07 Variant S's are worth?
- Proper RPM Shifting for best Performance & Fuel Economy
- I'm thinking of shaving/deleting the gills on my reiger bumper...Yay or Nay?
- Got sandwiched/caught in a domino effect accident in traffic on the way home from work..suggestions?
- My horn....
- remote key
- I need some pics for the FAQ! Eleven total
- Turbo noob : losing boost, what are the recommended steps to troubleshoot?
- Detecting a coolant leak
- What is that rubber boot on the steering rack?
- Torque Settings Needed Please - Rear Brake Pads / Rotor Problems
- what will make me happier...vogtland coilovers?.. or hsports, ssk, and carbonio cai.
- FYI: Did some measurements last night. Turbo Oil Feed Line 48", Turbo Drain Line 20" (with ends)
- Newb t-belt questions...
- Goodbye guys! Sold the B5 2.8 1996 A4 today.
- Strange brake light out warning. Anyone ever seen this?
- A/C & fan question- Should turning on the A/C force both the fans behind the radiator to spin?
- I'm looking for a set of 16 inch wheels to accomidate my brake upgrades...
- Pads for StopTech ST-40 Calipers? no track use just street...
- Another Wheel Post ---- Flik Justice Advice
- fvckin car. Total is $1104.29. What an expensive weekend.
- Airbag light on
- I just raped this auction...162.50
- Here are some photos of my valvetrain. Can anyone speculate the condition of my engine by these?
- Can ETKA people find a part number? HC in Ann Arbor can't find it.
- Need some help fellas...I *SUCK* with wheel offset/size calculations....
- Dead Pixels on Dash??
- Lame Wheel Bearings...WTF?
- Need opinions on what I should do with a set of wheels I have....
- Anyone bought Rep's on ebay before? quality? finish? B7 RS4 reps..
- Suggestions...air filter/intake
- Well, I finished up detailing the exterior of the A4 last night and here is my first daytime shot...
- What makes Euro parts different?
- Audi Bose System Experts
- Anyone wanna take a crack at what this place is?
- I know this has been covered but cant find it in the archives ... when engine is off, my boost gauge
- since APR is now making a KO4 set up for the B6 what's the chances we'll get one?
- I heard someone has their front seats out here, X-Post
- Some pics from last weekends car show ,sorry all Audi cars were in parking
- Help w/ fog lights Wiring Diagram Anyone?
- Buying a 1997 A4 1.8T Atuo Quattro with 137K miles
- I'm driving a B7 6AT quattro right now. Car needed a new part which had to be ordered.
- Is there a part number/name for the round caps/plugs ??? as seen in the picture
- The Bad Weekend , car gets hit&skipped , gets better...(long)
- Hawk makes ceramic pads now? Has anyone had a chance to try them?
- Still having problems getting my Nuespeed extreme on my GTRS
- Mmmmm, clean paint. All ready for wax in the morning. I'm whoooped.
- Would a boost leak result in timing retard
- sorry for the n00b question but is it okay to drive with a can of seafoam added to the crankcase?
- Lower Door Trim Screw...
- LED Dome Lights, Polarity Help!
- i like germany....
- question on h&r sport spring and bilstein sport shock install
- New wheels...
- Germany vs USA in terms of driving education and speedlimits
- Should I change my sway bar links, when I get h-sport sway bars? I wan't to order everything at once
- Couple teaser pics...
- Pedals are always a good thing.....
- Suggestions on brake pads to go with A8 rotor/TT carrier upgrade?
- Not a for sale thread, just asking what i could get for these parts:
- I was doing a pressure check post FMIC intsall and was surprised to hear a gurgling sound coming
- oh silly b7 owners:
- Fluid Capacities...
- Hey guys just bought a 1999.5 A4 1.8t manual quattro with grey exterior and black interior.
- Nitro boost, how much psi to be effective at most?
- Sell me your old shift knob
- telnet://ascii-wm.net 2006
- What does this look like to you? Power Steering pump?
- How bad is it to drive your car when its running LEAN? ive drove over 600 miles.
- i have a hose leak causing CEL (System too lean p0171) - how can i repair? how damaging is it?
- vortex post of the day
- Anyone around vegas that has used a fender roller before care to give me a hand plz?...
- greetings from england!
- ok guys it's about time..have a say in what wheels I get. $0-$700 for rims..let's get it on..
- summer oil: manual seems to insist on 5 weight, is 10 weight ok?
- B6 16" wheels on B5?
- A4 Suspension. What Do You Guys Think?
- why is it near impossible to move the seats forward or backward?
- So I removed my driver seat to see why it was "rocking"
- Besiders tire rack, any cheap placed to buy tires?
- GilliamOS: you know the part # for the turbo to cat gasket?
- Mike@PureMS... got a question for ya.
- Ok FAQ sig people....
- Can someone find me a price for part # 4B0 906 018M
- Replacing my tie rods
- is there a central point on the A4's to jack the car up from?
- I'm glad I went with APR
- Follow-up post from last night: Dealer is having issues replacing the bearing
- Just pulled the trigger on a Milltek exhaust...($425)
- Any interest in a L10 Hydrosystem/Valve Body GB?
- While using a torch to get the passenger-side TRE off, the boot got a little melted...
- Question: Should I wait until the suspension has settled more before doing the alignment?
- 2003 A4 1.8T Quattro...rough idle...engine light
- PSA: the CAPS calculator and database is now "TIP" friendly...
- Check engine light bulb in the instrument cluster
- This is what running lean will get you...
- Stereo Code
- Anyone suggest an amp and subs?
- How do I tell what brand of steering rack I have??
- just recived a good amount of money for graduation lookin to invest in my car!
- Do these differ from the regular RS4's?
- Buddy of mine is confused about which car to buy ... wanted AW's advice
- Well, my A4's first encounter with a flatbed today...acc. belt shredded
- Vogtland + Koni + 8 control arms + 2 tie-rod ends = OMGHI2U!
- Tire recomendation
- 2001 AWM APR 3+ Kit Impressions(long review)
- So I asked my son after 6 weeks.....what is the turbo you are putting into the a4?
- check engine light
- Working on cars just isnt my thing
- Review of Audi Carrier bars(aka roof racks)...
- Sunroof alignement question
- Hmmm.......for the haters. =)
- Damn, I had a fault code in every computer but the ABS and CLS after I finished
- What exactly is the difference between the US A4 rear bumper and the Euro rear?
- Sweet! Not much of a mod, but I changed the power souce of my XM radio from 75X
- cruise control failed - any common fail points besides fuses?
- Part Number
- Anybody have a set of finger plates (aka door pulls) laying around or know...
- Throttle Idle Issue
- pc-16 file question........
- Where to get an airbox clip/clamp?
- Black roof...
- parts help: does anyone know the parts numbers for the lower center grille and the drivers side
- radiator help..
- looking to buy audi
- Drivers front window getting very slow to come up. Happens more in humid weather.
- I posted before with response but no end solution. Has anyone else had door panels off in the rain?
- Air filter change and musty smell help...
- Remember those?!
- Dash warning light help.
- how hard is it to fight a ticket for 75 in a 65?
- Should I drive my car with a shot wastegate?
- a comment
- Steering rack options
- HI MY AUDI WONT START WHAT DO I DO??1
- Come on BLK Pearl....What's the word on STG 3+??? I'm gettin' ancy over here! =)
- New pics of my car + brakes
- trying to figure out why car is rich old thread just got off track and died.. values inside
- well 6 months of owning this gauge i finally put it in today...
- (sigh) Why are the B6 S4 owners so damn cocky?????-->(read for a good laugh)
- So another momentary lapse of reason for me and my HID woes
- Rear View Mirror Questions?
- Anybody get strange behavior with thunderstorms in the area? I had some odd surging before
- Part number for the rear differential plate (passenger side with filler plug)?
- Found out what possessed my car:
- Help...Lost boost after installing APR Turbo Inlet Pipe.
- Oxygen Sensor Gone bad??? 98 2.8 with 30V
- Hello to all from F1 Montreal! Met up with a bunch of AWers over the past two days..
- are these sides still available?
- Front end problems -Need a real engineer to solve this.
- Check Engine light at 45K miles (4th year)...What could be wrong?
- WWAWB5 do? Sell the H7 HID lighting kit and order a D2S HID kit or
- Power Steering Fluid Usage: How often to top up?
- turn signals stopped working. The relay for the turn signal is behind the hazard switch correct??
- Quick question ( coil pack)
- Getting new Control Arms installed next week...any other maintenance items you could/should
- Is the b5 outdated?. You judge...
- does anyone by chance know the bolt pattern to a 98 volvo 850??
- Installed my new wheels today.
- Which fuse is the cd changer on? (98.5 w/ Bose)
- Hahaha, the last pane is so true
- A4 suspension help
- F1 qualifying on speed. now!
- Time for Some New Wheels - Please Help!
- neuspeed recomends i get a 5 bar fpr but car is already running rich is this a good idea?
- My car is now possessed.
- Ebay seats
- That damn bolt...
- How/Where to add Bars Leak to radiator
- anyone have or want to swap 96-97 trunk for 01.5 s4 trunk?
