- My latest, minor mod (no pictures, car is too dirty from days of non-stop rain)
- O2 Sensor, Oh how I loathe thee...
- Cleaning out the intake...
- REPOST: Please help! Fuse showing as blown, but checked all fuses-NONE blown
- Car still will not start...
- im now running an open element filter. i need a filter for my SAI pump, where can I get one?
- Mysterious front-end noise continues (not control arms & have searched extensively)>>>
- Grilles??
- "The King!"
- So the oil cooler didn't solve my problem =( Coolant still turning yellow and thick fast....
- Someone I know needs a new rearview mirror for a 2001 A4 2.8. Links to sources?
- Wheel compatibility B5 A4 -> 01 TT
- Do you have a wholesale acct (cost +20%) at Riverside Audi parts?
- anyone here? sorry if repost :)
- KMAC bushings alignment problems....
- since accidents are the 'thing' these last few days... update on mine>
- Damnit! Muphy's Law strikes again...
- need some part numbers, pictures inside, no audi dealer close VW said they cant cross ref anymore
- Wow.... Seafoam to the rescue....
- Avalon is finalizing details on new B5 A4 Big Brake Upgrade....
- Add LED's to interior / exterior door handles?
- has anyone used http://www.specializedgerman.com/default.htm to buy used parts...
- Teaser post... any guesses?
- Finally got hammered
- any place to buy a pass side ecode headlight?
- Hmm.....
- Instrument cluster code 01316 ABS Control Module: No Signal/Communication. Helpz!
- suspension fwd vs quattro
- cheapest place to get oem lug bolts and anyone know what size they are
- So thanks to everyone's advice I will be getting my new oil cooler + lines tomorrow
- AW going to vBulletin.
- how important to replacing hydraulic lifters when damaged valves get replaced?
- electric fan not spinning
- changing tie rods
- My Milltek exhaust is finally off the car... :( The downpipe doesn't look very
- Car won't start, what else ?
- Pelican Head how did the transfer go??
- Are s4's going this cheap?
- Car gets much loving today
- Anyone know the ride height of a '98 sport suspension?
- Leaking "dummy" plug on the cooling pipe on the back of the head...are those normal to leak...
- Broke Something on the Fuel Injector
- Well guys it's a sad day indeed...
- 50-50 between repairable/totaled... :-/
- a4 tdi r reg mass flywheel
- Need Electrical Help! Center Console/Cigarette lighter illum out-get FUSE warning but fuses OK?
- Nice looking 1999 2.8qm at Riverside Audi...
- I'm looking for a 98 VR6 MAF
- Want to replace the center cap for my RS4 Reps to OEM RS4 center caps
- Still getting the 17549 - Load Calculation Cross Check: Implausible Value P1141 - 35-10 - - - Interm
- Repost: Where's the cheapest place to buy a new instument cluster for a 99.5 A4
- Does anyone know where the "load reduction relay" is on a '97 12v? I took this picture of my relays
- Problem Diagnosis - Squeeking noise from the the front
- Rear seat (drivers side) floor constantly damp..
- Here are accident pics... :(
- Need some part numbers please....
- Looks like I got my hands full....
- Ordering Milltek exhaust... Resonated or Non-Resonated??
- when it rains it pours
- Encountered an electrical gremlin this morning, ignition switch?
- Finally, front fenders rolled and no more rubbing.
- question about readiness...sec air injection
- Another possible parts car.
- I just got 450 out of my last tank...
- ignition wires and spark plugs from BLAU
- Turbo timer with custom LED mod...
- okay gettting 16" swings and i have boxster bbk need to know how big of spacers to run
- how do i replace post cat O2 sensor?
- Coming along nicely.....
- Crashed my car :(
- Cruise Control Question
- Hey Audi Junkie, tore apart my pump and here's the damage...
- Need a instrument cluster adaptation how to!
- Oh Joy....
- 01 2.8 QM A4- Parting out
- Rear Axle Seals?
- Some decent numbers.....
- Side mirror defroster issue
- Rear door handle mod. Seached but still confused.
- APR Stage 3 Owner's Corral at Waterfest 14!
- Here's what you guys are missing if you're not in the MidAtlantic area... Hyperfest recap w/ pics..
- anyone has write up how to change gear box sensor G38 searched no luck...
- anyone know where i can get g12+ from in Orange County? dealership stocks regular g12
- Avant cargo cover spring broke - won't roll up/retract anymore
- Rear seatbelts / retractors for an Avant : Same for a B5 as B5.5?
- Testpipe Question - Waye's Angle Sensor
- anyone looking for a set of oem a4 headlights?
- Where should I get a new bracket for my front sway bars from?
- 98 1.8t Manual..."thinks" it has side curtain airbags but it doesn't....
- Anyone ever hear anything about this. More MGS, More HP????
- OEM 1.8T Sparkplugs Source?
- 9 hours later, it finally doesn't leak as much oil, and or coolant...........
- Hi guys, Newbie here
- p/n request - coolant temp sensor for '01 1.8T
- Steering wheel noise
- G89 Sensor - HELP!
- im thinkin about going with 034 motor mounts... should i go with track or street? how rough is track
- anyone know how to reboot TCU
- Mileage Correction?
- My latest check engine light problem from STP cleaner?
- Transmission Problem
- Do we know of any clean B5 1.8tqm in Eastern PA/NJ??? Looking to spend $7k max. 2.8qm is ok too.
- I ask every couple of months... anyone parting out a Brillant Yellow A4?
- Can anyone recommend a place(web) with better price than ECStuning to buy O2 sensor for my Audi? Tha
- Well guys, I just accepted an offer my Pelican Beauty...The buyer will be picking her up tomorrow...
- Need new instrument cluster for 99.5 A4
- Rear Diff Mount or Power Ring?
- What are the signs of a bad steering pump or rack?
- Thinking about selling, and getting into something newer....and with a warranty. Whats it worth?
- Few more pics of my casavant that I'm still waiting to ship. :-(
- Hmmm. I e-mailed REVO tuning on the 18th. No reply. Things for Unitronics are looking promising!
- Anyone order a coil from Carson and get my dipstick instead?
- Major engine problem
- Anyone know where I can get "T-tap" electrical connectors..
- Whats the best way to flush coolant on my 1.8?
- the new tire test fitment was semi successful
- I don't know how much more perfect of a job this could be for an Audiworlder
- is there a faster and easier way to do ps flush or this is what we got
- Need an oil dipstick funnel (AWM/ATW)?
- Misfiring... was misfiring before changing plugs, and now it continues. Multiple cylinders.
- Should I plan on an ignition switch or load reduction relay soon?
- I'm back!
- Clear Bra + Window tinting
- '96 QM as a collectable, or sell it?
- opinions need (Car smoking)
- Rear Door Speakers
- SOMEONE BUY THIS!!! Super low miles B5 1.8T. Found this looking for a car for my brother,
- Just cleaned up after front brake job ,late start tonight
- arghhh.. why didn't anybody warn me about this??
- Pentosin DOT4 or Motul RBF600 Brake Fluid?
- 01 a4 1.8T reliability ???
- ECT sensor probs and climate control probs
- Mah New Aquisition
- 1.8 throttle pulsing when cold? ...
- Will a 97 a4 ignition work on a 96 A4??
- Door sag/wind noise
- Instrument Brake Light Doesnt Turn Off
- when filling cooling fluid, should i premix it with water
- For daily drivers (non track'd cars)....how often do you change your brake pads?
- MFer. center auto-dimming mirror now has a big amoeba floating around in it. and I can see 3 of
- So replaced my MAF and the CEL is still present :-( Any ideas?
- Call me crazy, thinking about this for a project...
- Inskip Audi wants $109.00 for a radio code!
- changing thermostat lost bolt, need help
- Paging Carson: Possible to get JUST a TT225 MAF housing, without the sensor??
- okedokey...runnning with no belly pan = annoying rattle from spring support slapping subframe?
- GRINDING BRAKES
- Never tell a shop that they can have the car for the week to do TREs you couldn't get out, alignment
- Anyone have luck with Ebay lights?
- Strange ABS
- soooo.... im not going to install my 034 motorsports high flow manifold with my gtrs elim
- Coolant leak on 1.8T... part name and number needed.
- Front right wheel noise
- When replacing the stock headunit to an aftermarket, will there be an issue using the OBD II
- Need some help with my wife's tranny...
- headlight replacement
- Would you rather pay $600 to have your old wheels refinished or scrap them and get new ones?
- ABS Control Module Writeup?
- Flickering Warning Lights ** Please Help!!!!! **
- something you guys might like
- mobil using a new oil filter for our cars?
- Confused about VW parts being cheaper?
- What is this a function of? Never happened before?
- airbag light - need a new airbag module
- Cannot remove radio - help needed, please.
- Fluids . . .
- Changed cluster, now no radio info... Also need 2001 ECU coding info...
- turbo feed line... stock one uses a banjo bolt to connect to oil filter bracket. joe@axis sent me
- some neat things around where i live
- 1996 A4 poor man's a/c recharge.... Works flawlessly.
- Bassed, other USRT users... How the heck do you get a hold of them?
- Thinking about replacing my "track tires B" with a set of 225/45-16's
- LOW BEAMS DON'T WORK!
- Major engine power loss on 99 A4 Avant Quattro 1.8T
- Turtle Wax liquid clay bar
- Boxter brakes vs. Regular. Question from Kenny.
- Just got off the phone with Ed @ WheelCollision.............1 of the DPE's is not repairable :(
- Quick brake color opinion question..
- B5, you sunk my battleship -- obligatory introductory post
- Paging Mr. Mom....
- If anyone knows where to get the double din bracket...
- Silver Streakin' or Bassed, do you guys have a VAG-COM?
- Suspension Question
- <shakes fist in air> damn you nate and jeff....
- Need VAG login code for B5 A4 1.8T...
- Looking to save $$ on my interval service.
- what shift knobs are people using?
- Fuel Pump stops like twenty while filling...
- umm wtf i open the drain port on the radiator and only a tiny bit of coolant comes out, then stops??
- Dension crapped out on me. Deciding what route to go. One that plugs into bottom of ipod and control
- No tach,couple service lights..Cam Pos sensor?? HELP
- Airbag Module
- hey guys just wondering what size vac line is our divter and how long is it?
- a car wreck of a thread
- low oil pressure - fix or sell 97 A4 1.8T with 117k
- Do all B5 A4's share the same wiper motor?
- used value prices are going down huh?
- Q re cluster swap. IC from MT car work in AT car?
- Can't find any Motul locally -- anyone ever use Russell, Wilwood, or US Brake high temp fluids?
- Bought a BMW -------------------------------------------------------->
- a PES g1 in our classifieds
- where to get an EGR blockoff plate?
- Don't know why, but this video makes me think of Dungbeetle and Mainer's in general :-)
- Side Subject, Pt 2: Hope you gentlemen out in the Midwest are drying out a bit...
- Anybody know if (with the right programs/hardware) the stock chip can be reprogrammed?
- Does anyone know if REVO will give trials on their BT software?
- Anyone know the PN for the newest (updated) AEB MAF off the top of their head??
- Intake
- cheapest place to buy apr DV?????
- Half way through replacing the alternator..some pics!
- oil pan repair: 96 12v q sedan if it matters
- shoot - after i clean my throttle body
- STFA; Auto dimming mirror failed on '01; not just failed, is now two-tone.
- oil reset button?
- wwawd... low oil
- Is this possible? Haul a 30V AHA with a runnning B5 Avant?
- Got the new toy......(ray...you of all people will appreciate this)
- how can i tell if my clutch is slipping or my transmission is bad?
- Replacing Bulbs with LEDs?
- WTB plastic guide for window regulator
- OEM S4 sport mirrors + new lip= ready to go in for paint
- Retro'd some HIDs into my ecodes and got fogs also
- I've been looking, anyone have 99.5+ 1.8t A/C lines?
- Audi crash in Poland, dont know what model it is. Looks pretty bad tho, car split in half.
- Frankenstien lives.. I now have parts from RallyVermont's car on my A6....
- Programming Keyless Entry on 2001.5 1.8tq....
- Electric AC fan in radiator support not working...is there a fuse I can check for this?
- O2 or Kombi-valve? Advice needed...
- Need some advice. Anyone have experience changing diffs? I have a couple of questions.
- Need help! Hood cable broken.
- Here's the damage.
- Does anyone know if REAR H&R race springs are any different between 1.8 and 2.8?
- Flashing Dash Lights
- Lets talk fuel injectors.
- Have to replace my flywheel, no extra cash...
- Bumping this thread: What's the diameter of the 2.8 down pipes?
- Swap Manual Seats for Power Seats in 01 A4?
- ::Review of the VVME 3000k hid bulbs::
- what is better, an intake of FMIC??
- k04 installed... question
- PCV Replacement on ATW Engine complete...some thoughts and ETKA pages
- ABS module failure - checked FAQ, no real answer
- H&R question I posted in S4 forum but wanted your opinion also.
- VMR Wheels | Brand new V710: 19x8.5 +35 Available in July! Pre-Order your set now!!
- My car got stolen...again...at 5PM. Back in my garage by 7PM.
- What intake or inter-cooler do you have?? Post pics if you like so I could get some ideas thanks
- Folks with catchcans: What would cause a catchcan to fill up within 3,000 miles?
- i need to recharge my ac
- some ETKA help please...
- qfrog: was that you in i280 east last night?
